    4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
    • Fogg
      Fogg @sonystar last edited by
      @sonystar @Neo110
      Sehe gerade Eure Posts hierzu. Spannend.
      Könnt ihr mal aus dem Debug die Zeile wo die Daten kommen direkt posten? Die ist leider abgeschnitten. Wäre diese da:
      sainlogic.0 2020-10-26 06:57:04.287 debug (9867) Data object: {"indoortemp":237,"indoortemptime":1589,"outdoortemp":82,"outdoortemptime":1316,"dewpointtemp":72,"dewpointtemptime":1316,"windchilltemp":82,"windchilltemptime":1316,"indoorhumidit
      Mal schauen was das an Rohdaten kommt. Eigentlich sollte alles bearbeitet werden. Ggf. kommt da einfach keine 0? D.h. ich müsste die Werte nachts einfach 'resetten'.
      • N
        Neo110 @Fogg last edited by
        @fogg
        sainlogic.0	2021-01-12 17:41:04.247	debug	(29105) Data object: {"indoortemp":237,"outdoortemp":11,"dewpointtemp":1,"windchilltemp":-27,"heatindex":11,"indoorhumidity":42,"outdoorhumidity":94,"pressureabs":9612,"pressurerel":9612,"winddir":238
        sainlogic.0	2021-01-12 17:41:04.246	debug	(29105) Data Command received: 11 subcommand 4
        sainlogic.0	2021-01-12 17:41:04.246	debug	(29105) FW Scheduler Received data string: ffff0b0050040100ed02000b03000104ffe505000b062a075e08258c09258c0a00ee0b00240c00290e000000001000000000110000000212000000051300000005140000281615000000001600021
        bzw.
        sainlogic.0	2021-01-12 17:41:04.269	debug	(29105) Data object: {"indoortemp":302,"outdoortemp":379,"dewpointtemp":246,"heatindex":416,"indoorhumidity":73,"outdoorhumidity":99,"pressureabs":10109,"pressurerel":10109,"windspeed":101,"windgustsp
        sainlogic.0	2021-01-12 17:41:04.269	debug	(29105) Data Command received: 11 subcommand 5
        sainlogic.0	2021-01-12 17:41:04.268	debug	(29105) FW Scheduler Received data string: ffff0b00450501012e02017b0300f60501a00649076308277d09277d0b00650c008f0e000003c0100000012511000002c2120000049b130000186d15002dc6c016ffff170f967c
        sainlogic.0	2021-01-12 17:41:04.257	debug	(29105) Scheduler connected to weather station run 255,255,11,0,6,5,5,27
        sainlogic.0	2021-01-12 17:41:04.256	debug	(29105) Target for yearlyrain unit is set: mm, using conversion: null
        bzw.
        sainlogic.0	2021-01-12 17:41:04.283	debug	(29105) Data object: {"indoortemp":197,"outdoortemp":-134,"dewpointtemp":-147,"windchilltemp":-134,"indoorhumidity":23,"outdoorhumidity":18,"pressureabs":9322,"pressurerel":9322}
        sainlogic.0	2021-01-12 17:41:04.282	debug	(29105) Data Command received: 11 subcommand 6
        sainlogic.0	2021-01-12 17:41:04.282	debug	(29105) FW Scheduler Received data string: ffff0b001c060100c502ff7a03ff6d04ff7a0617071208246a09246a9653
        sainlogic.0	2021-01-12 17:41:04.275	debug	(29105) Scheduler connected to weather station run 255,255,11,0,6,6,6,29
        sainlogic.0	2021-01-12 17:41:04.275	debug	(29105) Target for yearlyrain unit is set: mm, using conversion: null
        bzw.
