    4. Node-Red
    5. NodeRed function node soll toipc übernehmen
    • mickym
      mickym Most Active @Frank Traut last edited by
      @frank-traut Ganz ohne Programmieren - das was halt NodeRed kann. 😉
      Hier der Flow zum inportieren:
              "id": "31bdef5c.ed36e",
              "type": "inject",
              "z": "dce8fa20.2e93c8",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Gerät1",
              "payload": "Ein Wert von Gerät 1",
              "payloadType": "str",
              "x": 1860,
              "y": 3040,
              "wires": [
                      "ba02a6fc.2c0998",
                      "bc331dbc.1c7b9"
              "id": "1e2a7c04.762824",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Gerät2",
              "payload": "Ein Wert von Gerät 2",
              "x": 1860,
              "y": 3100,
              "wires": [
                      "ba02a6fc.2c0998",
                      "d116cd15.ec076"
              "id": "ba02a6fc.2c0998",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "object",
              "property": "payload",
              "propertyType": "msg",
              "key": "topic",
              "joiner": "\\n",
              "joinerType": "str",
              "accumulate": true,
              "timeout": "",
              "count": "1",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "",
              "reduceFixup": "",
              "x": 2140,
              "y": 3060,
              "wires": [
                      "66680e32.0877c",
                      "f087dbc4.94a158"
              "id": "bc331dbc.1c7b9",
              "type": "debug",
              "name": "Input Gerät1",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "targetType": "full",
              "statusVal": "",
              "statusType": "auto",
              "x": 2160,
              "y": 2980,
              "wires": []
              "id": "d116cd15.ec076",
              "type": "debug",
              "name": "Input Gerät2",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 2150,
              "y": 3140,
              "wires": []
              "id": "66680e32.0877c",
              "type": "debug",
              "name": "Aufbau Objekt",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 2400,
              "y": 3140,
              "wires": []
              "id": "f087dbc4.94a158",
              "type": "json",
              "name": "",
              "action": "",
              "pretty": false,
              "x": 2370,
              "y": 3060,
              "wires": [
                      "fb6c9ca8.21775"
              "id": "fb6c9ca8.21775",
              "type": "debug",
              "name": "JSON String - MQTT",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "x": 2620,
              "y": 3060,
              "wires": []
      • mickym
        @frank-traut sagte in NodeRed function node soll toipc übernehmen:
        Moin Moin,
        für MQTT benötige ich ein kleines "function-Node".
        Ich muss die Topic (gebe ich bei Name1 und Name2 als "msg.topic" mit) in der Ausgabe irgendwie in den unterstrichenen Bereich bekommen. Die Topic wird aber leider immer nur als extra Spalte angegeben. Was mache ich falsch?
        bg Frank
        Funktioniert es oder brauchst Du immer noch eine Function Node?
        Frank Traut 1 Reply Last reply Reply Quote 1
        • Frank Traut
          Frank Traut @mickym last edited by
          @mickym Sahnemäßig! Kann man dir irgendwo nin Kaffee ausgeben?
          • mickym
            mickym Most Active @Frank Traut last edited by mickym
            Passt scho. 😉 Es freut mich ja selbst, wenn ich helfen konnte. Ich musste ja auch Lernen.
            Nur ein kleiner Tipp für die Zukunft 😉 :
            Wenn Du Dir mal Dein Eingangsposting anschaust und was nun dabei rausgekommen ist. Manchmal ist es einfacher das Problem im Großen zu schildern, dann kann man oft besser helfen, als wenn ich Dir nur beschreibe, wie Du eine payload aus unterschiedlichen Strings zusammensetzt und Du ja auch noch soviel anderes hättes unnötigerweise programmieren müssen. Es reicht ja nicht nur, dass Du diese Strings dann zusammengesetzt hättest, sondern Du hättest ja jedes Mal nach dem Key in Deinen Strings suchen müssen, wenn sich der Wert geändert hätte.
            Da hättest Du Dir Stunden und Tage Programmierarbeit aufgehalst, die die Node-Entwickler der JOIN Node bereits gemacht haben.
            Also viel Spaß weiterhin mit NodeRed. Ich kann immer nur wieder sagen, ich liebe es inzwischen. 😉
            Frank Traut 2 Replies Last reply Reply Quote 1
            • Frank Traut
              @mickym Super! Werde ich mir zu Herzen nehmen!
