    4. Test Adapter HeatingControl v2.12.x
      Michi_Pi @Rene_HM last edited by
      @rene_hm
      hier nochmal der Log
      heatingcontrol.0	2021-02-05 09:26:40.009	debug	(32643) CreateWindowStatesTable done
      heatingcontrol.0	2021-02-05 09:26:40.003	debug	(32643) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
      heatingcontrol.0	2021-02-05 09:26:40.001	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.StatusLog {"val":" 05.02.2021 08:04:36 auto 17°C <br> 05.02.2021 08:04:10 starting 17°C <br> 05.02.2021 08:04:06 starting <br>","ack
      heatingcontrol.0	2021-02-05 09:26:39.908	debug	(32643) CreateWindowStatesTable called
      heatingcontrol.0	2021-02-05 09:26:39.855	debug	(32643) AddStatusToLog skip Schlafzimmer auto 17°C
      heatingcontrol.0	2021-02-05 09:26:39.849	debug	(32643) Reaching SetWindowState for Rooms.Schlafzimmer.WindowIsOpen
      heatingcontrol.0	2021-02-05 09:26:39.849	debug	(32643) HandleStateChanges WindowIsOpen true
      heatingcontrol.0	2021-02-05 09:26:39.849	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.WindowIsOpen {"val":true,"ack":false,"ts":1612513599845,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","l
      heatingcontrol.0	2021-02-05 09:26:39.758	debug	(32643) HandleStateChanges CurrentTimePeriod 2
      heatingcontrol.0	2021-02-05 09:26:39.757	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.CurrentTimePeriod {"val":2,"ack":false,"ts":1612513599754,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin",
      heatingcontrol.0	2021-02-05 09:26:39.579	debug	(32643) UpdateDPs for Schlafzimmer auto
      heatingcontrol.0	2021-02-05 09:26:39.579	debug	(32643) HandleActors for Schlafzimmer auto
      heatingcontrol.0	2021-02-05 09:26:39.579	debug	(32643) Schlafzimmer nothing to do to for hm-rpc.1.00201A499795D0.1.SET_POINT_TEMPERATURE , target 17 is already set 17
      heatingcontrol.0	2021-02-05 09:26:39.538	debug	(32643) SetRoomTemperature started for Schlafzimmer target 17 with offset 0
      heatingcontrol.0	2021-02-05 09:26:39.537	debug	(32643) got {"val":5,"ack":true,"ts":1612336643480,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336643480}
      heatingcontrol.0	2021-02-05 09:26:39.521	debug	(32643) checking min temp with Rooms.Schlafzimmer.MinimumTemperature
      heatingcontrol.0	2021-02-05 09:26:39.521	debug	(32643) Schlafzimmer auto mode (incl. reduced): target 17
      heatingcontrol.0	2021-02-05 09:26:39.521	debug	(32643) Schlafzimmer auto mode: target 17
      heatingcontrol.0	2021-02-05 09:26:39.521	debug	(32643) CalculateRoomTemperature for Schlafzimmer auto
      heatingcontrol.0	2021-02-05 09:26:39.521	debug	(32643) Change Status WindowOpen in Schlafzimmer to true
      heatingcontrol.0	2021-02-05 09:26:39.521	debug	(32643) result for AddSensorState in Schlafzimmer is true
      heatingcontrol.0	2021-02-05 09:26:39.520	debug	(32643) one window open in Schlafzimmer hm-rpc.1.001558A9A48BAD.1.STATE
      heatingcontrol.0	2021-02-05 09:26:39.520	debug	(32643) add new sensor state in Schlafzimmer hm-rpc.1.001558A9A48BAD.1.STATE 1
      heatingcontrol.0	2021-02-05 09:26:39.520	debug	(32643) Schlafzimmer ### ChangeStatus Sensor to {"OID":"hm-rpc.1.001558A9A48BAD.1.STATE","state":1} in auto
      heatingcontrol.0	2021-02-05 09:26:39.520	debug	(32643) handle sensor auto false 1 0 0
