    4. Test Adapter HeatingControl v2.12.x
    • Rene_HM
      Rene_HM Developer @Michi_Pi last edited by
      @michi_pi schau mal in den Datenpunkten (nicht im vis) ob da wirklich die 12°C als reduzierte Temperatur für das Schlafzimmer steht. Laut log ist das nicht so...
        Samsity @Rene_HM last edited by
        @rene_hm
        Hallo, das steht beim Adapter start im Log:
        heatingcontrol.0 2021-02-05 18:51:51.951 info (26711) statemachine started
        heatingcontrol.0 2021-02-05 18:51:51.692 info (26711) start calculate current profile point for profile type 3 (every day)
        heatingcontrol.0 2021-02-05 18:51:51.688 info (26711) calculate current profile point for all rooms
        heatingcontrol.0 2021-02-05 18:51:51.688 info (26711) checking external states done
        heatingcontrol.0 2021-02-05 18:51:50.938 info (26711) checking external states
        heatingcontrol.0 2021-02-05 18:51:50.831 info (26711) check all active sensors
        heatingcontrol.0 2021-02-05 18:51:50.669 info (26711) start statemachine
        heatingcontrol.0 2021-02-05 18:51:50.667 error (26711) exception in SetVis [TypeError: Cannot read property 'val' of null]
        heatingcontrol.0 2021-02-05 18:51:48.610 info (26711) 35 cron job(s) created
        heatingcontrol.0 2021-02-05 18:51:48.093 info (26711) start create cron jobs for profile type 3 (ery day)
        heatingcontrol.0 2021-02-05 18:51:48.065 info (26711) subscribe devices done
        heatingcontrol.0 2021-02-05 18:51:48.064 info (26711) subscribe sensor FK-Dirk-Wohnzimmer:1 hm-rpc.1.NEQ0065715.1.STATE
        heatingcontrol.0 2021-02-05 18:51:48.063 info (26711) subscribe thermostat current TH-Dirk 1 hm-rpc.1.MEQ1879515.4.ACTUAL_TEMPERATURE
        heatingcontrol.0 2021-02-05 18:51:48.062 info (26711) subscribe thermostats current 1
        heatingcontrol.0 2021-02-05 18:51:48.061 info (26711) subscribe devices start
        heatingcontrol.0 2021-02-05 18:51:48.058 info (26711) subscribe feiertage.0.heute.boolean
        heatingcontrol.0 2021-02-05 18:51:48.014 info (26711) SetCurrent done
        heatingcontrol.0 2021-02-05 18:51:47.964 info (26711) start SetCurrent
        heatingcontrol.0 2021-02-05 18:51:47.963 info (26711) SetInfo done
        heatingcontrol.0 2021-02-05 18:51:47.877 info (26711) start SetInfo
        heatingcontrol.0 2021-02-05 18:51:47.665 info (26711) CreateDatapoints done
        heatingcontrol.0 2021-02-05 18:51:46.472 info (26711) start CreateDatapoints
        heatingcontrol.0 2021-02-05 18:51:46.469 info (26711) CreateDatabase done with 1 rooms
        heatingcontrol.0 2021-02-05 18:51:46.466 info (26711) start CreateDatabase
        heatingcontrol.0 2021-02-05 18:51:46.412 info (26711) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v12.20.1, js-controller: 3.1.6
        • Rene_HM
          Rene_HM Developer @kaschperle83 last edited by
          @kaschperle83 Nutzt du dem TemperaturOffset? ansonsten ist das mit den hier geschriebenen Infos Glaskugellesen...
          • Rene_HM
            Rene_HM Developer @Samsity last edited by Rene_HM
            @samsity sagte in Test Adapter HeatingControl v2.1.x:
            okay. gut. Die exception hier kannst du ignorieren, die geht weg, wenn alles richtig konfiguriert ist...
            Der screen shot oben passt nun aber nicht zu dem log. Laut log hast du ein Thermostat "TH-Dirk 1" und "1". Die sehe ich im screen shot oben nicht. Also zeige mir bitte die Konfiguration. Du kannst sie auch herunterladen und als Datei posten:
              @rene_hm das kann sein, da ich tlw. zum ausprobieren die anderen Räume als inaktiv gesetzt habe, damit nicht Räume plötzlich ungeheizt/geheizt werden ohne das es notwendig ist. Hab jetzt die Räume auf aktiv gesetzt und die Config runtergeladen.
              system.adapter.heatingcontrol.0 (1).json
              • Rene_HM
                @samsity für den Anfang wäre es besser, nur mit ein oder zwei Räumen zu starten und dann zu erweitern... Aber okay, die Konfiguration sieht soweit gut aus, aber:
                • wenn dein Wandthermostat ein oder mehrere Heizkörperthermostate steuert, musst du die Heizkörperthermostate NICHT im Adapter konfigurieren. Lösche die bitte... Inaktiv schalten sollte zwar auch reichen, aber sicher ist sicher
                Wenn du die Vis von Pittini verwenden willst, musst du das aber auch einschalten
                Wenn das an ist, und du auch die richtige Version der vis installiert hast (3.1.2, Anleitung findest du unter iobroker-heatingcontrol-vis dann poste ein bild von deiner vis...