              • Frank Traut
                @mickym
                Hi, ich hätte da noch eine Sache.
                Ich würde gerne bei der Nachrichten einen Timestep nach folgender Vorgabe mitgeben:
                {"ts":1451649600512, "values":{"key1":"value1", "key2":"value2"}}
                Quelle: https://thingsboard.io/docs/reference/mqtt-api/ (Telemetry upload API)
                Ich brauche also den "values"-Teil und den Timestep-Teil.
                Mit einem Timestep und dem Join-node komme ich leider nicht weiter, weil ja der Timestep immer dann auslösen muss, wenn Nachrichten reinkommen - Ich habe aber leider keinen festen Auslöspunkt.
                Mein Subflow für die Übertragung sieht jetzt so aus:
                [{"id":"bf4174a4.dbbe6","type":"subflow","name":"NodeRed->TB","info":"","category":"","in":[{"x":240,"y":220,"wires":[{"id":"5b19eba3.5f6444"}]}],"out":[{"x":840,"y":220,"wires":[{"id":"40eaa341.edd0d4","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"5b19eba3.5f6444","type":"join","z":"bf4174a4.dbbe6","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":220,"wires":[["48cab473.26637c","40eaa341.edd0d4"]]},{"id":"48cab473.26637c","type":"debug","z":"bf4174a4.dbbe6","name":"Aufbau Objekt","active":true,"tosidebar":false,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":540,"y":280,"wires":[]},{"id":"40eaa341.edd0d4","type":"json","z":"bf4174a4.dbbe6","name":"","property":"payload","action":"","pretty":false,"x":570,"y":220,"wires":[["c385db35.b5a488"]]},{"id":"c385db35.b5a488","type":"debug","z":"bf4174a4.dbbe6","name":"JSON String - MQTT","active":true,"tosidebar":false,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":560,"y":160,"wires":[]}]
                Hast du ne Idee? Der Subflow ist quasi genau dein Code.
                bg
                • mickym
                  @frank-traut Ehrlich gesagt im ersten Moment verstand ich nur Bahnhof. Du hast mir jedenfalls alles andere als "meinen Subflow" gepostet. 😉 😉 Inzwischen hoffe ich aber, einfach Deine Anforderung umgesetzt zu haben. 😉
                  Also hier mein ursprünglicher Flow mit dem Timestamp ergänzt.
                          "id": "cc5a699c.5b95e8",
                          "type": "inject",
                          "z": "2821dd31.a0dd62",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "key1",
                          "payload": "value1",
                          "x": 510,
                          "y": 1580,
                          "wires": [
                                  "535efea7.5d7d2"
                          "id": "cc5cf91d.e86dd8",
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "key2",
                          "payload": "value2",
                          "x": 510,
                          "y": 1640,
                          "wires": [
                                  "535efea7.5d7d2"
                          "id": "535efea7.5d7d2",
                          "type": "join",
                          "name": "",
                          "mode": "custom",
                          "build": "object",
                          "key": "topic",
                          "joiner": "\\n",
                          "accumulate": true,
                          "timeout": "",
                          "count": "1",
                          "reduceExp": "",
                          "reduceInit": "",
                          "reduceFixup": "",
                          "x": 700,
                          "y": 1600,
                          "wires": [
                                  "a78ff8d6.108498"
                          "id": "ccbb833c.4dcc7",
                          "type": "debug",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "complete": "true",
                          "statusVal": "",
                          "x": 1360,
                          "y": 1600,
                          "wires": []
                          "id": "a78ff8d6.108498",
                          "type": "change",
                          "name": "Timestamp setzen und Objekt bilden",
                          "rules": [
                                  "t": "move",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "values",
                                  "tot": "msg"
                                  "t": "set",
                                  "p": "payload.ts",
                                  "pt": "msg",
                                  "to": "",
                                  "tot": "date"
                                  "t": "move",
                                  "p": "values",
                                  "pt": "msg",
                                  "to": "payload.values",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 950,
                          "y": 1600,
                          "wires": [
                                  "5ef66e6c.2549f"
                          "id": "5ef66e6c.2549f",
                          "type": "json",
                          "name": "",
                          "action": "",
                          "pretty": false,
                          "x": 1170,
                          "y": 1600,
                          "wires": [
                                  "ccbb833c.4dcc7"
                  Damit sieht das Objekt bzw. der JSON-String exakt so aus, wie in Deiner Vorgabe:
                  Da die JOIN Node ja mit jeder Nachricht diese sofort weitergibt, wird der Timestamp auch immer aktualisiert.
