    4. Material Design Widgets: JSON Chart Widget
    • Scrounger
      Scrounger Developer @Morluktom last edited by
      @Trikolon
      Zeig mal den json string, der mit dem code erzeugt wird.
      @morluktom
      Stack ist nur möglich mit Bars nicht mit Line.
      wie das geht siehe JSON 2. Example:
      https://github.com/Scrounger/ioBroker.vis-materialdesign#example-1
      T M 2 Replies Last reply Reply Quote 0
        Trikolon @Scrounger last edited by
        @scrounger
        	{"axisLabels":["2021/1/30","2021/1/31","2021/2/1","2021/2/2","2021/2/3","2021/2/4","2021/2/5","2021/2/6","2021/2/7","2021/2/8","2021/2/9","2021/2/10","2021/2/11","2021/2/12"],"graphs":[{"data":[9841,8425,6657,7627,12564,13024,10595,8888,6445,4789,5821,9246,9918,5545],"type":"bar","color":"#70aeff","legendText":"Neuinfektionen","barIsStacked":true,"yAxis_id":0,"displayOrder":2,"line_Thickness":2,"line_pointSize":0,"datalabel_show":true,"datalabel_rotation":90,"datalabel_fontSize":10,"datalabel_color":"#FFFFFF","datalabel_align":"end","datalabel_anchor":"center","xAxis_bounds":"ticks","yAxis_zeroLineWidth":0,"xAxis_timeFormats":{"millisecond":"H:mm:ss.SSS","second":"H:mm:ss","minute":"H:mm","hour":"dd.[\\n]H:mm","day":"dd[\\n]DD.MM","week":"dd[\\n]DD.MM","month":"MMM[\\n]YYYY","quarter":"[Q]Q - YYYY","year":"YYYY"}},{"data":[79.31,81.33,81.62,74.98,69.04,69.25,70.15,70.7,70.45,67.07,59.04,54.54,53.73,48.19],"type":"line","color":"#FF3030","legendText":"Inzidenz","yAxis_id":1,"displayOrder":0,"line_Thickness":2,"line_pointSize":0,"datalabel_show":false,"barIsStacked":false,"yAxis_position":"right","yAxis_color":"#FF3030"},{"data":[107.9,107.9,99,103,122.8,122.8,108.9,103,94,95,107.9,107.9,85.1,85.1],"type":"line","color":"#FF8330","legendText":"Inzidenz NEA","yAxis_id":1,"displayOrder":1,"line_Thickness":2,"line_pointSize":0,"datalabel_show":false,"barIsStacked":false,"yAxis_position":"right","yAxis_color":"#FF3030"}]}
        • Scrounger
          Scrounger Developer @Trikolon last edited by
          @trikolon
          ich kann da keinen Fehler entdecken, sieht bei mir so aus wie es soll:
          Probier mal folgendes:
          • Widget löschen und neu erstellen
          • debug modus aktivieren und consolen log (F12) zur runtime zu verfügung stellen.
            @scrounger
            Ein Update auf die letzte Version des addons hat die Lösung gebracht. Oh man hätte ich auch vorher probieren können.
            Danke für den Support!
            Ben
              Morluktom @Scrounger last edited by
              @scrounger
              Stacken von Lines funktioniert bei mir.
              Aber dann eben nur alle.
              	"axisLabels": ["1h", "2h", "3h"],
              	"graphs": [{
              			"type": "line",
              			"color": "#8B4513",
              			"legendText": "Netzeinspeisung",
              			"barIsStacked": true,
              			"barStackId": 1,
              			"displayOrder": 0,
              			"line_Thickness": 2,
              			"line_pointSize": 0,
              			"datalabel_show": false,
              			"yAxis_id": 0,
              			"yAxis_zeroLineWidth": 1,
              			"yAxis_appendix": " W",
              			"yAxis_min": 0,
              			"yAxis_max": 16000,
              			"data": [1000, 2000, 1000]
              			"type": "line",
              			"color": "#000000",
              			"legendText": "Ladung Akku",
              			"barStackId": 1,
              			"yAxis_id": 0,
              			"displayOrder": 1,
              			"data": [2000, 1000, 2000]
              			"type": "line",
              			"color": "#ccc7c7",
              			"legendText": "Direkt Verbrauch",
              			"barStackId": 1,
              			"yAxis_id": 0,
              			"displayOrder": 2,
              			"data": [4000, 1000,4000]
              			"type": "line",
              			"color": "#ff9a04",
              			"legendText": "Leistung PV Total",
              			"yAxis_id": 0,
              			"line_UseFillColor": true,
              			"displayOrder": 3,
              			"line_pointSize": 0,"datalabel_show": false,
              			"barStackId": 2,
              			"data": [10000,9000,7000]
              • Glasfaser
                Glasfaser last edited by Glasfaser
                @morluktom
                Könntest du mir vielleicht dein Script dafür zur Verfügung stellen , was den JSON erzeugt !?