      heatingcontrol.0	2021-02-05 09:24:15.411	debug	(32643) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
      heatingcontrol.0	2021-02-05 09:24:15.411	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.StatusLog {"val":" 05.02.2021 08:04:36 auto 17°C <br> 05.02.2021 08:04:10 starting 17°C <br> 05.02.2021 08:04:06 starting <br>","ack
      heatingcontrol.0	2021-02-05 09:24:15.252	debug	(32643) AddStatusToLog skip Schlafzimmer auto 17°C
      heatingcontrol.0	2021-02-05 09:24:15.160	debug	(32643) HandleStateChanges CurrentTimePeriod 2
      heatingcontrol.0	2021-02-05 09:24:15.160	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.CurrentTimePeriod {"val":2,"ack":false,"ts":1612513455156,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin",
      heatingcontrol.0	2021-02-05 09:24:14.907	debug	(32643) UpdateDPs for Schlafzimmer auto
      heatingcontrol.0	2021-02-05 09:24:14.907	debug	(32643) new temp offset for Schlafzimmer is 0
      heatingcontrol.0	2021-02-05 09:24:14.862	debug	(32643) (avg) TempOffset 0
      heatingcontrol.0	2021-02-05 09:24:14.862	debug	(32643) tempDiff -0.040000000000000924
      heatingcontrol.0	2021-02-05 09:24:14.862	debug	(32643) Ist-Temperatur am zusätzl. Sensor 15.86
      heatingcontrol.0	2021-02-05 09:24:14.862	debug	(32643) (avg) Ist-Temperatur am Thermostat 15.9
      heatingcontrol.0	2021-02-05 09:24:14.862	debug	(32643) TempOffset Schlafzimmer
      heatingcontrol.0	2021-02-05 09:24:14.862	debug	(32643) tempdiff: 15.86 - 15.9 = -0.040000000000000924
      heatingcontrol.0	2021-02-05 09:24:14.861	debug	(32643) got 15.9 from hm-rpc.1.00201A499795D0.1.ACTUAL_TEMPERATURE
      heatingcontrol.0	2021-02-05 09:24:14.849	debug	(32643) calculate temp offset for Schlafzimmer old value is 0, got value {"val":15.86,"ack":true,"ts":1612513454836,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1612513454836
      heatingcontrol.0	2021-02-05 09:24:14.849	debug	(32643) Schlafzimmer ### ChangeStatus AddTempSensor to {"val":15.86,"ack":true,"ts":1612513454836,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1612513454836} in auto
      heatingcontrol.0	2021-02-05 09:23:56.601	debug	(32643) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
      heatingcontrol.0	2021-02-05 09:23:03.196	debug	(32643) CreateWindowStatesTable done
      heatingcontrol.0	2021-02-05 09:23:03.191	debug	(32643) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
      heatingcontrol.0	2021-02-05 09:23:03.191	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.StatusLog {"val":" 05.02.2021 08:04:36 auto 17°C <br> 05.02.2021 08:04:10 starting 17°C <br> 05.02.2021 08:04:06 starting <br>","ack
      heatingcontrol.0	2021-02-05 09:23:03.072	debug	(32643) CreateWindowStatesTable called
      heatingcontrol.0	2021-02-05 09:23:03.007	debug	(32643) AddStatusToLog skip Schlafzimmer auto 17°C
      heatingcontrol.0	2021-02-05 09:23:03.005	debug	(32643) Reaching SetWindowState for Rooms.Schlafzimmer.WindowIsOpen
      heatingcontrol.0	2021-02-05 09:23:03.005	debug	(32643) HandleStateChanges WindowIsOpen false
      heatingcontrol.0	2021-02-05 09:23:03.005	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.WindowIsOpen {"val":false,"ack":false,"ts":1612513383000,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","
