    4. Test Adapter fb-checkpresence v1.1.x
    • Fenriswolf
      Fenriswolf last edited by
      Habe seit einigen Tage auch immer wieder folgende Einträge im Log:
      fb-checkpresence.0	2021-02-04 11:44:01.212	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 11:33:31.488	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 11:12:30.323	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 11:02:01.188	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 10:41:02.088	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 10:30:32.291	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 10:09:34.150	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 09:59:03.731	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 09:38:03.322	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 09:27:33.278	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 09:06:29.985	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 08:56:00.038	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 08:34:58.569	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 08:24:26.841	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 08:03:29.066	error	(8059) getMeshList: {}
      fb-checkpresence.0	2021-02-04 08:03:18.612	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 07:52:48.685	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 07:31:41.328	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 07:21:15.408	error	(8059) getMeshList: {}
      fb-checkpresence.0	2021-02-04 07:21:05.115	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 07:10:43.357	error	(8059) getMeshList: {}
      fb-checkpresence.0	2021-02-04 07:00:04.151	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 06:49:33.055	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 06:28:30.790	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 06:17:59.344	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 05:56:55.564	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      fb-checkpresence.0	2021-02-04 05:46:25.646	error	(8059) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @Stephan Schleich last edited by
        @stephan-schleich sagte in Test Adapter fb-checkpresence v1.1.x:
        Edit: Greifst du bereits auf den upnp Adapter zu?
        Nein. Das ist das TR-064 Protokoll der Fritzbox. In der Doku ist ein Link auf die AVM Seite.
        • afuerhoff
          Edit: Könnte man bei present und absent je einen zusätzlichen Wert hinzufügen welcher zeigt wie lange man weg war? Jetzt ist es so dass wenn ich heim komme nicht mehr sehen kann wie lang ich weg war.
          Verstehe ich nicht. Es gibt doch absent.since und present.since.
          Stephan Schleich 1 Reply Last reply Reply Quote 0
          • afuerhoff
            afuerhoff Developer @Fenriswolf last edited by
            @fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
            Ich muss leider auch gestehen, das mir in der vergangenen Woche zweimal aufgefallen ist, das er Familienmitglieder nicht als abwesend erkennt.
            Wie sieht es denn dann in der Fritzbox aus? Evtl. Verschleierung der Mac-Adresse, die zuschlägt?
            Fenriswolf 1 Reply Last reply Reply Quote 0
            • afuerhoff
              Da bräuchte ich mehr Informationen. Am Besten mal auf Log-Stufe Debug laufen lassen und dann posten.
              • Stephan Schleich
                Stephan Schleich @afuerhoff last edited by Stephan Schleich
                @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                Wenn ich present bin springt Absent bei mir wieder auf 0
                Neuschwansteini 1 Reply Last reply Reply Quote 0
                • Neuschwansteini
                  Neuschwansteini @Stephan Schleich last edited by
                  logisch, bist ja auch nicht mehr abwesend.. 🙂
                  Der Zähler muss doch auf 0 sein...
                  • Fenriswolf
                    Fenriswolf @afuerhoff last edited by
                    Nein, die ist definitiv ausgeschaltet an den Handys. Zumal das Problem bei der Abwesenheit auftritt, nicht bei der Anwesenheit 😉
                    Momentan starte ich die Instanz täglich einmal automatisert neu. Das hilft als Workaround.
                    Ist umgestellt .... ich werde berichten.
                    • Neuschwansteini
                      Neuschwansteini @Fenriswolf last edited by
                      @fenriswolf @afuerhoff
                      Ja, leider haengt er bei mir auch irgendwann mal, daher lass ich den Adapter alle 12h neu starten, seitdem ist gut.
                      Kann leider nicht sagen, wann er stecken bleibt.. hatte ich auch schon auf debug, aber kein Fehler gefunden...
                      • Fenriswolf
                        Fenriswolf @afuerhoff last edited by Fenriswolf
                        Hier das Log:
                        20210204 fb-checkpresence.txt
                        Zeile 57:
                        musste aber wieder von debug zurück auf Info .... mir quoll das LogFile über
                        • Stephan Schleich
                          Stephan Schleich @Neuschwansteini last edited by
                          @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
                          Will aber mein letzten absent sehen
                          • Neuschwansteini
                            @stephan-schleich
                            dafuer gibts doch coming and going mit datum und uhrzeit.
                            Stephan Schleich 1 Reply Last reply Reply Quote 1
                            • Stephan Schleich
                              @ilovegym ahh ja okay, das könnte man auch nehmen, muss ich dann nur umschreiben auf die differenz
                                Saschag last edited by Saschag
                                ich wollte den Adapter auch mal testet/nutzen. Er bleibt aber GELB und ich bekomme folgendes fehler-Log Version 1.1.2 aus Git. User und Password habe ich mehrfach geprüft. Einstellungen in der FB sollten passen da der TR-046 adapter funktioniert.
