    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      Sneak-L8 @tombox last edited by
      @tombox Heute mal eine neue Fehlermeldung. Ich denke, das war nur temporär und nur ein Sonderfall. Aber scheint, als würde das Problem technishc nicht sauber gefangen:
      16:13:43.655	vw-connect.0	(5181) "time out"
      16:13:43.656	vw-connect.0	(5181) Failed refresh token. Relogin
      16:13:44.897	vw-connect.0	(5181) Failed in receive login url
      16:13:44.898	vw-connect.0	(5181) Error: Invalid protocol: weconnect:
      16:13:44.902	vw-connect.0	(5181) Failled url login
      16:13:44.908	Unhandled	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      16:13:44.909	vw-connect.0	(5181) unhandled promise rejection: loginRequest is not defined
      16:13:44.965	vw-connect.0	(5181) ReferenceError: loginRequest is not defined
      16:13:45.585	host.ioBroker-RasPi	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      16:13:45.586	host.ioBroker-RasPi	Caught by controller[1]: ReferenceError: loginRequest is not defined
      16:13:45.587	host.ioBroker-RasPi	Caught by controller[1]: at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.vw-connect/main.js:343:25)
      16:13:45.587	host.ioBroker-RasPi	Caught by controller[1]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      16:13:45.588	host.ioBroker-RasPi	Caught by controller[1]: at Request.emit (events.js:198:13)
      16:13:45.588	host.ioBroker-RasPi	Caught by controller[1]: at Request.EventEmitter.emit (domain.js:448:20)
      16:13:45.588	host.ioBroker-RasPi	Caught by controller[1]: at Request.init (/opt/iobroker/node_modules/request/request.js:231:17)
      16:13:45.589	host.ioBroker-RasPi	Caught by controller[1]: at new Request (/opt/iobroker/node_modules/request/request.js:127:8)
      16:13:45.590	host.ioBroker-RasPi	Caught by controller[1]: at request (/opt/iobroker/node_modules/request/index.js:53:10)
      16:13:45.590	host.ioBroker-RasPi	Caught by controller[1]: at Promise (/opt/iobroker/node_modules/iobroker.vw-connect/main.js:309:34)
      16:13:45.590	host.ioBroker-RasPi	Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:68:7)
      Bei der Meldung in Zeile 5 (Failled url login) könnte man den Tippfehler (failed nur mit einem L) bei der Gelegenheit mit bereinigen.
      Ist nichts Dramatisches, fällt eher in die Kategorie "clean code"...
        tombox @Sneak-L8 last edited by
        @sneak-l8 Danke für den Hinweis habe ich behoben
          @tombox sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
          Super, danke!
            A Former User last edited by
            Hallo Gemeinde,
            erneut danke an @tombox für den Eifer beim erstellen des Adapters.
            Auch die Möglichkeit des auslesens der Ladevorgänge aus der Wallbox finde ich gut, habe hier jedoch eine Verständnisfrage:
            Ist es möglich, in der VIS NUR die Lademengen je Monat anzuzeigen? Derzeit sind ja viele Informationen drin, die ich nicht brauche. Was für mich spannend isz wäre NUR die Information, wie viele KWh im Januar, Februar, ... geladen wurden.
            Geht das irgendwie?
            • Glasfaser
              Glasfaser @Guest last edited by
              @frankdce sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
              .... wie viele KWh im Januar, Februar, ... geladen wurden.
              Geht das irgendwie?
              Ja ... ist möglich , in Verbindung mit dem Sourceanalytix Adapter
              ? 2 Replies Last reply Reply Quote 0
                A Former User @Glasfaser last edited by A Former User
                gelöscht
                • Glasfaser
                  @glasfaser
                  gelöscht
                  Wie kann ich dir helfen !?
                  • Wszene
                    Wszene last edited by
                    Ich habe vorgestern (10.02.2021) auf die Version 0.29 geupdatet
                    Nun kann ich meine Standheizung nicht mehr über den ioBroker schalten
                    Ich habe es immer über diesen Datenpunkt gemacht
                    Wenn ich diesen jetzt auf true stelle passiert leider nichts
                    Nun habe ich es mit diesem probiert
                    Leider auch ohne Erfolg
                    Nun stelle ich mir die Frage
                    Was ist der Unterschied von den beiden DPs
                    Und was machen die markierten Datenpunkte überhaupt
                    Danke für Eure Infos
                      tombox @Wszene last edited by
                      @wszene es gibt leider verschiedene Arten von den Heizungen bei den Modelle
                      Was sagt der log? Irgendwelche Fehler?
