    4. Proxmox ständig Fragezeichen im GUI
    • opossum
      opossum @opossum last edited by
      @opossum
      hier ein Auszug aus dem Kernellog:
      Feb 13 18:14:52 pve kernel: [27686.801585] show_signal_msg: 6 callbacks suppressed
      Feb 13 18:14:52 pve kernel: [27686.801587] pvemailforward.[15105]: segfault at 8008 ip 000055576fd6014e sp 00007fff73148950 error 4 in perl[55576fd34000+15e000]
      Feb 13 18:14:52 pve kernel: [27686.802852] Code: 49 89 fd 41 54 45 31 e4 55 48 89 f5 53 48 8b 55 10 83 4c c2 38 01 48 8b 45 10 49 63 d4 48 8b 1c d0 48 85 db 0f 84 32 01 00 00 <48> 8b 43 08 48 63 50 04 48 8d 70 08 48 89 d1 48 83 fa 01 76 0b 80
      Feb 13 18:17:01 pve kernel: [27816.019079] pvesr[15941]: segfault at 800e ip 0000560a307fe98e sp 00007fff0c40ff90 error 4 in perl[560a3073f000+15e000]
      Feb 13 18:17:01 pve kernel: [27816.020082] Code: 10 74 1e 48 c7 40 28 00 00 00 00 8b 56 08 83 fa 01 0f 86 b5 00 00 00 83 ea 01 89 56 08 48 8b 43 10 48 8b 70 20 48 85 f6 74 20 <f6> 46 0e 10 74 1a 48 c7 40 20 00 00 00 00 8b 56 08 83 fa 01 76 7c
      Feb 13 18:24:36 pve kernel: [28270.581881] pvedaemon worke[19407]: segfault at 9 ip 0000556f0ff187fd sp 00007fffcc5a5080 error 4 in perl[556f0fe6e000+15e000]
      Feb 13 18:24:36 pve kernel: [28270.583315] Code: 24 10 48 8b 50 18 4d 85 c9 0f 84 c6 09 00 00 49 8b 9f 60 08 00 00 23 94 24 d0 00 00 00 4d 8d 34 d1 48 85 db 0f 84 d3 09 00 00 <48> 8b 03 49 89 87 60 08 00 00 f6 45 0f 20 0f 85 ef 03 00 00 49 39
      Feb 13 18:26:36 pve kernel: [28390.648759] vgs[19960]: segfault at 8000 ip 00005624d52ed0c0 sp 00007ffe7ae52380 error 4 in lvm[5624d5175000+17c000]
      Feb 13 18:26:36 pve kernel: [28390.649911] Code: 75 d0 c7 45 ec 00 00 00 00 eb 4a 48 8b 45 d8 48 8b 40 08 8b 55 ec 48 c1 e2 03 48 01 d0 48 8b 00 48 89 45 f0 eb 24 48 8b 45 f0 <48> 8b 00 48 89 45 f8 48 8b 45 f0 48 8b 50 08 48 8b 45 d0 48 89 d7
      Feb 13 18:54:01 pve kernel: [30035.656905] mce: CPU7: Core temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656906] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656907] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656908] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656910] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656910] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656912] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656913] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.656913] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.657770] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
      Feb 13 18:54:01 pve kernel: [30035.657946] mce: CPU3: Core temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.657947] mce: CPU6: Package temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.657948] mce: CPU4: Package temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.657948] mce: CPU0: Package temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.657949] mce: CPU5: Package temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.657950] mce: CPU1: Package temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.657950] mce: CPU3: Package temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.658629] mce: CPU2: Package temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.660247] mce: CPU7: Core temperature/speed normal
      Feb 13 18:54:01 pve kernel: [30035.678546] mce: CPU7: Package temperature/speed normal
      JLeg 1 Reply Last reply Reply Quote 0
        crunchip Forum Testing Most Active @opossum last edited by
        @opossum mit der Meldung kann ich leider auch nichts anfangen, wüsste nicht was das genau bedeuten soll
        allerdings wenn man dem Hinweis folgt
        https://www.ionos.com/help/index.php?id=2425&ip=178.25.103.20&c=bl)
        gibt es mehrere Möglichkeiten für den Fehler 554
        jedoch sollte das aber nicht dein generelles Problem lösen, gibts irgendwelche Hinweise im log, bevor er nicht mehr erreichbar war?
          apollon77 last edited by apollon77
          Das mit der email. Naja. Ignore erstmal. Die segfaults und CPU temperaturwarnungen würden mir eher Sorgen machen und können gut der Grund sein.
