    4. Betatester für Backitup 2.0.0 gesucht
      ente34 @simatec last edited by
      @simatec
      Beim Jarvis-Restore gibt es einen Fehler (2.0.0-beta4):
      jarvis.0	2021-02-06 18:39:37.536	info	(1769) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      jarvis.0	2021-02-06 18:39:37.536	info	(1769) terminating
      jarvis.0	2021-02-06 18:39:37.535	info	(1769) Adapter stopped und unloaded.
      jarvis.0	2021-02-06 18:39:37.533	info	(1769) Got terminate signal TERMINATE_YOURSELF
      backitup.0	2021-02-06 18:39:37.529	info	(743) cleaned everything up...
      backitup.0	2021-02-06 18:39:37.527	error	at FSReqCallback.oncomplete (fs.js:156:23)
      backitup.0	2021-02-06 18:39:37.527	error	at /opt/iobroker/node_modules/targz/node_modules/tar-fs/index.js:248:25
      backitup.0	2021-02-06 18:39:37.527	error	at onunlock (/opt/iobroker/node_modules/targz/node_modules/tar-stream/extract.js:73:26)
      backitup.0	2021-02-06 18:39:37.527	error	at Extract.destroy (/opt/iobroker/node_modules/targz/node_modules/tar-stream/extract.js:196:17)
      backitup.0	2021-02-06 18:39:37.527	error	at Extract.emit (events.js:326:22)
      backitup.0	2021-02-06 18:39:37.527	error	at Extract.error (/opt/iobroker/node_modules/targz/lib/targz.js:51:13)
      backitup.0	2021-02-06 18:39:37.527	error	at /opt/iobroker/node_modules/iobroker.backitup/lib/restore/jarvis.js:55:21
      backitup.0	2021-02-06 18:39:37.527	error	at Object.error (/opt/iobroker/node_modules/iobroker.backitup/lib/restore.js:136:47)
      backitup.0	2021-02-06 18:39:37.527	error	(743) TypeError: Cannot read property 'toString' of undefined
      backitup.0	2021-02-06 18:39:37.526	error	(743) uncaught exception: Cannot read property 'toString' of undefined
      host.raspi-iobroker	2021-02-06 18:39:37.526	info	stopInstance system.adapter.jarvis.0 (force=false, process=true)
      host.raspi-iobroker	2021-02-06 18:39:37.525	info	"system.adapter.jarvis.0" disabled
      backitup.0	2021-02-06 18:39:37.523	error	(743) [jarvis] jarvis restore not completed
      host.raspi-iobroker	2021-02-06 18:39:37.511	info	instance "system.adapter.jarvis.0" disabled via .alive
      backitup.0	2021-02-06 18:39:37.501	debug	(743) [jarvis] jarvis.0 stopped
      backitup.0	2021-02-06 18:39:37.487	debug	(743) [jarvis] old jarvis database directory was successfully deleted
      backitup.0	2021-02-06 18:39:37.480	debug	(743) [jarvis] jarvis tmp directory created: /opt/iobroker/backups/jarvis_0
      backitup.0	2021-02-06 18:39:37.473	debug	(743) [jarvis] filename for restore: /opt/iobroker/backups/jarvis.0_2021_02_06-11_00_34_backupiobroker.tar.gz
      backitup.0	2021-02-06 18:39:37.472	debug	(743) [jarvis] Start Jarvis Restore ...
      backitup.0	2021-02-06 18:39:22.812	debug	(743) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
      backitup.0	2021-02-06 18:39:20.802	debug	(743) mount successfully completed
      backitup.0	2021-02-06 18:39:20.302	debug	(743) Backup list be read ...
      javascript.0	2021-02-06 18:38:11.589	debug	(902) system.adapter.admin.0: logging true
      backitup.0	2021-02-06 18:38:11.584	debug	(743) system.adapter.admin.0: logging true
        ente34 last edited by ente34
        @simatec
        Noch ein kleines Problem: Backup unvollständig ohne Fehlermeldung
        Hier das Listing von meiner NAS.
        Das Backup vom 6.2 11:00 ist vollständig, danach nicht mehr.