                      Wszene 1 Reply Last reply Reply Quote 0
                      • Wszene
                        Wszene @tombox last edited by Wszene
                        @tombox
                        nein leider nichts
                        keine Fehler im Log
                        vw-connect.0	2021-02-12 17:07:27.391	info	(17367) {"performActionResponse":{"requestId":"19533020","vin":"TMBJB7NS7KNXXXXXX"}}
                        und hier die Objekte
                        Wenn ich jetzt über die Fernbedienung die Standheizung starte dann schalte die die Objekte um
                        Dann bekomme ich auch meine Telegram Nachricht
                          @wszene lösche mal die vin
                          Dann liegt es denke ich nicht am Adapter. Geht es denn über die App?
                          Wenn du auf eine vorherige Version gehst geht es dann?
                          • Wszene
                            @tombox
                            Entschuldige meine Frage
                            Was ist die vin?
                            Mit der App geht es schon ewig nicht da habe ich auch schon ein Ticket bei Skoda laufen die suchen auch nach dem Fehler (hoffe ich zumindest)
                            Die App zeig mir immer an das ein Fehler auf getreten ist und das es bei meiner nächsten Fahrt wieder funktionieren soll
                            Was es natürlich nicht macht
                            Beim Auto meiner Frau kann ich auch keine Daten senden da geht es aber problemlos mit der App
                            Aber sie hat keine Standheizung daher kann ich das nicht testen
                            EDIT:
                            Beim Scala bekomme ich nur immer diese Meldungen im Log
                            vw-connect.1	2021-02-12 17:22:10.429	error	(17373) force status update Failed
                            vw-connect.1	2021-02-12 17:22:10.423	error	(17373) 429
                            vw-connect.1	2021-02-12 17:22:10.405	error	(17373) Too many requests. Please turn on your car to send new requests. Maybe force update is too often.
                            • Glasfaser
                              Glasfaser @Wszene last edited by
                              @wszene sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                              Steht dein Auto schon längere Zeit ?
                              Du sollst zu deinem Auto gehen und es an machen !
                              • Wszene
                                Wszene @Glasfaser last edited by
                                @glasfaser
                                jupp
                                meine Frau ist kurz nach 17Uhr nach Hause gekommen
                                Beim Kodiaq ist der Fehler weg wenn ich ihn täglich bewegen
                                In meiner Home-Office Woche ist der Fehler auch bei mir da
                                Meine Frau ist täglich mit ihrem Scale Unterwegs
                                Sie stellt ihn auch mehrmals am Tag ab aber der Fehler geht nicht weg
                                Aber bei ihr funktioniert trotzdem alles
                                • Glasfaser
                                  @wszene
                                  Als würde dein Account zu viele Anfragen bekommen ... wie häufig fragst du ab .
                                  Habe diese Werte und komme damit zurrecht, ( bei AUDI )
                                  • Wszene
                                    @glasfaser
                                    Beim Kodiaq
                                    Update interval in minutes: 1
                                    Status Update erzwingen: 30
                                    Beim Scala (wo der Fehler kommt)
                                    Update interval in minutes: 10
                                    Glasfaser T 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      @wszene
                                      Nimmst du einen anderen Account für den ioBroker !?
                                      Ich glaube nicht das es daran liegt , aber ein Versuch ist es Wert.
                                        @wszene Mach mal Status update erwzwingen auf 0 und starte das Auto und probiere direkt danach mal ob es geht
                                        • Wszene
                                          Wszene @Glasfaser last edited by Wszene
                                          @glasfaser
                                          Beide Autos haben einen anderen Account
                                          Die Vermutung mit dem ACC hatte ich auch schon gegenüber Skoda geäußert
                                          Die sagten aber auch das es nicht daran liegt
                                          Das werde ich morgen Früh mal machen
                                          Glasfaser A 2 Replies Last reply Reply Quote 0
                                          • Glasfaser
                                            Sorry , vielleicht falsch ausgedrückt :
                                            Ein Auto :
                                            Meinte einen zweiten Benutzer , also
                                            1 x in der Handy App // bist du
                                            1 x in ioBroker // ist ein Alias Account
                                            so habe ich es .
                                            T Wszene 2 Replies Last reply Reply Quote 0
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1600794