                  @rene_hm Danke, ich werde die Heizkörperthermostate löschen, die über einen Wandthermostat verbunden sind.
                  Werde dann weiter testen und berichten.
                  Danke, Spende ist auch unterwegs.
                    @rene_hm achso, hier das Bild der bis jetzt konfigurierten VIS:
                    • Rene_HM
                      @samsity Wenn du auf den Raum "Dirk" umschaltest, hast du da auch die leeren Felder in der Profileinstellung unten?
                        @rene_hm das ist ein Fehler von mir, hatte bei den VIS Einstellungen die Mindesttemperatur falsch eingestellt.
                        Was mit gerade auffällt ist, das wenn ich im Speiseraum das Aktive Profil umstelle werden alle anderen Raumprofile auch mit umgestellt.
                        • Rene_HM
                          Das ist normal. Ein Profil beinhaltet immer alle Räume...
                            @rene_hm schade, hatte verstanden das ich jeden Raum ein eigenes Profil zuordnen kann und auch in jeden Raum ein anderes Profil aktivieren kann.
                            Das ist für mich das wichtigste an der ganzen Steuerung.
                            Könnte ich das evtl. umgehen in dem ich in der VIS auf die heatingcontrol.0.Rooms.RAUMNAME.ActiveTimeSlot zugreife und das benötigte Profil setze?
                            • Rene_HM
                              @samsity erkläre erst mal, was du eigentlich vorhast, dann schaun wir mal, wie wir das lösen...
                                @rene_hm ich betreibe ein Jugendhaus, da benötige ich für Räume die von den Gästen ganz andere Profile wie in meinem Privaten Bereich.
                                Beispiel :
                                Ich Homeoffice 21° ab 8 Uhr bis 22 Uhr
                                Vater daueranwesend 21°
                                Kein Gast da alle Gästeräume, 10°
                                Ich in der Arbeit 18° bis 12.30 Uhr, 21° bis 22 Uhr
                                Vater daueranwend 21°
                                Gäste da Speiseraum 21° 8 - 22 Uhr/ WC 18° 0-24 Uhr/ Aufenthaltsraum bleibt bei 10° wird mit Kachelofen geheizt(Heizkörper nur für Frostschutz)
                                Ich hoffe das ist verständlich geschrieben was ich mir Vorstelle.
                                Insgesamt habe ich für meinen Raum 4 Profile, bei meinem Vater aber nur zwei, und bei den Gästen 3-4 Profile.
                                • Rene_HM
                                  @samsity ich würde folgendes machen:
                                  1. vom Adapter zwei (oder evtl auch drei) instanzen installieren:
                                  • eine für deine Räume
                                  • eine für die Gästeräume
                                  • eine evtl. für die Räume des Vaters
                                  1. für deine Räume nur zwei Profile
                                  • HomeOffice
                                  • normal
                                  1. für die Gästeräume ein Profil, dafür aber ein Feature nutzen, was in der 2.2 kommt und sich "Einzelraumabschaltung" nennt. Räume, die nicht belegt sind werden dann einfach abgeschaltet und auf eine feste Temperatur geregelt.
                                  Zusätzlich würde ich die Features "Anwesenheit" nutzen um bei Abwesenheit zu reduzieren. Das würde ich nicht über Profile machen...
                                    @rene_hm okay, dann werd ich das so machen und testen.
                                    Danke schon mal für die Hilfe!
                                    • Rene_HM
                                      @samsity sorry, war noch nicht fertig oben.... Zusatzfrage: Warum so viele Profile?
                                      Bei mehreren Instanzen haben wir nur Anpassungen bzgl. der vis zu machen... Die kann das nicht out of the box...
                                        @rene_hm kein Problem, bin ja froh um die Unterstützung.
                                        Profil Privat 1 Homeoffice
                                        Profil Privat 2 kein HomeOffice
                                        Profil Privat 3 Urlaub anwesend
                                        Profil Privat 4 Urlaub abwesend
                                        Profil Gäste 1 nur Wochenende anwesend
                                        Profil Gäste 2 ganze Woche anwesend
                                        Profil Gäste keine Gäste anweesend
                                          @rene_hm die Anpassungen der VIS für mehrere Adapter-Instanzen müsste ich hinbekommen. Hoffe ich wenigstens 😂
                                            Michi_Pi @Rene_HM last edited by
                                            @rene_hm Unter WindowOpenDecrease stehten schon die 12grad
                                            heating
                                            236
                                            3158
                                            1847678
