    4. Test Adapter OctoPrint
    • DasLukas
      DasLukas @da_Woody last edited by
      @da_Woody API Key jetzt nochmal neu erzeugt. Kopiert und in iobroker eingefügt. Gleiches Ergebnis.
      octoprint.0	2020-12-24 16:22:49.234	error	(523) Cannot read property 'toFixed' of null
      octoprint.0	2020-12-24 16:22:19.110	error	(523) Cannot read property 'toFixed' of null
      octoprint.0	2020-12-24 16:21:49.092	error	(523) Cannot read property 'toFixed' of null
      octoprint.0	2020-12-24 16:21:19.019	error	(523) Cannot read property 'toFixed' of null
      octoprint.0	2020-12-24 16:20:49.102	error	(523) Cannot read property 'toFixed' of null
      octoprint.0	2020-12-24 16:20:48.446	info	(523) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.octoprint, node: v10.17.0, js-controller: 3.1.6
      Hier einmal die Infos aus octoprint:
      browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0 Safari/605.1.15
      connectivity.connection_check: 8.8.8.8:53
      connectivity.connection_ok: true
      connectivity.enabled: true
      connectivity.online: true
      connectivity.resolution_check: octoprint.org
      connectivity.resolution_ok: true
      env.hardware.cores: 4
      env.hardware.freq: 1200
      env.hardware.ram: 917016576
      env.os.bits: 32
      env.os.id: linux
      env.os.platform: linux
      env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
      env.plugins.pi_support.octopi_version: 0.17.0
      env.plugins.pi_support.throttle_state: 0x0
      env.python.pip: 20.2.3
      env.python.version: 3.7.3
      env.python.virtualenv: true
      octoprint.safe_mode: false
      octoprint.version: 1.5.2
      printer.firmware: Klipper
      • da_Woody
        da_Woody @DasLukas last edited by
        @DasLukas said in Test Adapter OctoPrint 1.0.1:
        sieht bei mir so aus:
         starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.octoprint, node: v12.20.0, js-controller: 3.1.6
        octoprint aktuell? war ja vor kurzem ein update...
        DasLukas 1 Reply Last reply Reply Quote 0
        • DasLukas
          @da_Woody Okay, node wie hier beschrieben aktualisiert. Dann im iobroker admin nochmal geschaut ob unter Adapter ein update für octoprint bereitsteht. Negativ. octoprint unter Adapter deinstalliert und per GitHub manuell installiert. Die Version 1.0.5 wird dort jetzt auch angezeigt. Großes Problem ist das es keine octoprint Instanz mehr gibt. Die Logs sagen auch nicht. Jemand eine Idee?
          DasLukas haus-automatisierung 2 Replies Last reply Reply Quote 0
          • DasLukas
            DasLukas @DasLukas last edited by
            @DasLukas Selber die Lösung gefunden. Nachdem manuellen installieren über GitHub ist es anscheinend notwendig auch manuell eine Instanz zu erstellen. Bin noch neu beim iobroker.
            Jetzt läuft alles und die API läuft auch. Danke.
            • da_Woody
              @DasLukas na siehste, kleines xmas gift... 😉 gern geschehn!
              jup, das ist vielen schon passiert nach einer github install... 😄
              • haus-automatisierung
                haus-automatisierung Developer Most Active @DasLukas last edited by haus-automatisierung
                @DasLukas Bitte NIEMALS (außer Du willst mit am Adapter entwickeln) die Adapter per GitHub installieren. Dafür gibt es keinen Support, da Du einen undefinierten Stand ohne Versionsnummer installierst.
                Wenn Du die aktuellste freigegebene Version installieren möchtest, dann bitte den "Verwahrungsort" auf "latest" stellen.
