    4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
      Haifisch_777 @Haifisch_777 last edited by
      @haifisch_777
      die meisten Daten sind richtig, bis z.B. auf wind speed,
      • Glasfaser
        Glasfaser @Haifisch_777 last edited by
        @haifisch_777 sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
        error (11718) Cannot start server on 0.0.0.0:45000: Error: listen EADDRINUSE: address already in use 0.0.0.0:45000
        Der Port wird laut Log schon benutzt !
        • Glasfaser
          @haifisch_777
          Aktiviere mal nur diesen Punkt , inkl. Angabe der IP .
            Haifisch_777 @Glasfaser last edited by
            @glasfaser
            sainlogic.0	2021-02-14 16:09:43.762	debug	(24879) statesDB connected
            sainlogic.0	2021-02-14 16:09:43.761	debug	(24879) States connected to redis: 127.0.0.1:9000
            sainlogic.0	2021-02-14 16:09:43.752	debug	(24879) States create System PubSub Client
            sainlogic.0	2021-02-14 16:09:43.749	debug	(24879) States create User PubSub Client
            sainlogic.0	2021-02-14 16:09:43.742	debug	(24879) Redis States: Use Redis connection: 127.0.0.1:9000
            sainlogic.0	2021-02-14 16:09:43.740	debug	(24879) objectDB connected
            sainlogic.0	2021-02-14 16:09:43.733	debug	(24879) Objects connected to redis: 127.0.0.1:9001
            sainlogic.0	2021-02-14 16:09:43.713	debug	(24879) Objects client initialize lua scripts
            sainlogic.0	2021-02-14 16:09:43.712	debug	(24879) Objects create User PubSub Client
            sainlogic.0	2021-02-14 16:09:43.710	debug	(24879) Objects create System PubSub Client
            sainlogic.0	2021-02-14 16:09:43.706	debug	(24879) Objects client ready ... initialize now
            sainlogic.0	2021-02-14 16:09:43.682	error	at internal/main/run_main_module.js:17:47
            sainlogic.0	2021-02-14 16:09:43.682	error	at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
            sainlogic.0	2021-02-14 16:09:43.682	error	at Function.Module._load (internal/modules/cjs/loader.js:708:14)
            sainlogic.0	2021-02-14 16:09:43.682	error	at Module.load (internal/modules/cjs/loader.js:863:32)
            sainlogic.0	2021-02-14 16:09:43.682	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
            sainlogic.0	2021-02-14 16:09:43.682	error	at Module._compile (internal/modules/cjs/loader.js:999:30)
            sainlogic.0	2021-02-14 16:09:43.682	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:281:5)
            sainlogic.0	2021-02-14 16:09:43.682	error	at new Sainlogic (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:30:53)
            sainlogic.0	2021-02-14 16:09:43.682	error	(24879) TypeError: Cannot read property 'bind' of undefined
            sainlogic.0	2021-02-14 16:09:43.681	error	(24879) uncaught exception: Cannot read property 'bind' of undefined
            sainlogic.0	2021-02-14 16:09:43.668	debug	(24879) Redis Objects: Use Redis connection: 127.0.0.1:9001
            sainlogic.0	2021-02-14 16:09:33.628	debug	(24803) statesDB connected
            sainlogic.0	2021-02-14 16:09:33.626	debug	(24803) States connected to redis: 127.0.0.1:9000
            sainlogic.0	2021-02-14 16:09:33.487	warn	(24803) Terminated (UNCAUGHT_EXCEPTION): Without reason
            sainlogic.0	2021-02-14 16:09:33.171	debug	(24803) States create System PubSub Client
            sainlogic.0	2021-02-14 16:09:33.167	debug	(24803) States create User PubSub Client
            sainlogic.0	2021-02-14 16:09:33.144	debug	(24803) Redis States: Use Redis connection: 127.0.0.1:9000
            sainlogic.0	2021-02-14 16:09:33.133	debug	(24803) objectDB connected
            sainlogic.0	2021-02-14 16:09:33.106	debug	(24803) Objects connected to redis: 127.0.0.1:9001
            sainlogic.0	2021-02-14 16:09:32.807	debug	(24803) Objects client initialize lua scripts
            sainlogic.0	2021-02-14 16:09:32.805	debug	(24803) Objects create User PubSub Client
            sainlogic.0	2021-02-14 16:09:32.804	debug	(24803) Objects create System PubSub Client
            sainlogic.0	2021-02-14 16:09:32.671	debug	(24803) Objects client ready ... initialize now
            sainlogic.0	2021-02-14 16:09:32.486	error	at internal/main/run_main_module.js:17:47
            sainlogic.0	2021-02-14 16:09:32.486	error	at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
            sainlogic.0	2021-02-14 16:09:32.486	error	at Function.Module._load (internal/modules/cjs/loader.js:708:14)
            sainlogic.0	2021-02-14 16:09:32.486	error	at Module.load (internal/modules/cjs/loader.js:863:32)
            sainlogic.0	2021-02-14 16:09:32.486	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
            sainlogic.0	2021-02-14 16:09:32.486	error	at Module._compile (internal/modules/cjs/loader.js:999:30)
            sainlogic.0	2021-02-14 16:09:32.486	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:281:5)
            sainlogic.0	2021-02-14 16:09:32.486	error	at new Sainlogic (/opt/iobroker/node_modules/iobroker.sainlogic/main.js:30:53)
            sainlogic.0	2021-02-14 16:09:32.486	error	(24803) TypeError: Cannot read property 'bind' of undefined
            sainlogic.0	2021-02-14 16:09:32.484	error	(24803) uncaught exception: Cannot read property 'bind' of undefined
            sainlogic.0	2021-02-14 16:09:32.473	debug	(24803) Redis Objects: Use Redis connection: 127.0.0.1:9001
              @haifisch_777
              Listener Setting hatte ich deaktiviert, war das richtig ?
