    4. Phoscon / deCONZ Totalausfall - Benötige Hilfe
      Thomas Braun Most Active @cherberg last edited by
      @cherberg sagte in Phoscon / deCONZ Totalausfall - Benötige Hilfe:
      lightdm.service
      Sollte gar nicht überhaupt versucht gestartet zu werden. Schalt den Desktop ab:
      sudo raspi-config
      Menü: 1 - S5 - B1
        cherberg @Thomas Braun last edited by
        pi@raspberrypi:~ $ apt policy deconz
        deconz:
          Installed: 2.09.03-raspbian-buster-beta
          Candidate: 2.09.03-raspbian-buster-beta
          Version table:
         *** 2.09.03-raspbian-buster-beta 100
                100 /var/lib/dpkg/status
        /etc/apt/sources.list.d/deconz.list habe ich nach Deiner Empfehlung abgeändert
        pi@raspberrypi:~ $ systemctl status deconz
        ● deconz.service - deCONZ: ZigBee gateway -- REST API
           Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: e
           Active: active (running) since Fri 2021-02-12 23:08:35 CET; 3min 53s ago
         Main PID: 19751 (deCONZ)
            Tasks: 5 (limit: 4915)
           CGroup: /system.slice/deconz.service
                   └─19751 /usr/bin/deCONZ -platform minimal --http-port=80
        Feb 12 23:08:35 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST A
        Feb 12 23:08:35 raspberrypi deCONZ[19751]: QStandardPaths: XDG_RUNTIME_DIR not s
        Feb 12 23:08:35 raspberrypi deCONZ[19751]: libpng warning: iCCP: known incorrect
        Feb 12 23:08:36 raspberrypi deCONZ[19751]: This plugin does not support propagat
        Feb 12 23:08:39 raspberrypi deCONZ[19751]: This plugin does not support propagat
        lines 1-14/14 (END)...skipping...
           Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
        Feb 12 23:08:35 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
        Feb 12 23:08:35 raspberrypi deCONZ[19751]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
        Feb 12 23:08:35 raspberrypi deCONZ[19751]: libpng warning: iCCP: known incorrect sRGB profile
        Feb 12 23:08:36 raspberrypi deCONZ[19751]: This plugin does not support propagateSizeHints()
        Feb 12 23:08:39 raspberrypi deCONZ[19751]: This plugin does not support propagateSizeHints()
        lines 1-14/14 (END)
        pi@raspberrypi:~ $ systemctl status deconz-gui
        ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
           Loaded: loaded (/lib/systemd/system/deconz-gui.service; enabled; vendor preset: enabled)
           Active: activating (auto-restart) (Result: exit-code) since Fri 2021-02-12 23:13:58 CET; 28s ago
          Process: 23250 ExecStart=/usr/bin/deCONZ --http-port=80 (code=exited, status=1/FAILURE)
         Main PID: 23250 (code=exited, status=1/FAILURE)
          @thomas-braun said in Phoscon / deCONZ Totalausfall - Benötige Hilfe:
          sudo raspi-config
          habe ich gemacht, der lightdm.service ist nun weg. der deconz-init.service steht leider immer noch auf failed
            Thomas Braun Most Active @cherberg last edited by Thomas Braun
            @cherberg
            sudo systemctl stop deconz-gui
            sudo systemctl disable deconz-gui
            sudo apt update
            apt policy deconz
              apt policy deconz
              das deconz paket wurde wieder als upgradable gelistet, ich habe das upgrade noch durchgeführt
              deconz:
                Installed: 2.09.03-raspbian-buster-stable
                Candidate: 2.09.03-raspbian-buster-stable
                Version table:
               *** 2.09.03-raspbian-buster-stable 500
                      500 http://phoscon.de/apt/deconz buster/main armhf Packages
              leider komme ich nun gar nicht mehr auf die Phoscon Oberfläche 😞
              gibt es eine Möglichkeit deconz komplett/restlos zu entfernen und neu zu installieren? ich habe das Gefühl nun ist irgendwie alles vergniesgnaddelt 😞
                @cherberg Starte den Rechner mal neu.
                  erledigt, Weboberfläche leider immer noch nicht erreichbar:
                    @cherberg
                    Komische Meldung.
                         Active: active (running) since Fri 2021-02-12 23:37:39 CET; 10min ago
                       Main PID: 369 (deCONZ)
                                 └─369 /usr/bin/deCONZ -platform minimal --http-port=80
                      Feb 12 23:37:39 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                      Feb 12 23:37:39 raspberrypi deCONZ[369]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                      Feb 12 23:37:39 raspberrypi deCONZ[369]: libpng warning: iCCP: known incorrect sRGB profile
                      Feb 12 23:37:40 raspberrypi deCONZ[369]: This plugin does not support propagateSizeHints()
                      Feb 12 23:37:43 raspberrypi deCONZ[369]: This plugin does not support propagateSizeHints()
                         Loaded: loaded (/lib/systemd/system/deconz-gui.service; disabled; vendor preset: enabled)
                         Active: inactive (dead)
                      Feb 12 23:48:08 raspberrypi systemd[1]: /lib/systemd/system/deconz-gui.service:10: Unknown lvalue 'StartLimitIntervalSec' in s
                      lines 1-5/5 (END)...skipping...