                Bin gerade selber am Basteln 🙂
                  Morluktom @Glasfaser last edited by
                  @glasfaser
                  Es gibt kein Script, der JSON ist über Notepad++ erstellt. Ich möchte das in meinen Adapter für den LG-ESS Wechselrichter integrieren, und suche gerade nach einer Lösung.
                  • Glasfaser
                    Glasfaser @Morluktom last edited by
                    @morluktom sagte in Material Design Widgets: JSON Chart Widget:
                    Aber die Datenpunkte "data": müssen doch dementsprechend aktualisiert werden und das macht der Adapter !?
                    • Scrounger
                      @morluktom
                      Tatsache, die chartjs api bietet auch die Option stacked für line charts. Hab ich selber noch nie ausprobiert.
                      Was ist wenn du bei Leistung PV Total barIsStacked auf false setzt?
                        @scrounger
                        Sobald ich das barIsStacked auf flase setze, wird gar nichts mehr gestacked.
                        @Glasfaser
                        Ich bin gerade an der Lösungsfindung.
                        Ich würde dann denn kompletten JSON über meinen Adapter zur Verfügung stellen.
                          Jetzt bin ich einen Schritt weiter.
                          Habe mir deinen Code angesehen. Das barIsStacked wirkt ja auf die y Achse.
                          Ich habe jetzt die PV-Leistung auf eine eigene y Achse gelegt, dann funktioniert das soweit.
                          Die zweite könnte ich ja dann ausblenden.
                          Jetzt habe ich das Problem das die beiden y Achsen unterschiedlich skaliert werden.
                          Habe ich darauf einen Einfluß?
                          • Scrounger
                            @morluktom
                            Ja du kannst min Max Werte angeben. Musst dann halt immer wissen was der Max wert ist, aber das müsste im Code ja gehen?
                              @scrounger
                              Den Gedanken hatte ich auch, aber der gestackten Achse sind die min/max Werte egal. Egal was ich angegebe diese macht die Skalierung selbst.
                              Die "normale" Achse reagiert auf min/max.
                              • Scrounger
                                @morluktom
                                Ok, dass muss ich mir dann im Detail anschauen. Evtl. braucht man da noch was von der api.
                                  BooBär last edited by
                                  ich würde gern das JSON Chart Widget dazu verwenden, um diverse Verbrauchswerte meiner Viessmann-Heizung auf einen Blick zu visualisieren.
                                  Die Verrbauchs- und Ertragswerte der Heizung rufe ich mit Hilfe der viessmannapi Instanz ab. Die Werte werden als Zeichenkette (String) für die letzten 7 Tage abgerufen - siehe Screenshot.
                                  Da ich vom entwickeln keine Ahnung habe, habe ich mithilfe eurer Forenbeiträge folgendes Skript "zusammenkopiert" um den JSON-String zu erzeugen.
