    4. [Gelöst] Hilfe: ioBroker startet nicht mehr
    • mrFenyx
      mrFenyx last edited by
      @Thomas-Braun js-controller wurde neu installiert. Jetzt kommen diese werte raus:
      pi@home:/opt/iobroker $ iobroker status
      Objects type: file
      States  type: file
      pi@home:/opt/iobroker $ iobroker list instances
      + instance is alive
      Trotzdem geht da nichts...
      iobroker setup liefert das hier:
      object 0_userdata.0.example_state yet exists
      object 0_userdata.0 yet exists
      object alias.0 yet exists
      object system.certificates yet exists
      object system.repositories yet exists
      object system.config yet exists
      object enum.functions yet exists
      object enum.rooms yet exists
      object system.group.user yet exists
      object system.group.administrator yet exists
      object _design/system updated
      iobroker fix das hier:
      iobroker fix
      Execute the installation fixer script, this updates your ioBroker installation
      Options:
            --help     Show help  [boolean]
        -v, --version  Show version  [boolean]
        Thomas Braun Most Active @mrFenyx last edited by
        @mrfenyx
        iobroker list adapters
        • wendy2702
          @mrfenyx
          curl -sL https://iobroker.net/fix.sh | bash -
          • mrFenyx
            @Thomas-Braun
            + instance is alive
            pi@home:/opt/iobroker $ iobroker list adapters
            Da fehlt was....
            @wendy2702 danke für den Tipp, ist durchgelaufen, bringt leider nichts 😞
              Thomas Braun Most Active @mrFenyx last edited by Thomas Braun
              @mrfenyx
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              iobroker install admin
              • mrFenyx
                @Thomas-Braun
                pi@home:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                /usr/bin/nodejs
                v12.20.1
                /usr/bin/node
                v12.20.1
                /usr/bin/npm
                6.14.10
                nodejs:
                  Installed: 12.20.1-1nodesource1
                  Candidate: 12.20.1-1nodesource1
                  Version table:
                 *** 12.20.1-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.23.1~dfsg-1~deb10u1 500
                Ok, jetzt habe ich admin & info aber alles andere ist...weg... 😞
                  @mrfenyx
                  Jetzt zückst du dein Backup und spielst das für so einen Fall angelegte Backup wieder ein.
                  • mrFenyx
                    na dann...warten wir es mal ab...restore in progress 😄
                    • mrFenyx
                      @Thomas-Braun @wendy2702 danke für eure Hilfe! Hoffe es klappt jetzt alles. Gute Nacht!
                      • wendy2702
                        wendy2702 @mrFenyx last edited by
                        @mrfenyx Bitte kurzes Feedback!
                        Gute Nacht
                        • mrFenyx
                          Alles im grünen Bereich!👍
                          errors fehler hilfe
                          1326