                                fb-checkpresence.0	2021-02-05 09:51:34.322	info	(19412) createMemberObjects finished successfully
                                fb-checkpresence.0	2021-02-05 09:51:34.221	info	(19412) createGlobalObjects finished successfully
                                fb-checkpresence.0	2021-02-05 09:51:33.298	info	(19412) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.264	info	(19412) service DeviceConfig1-Reboot is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.251	info	(19412) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.232	info	(19412) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.218	info	(19412) service DeviceInfo1-GetInfo is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.188	info	(19412) service WLANConfiguration3-GetSecurityKeys is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.160	info	(19412) service WLANConfiguration3-GetInfo is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.134	info	(19412) service WLANConfiguration3-SetEnable is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.120	info	(19412) service WANPPPConnection1-GetInfo is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.103	info	(19412) service DeviceInfo1-GetSecurityPort is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.084	info	(19412) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.072	info	(19412) service Hosts1-GetSpecificHostEntry is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.053	info	(19412) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                                fb-checkpresence.0	2021-02-05 09:51:33.037	info	(19412) service Hosts1-X_AVM-DE_GetHostListPath is supported
                                fb-checkpresence.0	2021-02-05 09:51:32.831	info	(19412) start fb-checkpresence: ip-address: "192.168.000.1" - interval devices: 2 Min. - interval members: 60 s
                                fb-checkpresence.0	2021-02-05 09:51:32.800	info	(19412) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.18.3, js-controller: 3.1.6
                                fb-checkpresence.0	2021-02-05 09:51:27.477	warn	(19412) slow connection to objects DB. Still waiting ...
                                fb-checkpresence.0	2021-02-05 09:51:20.476	info	(19387) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                fb-checkpresence.0	2021-02-05 09:51:20.473	error	(19387) fb-checkpresence.0 invalid process id scenario 19412 vs. own ID 19387. Stopping
                                fb-checkpresence.0	2021-02-05 09:51:19.137	info	(19206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                fb-checkpresence.0	2021-02-05 09:51:19.133	error	(19206) fb-checkpresence.0 invalid process id scenario 19387 vs. own ID 19206. Stopping
                                fb-checkpresence.0	2021-02-05 09:51:12.526	warn	(18548) Got terminate signal. Checking desired PID: 0 vs own PID 18548
                                EDIT: System komplett neu gestartet (FritzBox und IObroker) nun ist der Adapter Grün mal schauen
                                • MichMein
                                  MichMein last edited by
                                  Hi @afuerhoff,
                                  bei uns hat sich heute ein neues Handy im WLAN angemeldet und im Adapter kamen die folgenden Warnmeldungen.
                                  2021-02-05 18:08:37.072 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.name" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.077 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.type" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.078 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.link" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.078 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.rx_rcpi" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.079 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.079 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.080 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.link" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.080 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.rx_rcpi" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.080 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                  2021-02-05 18:08:37.081 - warn: fb-checkpresence.0 (4350) State "fb-checkpresence.0.fb-devices.Galaxy-A51.0.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                  Kannst du das fixen?
                                  Vielen Dank
                                  Michael
                                  • afuerhoff
                                    afuerhoff Developer @MichMein last edited by
                                    @michmein
                                    Hallo, ja bin schon dabei. Hab im Moment allerdings sehr wenig Zeit. Wird noch etwas dauern.
                                      Thias last edited by
                                      ich setze die Version 1.1.2 ein, da ich bei der Vorgängerversion (letzte im Status "stable") das Problem hatte, dass die An-/Abwesenheiten oft erst nach einem Restart des Adapters aktualisiert wurden.
                                      Da scheint jetzt besser zu sein.
                                      Allerdings habe ich jetzt jede Minute einen "getMeshList {}" Error im Log.
                                      Das war nach der Installation der aktuellen Version nicht gleich der Fall.
                                      Adapter habe ich schon neu gestartet.
                                      Hat da jemand eine Idee?
                                      Matthias
                                        Linedancer @afuerhoff last edited by
                                        @grizzelbee sagte in Test Adapter fb-checkpresence v1.1.x:
                                        Ich denke, ich werde die Adapterentwicklung wieder auf die Hauptfunktionen konzentrieren.
                                        Gute Entscheidung,
                                        Ich sag nur KISS ( keep it safe and simple)
                                        • afuerhoff
                                          afuerhoff Developer @Thias last edited by
                                          @thias sagte in Test Adapter fb-checkpresence v1.1.x:
                                          getMeshList Fehler
                                          Hallo, ich arbeite an einem weiteren Update. Komme allerdings nicht so schnell voran. Wenig Zeit im Moment. Ich hoffe, dass der Fehler dann auch abgestellt ist.
                                            Thias @afuerhoff last edited by
                                            @afuerhoff kein Stress, der Fehler hat gestern das Logfile gefüllt und ist heute nicht einmal aufgetreten. Ohne Intervention....
                                            79.9k
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            245470