                  Im Prinip also nur die Change Node zwischen die JOIN Node und die JSON Node schieben und das wars!
                  Das würde ja dann diesem Bild aus Deinem Link entsprechen:
                  • Frank Traut
                    @mickym Sieht gut aus! Auf dem Testsystem klappt das schon Mal ohne Probleme 🙂
                    Frank Traut 1 Reply Last reply Reply Quote 0
                    • Frank Traut
                      Frank Traut @Frank Traut last edited by
                      @mickym
                      Ich hab da mal noch eine Frage 🐶
                      Ich möchte Daten aus Thindgsboard in die S7 schicken:
                      Links Thingsboard -> rechts S7
                      Die Daten werden korrekt aus TB aboniert und auch an die Nodes für die S7 weitergegeben. Immer mit dem Schema "Name" "Satus". Unter den S7-Nodes sieht man auch, dass Werte ankommen. Die S7-Nodes übernhemen aber die Werte nicht.
                      Was gehen würde: Mit Split und Switch-Node von Hand die Werte trennen. Das wäre extrem aufwendig, weil ich mehr als nur die 4 Eingänge habe. Ich hatte schon Mal eine Lösung dafür - finde diese aber leider nicht wider.
                      Nachfolgend mein Code:
                      [{"id":"e6b2f5a5.f67e4","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"5832dbde.f274f4","type":"comment","z":"e6b2f5a5.f67e4","name":"Test: TB -> NodeRed -> S7","info":"","x":720,"y":160,"wires":[]},{"id":"7b6c8520.abff4c","type":"mqtt in","z":"e6b2f5a5.f67e4","name":"","topic":"v1/devices/me/attributes","qos":"1","datatype":"auto","broker":"d6a1db0.7bf03a8","x":570,"y":240,"wires":[["fb3e812f.5f3518","10d7ba9c.c296b5","169520d1.0b58af","cafa5741.a85778","af40042.86e75f8"]]},{"id":"fb3e812f.5f3518","type":"debug","z":"e6b2f5a5.f67e4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":540,"wires":[]},{"id":"10d7ba9c.c296b5","type":"s7 out","z":"e6b2f5a5.f67e4","endpoint":"5dd03a7c.af7b9c","variable":"(1555)_betriebsstunden_p1","name":"","x":960,"y":240,"wires":[]},{"id":"7b14759d.8b13bc","type":"s7 out","z":"e6b2f5a5.f67e4","endpoint":"5dd03a7c.af7b9c","variable":"(1555)_betriebsstunden_p1","name":"","x":860,"y":840,"wires":[]},{"id":"b774c83c.f619d8","type":"inject","z":"e6b2f5a5.f67e4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":578,"y":841,"wires":[["7b14759d.8b13bc","ba50d833.15818"]]},{"id":"9120c446.14b768","type":"inject","z":"e6b2f5a5.f67e4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2","payloadType":"num","x":588,"y":901,"wires":[["7b14759d.8b13bc","ba50d833.15818"]]},{"id":"ba50d833.15818","type":"s7 out","z":"e6b2f5a5.f67e4","endpoint":"5dd03a7c.af7b9c","variable":"(1556)_betriebsstunden_p2","name":"","x":870,"y":900,"wires":[]},{"id":"169520d1.0b58af","type":"s7 out","z":"e6b2f5a5.f67e4","endpoint":"5dd03a7c.af7b9c","variable":"(1501)_run_stop","name":"","x":930,"y":300,"wires":[]},{"id":"cafa5741.a85778","type":"s7 out","z":"e6b2f5a5.f67e4","endpoint":"5dd03a7c.af7b9c","variable":"(1541)_anlagenlaufzeit_monat_8","name":"","x":980,"y":360,"wires":[]},{"id":"af40042.86e75f8","type":"s7 