                        wie beschrieben muss ich eh alles neu anlernen wenns denn mal wieder läuft. Ein kompletter Reset und eine saubere Neuinstallation wäre also kein Problem
                          am liebsten würde ich (mal wieder) alles neu aufsetzen, aber meinen iobroker so wieder hin zu bekommen wird sehr sehr viel Arbeit sein. Backup einspielen hat beim letzten mal nicht funktioniert. und mit Linux kenne ich mich leider nicht besonders gut aus.
                          Das Einzige was mir nun noch einfällt wäre den Raspbee in einen wekiteren RPI einzubauen mit einer frischen Raspbian installation in der Hoffnung, dass er dann wieder funktioniert. Wäre dann auch der Test ob es ein Hardware Problem ist. Was denkst Du?
                            @cherberg Versehentlich zweimal gepostet oder kommt die Ausgabe wirklich doppelt?
                              mal so, mal so, manchmal springt der Terminal irgendwie in eine Art "Log Ansicht" anstatt zur Befehlseingabe zurück zu springen. Sorry für meine Noobität :-0
                              Feb 12 23:48:08 raspberrypi systemd[1]: /lib/systemd/system/deconz-gui.service:10: Unknown lvalue 'StartLimitIntervalSec' in section 'Service', ignoring
                              Feb 13 00:03:22 raspberrypi systemd[1]: /lib/systemd/system/deconz-gui.service:10: Unknown lvalue 'StartLimitIntervalSec' in section 'Service', ignoring
                                 Active: active (running) since Fri 2021-02-12 23:37:39 CET; 25min ago
                              pi@raspberrypi:~ $
                                @cherberg
                                Die Services passen.
                                  mein Fehler aus irgendeinem Grund hatte ich https in der Adresszeile.
                                  Die Weboberfläche ist erreichbar, jedoch kann ich weiterhin kein Gerät anmelden 😞
                                  Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                                    @cherberg Noch irgendwelche Meldungen in
                                    dmesg
                                    drin?
                                    Node könntest du auch mal aktualisieren.
                                    Asgothian C 2 Replies Last reply Reply Quote 0
                                    • Asgothian
                                      Asgothian Developer @Thomas Braun last edited by
                                      @thomas-braun sagte in Phoscon / deCONZ Totalausfall - Benötige Hilfe:
                                      Nur so als Hinweis: Deconz arbeitet nicht mit nodejs. Also besser Node erst dann aktualisieren wenn deconz sauber läuft.
                                      A.
                                        Thomas Braun Most Active @Asgothian last edited by
                                        @asgothian sagte in Phoscon / deCONZ Totalausfall - Benötige Hilfe:
                                        Ist mir vollkommen bewusst. War auch ein Hinweis außer der Reihe. node10 wird in ein paar Wochen abgekündigt werden. Dann kann man da auch jetzt Hand anlegen, wenn man sich eh mit dem System auseinandersetzt.
                                        • Asgothian
                                          Asgothian Developer @cherberg last edited by
                                          • Was genau tust du zum anmelden, und was genau passiert ?
                                          • wenn du in deconz den status des Gateways anschaust, was sagt deconz da zu Stick und dessen firmware ?
                                          • wenn du einen Windows Rechner hast macht es ggf. sinn die HW dadurch zu testen das du deconz mit gui auf diesem installierst, den Stick ansteckst und schaust ob da etwas geht.
                                          A.
                                            cherberg @Asgothian last edited by
                                            @asgothian
                                            ich versuche Geräte wie gewohnt anzumelden, (Xiaomi) Sensoren, (Symfonisk/Trädfri) Schalter oder (Trädfri) Lichter. Natürlich hate ich sie vorher resettet. Die Suche in der Oberfläsche läuft wie gewohnt, es werden aber keine Geräte gefunden. Vorher hat es meist beim ersten Versuch geklappt.
                                            Ich habe einen Raspbee 1 und nicht den Conbee USB Stick. Der Gateway zeigt die Firmware an, die Verbindung scheint also zu bestehen.
                                            Leider kann ich den Rasbpee nicht an einem Windows PC ausprobieren, werde aber mal einen zweiten Pi aufsetzen und den Adapter dort probieren, so langsam gehe ich von einem Hardware Defekt aus. Schade, dass es keinerlei Logs gibt.
                                            5170
