    4. MieleCloudService Adapter
      kleine_kuh @Grizzelbee last edited by
      Hallo @grizzelbee
      Ich habe mein System komplett neu aufsetzen müssen. Jetzt habe ich leider Probleme mit Deinem Adapter. Ich bekomme einfach keine Verbindung, er bleibt einfach rot.
      Das Log schmeißt folgendes raus:
      host.raspberrypi	2021-01-24 15:47:37.693	info	Do not restart adapter system.adapter.mielecloudservice.0 because desired by instance
      host.raspberrypi	2021-01-24 15:47:37.693	error	instance system.adapter.mielecloudservice.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      mielecloudservice.0	2021-01-24 15:47:37.160	error	(23097) [main] {}
      mielecloudservice.0	2021-01-24 15:47:37.159	info	(23097) Terminated (ADAPTER_REQUESTED_TERMINATION): Terminating adapter due to error on token request.
      mielecloudservice.0	2021-01-24 15:47:37.156	error	(23097) Are your credentials okay? Please doublecheck them in your adapters configuration.
      mielecloudservice.0	2021-01-24 15:47:37.156	error	(23097) Error: Request failed with status code 401
      mielecloudservice.0	2021-01-24 15:47:37.155	error	(23097) OAuth2 returned an error!
      mielecloudservice.0	2021-01-24 15:47:36.905	debug	(23097) config API Language: [de]
      mielecloudservice.0	2021-01-24 15:47:36.905	debug	(23097) options OAuth2-VG: [de-DE]
      mielecloudservice.0	2021-01-24 15:47:36.904	debug	(23097) OAuth2 grant_type: [password]
      mielecloudservice.0	2021-01-24 15:47:36.904	debug	(23097) Awaiting OAuth2 Token.
      mielecloudservice.0	2021-01-24 15:47:36.900	debug	(23097) function APIGetAccessToken
      mielecloudservice.0	2021-01-24 15:47:36.867	info	(23097) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v12.20.1, js-controller: 3.1.6
      mielecloudservice.0	2021-01-24 15:47:36.583	debug	(23097) statesDB connected
      mielecloudservice.0	2021-01-24 15:47:36.582	debug	(23097) States connected to redis: 127.0.0.1:9000
      mielecloudservice.0	2021-01-24 15:47:36.570	debug	(23097) States create System PubSub Client
      mielecloudservice.0	2021-01-24 15:47:36.567	debug	(23097) States create User PubSub Client
      mielecloudservice.0	2021-01-24 15:47:36.553	debug	(23097) Redis States: Use Redis connection: 127.0.0.1:9000
      mielecloudservice.0	2021-01-24 15:47:36.550	debug	(23097) objectDB connected
      mielecloudservice.0	2021-01-24 15:47:36.542	debug	(23097) Objects connected to redis: 127.0.0.1:9001
      mielecloudservice.0	2021-01-24 15:47:36.524	debug	(23097) Objects client initialize lua scripts
      mielecloudservice.0	2021-01-24 15:47:36.522	debug	(23097) Objects create User PubSub Client
      mielecloudservice.0	2021-01-24 15:47:36.521	debug	(23097) Objects create System PubSub Client
      mielecloudservice.0	2021-01-24 15:47:36.517	debug	(23097) Objects client ready ... initialize now
      mielecloudservice.0	2021-01-24 15:47:36.482	debug	(23097) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.raspberrypi	2021-01-24 15:47:35.506	info	instance system.adapter.mielecloudservice.0 started with pid 23097
      Die Miele Credentials habe ich schon erneuert/ausgetauscht. Keine Wirkung.
      Wo liegt denn noch mein Fehler?
      Grizzelbee 1 Reply Last reply Reply Quote 0
      • Grizzelbee
        Grizzelbee Developer @kleine_kuh last edited by
        Hi!
        @kleine_kuh sagte in MieleCloudService Adapter:
        HTTP-Code 401 ist ganz eindeutig ein Problem mit deinen Credentials - sprich Zugangsdaten.
        Das kann Username/Passwort sein, oder die developer Daten von Miele.
        Am Besten wirklich alles noch einmal per Copy/Paste eintragen und doppelt prüfen.
        In der main.js sind auch ein paar Zeilen auskommentiert und passend markiert. Wenn die wieder aktiviert werden werden für solche Fälle die Passwörter wieder ins Log geschrieben.
        Das könntest du probieren.