        Bitte beachte das Directory jarvis_0 vom 6.2 18:39
        Sorry, beim Hochladen kommt Meldung "etwas schief gegangen"
        Und beim Absenden "forbidden"
        • simatec
          Die Version 2.0.0-beta.5 ist auf Github Online
          E 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @ente34 last edited by
            @ente34 sagte in Betatester für Backitup 2.0.0 gesucht:
            browser neuladen, dann geht es
              @simatec
              Beide Punkte behoben, vielen Dank.
              Neues Problem: Bekomme keine Liste der zu restorenden Files,
              der Button "Get Backups" wird kurz grau und dann wieder blau
              • simatec
                simatec Developer Most Active @ente34 last edited by
                @ente34
                Lösche mal alte Unterordner im Backup Verzeichnis
                  @simatec
                  Beim Restore von Scripten landen die Files im Filesystem, aber im javascript Adapter fehlen Scripte (s.Lampen)
                  Filesystem:
                  Javascript:
                    @simatec
                    Kann ich machen, aber willst Du nicht den Fehler im Programm beheben?
                    • simatec
                      @ente34
                      Kann ich nicht bestätige ... hab es gerade getestet ...
                      • simatec
                        @ente34
                        Schaue noch mal, wie da einen besseren Filter hinbekomme
                          @simatec
                          Mein Backup-Verzeichnis
                          • simatec
                            @ente34 Versuche mal bitte die 2.0.0-beta.6 von Github
                              @simatec
                              Perfekt!
                              Das Problem mit den Javascript Files kann ich leider nicht reproduzieren.
                              Ich habe es einmal beim Restore von Scripts von einem anderen Host gesehen.
                              Neustart des javascript adapter brachte nichts, aber ein touch auf die Scripte
                                @simatec
                                Mit den Scripten gibt es definitiv (manchmal) ein Problem, es fehlen wieder welche
                                (im Filesystem liegen fünf)
                                Der javascript Adapter merkt auch etwas:
                                javascript.0	2021-02-08 15:29:55.315	warn	(14644) Please delete file C:\Program Files\iobroker\SmartHome1\iobroker-data\scripts\Lampen\LampenSchalten
                                javascript.0	2021-02-08 15:29:55.315	warn	(14644) Please delete file C:\Program Files\iobroker\SmartHome1\iobroker-data\scripts\Lampen\Schalten
                                javascript.0	2021-02-08 15:29:55.314	warn	(14644) Please delete file C:\Program Files\iobroker\SmartHome1\iobroker-data\scripts\Test\ttt
                                • simatec
                                  @ente34 Ich nehme mal den Stop raus. Eventuell hat der Javascript-Adapter damit ein Problem, da er ja mit den Scriptpfad synchron arbeitet
                                    @simatec
                                    Beim IoBroker Restore ist mir noch etwas aufgefallen, trotz "Start all adapters after restore" laufen nach Restore nur admin und backitup. Alle anderen muss ich manuell starten. Js-Controller ?
                                    C:\Program Files\iobroker\SmartHome1>iobroker -v
                                    3.2.16
                                    da_Woody simatec 2 Replies Last reply Reply Quote 0
                                    • da_Woody
                                      da_Woody @ente34 last edited by
                                      @ente34 sicher? hat bei mir auch ewig gedauert bis alle wieder gelaufen sind...
                                      • simatec
                                        simatec Developer Most Active @da_Woody last edited by
                                        @da_woody
                                        Werde morgen die Beta 7 fertig machen, wo der Restore inkl. menü etwas überarbeitet wurde.
                                        Dort werde ich zum testen mal den Stop von JavaScript beim Restore deaktivieren
                                        • da_Woody
                                          da_Woody @simatec last edited by
                                          @simatec said in Betatester für Backitup 2.0.0 gesucht:
                                          wieder was zum umgewöhnen! 😄
                                          ich meinte ja nur, logisch das am anfang nur admin und backitup laufen. logisch, sonst würds ja nicht funktionieren, aber es dauert halt seine zeit bis die anderen adapter wieder starten. da kann man schon auf 2-3 bierchen gehn, oder was anderes... 😉
                                          • simatec
                                            @da_woody
                                            Nein so schlimm wird es nicht. Nur das Restore Menü sieht nun etwas schicker aus, wird übersetzt und man hat etwas mehr Infos tu den vorhandenen Backups
                                            293
                                            33493