          Pvesr und die anderen pve Prozesse die da sterben sind wohl dein Grund. Ist aber interessant das das ganz unterschiedliche Prozesse sind. Also ja könnte auch die ssd sein und damit Fehler in den dateien.
            Ich würde anfragen und erstmal schauen ob Updates fehlen. Also alles aktualisieren.
            apt update
            Poste mal Ausgabe
            opossum 1 Reply Last reply Reply Quote 0
            • opossum
              opossum @apollon77 last edited by
              @apollon77 ,
              sudo apt update
              Get:1 http://security.debian.org buster/updates InRelease [65.4 kB]
              Hit:2 http://ftp.de.debian.org/debian buster InRelease
              Get:3 http://ftp.de.debian.org/debian buster-updates InRelease [51.9 kB]
              Get:4 http://security.debian.org buster/updates/main amd64 Packages [267 kB]
              Hit:5 http://download.proxmox.com/debian/pve buster InRelease
              Fetched 384 kB in 0s (771 kB/s)
              Reading package lists... Done
              Building dependency tree
              12 packages can be upgraded. Run 'apt list --upgradable' to see them.
              michael@pve:~$ sudo apt list --upgradable
              Listing... Done
              libpve-access-control/stable 6.1-3 all [upgradable from: 6.0-6]
              libpve-common-perl/stable 6.3-2 all [upgradable from: 6.0-12]
              libpve-guest-common-perl/stable 3.1-4 all [upgradable from: 3.0-3]
              libpve-http-server-perl/stable 3.1-1 all [upgradable from: 3.0-4]
              libpve-storage-perl/stable 6.3-5 all [upgradable from: 6.1-4]
              lxc-pve/stable 4.0.6-2 amd64 [upgradable from: 3.2.1-1]
              proxmox-ve/stable 6.3-1 all [upgradable from: 6.1-2]
              pve-container/stable 3.3-3 all [upgradable from: 3.0-19]
              pve-kernel-5.3/stable 6.1-6 all [upgradable from: 6.1-4]
              pve-manager/stable 6.3-3 amd64 [upgradable from: 6.1-7]
              pve-qemu-kvm/stable 5.1.0-8 amd64 [upgradable from: 4.1.1-2]
              qemu-server/stable 6.3-4 amd64 [upgradable from: 6.1-5]
                apollon77 @opossum last edited by
                @opossum Naja ich würde sagen bist doch ein bissl weg. Update mal und schau ob es dann besser wird.
                Am besten
                apt dist-upgrade
                (wenn soweit weg dann vermisse ich an sich ein Kernel update)
                  crunchip Forum Testing Most Active @apollon77 last edited by
                  @apollon77 sagte in Proxmox ständig Fragezeichen im GUI:
                  Am besten
                  apt dist-upgrade
                  ist das nicht eher ein muss! beim Proxmox Host, allerdings macht man das in der Regel direkt in der Gui
                  opossum apollon77 2 Replies Last reply Reply Quote 0
                  • opossum
                    opossum @crunchip last edited by opossum
                    hallo,
                    haben wir jetzt gemacht, Kernel wurde ebenfalls erneuert. Wir werden jetzt die VMs wieder starten und das weiter beobachten.
                    Die Temperaturen sind anscheinend hochgegangen, als der Proxmox versucht hat, eine Nachricht zu senden.
                    Diese Message:
                    Feb 13 03:09:00 pve postfix/error[23625]: 8E311102C23: to=<xxx@xxx.de>, relay=none, delay=151923, delays=151923/0.14/0/0.01, dsn=4.0.0, status=deferred (delivery temporarily suspended: host mx00.emig.kundenserver.de[212.227.15.40] refused to talk to me: 554-kundenserver.de (mxeue012) Nemesis ESMTP Service not available 554-No SMTP service 554-IP address is black listed. 554 For explanation visit https://www.ionos.com/help/index.php?id=2425&ip=178.25.103.20&c=bl)
                    haben wir 125731 mal im heutigen Syslog, warum auch immer. Diese Message wird zum Beispiel um 18:23:32 627 mal aufgeführt. Kann es sein, dass dadurch die CPU mit Ihrer Temperatur hochgehen und dann das System eine Überhitzung feststellt und damit die Performance reduziert. Das hätte dann das Prozesssterben zur Folge?