        sainlogic.0	2021-01-12 17:41:04.298	debug	(29105) Data object: {"indoortemp":255,"indoortemptime":3378,"outdoortemp":12,"outdoortemptime":4352,"dewpointtemp":4,"dewpointtemptime":3885,"windchilltemp":12,"windchilltemptime":4352,"indoorhumidit
        sainlogic.0	2021-01-12 17:41:04.298	debug	(29105) Data Command received: 11 subcommand 7
        sainlogic.0	2021-01-12 17:41:04.297	debug	(29105) FW Scheduler Received data string: ffff0b004d074100ff0d3242000c11004300040f2d45000c1100462d0d0e47610a1a4825e900014925e900014b0033101a4c0047100f4e000000000000550001683c0b34560002000057000000631
        sainlogic.0	2021-01-12 17:41:04.286	debug	(29105) Scheduler connected to weather station run 255,255,11,0,6,7,7,31
        oder noch diese Zeile:
        sainlogic.0	2021-01-12 17:41:04.312	debug	(29105) Data object: {"indoortemp":232,"indoortemptime":1553,"outdoortemp":-40,"outdoortemptime":27,"dewpointtemp":-58,"dewpointtemptime":20,"windchilltemp":-88,"windchilltemptime":300,"indoorhumidity
        sainlogic.0	2021-01-12 17:41:04.312	debug	(29105) Data Command received: 11 subcommand 8
        sainlogic.0	2021-01-12 17:41:04.311	debug	(29105) FW Scheduler Received data string: ffff0b002c084100e8061142ffd8001b43ffc6001444ffa8012c461d0836475700004825830e1a4925830e1a2077
        sainlogic.0	2021-01-12 17:41:04.303	debug	(29105) Scheduler connected to weather station run 255,255,11,0,6,8,8,33
        Die Daten sind alle mit dem gleichen Zeitstempel gekommen.
        • N
          Neo110 @Neo110 last edited by Neo110
          Leider kommt nach "indoorhumidity" nichts mehr
          Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
          • Johannes Bauerstatter
            Johannes Bauerstatter @Neo110 last edited by
            Hallo, hat jemand die Sainlogic FT0300 zum laufen gebracht?
            https://www.amazon.de/gp/product/B0836FVVYZ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
            • Glasfaser
              Glasfaser @Johannes Bauerstatter last edited by
              @johannes-bauerstatter said in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
              Ja ... User Legoracer70 hat die Station ... siehe hier Link Text
                Sender last edited by
                ich habe vor kurzem diesen Adapter entdeckt, erstmal danke dafür!!!
                Also sofort eine WH4000SE geshoppt und eingebunden funktioniert bis dahin alles problemlos.
                Leider musste ich auch feststellen, dass div. Werte keine Updates erhalten offenbar meist dann, wenn der neue Wert "0" sein müsste.
                Wenn es hilft, bin ich auch gern dabei, wenn es auf die Fehlersuche geht.
                Grüße...
                  Sender @Sender last edited by
                  nach einigen Tagen Beobachtung, konnte ich feststellen, dass u.a. "rain" und "dailyrain" nicht upgadated wenn die Werte "0" sind. Während das Zurücksetzten des Wertes für "dailyrain" am Tagesanfang seinen Zweck erfüllen würde, ist das mit "rain" sicher nicht so einfach, es kann ja mehrmals am Tag anfangen und aufhören zu regnen. Das Erfassen eines Regenevents wäre schon eine feine Sache z.Bsp. zum Schließen von Dachflächenfenstern. Auch der Lux-Wert kann ja je nach Aufstellort täglich "0" werden, er bleibt aber auch, offenbar auf dem letzten Wert vor der "Nullmeldung" hängen. Im Falle der Helligkeit ist das m.E. aber kein Beinbruch.
                  Evtl. kann man, wenn der enstprechende Wert nach mehreren Zyklen kein Update erhalten hat, den Wert zurücksetzen?
                  Trotzdem möchte ich mich nochmals bei @Fogg für die fantastische Arbeit bedanken.
                  Grüße...
                  • N
                    Neo110 @Sender last edited by Neo110
                    @sender Ich habe für mich in ioBroker testweise mal ein Blockly Script laufen, in dem ich bei jeder Aktualisierung vom Adapter den Zeitstempel vom entsprechenden Wert mit dem aktuellen vergleiche. Sollte dieser älter als 2 Minuten (z.B. bei regen) sein, so wird dieser automatisch auf 0 gestellt.
                    Auf diesen Lösungsansatz bin ich hierrüber gekommen:
                    https://forum.iobroker.net/topic/11551/gelöst-mittels-blockly-mqtt-zeitstempel-auf-alter-prüfen/9
                    Ich lasse mir jetzt die Werte in influx mal mitschreiben und werde die tage mal sehen ob es evtl. Probleme gibt.
