    4. Betatester für Backitup 2.0.0 gesucht
    • simatec
      simatec Developer Most Active @MalleRalle last edited by simatec
      @malleralle
      Was hast du für einen OwnCloud Server laufen?
      Würde mir zum testen auch was aufsetzen
      • MalleRalle
        @simatec
        Ich habe einen eigenen Centos 7 vServer laufen.
        Dazu die Software von Owncloud.
        Owncloud
        • simatec
          @malleralle
          Danke schaue ich mir mal an
            ente34 @simatec last edited by
            @simatec
            Beim Jarvis-Restore gibt es einen Fehler (2.0.0-beta4):
            jarvis.0	2021-02-06 18:39:37.536	info	(1769) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            jarvis.0	2021-02-06 18:39:37.536	info	(1769) terminating
            jarvis.0	2021-02-06 18:39:37.535	info	(1769) Adapter stopped und unloaded.
            jarvis.0	2021-02-06 18:39:37.533	info	(1769) Got terminate signal TERMINATE_YOURSELF
            backitup.0	2021-02-06 18:39:37.529	info	(743) cleaned everything up...
            backitup.0	2021-02-06 18:39:37.527	error	at FSReqCallback.oncomplete (fs.js:156:23)
            backitup.0	2021-02-06 18:39:37.527	error	at /opt/iobroker/node_modules/targz/node_modules/tar-fs/index.js:248:25
            backitup.0	2021-02-06 18:39:37.527	error	at onunlock (/opt/iobroker/node_modules/targz/node_modules/tar-stream/extract.js:73:26)
            backitup.0	2021-02-06 18:39:37.527	error	at Extract.destroy (/opt/iobroker/node_modules/targz/node_modules/tar-stream/extract.js:196:17)
            backitup.0	2021-02-06 18:39:37.527	error	at Extract.emit (events.js:326:22)
            backitup.0	2021-02-06 18:39:37.527	error	at Extract.error (/opt/iobroker/node_modules/targz/lib/targz.js:51:13)
            backitup.0	2021-02-06 18:39:37.527	error	at /opt/iobroker/node_modules/iobroker.backitup/lib/restore/jarvis.js:55:21
            backitup.0	2021-02-06 18:39:37.527	error	at Object.error (/opt/iobroker/node_modules/iobroker.backitup/lib/restore.js:136:47)
            backitup.0	2021-02-06 18:39:37.527	error	(743) TypeError: Cannot read property 'toString' of undefined
            backitup.0	2021-02-06 18:39:37.526	error	(743) uncaught exception: Cannot read property 'toString' of undefined
            host.raspi-iobroker	2021-02-06 18:39:37.526	info	stopInstance system.adapter.jarvis.0 (force=false, process=true)
            host.raspi-iobroker	2021-02-06 18:39:37.525	info	"system.adapter.jarvis.0" disabled
            backitup.0	2021-02-06 18:39:37.523	error	(743) [jarvis] jarvis restore not completed
            host.raspi-iobroker	2021-02-06 18:39:37.511	info	instance "system.adapter.jarvis.0" disabled via .alive
            backitup.0	2021-02-06 18:39:37.501	debug	(743) [jarvis] jarvis.0 stopped
            backitup.0	2021-02-06 18:39:37.487	debug	(743) [jarvis] old jarvis database directory was successfully deleted
            backitup.0	2021-02-06 18:39:37.480	debug	(743) [jarvis] jarvis tmp directory created: /opt/iobroker/backups/jarvis_0
            backitup.0	2021-02-06 18:39:37.473	debug	(743) [jarvis] filename for restore: /opt/iobroker/backups/jarvis.0_2021_02_06-11_00_34_backupiobroker.tar.gz
            backitup.0	2021-02-06 18:39:37.472	debug	(743) [jarvis] Start Jarvis Restore ...
            backitup.0	2021-02-06 18:39:22.812	debug	(743) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
            backitup.0	2021-02-06 18:39:20.802	debug	(743) mount successfully completed
            backitup.0	2021-02-06 18:39:20.302	debug	(743) Backup list be read ...
            javascript.0	2021-02-06 18:38:11.589	debug	(902) system.adapter.admin.0: logging true
            backitup.0	2021-02-06 18:38:11.584	debug	(743) system.adapter.admin.0: logging true
              ente34 last edited by ente34
              @simatec
              Noch ein kleines Problem: Backup unvollständig ohne Fehlermeldung
              Hier das Listing von meiner NAS.