      heatingcontrol.0	2021-02-05 09:23:02.935	debug	(32643) HandleStateChanges CurrentTimePeriod 2
      heatingcontrol.0	2021-02-05 09:23:02.935	debug	(32643) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.CurrentTimePeriod {"val":2,"ack":false,"ts":1612513382931,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin",
      heatingcontrol.0	2021-02-05 09:23:02.760	debug	(32643) UpdateDPs for Schlafzimmer auto
      heatingcontrol.0	2021-02-05 09:23:02.759	debug	(32643) HandleActors for Schlafzimmer auto
      heatingcontrol.0	2021-02-05 09:23:02.759	debug	(32643) Schlafzimmer nothing to do to for hm-rpc.1.00201A499795D0.1.SET_POINT_TEMPERATURE , target 17 is already set 17
      heatingcontrol.0	2021-02-05 09:23:02.718	debug	(32643) SetRoomTemperature started for Schlafzimmer target 17 with offset 0
      heatingcontrol.0	2021-02-05 09:23:02.718	debug	(32643) got {"val":5,"ack":true,"ts":1612336643480,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336643480}
      heatingcontrol.0	2021-02-05 09:23:02.709	debug	(32643) checking min temp with Rooms.Schlafzimmer.MinimumTemperature
      heatingcontrol.0	2021-02-05 09:23:02.708	debug	(32643) Schlafzimmer auto mode (incl. reduced): target 17
      heatingcontrol.0	2021-02-05 09:23:02.708	debug	(32643) Schlafzimmer auto mode: target 17
      heatingcontrol.0	2021-02-05 09:23:02.708	debug	(32643) CalculateRoomTemperature for Schlafzimmer auto
      heatingcontrol.0	2021-02-05 09:23:02.708	debug	(32643) Change Status WindowOpen in Schlafzimmer to false
      heatingcontrol.0	2021-02-05 09:23:02.708	debug	(32643) result for AddSensorState in Schlafzimmer is false
      heatingcontrol.0	2021-02-05 09:23:02.708	debug	(32643) add new sensor state in Schlafzimmer hm-rpc.1.001558A9A48BAD.1.STATE 0
      heatingcontrol.0	2021-02-05 09:23:02.704	debug	(32643) Schlafzimmer ### ChangeStatus Sensor to {"OID":"hm-rpc.1.001558A9A48BAD.1.STATE","state":0} in auto
      heatingcontrol.0	2021-02-05 09:23:02.704	debug	(32643) handle sensor auto true 0 0 0
      heatingcontrol.0	2021-02-05 09:22:48.844	debug	(32643) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
        kaschperle83 last edited by
        Hallo bin jetzt auf die aktuelle Version umgestiegen. Eigentlich läuft alls aber eines ist komisch. Die Thermostate (Max) werden immer auf 0,5 Grad höher als eingestellt gesetzt. Woran liegt das?
        • Rene_HM
          Rene_HM Developer @Stephan Schleich last edited by
          @stephan-schleich Die Meldung kommt, weil beim Lesen auf den angegebenen Datenpunkt ein null oder gar nichts zurückkommt. Ist der DP gültig und hat er einen Wert?
          Stephan Schleich 1 Reply Last reply Reply Quote 0
          • Rene_HM
            Rene_HM Developer @Samsity last edited by
            @samsity sagte in Test Adapter HeatingControl v2.1.x:
            Ich hoffe die Infos reichen und mir ist noch zu helfen um den Adapter inkl. VIS zum laufen zu bringen.
            Mir ist nicht so richtig klar, was dein Problem ist... Also fangen wir von vorn an: Der Adapter läuft hoch und bringt beim Starten auch keine Fehlermeldungen?
            • Rene_HM
              Rene_HM Developer @Michi_Pi last edited by
              @michi_pi schau mal in den Datenpunkten (nicht im vis) ob da wirklich die 12°C als reduzierte Temperatur für das Schlafzimmer steht. Laut log ist das nicht so...