                Vergiss einfach den Button mit der OctoCat und klick da im Produktivsystem nie drauf 😉 Dann ist alles gut. Siehe auch https://www.youtube.com/watch?v=rPR_QRGhAzM
                • da_Woody
                  da_Woody @haus-automatisierung last edited by
                  @haus-automatisierung hast ja recht, aber, no risk, no fun! 😉
                    haus-automatisierung Developer Most Active @da_Woody last edited by
                    @da_Woody sagte in Test Adapter OctoPrint 1.0.1:
                    Das Problem ist, dass viele Anfänger das als Standard-Weg für sich entdecken und dann nur Probleme haben. Gibt ja auch etliche YouTube-Videos wo das als Lösung vorgeschlagen wird. Daher stelle ich das gerne direkt richtig 😉 Von mir ist ja auch die Meldung im Popup, dass man das besser gerade nicht machen sollte.
                      Andre R. last edited by
                      Beim Update auf 1.0.7 kommt alle 5 Minuten "api not Connected" lässt sich auch nicht mehr einstellen. Kannst du da mal schauen?
                        haus-automatisierung Developer Most Active @Andre R. last edited by
                        @andre-r sagte in Test Adapter OctoPrint 1.0.5:
                        Beim Update auf 1.0.7 ...
                        Aktuell ist 1.0.8
                        Hast Du das Verhalten da auch? Mit welcher OctoPrint Version?
                          Andre R. @haus-automatisierung last edited by
                          @haus-automatisierung kommt bei 1.0.8 auch. die Meldung kommt nur wenn der Drucker inkl. Octoprint aus ist.
                          • da_Woody
                            da_Woody @Andre R. last edited by da_Woody
                            @andre-r na wenn der drucker und octoprint off sind kommen immer meldungen
                            octoprint.0	2021-02-08 20:55:32.311	info	(18308) timeout of 2000ms exceeded
                            edith: vorher einen drucker abgedreht, kommt auch die selbe meldung. adapter gelb und
                            octoprint.0	2021-02-08 22:35:53.745	info	(18308) OctoPrint API not connected
                              Andre R. @da_Woody last edited by
                              @da_woody man konnte aber den Aktualisierungsintervall einstellen wenn der Drucker offline ist. Die Einstellung ist zwar noch vorhanden aber wird ignoriert.
                              • da_Woody
                                @andre-r ist eine info meldung im log, nix weiter. kein warn, kein error, so what. schnurzpiepegal.
                                  @da_woody das ist mir schon klar. Die Meldung kommt alle 5 Minuten und spammt mir den Log zu, das stört mich.
                                  da_Woody -cs- 2 Replies Last reply Reply Quote 0
                                  • da_Woody
                                    @andre-r alle 5min und zuspammen? wenn du meinst... du kannst den adapter aber auch stoppen wenn der drucker nicht läuft. dann gibts auch keine meldungen.
                                    • -cs-
                                      -cs- @Andre R. last edited by -cs-
                                      Und warum stellst dann die Logstufe nicht auf "warn"?
                                      Instanzen -> Experteneinstellungen aktivieten ->
                                      Log-Stufe auf warn
                                      Dann kommen die Infos nicht.
                                      B 1 Reply Last reply Reply Quote 2
                                        bishop @-cs- last edited by
                                        Habe das OctoPrint-Enclosure Plugin am laufen mit dem ich Lüfter und Beleuchtung steuern kann. Es gibt dafür auch eine API, ist es möglich das in den Adapter zu integrieren?
                                        https://github.com/vitormhenrique/OctoPrint-Enclosure/wiki/API-Control
                                          haus-automatisierung Developer Most Active @bishop last edited by
                                          @bishop said in Test Adapter OctoPrint 1.0.5:
                                          Nur leider erweitert das Plugin nicht die offizielle API, sondern stellt eine separate bereit. 😞
                                            bishop @haus-automatisierung last edited by bishop
                                            ist es vielleicht möglich die json in den adapter zu bekommen um die daten zu verarbeiten?
                                            Oder wie bekomme ich z.b. die Temperatur oder das Relais in iobroker?
                                            Die Temperatur kann ich mit "http://ip.octoprint/plugin/enclosure/inputs/1" auslesen.
                                            adapter entwicklung adatper updates developer testen
                                            49
                                            461
                                            94950