out","z":"e6b2f5a5.f67e4","endpoint":"5dd03a7c.af7b9c","variable":"(1563)_betriebsstunden_09","name":"","x":960,"y":420,"wires":[]},{"id":"d6a1db0.7bf03a8","type":"mqtt-broker","name":"NodeRed_out","broker":"138.197.182.168","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"5dd03a7c.af7b9c","type":"s7 endpoint","transport":"iso-on-tcp","address":"172.16.58.1","port":"102","rack":"0","slot":"0","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapter":"","busaddr":"2","cycletime":"3000","timeout":"2000","name":"TB_NodeRed_S7","vartable":[{"addr":"DB1500,X0.0","name":"(1501)_run_stop"},{"addr":"DB1500,X0.1","name":"(1502)_anlagentyp1_2"},{"addr":"DB1500,X0.2","name":"(1503)_basic_03"},{"addr":"DB1500,X0.3","name":"(1504)_basic_04"},{"addr":"DB1500,X0.4","name":"(1505)_basic_05"},{"addr":"DB1500,X0.5","name":"(1506)_basic_06"},{"addr":"DB1500,X0.6","name":"(1507)_basic_07"},{"addr":"DB1500,X0.7","name":"(1508)_basic_08"},{"addr":"DB1500,X1.0","name":"(1509)_basic_09"},{"addr":"DB1500,WORD2","name":"(1510)_anlagenleistung_monat_1"},{"addr":"DB1500,WORD4","name":"(1511)_anlagenleistung_monat_2"},{"addr":"DB1500,WORD6","name":"(1512)_anlagenleistung_monat_3"},{"addr":"DB1500,WORD8","name":"(1513)_anlagenleistung_monat_4"},{"addr":"DB1500,WORD10","name":"(1514)_anlagenleistung_monat_5"},{"addr":"DB1500,WORD12","name":"(1515)_anlagenleistung_monat_6"},{"addr":"DB1500,WORD14","name":"(1516)_anlagenleistung_monat_7"},{"addr":"DB1500,WORD16","name":"(1517)_anlagenleistung_monat_8"},{"addr":"DB1500,WORD18","name":"(1518)_anlagenleistung_monat_9"},{"addr":"DB1500,WORD20","name":"(1519)_anlagenleistung_monat_10"},{"addr":"DB1500,WORD22","name":"(1520)_anlagenleistung_monat_11"},{"addr":"DB1500,WORD24","name":"(1521)_anlagenleistung_monat_12"},{"addr":"DB1500,X26.0","name":"(1522)_anzahl_pumpen_monat_1"},{"addr":"DB1500,X26.1","name":"(1523)_anzahl_pumpen_monat_2"},{"addr":"DB1500,X26.2","name":"(1524)_anzahl_pumpen_monat_3"},{"addr":"DB1500,X26.3","name":"(1525)_anzahl_pumpen_monat_4"},{"addr":"DB1500,X26.4","name":"(1526)_anzahl_pumpen_monat_5"},{"addr":"DB1500,X26.5","name":"(1527)_anzahl_pumpen_monat_6"},{"addr":"DB1500,X26.6","name":"(1528)_anzahl_pumpen_monat_7"},{"addr":"DB1500,X26.7","name":"(1529)_anzahl_pumpen_monat_8"},{"addr":"DB1500,X27.0","name":"(1530)_anzahl_pumpen_monat_9"},{"addr":"DB1500,X27.1","name":"(1531)_anzahl_pumpen_monat_10"},{"addr":"DB1500,X27.2","name":"(1532)_anzahl_pumpen_monat_11"},{"addr":"DB1500,X27.3","name":"(1533)_anzahl_pumpen_monat_12"},{"addr":"DB1500,WORD28","name":"(1534)_anlagenlaufzeit_monat_1"},{"addr":"DB1500,WORD30","name":"(1535)_anlagenlaufzeit_monat_2"},{"addr":"DB1500,WORD32","name":"(1536)_anlagenlaufzeit_monat_3"},{"addr":"DB1500,WORD34","name":"(1537)_anlagenlaufzeit_monat_4"},{"addr":"DB1500,WORD36","name":"(1538)_anlagenlaufzeit_monat_5"},{"addr":"DB1500,WORD38","name":"(1539)_anlagenlaufzeit_monat_6"},{"addr":"DB1500,WORD40","name":"(1540)_anlagenlaufzeit_monat_7"},{"addr":"DB1500,WORD42","name":"(1541)_anlagenlaufzeit_monat_8"},{"addr":"DB1500,WORD44","name":"(1542)_anlagenlaufzeit_monat_9"},{"addr":"DB1500,WORD46","name":"(1543)_anlagenlaufzeit_monat_10"},{"addr":"DB1500,WORD48","name":"(1544)_anlagenlaufzeit_monat_11"},{"addr":"DB1500,WORD50","name":"(1545)_anlagenlaufzeit_monat_12"},{"addr":"DB1500,WORD52","name":"(1546)_temp_luft_1"},{"addr":"DB1500