                Samsity @Rene_HM last edited by
                @rene_hm
                Hallo, das steht beim Adapter start im Log:
                heatingcontrol.0 2021-02-05 18:51:51.951 info (26711) statemachine started
                heatingcontrol.0 2021-02-05 18:51:51.692 info (26711) start calculate current profile point for profile type 3 (every day)
                heatingcontrol.0 2021-02-05 18:51:51.688 info (26711) calculate current profile point for all rooms
                heatingcontrol.0 2021-02-05 18:51:51.688 info (26711) checking external states done
                heatingcontrol.0 2021-02-05 18:51:50.938 info (26711) checking external states
                heatingcontrol.0 2021-02-05 18:51:50.831 info (26711) check all active sensors
                heatingcontrol.0 2021-02-05 18:51:50.669 info (26711) start statemachine
                heatingcontrol.0 2021-02-05 18:51:50.667 error (26711) exception in SetVis [TypeError: Cannot read property 'val' of null]
                heatingcontrol.0 2021-02-05 18:51:48.610 info (26711) 35 cron job(s) created
                heatingcontrol.0 2021-02-05 18:51:48.093 info (26711) start create cron jobs for profile type 3 (ery day)
                heatingcontrol.0 2021-02-05 18:51:48.065 info (26711) subscribe devices done
                heatingcontrol.0 2021-02-05 18:51:48.064 info (26711) subscribe sensor FK-Dirk-Wohnzimmer:1 hm-rpc.1.NEQ0065715.1.STATE
                heatingcontrol.0 2021-02-05 18:51:48.063 info (26711) subscribe thermostat current TH-Dirk 1 hm-rpc.1.MEQ1879515.4.ACTUAL_TEMPERATURE
                heatingcontrol.0 2021-02-05 18:51:48.062 info (26711) subscribe thermostats current 1
                heatingcontrol.0 2021-02-05 18:51:48.061 info (26711) subscribe devices start
                heatingcontrol.0 2021-02-05 18:51:48.058 info (26711) subscribe feiertage.0.heute.boolean
                heatingcontrol.0 2021-02-05 18:51:48.014 info (26711) SetCurrent done
                heatingcontrol.0 2021-02-05 18:51:47.964 info (26711) start SetCurrent
                heatingcontrol.0 2021-02-05 18:51:47.963 info (26711) SetInfo done
                heatingcontrol.0 2021-02-05 18:51:47.877 info (26711) start SetInfo
                heatingcontrol.0 2021-02-05 18:51:47.665 info (26711) CreateDatapoints done
                heatingcontrol.0 2021-02-05 18:51:46.472 info (26711) start CreateDatapoints
                heatingcontrol.0 2021-02-05 18:51:46.469 info (26711) CreateDatabase done with 1 rooms
                heatingcontrol.0 2021-02-05 18:51:46.466 info (26711) start CreateDatabase
                heatingcontrol.0 2021-02-05 18:51:46.412 info (26711) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v12.20.1, js-controller: 3.1.6
                • Rene_HM
                  Rene_HM Developer @kaschperle83 last edited by
                  @kaschperle83 Nutzt du dem TemperaturOffset? ansonsten ist das mit den hier geschriebenen Infos Glaskugellesen...
                  • Rene_HM
                    Rene_HM Developer @Samsity last edited by Rene_HM
                    okay. gut. Die exception hier kannst du ignorieren, die geht weg, wenn alles richtig konfiguriert ist...
                    Der screen shot oben passt nun aber nicht zu dem log. Laut log hast du ein Thermostat "TH-Dirk 1" und "1". Die sehe ich im screen shot oben nicht. Also zeige mir bitte die Konfiguration. Du kannst sie auch herunterladen und als Datei posten:
                      @rene_hm das kann sein, da ich tlw. zum ausprobieren die anderen Räume als inaktiv gesetzt habe, damit nicht Räume plötzlich ungeheizt/geheizt werden ohne das es notwendig ist. Hab jetzt die Räume auf aktiv gesetzt und die Config runtergeladen.
                      system.adapter.heatingcontrol.0 (1).json
                      • Rene_HM
                        @samsity für den Anfang wäre es besser, nur mit ein oder zwei Räumen zu starten und dann zu erweitern... Aber okay, die Konfiguration sieht soweit gut aus, aber:
                        • wenn dein Wandthermostat ein oder mehrere Heizkörperthermostate steuert, musst du die Heizkörperthermostate NICHT im Adapter konfigurieren. Lösche die bitte... Inaktiv schalten sollte zwar auch reichen, aber sicher ist sicher
                        Wenn du die Vis von Pittini verwenden willst, musst du das aber auch einschalten
                        Wenn das an ist, und du auch die richtige Version der vis installiert hast (3.1.2, Anleitung findest du unter iobroker-heatingcontrol-vis dann poste ein bild von deiner vis...