                                  let chart = {};
                                  let values = [];
                                  let axisLabels = [];
                                      var state_name = 'viessmannapi.0.heating.';
                                      var GasConsumptionHeating = getState(state_name + 'gas.consumption.heating.day').val;
                                      var GasConsumptionDHW = getState(state_name + 'gas.consumption.dhw.day').val;
                                      var SolarPowerProduction = getState(state_name + 'solar.power.production.day').val;
                                      console.log(GasConsumptionHeating);
                                      console.log(GasConsumptionDHW);
                                      console.log(SolarPowerProduction);
                                      var jetzt = new Date();
                                      var heute = new Date(jetzt.getTime());
                                      var heuteMinus1 = new Date(jetzt.getTime()-(1000 * 60 * 60 * 24 * 1));
                                      var heuteMinus2 = new Date(jetzt.getTime()-(1000 * 60 * 60 * 24 * 2));
                                      var heuteMinus3 = new Date(jetzt.getTime()-(1000 * 60 * 60 * 24 * 3));
                                      var heuteMinus4 = new Date(jetzt.getTime()-(1000 * 60 * 60 * 24 * 4));
                                      var heuteMinus5 = new Date(jetzt.getTime()-(1000 * 60 * 60 * 24 * 5));
                                      var heuteMinus6 = new Date(jetzt.getTime()-(1000 * 60 * 60 * 24 * 6));
                                      var heuteMinus7 = new Date(jetzt.getTime()-(1000 * 60 * 60 * 24 * 7));
                                  chart = {
                                      axisLabels: [heute.getDate()+ "." + (heute.getMonth()+1),
                                                   heuteMinus1.getDate()+ '.' + (heuteMinus1.getMonth()+1),
                                                   heuteMinus2.getDate()+ "." + (heuteMinus2.getMonth()+1),
                                                   heuteMinus3.getDate()+ "." + (heuteMinus3.getMonth()+1),
                                                   heuteMinus4.getDate()+ "." + (heuteMinus4.getMonth()+1),
                                                   heuteMinus5.getDate()+ "." + (heuteMinus5.getMonth()+1),
                                                   heuteMinus6.getDate()+ "." + (heuteMinus6.getMonth()+1),
                                                   heuteMinus7.getDate()+ "." + (heuteMinus7.getMonth()+1)
                                      graphs: [
                                          data: GasConsumptionHeating,
                                          //data: [39, 77, 80, 99, 110, 97, 84, 91],
                                          type: 'bar',
                                          displayOrder: 1,
                                          barStackId: 1,
                                          barIsStacked: true,
                                          color: 'orange',
                                          legendText: "Heizung",
                                  		tooltip_MaxDigits: 1,
                                  		tooltip_AppendText: " kWh",
                                          datalabel_color: 'red',
                                          yAxis_id: 1,
                                          yAxis_show: "true",
                                          yAxis_appendix: " kWh",
                                          xAxis_timeFormats: {
                                              millisecond: "H:mm:ss.SSS",
                                              second: "H:mm:ss",
                                              minute: "H:mm",
                                              hour: "dd.[\\n]H:mm",
                                              day: "dd[\\n]DD.MM",
                                              week: "dd[\\n]DD.MM",
                                              month: "MMM[\\n]YYYY",
                                              quarter: "[Q]Q - YYYY",
                                              year: "YYYY"
                                          data: (GasConsumptionDHW),
                                          //data: [6, 6, 2, 2, 2, 8, 6, 11],
                                          type: 'bar',
                                          displayOrder: 1,
                                          barStackId: 1,
                                          barIsStacked: true,
                                          //color: 'blue',
                                          legendText: "Warmwasser",
                                          yAxis_id: 1,
                                          data: SolarPowerProduction,
                                          //data: [13, 0, 17, 20, 17, 13, 0, 0],
                                          type: 'bar',
                                          displayOrder: 1,
                                          barStackId: 2,
                                          barIsStacked: true,
                                          color: 'red',
                                          legendText: "Solarthermie",
                                          yAxis_id: 1,
                                  setState('javascript.0.test3', JSON.stringify(chart), true);
                                  Leider werden bei der Ausgabe die Variablen immer in Anführungszeichen ausgegeben was dann von dem JSON Chart Widget nicht interpretiert werden kann.