              Das Backup vom 6.2 11:00 ist vollständig, danach nicht mehr.
              Bitte beachte das Directory jarvis_0 vom 6.2 18:39
              Sorry, beim Hochladen kommt Meldung "etwas schief gegangen"
              Und beim Absenden "forbidden"
              • simatec
                Die Version 2.0.0-beta.5 ist auf Github Online
                E 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @ente34 last edited by
                  @ente34 sagte in Betatester für Backitup 2.0.0 gesucht:
                  browser neuladen, dann geht es
                    @simatec
                    Beide Punkte behoben, vielen Dank.
                    Neues Problem: Bekomme keine Liste der zu restorenden Files,
                    der Button "Get Backups" wird kurz grau und dann wieder blau
                    • simatec
                      simatec Developer Most Active @ente34 last edited by
                      @ente34
                      Lösche mal alte Unterordner im Backup Verzeichnis
                        @simatec
                        Beim Restore von Scripten landen die Files im Filesystem, aber im javascript Adapter fehlen Scripte (s.Lampen)
                        Filesystem:
                        Javascript:
                          @simatec
                          Kann ich machen, aber willst Du nicht den Fehler im Programm beheben?
                          • simatec
                            @ente34
                            Kann ich nicht bestätige ... hab es gerade getestet ...
                            • simatec
                              @ente34
                              Schaue noch mal, wie da einen besseren Filter hinbekomme
                                @simatec
                                Mein Backup-Verzeichnis
                                • simatec
                                  @ente34 Versuche mal bitte die 2.0.0-beta.6 von Github
                                    @simatec
                                    Perfekt!
                                    Das Problem mit den Javascript Files kann ich leider nicht reproduzieren.
                                    Ich habe es einmal beim Restore von Scripts von einem anderen Host gesehen.
                                    Neustart des javascript adapter brachte nichts, aber ein touch auf die Scripte
                                      @simatec
                                      Mit den Scripten gibt es definitiv (manchmal) ein Problem, es fehlen wieder welche
                                      (im Filesystem liegen fünf)
                                      Der javascript Adapter merkt auch etwas:
                                      javascript.0	2021-02-08 15:29:55.315	warn	(14644) Please delete file C:\Program Files\iobroker\SmartHome1\iobroker-data\scripts\Lampen\LampenSchalten
                                      javascript.0	2021-02-08 15:29:55.315	warn	(14644) Please delete file C:\Program Files\iobroker\SmartHome1\iobroker-data\scripts\Lampen\Schalten
                                      javascript.0	2021-02-08 15:29:55.314	warn	(14644) Please delete file C:\Program Files\iobroker\SmartHome1\iobroker-data\scripts\Test\ttt
                                      • simatec
                                        @ente34 Ich nehme mal den Stop raus. Eventuell hat der Javascript-Adapter damit ein Problem, da er ja mit den Scriptpfad synchron arbeitet
                                          @simatec
                                          Beim IoBroker Restore ist mir noch etwas aufgefallen, trotz "Start all adapters after restore" laufen nach Restore nur admin und backitup. Alle anderen muss ich manuell starten. Js-Controller ?
                                          C:\Program Files\iobroker\SmartHome1>iobroker -v
                                          3.2.16
                                          da_Woody simatec 2 Replies Last reply Reply Quote 0
                                          • da_Woody
                                            da_Woody @ente34 last edited by
                                            @ente34 sicher? hat bei mir auch ewig gedauert bis alle wieder gelaufen sind...
                                            293
                                            33499