                          @rene_hm Danke, ich werde die Heizkörperthermostate löschen, die über einen Wandthermostat verbunden sind.
                          Werde dann weiter testen und berichten.
                          Danke, Spende ist auch unterwegs.
                            @rene_hm achso, hier das Bild der bis jetzt konfigurierten VIS:
                            • Rene_HM
                              @samsity Wenn du auf den Raum "Dirk" umschaltest, hast du da auch die leeren Felder in der Profileinstellung unten?
                                @rene_hm das ist ein Fehler von mir, hatte bei den VIS Einstellungen die Mindesttemperatur falsch eingestellt.
                                Was mit gerade auffällt ist, das wenn ich im Speiseraum das Aktive Profil umstelle werden alle anderen Raumprofile auch mit umgestellt.
                                • Rene_HM
                                  Das ist normal. Ein Profil beinhaltet immer alle Räume...
                                    @rene_hm schade, hatte verstanden das ich jeden Raum ein eigenes Profil zuordnen kann und auch in jeden Raum ein anderes Profil aktivieren kann.
                                    Das ist für mich das wichtigste an der ganzen Steuerung.
                                    Könnte ich das evtl. umgehen in dem ich in der VIS auf die heatingcontrol.0.Rooms.RAUMNAME.ActiveTimeSlot zugreife und das benötigte Profil setze?
                                    • Rene_HM
                                      @samsity erkläre erst mal, was du eigentlich vorhast, dann schaun wir mal, wie wir das lösen...
                                        @rene_hm ich betreibe ein Jugendhaus, da benötige ich für Räume die von den Gästen ganz andere Profile wie in meinem Privaten Bereich.
                                        Beispiel :
                                        Ich Homeoffice 21° ab 8 Uhr bis 22 Uhr
                                        Vater daueranwesend 21°
                                        Kein Gast da alle Gästeräume, 10°
                                        Ich in der Arbeit 18° bis 12.30 Uhr, 21° bis 22 Uhr
                                        Vater daueranwend 21°
                                        Gäste da Speiseraum 21° 8 - 22 Uhr/ WC 18° 0-24 Uhr/ Aufenthaltsraum bleibt bei 10° wird mit Kachelofen geheizt(Heizkörper nur für Frostschutz)
                                        Ich hoffe das ist verständlich geschrieben was ich mir Vorstelle.
                                        Insgesamt habe ich für meinen Raum 4 Profile, bei meinem Vater aber nur zwei, und bei den Gästen 3-4 Profile.
                                        • Rene_HM
                                          @samsity ich würde folgendes machen:
                                          1. vom Adapter zwei (oder evtl auch drei) instanzen installieren:
                                          • eine für deine Räume
                                          • eine für die Gästeräume
                                          • eine evtl. für die Räume des Vaters
                                          1. für deine Räume nur zwei Profile
                                          • HomeOffice
                                          • normal
                                          1. für die Gästeräume ein Profil, dafür aber ein Feature nutzen, was in der 2.2 kommt und sich "Einzelraumabschaltung" nennt. Räume, die nicht belegt sind werden dann einfach abgeschaltet und auf eine feste Temperatur geregelt.
                                          Zusätzlich würde ich die Features "Anwesenheit" nutzen um bei Abwesenheit zu reduzieren. Das würde ich nicht über Profile machen...
                                            @rene_hm okay, dann werd ich das so machen und testen.
                                            Danke schon mal für die Hilfe!
                                            heating
                                            236
                                            3158
                                            1847291