                                  {"axisLabels":["17.2","16.2","15.2","14.2","13.2","12.2","11.2","10.2"],"graphs":[{"data":"[29,62,77,80,99,110,97,84]","type":"bar","displayOrder":1,"barStackId":1,"barIsStacked":true,"color":"orange","legendText":"Heizung","tooltip_MaxDigits":1,"tooltip_AppendText":" kWh","datalabel_color":"red","yAxis_id":1,"yAxis_show":"true","yAxis_appendix":" kWh","xAxis_timeFormats":{"millisecond":"H:mm:ss.SSS","second":"H:mm:ss","minute":"H:mm","hour":"dd.[\\n]H:mm","day":"dd[\\n]DD.MM","week":"dd[\\n]DD.MM","month":"MMM[\\n]YYYY","quarter":"[Q]Q - YYYY","year":"YYYY"}},{"data":"[0,12,6,2,2,2,8,6]","type":"bar","displayOrder":1,"barStackId":1,"barIsStacked":true,"legendText":"Warmwasser","yAxis_id":1,"tooltip_AppendText":" kWh"},{"data":"[4.67,13.474,0,17.137,20.263,16.924,13.206,0]","type":"bar","displayOrder":1,"barStackId":2,"barIsStacked":true,"color":"red","legendText":"Solarthermie","yAxis_id":1,"tooltip_AppendText":" kWh"}]}
                                  Könnt Ihr mir hier unter die Arme greifen? Vielen lieben Dank vorab und Hut ab für eure tolle Arbeit!
                                  Viele Grüße
                                  M Scrounger 2 Replies Last reply Reply Quote 0
                                    Morluktom @BooBär last edited by
                                    @boobär
                                    Lass mal in der letzten Zeile das JSON.stringify() weg.
                                    • Scrounger
                                      Scrounger Developer @BooBär last edited by Scrounger
                                      @boobär
                                      Problem hier ist, dass die Eingabe "data":"[29,62,77,80,99,110,97,84]", was nach dem parsen ein String ist und nicht wie benötigt ein Array<Number>.
                                      Korrekt muss das so aussehen "data": [29,62,77,80,99,110,97,84]. Das müsstest du mit GasConsumptionHeating.split(",") erreichen, wenn das ein String ist.
                                      Korrekter JSON string muss so aussehen:
                                      	"axisLabels": ["17.2", "16.2", "15.2", "14.2", "13.2", "12.2", "11.2", "10.2"],
                                      	"graphs": [{
                                      			"data": [29,62,77,80,99,110,97,84],
                                      			"type": "bar",
                                      			"displayOrder": 1,
                                      			"barStackId": 1,
                                      			"color": "orange",
                                      			"legendText": "Heizung",
                                      			"tooltip_MaxDigits": 1,
                                      			"tooltip_AppendText": " kWh",
                                      			"datalabel_color": "red",
                                      			"yAxis_id": 1,
                                      			"yAxis_show": "true",
                                      			"yAxis_appendix": " kWh",
                                      			"xAxis_timeFormats": {
                                      				"millisecond": "H:mm:ss.SSS",
                                      				"second": "H:mm:ss",
                                      				"minute": "H:mm",
                                      				"hour": "dd.[\\n]H:mm",
                                      				"day": "dd[\\n]DD.MM",
                                      				"week": "dd[\\n]DD.MM",
                                      				"month": "MMM[\\n]YYYY",
                                      				"quarter": "[Q]Q - YYYY",
                                      				"year": "YYYY"
                                      			"data": [0,12,6,2,2,2,8,6],
                                      			"type": "bar",
                                      			"displayOrder": 1,
                                      			"barStackId": 1,
                                      			"legendText": "Warmwasser",
                                      			"yAxis_id": 1,
                                      			"data": [4.67,13.474,0,17.137,20.263,16.924,13.206,0],
                                      			"type": "bar",
                                      			"displayOrder": 1,
                                      			"barStackId": 2,
                                      			"color": "red",
                                      			"legendText": "Solarthermie",
                                      			"yAxis_id": 1,
                                      Würde dir aber in deinem Fall sogar empfehlen eine echte zeitachse zu bauen, mehr dazu siehe hier:
                                      https://github.com/Scrounger/ioBroker.vis-materialdesign#chart-with-time-axis
                                      Vorteil wäre das die Formatierung automatisch gemacht wird.
                                      • Gargano
                                        Gargano @Scrounger last edited by
                                        @scrounger Wie kann ich denn die Datalabels beim JSON Chart senkrecht stellen ? Ich habe etwas gelesen von datalabel_rotation in den Properties, aber wo kann ich dies einstellen ?
                                        • Scrounger
                                          Scrounger Developer @Gargano last edited by
                                          @gargano
                                          Ist eine property des Json objects, also dort mit angeben
                                          Gargano 1 Reply Last reply Reply Quote 0
                                          • Gargano
                                            @scrounger Danke, hat funktioniert
                                            vis
                                            37
                                            191
                                            35919