        Ich hatte aber auch schon einen Fall in dem die (frischen) Developer Credentials einfach nicht funktioniert haben. Da war die Lösung die Anforderung neuer Creadentials mit denen es dann auf Anhieb ging.
        Hoffe das hilft dir weiter - falls nicht: einfach weiter Fragen bei dem was unklar ist.
        viele Grüße
        grizzelbee
          @grizzelbee
          Ja, ich hatte in einem anderen Thread dazu schon die Beschreibung gesehen zu Deiner Lösung.
          Daraufhin hab ich dann nochmal die Credentials neu angefordert, auch extra nochmal über Nacht gewartet.... Komisch. Ich probier es einfach nochmal. Danke Dir.
          • Grizzelbee
            @kleine_kuh
            Haben die Zugangsdaten denn jemals vorher funktioniert, oder ist das dein erster Versuch?
              @grizzelbee
              Es lief schonmal, allerdings hatte ich damals blöderweise die Credentials nicht notiert. Daher hatte ich sie jetzt neu angefordert. Das ganze jetzt allerdings schon dreimal. Hatte jetzt extra bis heute nochmal abgewartet. Aber es funktioniert wieder nicht. Hab alles mit c+p eingefügt, hatte es auch händisch abgetippt. Immer wieder dasgleiche. Ich hab echt keine Ahnung
              • Grizzelbee
                @kleine_kuh
                Dann schreib Miele doch eine eMail. Wenn ich das richtig im Kopf habe developer@miele.com und schildere denen deine Login-Probleme und bitte darum das die das fixen. Etwas besseres fällt mir da gerade auch nicht ein.
                  @grizzelbee
                  Guter Tip, habe ich soeben getan. Ich bin gespannt und lass Euch gern wissen, was dabei raus kommt.
                    kleine_kuh @kleine_kuh last edited by
                    @grizzelbee
                    Guten Morgen,
                    wollte Euch nur kurz informieren, dass sich mein Problem mit der Anmeldung erledigt hat. Miele hat sich zwar immer noch nicht gemeldet, aber ich habe mir gestern nochmal alles angeschaut. Und was soll ich sagen.... 😬... ich hatte eine völlig falsche Email Adresse eingetragen, hatte zwei Email Adressen von mir durcheinander gewürfelt. Das las sich allerdings sooo richtig, dass ich es wirklich nicht gemerkt hatte. Depp halt. Nun ja, es ist mir sehr peinlich, wollte Dir trotzdem mitteilen, dass der Adapter jetzt wieder super läuft! Danke Dir!
                    Grizzelbee 1 Reply Last reply Reply Quote 1
                    • Grizzelbee
                      @kleine_kuh
                      Solche blinden Momente haben wir doch alle mal. 😉
                      Freut mich aber zu hören, dass jetzt wieder alles läuft. Das ist doch die Hauptsache.
                      Und jetzt: Alles schön notieren! 😉 🤣
                      • U
                        Ulli 0 last edited by Ulli 0
                        erstmal Danke für den Adapter!
                        Ich versuche grade meine API-Client-ID und API-Client-Secret über https://www.miele.com/f/com/en/register_api.aspx zu generieren. Leider passiert nach dem Klick auf "register" nichts ausser die Meldung "Your registration request has been processed successfully. Please check your inbox for an e-mail with your personal activation link."
                        Da kommt aber keine Mail - nix im Spam, und ich warte schon 30min. Was muss ich bei "Enter your application name" eingeben?
                        Schöne Grüße!
                        • Grizzelbee
                          Grizzelbee Developer @Ulli 0 last edited by Grizzelbee
                          Hi @ulli-0 ,
                          Uff! Gute Fragen!
                          Ich habe bei Application Name damals den Namen des Adapters eingegeben (der sich danach aber noch einmal geändert hat) - insofern glaube ich, das das einigermaßen egal ist, was du da angibst.
                          Und ja - da müsste eine Mail kommen - allerdings hat Miele den Prozeß nach meiner registrierung umgestellt. Da bin ich also nicht auf dem Laufenden.
                          Vielleicht kann ja jemand der erst vor kuzem registiert hat mit aktuelleren Infos aushelfen?
                          Im Zweifel würde ich der Sache aber noch ein bisschen Zeit geben. Firmen machen am Wochenende gerne mal Wartungsarbeiten an ihrer Infrastruktur.