,WORD54","name":"(1547)_temp_luft_2"},{"addr":"DB1500,WORD56","name":"(1548)_temp_wasser_1"},{"addr":"DB1500,WORD58","name":"(1549)_temp_wasser_2"},{"addr":"DB1500,WORD60","name":"(1550)_messwert_05"},{"addr":"DB1500,WORD62","name":"(1551)_messwert_06"},{"addr":"DB1500,WORD64","name":"(1552)_messwert_07"},{"addr":"DB1500,WORD66","name":"(1553)_messwert_08"},{"addr":"DB1500,WORD68","name":"(1554)_messwert_09"},{"addr":"DB1500,WORD70","name":"(1555)_betriebsstunden_p1"},{"addr":"DB1500,WORD72","name":"(1556)_betriebsstunden_p2"},{"addr":"DB1500,WORD74","name":"(1557)_betriebsstunden_03"},{"addr":"DB1500,WORD76","name":"(1558)_betriebsstunden_04"},{"addr":"DB1500,WORD78","name":"(1559)_betriebsstunden_05"},{"addr":"DB1500,WORD80","name":"(1560)_betriebsstunden_06"},{"addr":"DB1500,WORD82","name":"(1561)_betriebsstunden_07"},{"addr":"DB1500,WORD84","name":"(1562)_betriebsstunden_08"},{"addr":"DB1500,WORD86","name":"(1563)_betriebsstunden_09"},{"addr":"DB1500,X106.0","name":"(1564)_alarm_ms_p1"},{"addr":"DB1500,X106.1","name":"(1565)_alarm_ms_p2"},{"addr":"DB1500,X106.2","name":"(1566)_temp_luft_1_hoch"},{"addr":"DB1500,X106.3","name":"(1567)_temp_luft_1_niedrig"},{"addr":"DB1500,X106.4","name":"(1568)_messfehler_temp_luft_1"},{"addr":"DB1500,X106.5","name":"(1569)_messfehler_temp_luft_2"},{"addr":"DB1500,X106.6","name":"(1570)_messfehler_temp_wasser_1"},{"addr":"DB1500,X106.7","name":"(1571)_messfehler_temp_wasser_2"},{"addr":"DB1500,X107.0","name":"(1572)_alarm_08"},{"addr":"DB1500,X107.1","name":"(1573)_alarm_09"}]}]
                      • mickym
                        siehe nächster Beitrag
                        mickym 1 Reply Last reply Reply Quote 1
                        • mickym
                          mickym Most Active @mickym last edited by mickym
                          habs schon gesehen -
                                  "id": "c6a50eae.ea43c",
                                  "type": "json",
                                  "z": "6e170384.60c96c",
                                  "name": "",
                                  "action": "",
                                  "pretty": false,
                                  "x": 1740,
                                  "y": 4220,
                                  "wires": [
                                          "e45442d.763bdc"
                                  "id": "e45442d.763bdc",
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "payload.(1555)_betriebsstunden_p1",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1960,
                                  "y": 4220,
                                  "wires": [
                          klemm diese beiden Nodes hinter Deine mqtt Node - dann müsste es gehen.
                          Also um es nochmal zu erklären, was die beiden Nodes machen. Der erste konvertiert den JSON String in ein Objekt. Der Change Node extrahiert die gewünschte Eigenschaft und kopiert die in die payload.
                          • Frank Traut
                            @mickym Moin, wenn ich das mache bekomme ich doch ich vor und nach dem cahnge Node genau die gleiche Nachricht: node.JPG
                            Müsste ich dann für jede Variable diesen Baum aufbauen?
