    4. Test eCharts Adapter
      AndyUM61 @Homoran last edited by
      Ja, alles korrekt.
      Über Port 8082 funktioniert nichts.
      "http://192.168.0.99:8082/echarts/index.html?preset=echarts.0.Temperaturen"
      ...und das funktioniert:
      "http://192.168.0.99:8081/adapter/echarts/chart/index.html?preset=echarts.0.Temperaturen"
      K Homoran 2 Replies Last reply Reply Quote 0
        Kueppert @AndyUM61 last edited by
        @andyum61 das ist sehr komisch, bei mir funktioniert
        http://192.168.178.69:8081/adapter/echarts/chart/index.html?preset=echarts.0.Temperaturen
        als auch
        http://192.168.178.69:8082/echarts/index.html?preset=echarts.0.Temperaturen
          Homoran Global Moderator Administrators @AndyUM61 last edited by
          @andyum61 sagte in Test eCharts Adapter:
          da bleibt eine Idee:
          was hast du in dem Webadapter als socket eingestellt?
            Saschag last edited by
            Ich versuche mich am Versand eines Charts. Bekomme aber schon beim erstellen der "Datei" folgenden Fehler:
            echarts.0	2021-01-20 20:31:52.764	info	(22218) Terminated (NO_ERROR): Without reason
            echarts.0	2021-01-20 20:31:52.762	info	(22218) terminating
            echarts.0	2021-01-20 20:31:52.258	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
            echarts.0	2021-01-20 20:31:52.258	error	at runMicrotasks (<anonymous>)
            echarts.0	2021-01-20 20:31:52.258	error	at /opt/iobroker/node_modules/iobroker.echarts/_helpers/ChartModel.js:762:45
            echarts.0	2021-01-20 20:31:52.258	error	(22218) TypeError: this.socket.subscribeState is not a function
            echarts.0	2021-01-20 20:31:52.256	error	(22218) unhandled promise rejection: this.socket.subscribeState is not a function
            Unhandled	2021-01-20 20:31:52.252	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0	2021-01-20 20:31:49.860	info	(3839) script.js.Pushover.testeCharts2: registered 0 subscriptions and 0 schedules
            Skript:
            sendTo('echarts.0', {
                preset:   'echarts.0.Strom', // the only mandatory attribute
                renderer: 'jpg',                // svg | png | jpg | pdf, default: svg
                width: 1024,                    // default 1024
                height: 300,                    // default 300
                background: '#000000',          // Background color
                theme: 'dark',                 // Theme type: 'light', 'dark'
                title: 'ioBroker Chart',        // Title of PDF document
                quality: 0.8,                   // quality of JPG
                compressionLevel: 3,            // Compression level of PNG
                filters: 8,                     // Filters of PNG (Bit combination https://github.com/Automattic/node-canvas/blob/master/types/index.d.ts#L10)
                fileOnDisk: '/opt/iobroker/temp/eCharts',                 // Path on disk to save the file.
                fileName: 'chart.jpg',                   // Path in ioBroker DB to save the files on 'echarts.0'. E.g. if your set "chart.svg", so you can access your picture via http(s)://ip:8082/echarts.0/chart.png
            }, result => {
                if (result.error) {
                    console.error(result.error);
                } else {
                    console.log(result.data);
            Jemand vielleicht ne Idee?
              AndyUM61 @Homoran last edited by AndyUM61
              @homoran sagte in Test eCharts Adapter:
              Daran scheint es tatsächlich zu liegen:).
              Ich habe jetzt mal das Häkchen bei "Nur Web-Sockets" entfernt,
              und siehe da, es geht;).
              Sogar mit relativer Addressierung!
              SUPER! DANKESCHÖN:)!
              • Bostil
                Bostil last edited by Bostil
                Ein schöner Adapter, der mir irgendwie bisher komplett entgangen ist. Danke für eure Arbeit erstmal !!!
                Würde gerne für einzelne Wochentage (Montag - Sonntag) eigentlich gerne in einer klassischen Säulenansicht die Erzeugung meiner PV-Anlage und den Hausverbrauch ausweisen. Wenn ich das richtig sehe, kann man ein Säulen-/Balkendiagramm leider nicht auswählen, oder?
                DANKE euch.
                So ist der Status ...
