    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер ModBus
    Драйвер ModBus
    • Bluefox
      Bluefox last edited by
      @Haus:
      Ошибка при обновлении
      ! iobroker 2016-11-09 07:18:34.694 info exit 0 iobroker 2016-11-09 07:18:34.667 info Adapter "modbus" updated iobroker 2016-11-09 07:18:34.512 info upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png iobroker 2016-11-09 07:18:34.433 info upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html iobroker 2016-11-09 07:18:34.344 info upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css iobroker 2016-11-09 07:18:34.254 info upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css iobroker 2016-11-09 07:18:34.179 info upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css iobroker 2016-11-09 07:18:34.114 info upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css iobroker 2016-11-09 07:18:34.039 info upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript iobroker 2016-11-09 07:18:33.971 info upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript iobroker 2016-11-09 07:18:33.888 info upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript iobroker 2016-11-09 07:18:33.754 info upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript host.Server-PC 2016-11-09 07:18:33.737 info object change system.adapter.modbus.0 iobroker 2016-11-09 07:18:33.721 info Update "system.adapter.modbus.0" iobroker 2016-11-09 07:18:33.626 info upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png iobroker 2016-11-09 07:18:33.589 info got /opt/iobroker/node_modules/iobroker.modbus/admin iobroker 2016-11-09 07:18:33.268 info npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/debug,npm WARN unmet dependency which is version 2.3.0 iobroker 2016-11-09 07:18:33.262 info WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load iobroker 2016-11-09 07:18:33.250 info npm iobroker 2016-11-09 07:18:26.658 info npm install --production --prefix "/opt/iobroker/node_modules/iobroker.modbus" (System call) iobroker 2016-11-09 07:18:26.072 info npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/debug,npm WARN unmet dependency which is version 2.3.0 iobroker 2016-11-09 07:18:26.065 info WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load iobroker 2016-11-09 07:18:26.058 info npm iobroker 2016-11-09 07:17:18.870 info npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call) iobroker 2016-11-09 07:17:16.912 info upgrade modbus `
      Игнорировать.
        leshyi last edited by
        Коллеги, не могу разобраться…
        Оборудование:
        Raspberry pi2
        iobroker.admin 1.6.6
        js-controller 0.13.2
        iobroker.modbus 0.4.7
        ОВЕН ПЛК150
        Настройки:
        ПЛК150: Modbus slave id 1
        iobroker.modbus: master
        Переменные все float начиная с первого адреса.
        Проблема:
        В ПЛК первая переменная REAL: 14655.73
        iobroker первая переменная (Float (Big Endian)) 14600.24
        C остальными такая же беда…
        Читаю другими средствами, все совпадает. Чистый вывод iobroker.modbus нигде не нашел как увидеть, даже в debug. String (Zero end) выводит какую-то ерунду...
        Скриншот:
        ! ![](</s><URL url=)<link_text text="https://4.downloader.disk.yandex.ru/dis ... 9127195a6b">https://4.downloader.disk.yandex.ru/disk/c3ca535dfa58336381d0937fb6660e9eeb8178b05bc74b0fa32fcb895ddf2ccc/58470c13/XGn0l5evRjfE4mkLQiECFfCGje_dBUTHUzY2X_mHX_c00lPD1EEz3Bb4XSc3R94PJJjsFCrrZnGZGInNRpcWtQ%3D%3D?uid=0&filename=2016-12-06_18-04-26.png&disposition=inline&hash=&limit=0&content_type=image%2Fpng&fsize=180743&hid=73c5d9980ea0f4cee1db84f47ddeb706&media_type=image&tknv=v2&etag=d46c1b9fa0aaa38c6ad36b9127195a6b</link_text>" />
        • Bluefox
          @leshyi:
          Оборудование:
          Raspberry pi2
          ОВЕН ПЛК150
          Настройки:
          Проблема:
          Скриншот:
          ! ![](</s><URL url=)<link_text text="https://4.downloader.disk.yandex.ru/dis ... 9127195a6b">https://4.downloader.disk.yandex.ru/disk/c3ca535dfa58336381d0937fb6660e9eeb8178b05bc74b0fa32fcb895ddf2ccc/58470c13/XGn0l5evRjfE4mkLQiECFfCGje_dBUTHUzY2X_mHX_c00lPD1EEz3Bb4XSc3R94PJJjsFCrrZnGZGInNRpcWtQ%3D%3D?uid=0&filename=2016-12-06_18-04-26.png&disposition=inline&hash=&limit=0&content_type=image%2Fpng&fsize=180743&hid=73c5d9980ea0f4cee1db84f47ddeb706&media_type=image&tknv=v2&etag=d46c1b9fa0aaa38c6ad36b9127195a6b</link_text>" /> ` А адреса какие? С нуля или с 1 начинаются?
            с 1…
            В ПЛК адреса вообще не ставятся... там по порядку...
            Есть скрипт, написанный на ruby, читает идеально. Там адреса с 1.
            Вообще, если в iobroker.modbus ставить первый адрес 0 - ругается.
            • Bluefox
              @leshyi:
              с 1…
              Вообще, если в iobroker.modbus ставить первый адрес 0 - ругается. `
              А у тебя какие настройки адресов? Alias или нет?
                нет, не alias…
                При alias адреса считаются с 40002... ситуация та же...
                • Bluefox
                  @leshyi:
                  нет, не alias…
                  При alias адреса считаются с 40002... ситуация та же... `
                  Вот этом и проблема. Alias начинаются с 1.
                  Покажи настройки обоих устройств.
                  И что, ни по адресу 2 или 3 тоже ничего нет?
                  Что за адресация такая у овена? Не алиас, но с единицы.