                            • mickym
                              @frank-traut ich habe festgestellt, dass die Change Node Probleme mit den Klammern im Objekt hat.
                                      "type": "json",
                                      "name": "",
                                      "action": "",
                                      "pretty": false,
                                      "x": 3310,
                                      "y": 1220,
                                      "wires": [
                                              "e45442d.763bdc"
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "payload.1555_betriebsstunden_p1",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 3490,
                                      "y": 1220,
                                      "wires": [
                                      "id": "7c121490.b9004c",
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "p": "payload",
                                              "pt": "msg",
                                              "from": "(",
                                              "fromt": "str",
                                              "to": "",
                                              "tot": "str"
                                              "t": "change",
                                              "p": "payload",
                                              "pt": "msg",
                                              "from": ")",
                                              "fromt": "str",
                                              "to": "",
                                              "tot": "str"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 3120,
                                      "y": 1220,
                                      "wires": [
                                              "c6a50eae.ea43c"
                              So müsste es nun funktionieren.
                              Auf Dein Frage, ob Du das für jede Variable machen musst - das kann ich Dir so nicht beantworten - ich weiß weder was aus der mqtt Node rauskommen kann, welche Variablen da rauskommen noch welche Werte dann weitergegeben werden müssen. Ich habe Dir nun gezeigt, wie Du aus dem String, dann Objekt, die entsprechenden Werte aus bestimmten Eigenschaften (properties - Objektnamen) rausbekommst.
                              Falls das in dem String auch grundsätzlich so rausbekommt und der 1. Teil im Prinzip das Topic also die 1555 ist - kann man das auch anders machen. Das heißt wenn immer "betriebsstunden_p1" rauskommt - sich aber das Gerät über die Klammer unterscheidet, dann macht man aus dem Inhalt der Klammer das topic - und aus dem Rest direkt die Zahl. Irgendwo musst Du ja immer nach Gerät und nach Eigenschaft aufteilen.
                              • Frank Traut
                                @mickym okay sehr cool das klappt. Ich habe jetzt vor der Umwandlung die entsprechenden Routen augebaut. So kommt dann immer nur genau der Wert beim Eingang an.
                                Gibt es noch eine Möglichkeit den Inhalt der "change-Node" "global" zu halten. Die macht ja nicht anderes als das Objekt in Number zu wechseln. Da müsste doch der Name egal sein, oder? Kann man da evtl. mit Sternchen o.ä. arbeiten?
                                mickym 3 Replies Last reply Reply Quote 0
                                • mickym
                                  gelöscht - da bessere finale Lösung oben
                                  • mickym
                                    • mickym
                                      @frank-traut
                                      Hier mal ein JSON String mit mehreren Objekten:
                                      {"(1522)_betriebsstunden_p1":39, "(1711)_betriebsstunden_p1":3569, "(2534)_betriebsstunden_p1":8839 }
                                      Mit dem unteren Beispiel bekommst Du auch dann die Werte nacheinander zurück, wenn dich die Eigenschaften nicht interessieren.
                                      willst Du die Eigenschaften nicht verlieren - lässt Du die Split Node das in den topic kopieren, dann bleibt Dir das für einen späteren switch Node erhalten:
                                      Das ist das gleiche wie oben nur die split Node wie folgt angepaßt:
                                      Insofern ist das wohl die Universallösung - also diese beiden Nodes hinter Dein mqtt:
                                              "id": "6163defd.b392b",
                                              "type": "json",
                                              "name": "",
                                              "action": "",
                                              "pretty": false,
                                              "x": 2610,
                                              "y": 2040,
                                              "wires": [
                                                      "6d2ebecd.0a80b"
                                              "id": "6d2ebecd.0a80b",
                                              "type": "split",
                                              "name": "",
                                              "splt": "\\n",
                                              "spltType": "str",
                                              "arraySplt": 1,
                                              "arraySpltType": "len",
                                              "stream": false,
                                              "addname": "topic",
                                              "x": 2780,
                                              "y": 2040,
                                              "wires": [
                                                      "422bae3b.6ab82"
                                      Manchmal habe ich selbst ein Brett vorm Kopf 🤔
                                      • Frank Traut
                                        @mickym Hast die Versionen zu spät gelöscht 😄 hab dann mal alle durchgespielt 🙂 aber die letzte Version klappt super!
                                        3610