                      apollon77 @crunchip last edited by
                      @crunchip Am Ende ists nur ein Linux. apt upgrade macht die "Normalen Upgrades" die primär Fixes sind. EIn dist-upgrade macht systemnahere und Dinge die am ehestens einen Reboot brauchen 🙂
                      Kann man per UI machen oder Kommandozeile :-))
                      • JLeg
                        JLeg @opossum last edited by
                        @opossum pvedaemon ist der Dienst, der für die ‚?‘ in der Proxmox-Gui sorgt, wenn er nicht läuft. Was er nicht mehr tut, da per Segfault gestorben. Gleiches gilt für pvesr (der Storages in Proxmox verwaltet).
                        Da hilft mit Sicherheit kein Update, das sieht nach Hardwareproblem aus. Vielleicht liefert ‚dmesg‘ oder /var/log/daemon.log mehr Infos zu der Ursache...
                          apollon77 @JLeg last edited by
                          @jleg Ist auch meine Vermutung, aber manchmal tun Kernel bzw Paket updates Wunder
                          JLeg 1 Reply Last reply Reply Quote 1
                          • JLeg
                            JLeg @apollon77 last edited by
                            Jo, aber hier stirbt Perl (pvedaemon). Perl stirbt nicht, egal was mit kernel & Co sonst ist 😉 - ausser die HW hat ein gravierendes Problem.
                            • opossum
                              wir hatten das System heute morgen auf einem NUC10i7 mit 64GB RAM. Um Hardwareprobs auszuschließen, haben wir die beiden SSDs in einen NUC8i5 eingebaut. Da hatten wir aber die gleichen Fehler. Demnach würde die SSD defekt sein, auf der die VMs liegen?
                                @apollon77 weiß ich, hatte aber im Proxmox Forum mal gelesen, daß beim Proxmox Host selbst, ein apt-upgrade vermieden werden sollte, da es zu Problemen führen könnte
                                • JLeg
                                  @opossum sagte in Proxmox ständig Fragezeichen im GUI:
                                  Das lässt sich m.E. nicht aus dem Logschnipsel oben ableiten - ich würde schauen, was die anderen Logs/dmesg so sagen... Das einzige, was oben klar erkennbar ist, ist dass der CPU zu heiss wird 😉
                                  • opossum
                                    opossum @JLeg last edited by
                                    @jleg ,
                                    ja, die CPU-Temperaturen steigen immer unmittelbar dann, wenn der Host versucht, eine Message abzusetzen. Wie ich oben schon schrieb, 627 mal in einer Sekunde. Könnte das sein? Wir würden den NUC jetzt wieder hochfahren und ihn mal bis morgen beobachten. Wenn jetzt der Fehler wieder auftritt, dann kann es eigentlich nur die SSD sein, auf der PVE läuft. Die würden wir dann morgen komplett austauschen, Proxmox neu installieren und dann die Backups der VM zurückschreiben.
                                      crunchip Forum Testing Most Active last edited by crunchip
                                      wäre es nicht auch möglich, das einer deiner laufenden Maschinen "Amok" läuft und die Probleme verursacht?
                                      Demnach würde ich mal alle Maschinen abschalten und eine nach der anderen dazu schalten
                                      • opossum
                                        opossum last edited by opossum
                                        Hallo, @crunchip ,
                                        danke für den Tip. Das wäre jetzt die nächste Möglichkeit. Wir haben jetzt den NUC durchgestartet, alle VMs hochgefahren und werden das jetzt beobachten. Wenn das wieder in die Knie geht, fahren wir die VMs einzeln. Wir werden weiter berichten, wie das hier weitergeht.
                                        Und: Vielen, vielen Dank für Eure Hilfe. Ist immer super, wenn man mit solchen Problemen nicht allein kämpfen muss.
                                          Aber ssd ich weiß net. Ggf mal postfix aus machen und schauen ob nicht der falsch konfiguriert ist. Und deswegen dann irgendwie das System „zuballert“
                                          • JLeg
                                            SSD finde ich hier auch eher unwahrscheinlich als Ursache. Was den Postfix angeht - da sollte es eigentlich ein /var/log/maillog geben mit weiteren Infos... Stoppen sollte man den auf jeden Fall, geblacklisted hat ihn Ionos aber schon... 😬
                                            79.9k
                                            proxmox fehler
                                            2503