                    Если бы…
                    Перед тем как писать, перепробовал все... и с alias, и без.. и с 0, и с 1, и с 2, и с 40001, и с 40000, и с 40002
                    Более менее близкий результат: с 1 без alias и с 40002 с alias... При этом результаты в обоих случаях одинаковые в точности, но не соответствуют ПЛК... сдвиг не помогает...
                    В ПЛК же настроек адресов Modbus вообще нет. Это скорее не ОВЕН, а Codesys 2.3... Просто добавляем модуль Modbus (slave), указываем адрес устройства (в данном случае 1), ставим порт (502).
                    Дальше добавляем переменные. в том порядке как добавили, они и встают начиная с 1 адреса и занимают соответствующий размер.
                    Самое главное, библиотека Ruby Modbus выдавала четкий результат в соответствии со спецификацией Modbus, и все работало...
                    Поищу код на ruby...
                    Еще вопрос: реально увидеть изначальный ответ в Modbus в iobroker?
                    • Bluefox
                      @leshyi:
                      Еще вопрос: реально увидеть изначальный ответ в Modbus в iobroker? `
                      А debug включал?
                      http://www.iobroker.net/docu/?page_id=2991&lang=ru (в конце)
                        В итоге заработало вот так…. метод тыка...
                        Вопрос был в типах переменных...
                        ! ![](</s><URL url=)<link_text text="https://3.downloader.disk.yandex.ru/dis ... d4619486ef">https://3.downloader.disk.yandex.ru/disk/33316f878bf0c0f92f0a79ebb4b92b0bfef7ce6eb4d047cd0991c99e3786b303/5848a99b/XGn0l5evRjfE4mkLQiECFY8STJ-p9RKQv9kfKf9-UKwJc_s1v1eSJYuPo4MI-TrXqubXGZw5JrlMnsuJMV4u5w%3D%3D?uid=0&filename=2016-12-07_23-29-43.png&disposition=inline&hash=&limit=0&content_type=image%2Fpng&fsize=79001&hid=cf1d1013be1183be6978b9e29201e6b6&media_type=image&tknv=v2&etag=6524f79167d915b1412869d4619486ef</link_text>" />
                          @Bluefox:
                          @leshyi:
                          А debug включал?
                          http://www.iobroker.net/docu/?page_id=2991&lang=ru (в конце) `
                          Включал… Честно говоря, debug на мой взгляд, с точки зрения Modbus показался совсем не информативным (
                          • Bluefox
                            @leshyi:
                            @Bluefox:
                            @leshyi:
                            А debug включал?
                            http://www.iobroker.net/docu/?page_id=2991&lang=ru (в конце) Включал… Честно говоря, debug на мой взгляд, с точки зрения Modbus показался совсем не информативным (
                            Да потому что он до сих пор просто работал и выплёвывать 100 сообщений каждую секунду смысла не было. 😞
                            • Bluefox
                              И ты точно правильные типы использовал? Какие ты используешь?
                                @Bluefox:
                                И ты точно правильные типы использовал? Какие ты используешь? `
                                Я в спойлерах прикладываю скриншоты… два поста выше
                                • Bluefox
                                  @leshyi:
                                  ! ![](</s><URL url=)<link_text text="https://3.downloader.disk.yandex.ru/dis ... d4619486ef">https://3.downloader.disk.yandex.ru/disk/33316f878bf0c0f92f0a79ebb4b92b0bfef7ce6eb4d047cd0991c99e3786b303/5848a99b/XGn0l5evRjfE4mkLQiECFY8STJ-p9RKQv9kfKf9-UKwJc_s1v1eSJYuPo4MI-TrXqubXGZw5JrlMnsuJMV4u5w%3D%3D?uid=0&filename=2016-12-07_23-29-43.png&disposition=inline&hash=&limit=0&content_type=image%2Fpng&fsize=79001&hid=cf1d1013be1183be6978b9e29201e6b6&media_type=image&tknv=v2&etag=6524f79167d915b1412869d4619486ef</link_text>" /> ` ~~Как то я пропустил это сообщение. Для меня, как знающего modbus всё выглядит логично.
                                  Может накидаешь word или telegra.ph документ: Как подключить овен. А я бы выложил… ;)~~
                                    Если не забуду, и как время будет…
                                    Но я бы добавил бы нормальное описание типов переменных... Мне, как не очень знающему Modbus, было сложно понять ху из ху...
                                      radon last edited by
                                      Тоже интересен небольшой help по подключению по modbus.
                                      У меня контроллер wago, так и не смог его подключить с этим драйвером, подключил через nodered, правда почему-то не могу записать значения, читает нормально данные но не пишет.
                                      У nodered типы FC1-FC5, тут же в драйвере 30000 и т.п., но даже указывая вроде бы верные значения не читает почему-то, плюс куча типов переменный, какой нужно выбрать не очень понятно.
                                      При исполдьзовании FC1 данный прямо из helpa контроллера берутся, номер канала с 0 и далее, всё понятно, тут же в драйвере сложно разобраться.
                                      • Bluefox
                                        @leshyi:
                                        Но я бы добавил бы нормальное описание типов переменных... Мне, как не очень знающему Modbus, было сложно понять ху из ху... `
                                        Так?
                                        https://github.com/ioBroker/ioBroker.modbus#data-types
                                        Или что то ещё написать?
                                          @Bluefox:
                                          @leshyi:
                                          Так?
                                          Или что то ещё написать? `
                                          Да, так явно понятнее ) Спасибо
                                            mgrusik last edited by
                                            Скажите, кто то проверял modbus tcp, discrete inputs и coils? не чего с ними не получается
                                            174
                                            51435