                          viele Grüße
                          grizzelbee
                          • U
                            Ulli 0 @Grizzelbee last edited by
                            @grizzelbee Mail kam mittlerweile an.
                            Ich habe da auch API-Client-ID und API-Client-Secret rauskopiert und im Adapter eingegeben.
                            -> Adapter rot
                            -> unter https://www.miele.com/developer/swagger-ui/index.html den API-key autorisiert.
                            -> Adapter rot
                            Fehlt mir irgendein Schritt?
                            • Grizzelbee
                              @ulli-0
                              Was steht denn im Log?
                              • U
                                @grizzelbee
                                mielecloudservice.0 2021-02-06 12:41:51.064 error (15846) [main] {}
                                mielecloudservice.0 2021-02-06 12:41:51.063 info (15846) Terminated (ADAPTER_REQUESTED_TERMINATION): Terminating adapter due to error on token request.
                                mielecloudservice.0 2021-02-06 12:41:51.061 error (15846) Are your credentials okay? Please doublecheck them in your adapters configuration.
                                mielecloudservice.0 2021-02-06 12:41:51.060 error (15846) Error: Request failed with status code 401
                                mielecloudservice.0 2021-02-06 12:41:51.059 error (15846) OAuth2 returned an error!
                                • Grizzelbee
                                  @ulli-0
                                  Hmmm. Das (401) ist eindeutig: Die Zugangsdaten funktionieren nicht.
                                  Bitte überprüfe noch einmal alles sehr sorgfältig.
                                  Du brauchst die Zugangsdaten, die du für die App verwedet hast und die Miele-Dev-Daten. Achte auch auf führende oder folgende Leerzeichen.
                                  Leider werden alle vier Zugangsdaten in einem Rutsch übermittelt. Deshalb kann ich nicht ganauer sagen welche gerade doof spielen.
                                  • U
                                    Ulli 0 @Grizzelbee last edited by Ulli 0
                                    @grizzelbee
                                    Dann nochmal die Schritte im Einzelnen. Der Miele@home Account besteht schon seit einem Jahr. Login (Mailadresse) und Passwort (in der App) stimmen.
                                    1. unter https://www.miele.com/f/com/en/register_api.aspx mit der Mailadresse aus der App registriert
                                    2. API-Client-ID und API-Client-Secret von der Miele-Seite in den Adapter kopiert.
                                    Folgendes im Adapter eingegeben:
                                    Miele-Konto -> Mail Adresse
                                    Miele Passwort -> Passwort, das auch in der App benutzt wird
                                    API-Client-ID -> 474f4195-ed6d-40f6-a849-.... (... sind 12 Zeichen)
                                    API-Client-Secret -> 32 Zeichen-String
                                    -> Adapter rot
                                    Ich hab jetzt nochmal unter https://www.miele.com/f/com/en/register_api.aspx neue Daten angefordert. Nachdem Klcik auf "accept" kommt die Meldung "Your token is invalid."
                                    • Grizzelbee
                                      @ulli-0
                                      Soweit ich weiß, kann man für eine eMailadresse immer nur einen Satz Credentials anfordern.
                                      Hier: https://www.miele.com/developer/swagger-ui/swagger.html gibt es auf der rechten Seite einen grünen Button Authorize - da kannst du deine Dev-Daten testen.
                                      • U
                                        @grizzelbee
                                        Wenn ich hier meine ID und SECRET eingebe,
                                        lande ich auf einer Seite, wo ich wieder meine Mail und Passwort eingeben muss.
                                        nach Eingabe kommt dann das hier
                                        • Grizzelbee
                                          @ulli-0
                                          Hmmm. Dann würde ich mich an den Dev-Support von Miele wenden. Da scheint etwas schief gelaufen zu sein.
                                          • U
                                            @grizzelbee
                                            Ich hab jetzt aus lauter Verzweiflung nochmal alles zurückgesetzt
                                            1. Passwort per app zurückgesetzt
                                            2. neue Credentials generiert https://www.miele.com/f/com/en/register_api.aspx
                                            3. Account mit den Credentials verknüft https://www.miele.com/developer/swagger-ui/swagger.html
                                            Ergebnis:
                                            0ae4f1a5-7d7f-4a1c-9afd-bd715ae381c9-image.png 🙂
                                            Da war echt irgendwo der Wurm drin. Danke an der Stelle!
                                            miele mieleathome mielecloudservice
                                            90
                                            846
                                            201527