                      Sender @Neo110 last edited by Sender
                      @neo110 Das Klingt nach 'ner Idee, schau ich mir auch mal an. Danke für's teilen. 👍
                      Edit: Ich teste das auch grad mit "rain", was ich aber nach längerer Zeit erst zurücksetze, mal sehen... Allerdings schneit es grad, der Test wird also noch auf sich warten lassen müssen...
                      Zusätzlich setze ich "dailyrain" 0:00 zurück, ich werde auch berichten.
                        @neo110
                        Nach ein paar Tagen Testerei würde ich sagen, Deine Idee funktioniert 1A! 👍
                        Ich setzte noch dailyrain, weeklyrain, monthlyrain und yearlyrain, jeweils täglich 0:01, montäglich 0:01, monatlich am 01. 0:01 und jährlich am 01.01. 0:01 zurück...
                        Nochmals Danke!
                        Fogg 1 Reply Last reply Reply Quote 0
                          Haifisch_777 last edited by Negalein
                          Hallo Zusammen,
                          als absoluter Laie brauche ich Hilfe.
                          Ich möchte meine ELV WS 980 in iobroker einbinden.
                          Dazu habe ich versucht den Adapter einzufügen, doch leider bekomme ich folgende Fehlermeldung:
                          $ ./iobroker url "https://github.com/repo/ioBroker.gh/tarball/master" gh
                          install https://github.com/repo/ioBroker.gh/tarball/master
                          NPM version: 7.5.3
                          npm install https://github.com/repo/ioBroker.gh/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                          npm
                           ERR!
                           code E404
                          npm
                           ERR!
                          404 Not Found - GET https://github.com/repo/ioBroker.gh/tarball/masternpm ERR!
                           404 npm ERR!
                           404  'https://github.com/repo/ioBroker.gh/tarball/master' is not in the npm registry.npm ERR! 404 This package name is not valid, because npm
                           ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
                          npm ERR!
                           A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-13T11_15_36_621Z-debug.log
                          ERROR: host.raspff Cannot install https://github.com/repo/ioBroker.gh/tarball/master: 1
                          ERROR: process exited with code 25
                          Was mach ich falsch?
                          Danke im Voraus!
                          Haifisch
                          • Glasfaser
                            Glasfaser @Haifisch_777 last edited by
                            @haifisch_777 sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                            NPM version: 7.5.3
                            Uhii .... bischen alt
                            Ziehe erstmal dein System Up to Date .
                            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                              Haifisch_777 @Glasfaser last edited by Negalein
                              @glasfaser
                              Ok, vielen Dank, ich habe das System nach Anleitung auf den neusten Stang gebarcht, auch ohne Fehler :-).
                              Leider gibt es den Fehler noch immer!
                              NPM version: 7.5.1
                              npm ERR! code E404npm ERR! 404 Not Found - GET https://github.com/repo/ioBroker.gh/tarball/masternpm ERR! 404 npm ERR! 404  'https://github.com/repo/ioBroker.gh/tarball/master' is not in the npm registry.npm ERR! 404 This package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
                              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-13T12_30_13_706Z-debug.log
                              Haifisch
                              Mod-Edit: Code in Code-Tag gepackt Screenshot_2021-02-13 Test Adapter ioBroker sainlogic v0 6 X GitHub Latest.png
                              Glasfaser 2 Replies Last reply Reply Quote 0
                              • Glasfaser
                                @haifisch_777
                                Welchen Link nutzt du in GitHub , um es zu installieren .
                                https://github.com/phifogg/ioBroker.sainlogic
                                  @glasfaser
                                  Ich gebe das ein:
                                  • Glasfaser
                                    @haifisch_777
                                    Mache mal das:
                                    • Glasfaser
                                      Er zieht es hiervon , die Adresse gibt es nicht :
                                        Haifisch_777 @Glasfaser last edited by Haifisch_777
                                        @glasfaser
                                        Suuuper, danke, das hat erst einmal funktioniert!
                                        Tolles Forum hier
                                          Haifisch_777 @Haifisch_777 last edited by
                                          @haifisch_777
                                          Naja , irgend ein Fehler habe ich noch.
                                          Vielleicht die Instanz nicht richtig eingerichtet?
                                          H Fogg 2 Replies Last reply Reply Quote 0
                                            @haifisch_777
                                            adapter froggit wh4000sh sainlogic wetterstation ws980wifi
                                            60
                                            326
                                            73571