                Weitere Anmerkungen / Feedback:
                • Änderung Schriftfarbe-
                • Fixiering min / max-Werte der Achsen
                • besterquester
                  besterquester Developer @Bluefox last edited by
                  @bluefox
                  I have tested the adapter it works perfect 👍 . One question is it planned also to integrate bar charts. Especially for Energy monitoring daily, hourly, etc it would be a nice feature ?
                  regards Chris
                  Bluefox 1 Reply Last reply Reply Quote 1
                  • Bluefox
                    Bluefox @besterquester last edited by
                    @besterquester one after other.... May be.
                    besterquester M 2 Replies Last reply Reply Quote 2
                      ratte-rizzo last edited by ratte-rizzo
                      Moin
                      Seit ich den Adapter am Laufen habe, bekomme ich des Öfteren folgende Fehlermeldung auf meinem Rechner im Firefox, wenn ich die VIS aufrufe:
                      Socket Error: Error: xhr post error
                      Oder alternativ manchmal auch:
                      Socket Error: Error: websocket error
                      Das war vorher definitiv nicht der Fall. Woran kann das liegen? der ioBroker läuft auf einem Nuc und die Adapter sind alle aktuell. Hat jemand eine Idee?
                      Dank & Gruß
                      Daniel
                      • besterquester
                        @bluefox Thanks 👍
                          funnsurfer @Bluefox last edited by
                          @bluefox
                          Moin zusammen,
                          gibt es die Möglichkeit die Schriftgröße der Legende für die dargestellten Daten zu ändern? Die Einstellung kann ich bei dem schönen Adapter nicht finden.
                          Wenn ich ein Theme wähle, ändert sich die Darstellung des Diagramms auch nicht. Was mache ich falsch? Der Fehler sitzt wahrscheinlich vor dem Monitor 🙂
                          Gruß + vielen Dank
                          lobomau 1 Reply Last reply Reply Quote 0
                          • lobomau
                            lobomau @funnsurfer last edited by
                            @funnsurfer geht noch nicht.
                            Issue habe ich erstellt:
                            https://forum.iobroker.net/topic/39172/test-echarts-adapter/52?_=1614584046099
                            https://github.com/ioBroker/ioBroker.echarts/issues/29
                            lobomau76 created this issue in ioBroker/ioBroker.echarts
                            closed Change size/color of x/y-axes numbers and legend #29
                            stephan1827 1 Reply Last reply Reply Quote 0
                            • stephan1827
                              stephan1827 @lobomau last edited by
                              Hat hier schonmal jemand versucht die Charts über iframe einzubetten? Ich benutze jarvis und da blockiert der Browser das Chart oben rechts. Unten links ist ein Chart aus der Visu eingebttet.
                                dskrt @stephan1827 last edited by
                                @stephan1827 Ich habe genau dasselbe Problem beim einbinden über IFrame in VIS
                                • David G.
                                  David G. @dskrt last edited by
                                  @dskrt
                                  @stephan1827
                                  Das Problem hatte ich auch mal mit Lovelace und Flot.
                                  Da lag es daran, dass die eine Instanz mittels Ssl verschlüsselt war und die andere nicht.
                                  Nachdem beides auf Ssl gestellt war, lief es dann.
                                  D stephan1827 3 Replies Last reply Reply Quote 0
                                    dskrt @David G. last edited by
                                    @david-g Beide Iaufen über https://, oder meintest du etwas anderes ?
                                      Kueppert @dskrt last edited by
                                      @dskrt ich hab irgendwie im Hinterkopf, das nur HTTP funktioniert, bin mir aber unsicher. Wäre aber nen Versuch wert...
                                      • David G.
                                        David G. @Kueppert last edited by
                                        @kueppert
                                        Ich hab lovelace und echarts per Ssl am laufen und in meine Visu eingebunden.
                                          dskrt @David G. last edited by dskrt
                                          @david-g Es ist definitiv ein Problem zwischen VIS und ECharts, ein Iframe in VIS mit JarVIS oder auch FLOT läuft einwandfrei, sowohl https wie auch http. Irgendwo in ECharts ist eine Option zum setzen von 'allow Iframes, aber wo ? Wer kann helfen ?
                                          • Steff
                                            Steff last edited by
                                            Moin,
                                            ich versuche mich immer noch an dem Server-Side-Rendering, ich möchte gerne Charts an Telegram versenden. Muss da noch etwas installiert / aktiviert werden? Wenn ich das Beispiel-Script von @Bluefox nehme, passiert bei mir rein gar nichts - es gibt auch keinen Log-Eintrag.
                                            Gruß Steffen
                                            echarts
                                            105
                                            652
                                            167317