              • Glasfaser
                @haifisch_777
                Ich nutze den Adapter nicht er ist aus, habe nur Erfolg mit Scheduler Settings , den anderen habe ich aus.
                Ich nutze das hier :
                https://forum.iobroker.net/topic/28384/linux-shell-skript-wlan-wetterstation
                  @glasfaser
                  Danke, das schau ich mir mal an
                    @glasfaser
                    Oh, das ist mir als Laie doch etwas kompliziert.
                    Vielleicht gibt es ja noch Hilfe für den sainlogic?
                    Vielleicht stimmen die Daten ja auch im WS view nicht?
                    • Negalein
                      Negalein Global Moderator @Haifisch_777 last edited by Negalein
                      Glaub mir, das ist nicht kompliziert. Du wirst es nicht bereuen.
                      Gibt auch ein super Wiki mit Schritt für Schritt Anleitung.
                      PS: Fogg ist seit 12. Jänner nicht mehr im Forum gewesen. Weiß nicht, ob da noch Support kommt. 😞
                        Haifisch_777 @Negalein last edited by
                        @negalein
                        Oh, die Wiki ist echt gut, ich versuche es, thanks
                          @negalein
                          Hai, nochmals Danke für den Tipp.
                          Es war wirklich nicht schwer, es ist eine super Wiki, und auch Respekt an den Programmierer.
                          Es läuft stabil!
                          Ich bin begeistert!
                          • Glasfaser
                            Glasfaser @Haifisch_777 last edited by Glasfaser
                            @Haifisch_777
                            Schön das es funktioniert.
                            Fogg 1 Reply Last reply Reply Quote 0
                            • Fogg
                              Fogg @Glasfaser last edited by
                              da sind ja ein paar Einträge... muss mal schauen warum ich vom Forum keine Emails dazu bekomme - schade.
                              Anyway, ich habe gestern und heute etwas die in git gemeldeten Dinge behoben. Es gibt ein neues Release 0.6.6: https://github.com/phifogg/ioBroker.sainlogic/releases/tag/0.6.6
                              Damit sollten auch die Fehler oben(Cannot read property 'bind' of undefined) behoben sein.
                              • Fogg
                                Fogg @Sender last edited by
                                @sender Spannende Variante!! Klingt nach einer guten Lösung.
                                Wenn ich das Intervall kenne kann ich die Werte nach längerer Zeit zurücksetzen. Beim Scheduler ist das einfach, beim Listener müsste ich das noch als Konfig mit angeben was das Reset-Intervall ist...
                                • Fogg
                                  Fogg @Haifisch_777 last edited by
                                  @haifisch_777 Das habe ich im neuesten Release (0.6.6) behoben. Bitte nochmals neu von github installieren.
                                    Jackson_White last edited by
                                    @fogg Einen wunderschönen guten Abend.
                                    Ich habe probleme den Adapter zu instalieren, gibt es da was zu beachten ?
                                    $ ./iobroker url "https://github.com/phifogg/ioBroker.sainlogic" --debug
                                    install phifogg/ioBroker.sainlogic#b2226dcac5056624a34d4384cfb2d1eaf7e8f333
                                    NPM version: 6.14.11
                                    npm install phifogg/ioBroker.sainlogic#b2226dcac5056624a34d4384cfb2d1eaf7e8f333 --loglevel error --prefix "/opt/iobroker" (System call)
                                    > node-bluetooth@1.2.6 install /opt/iobroker/node_modules/node-bluetooth> node-gyp configure build
                                    make: Entering directory '/opt/iobroker/node_modules/node-bluetooth/build'
                                      CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o
                                    ../src/linux/BluetoothSerialPort.cc:18:6: error: variable or field ‘InitAll’ declared void   18 | void InitAll(Handle<Object> exports) {      |      ^~~~~~~
                                    ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope   18 | void InitAll(Handle<Object> exports) {      |              ^~~~~~../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token   18 | void InitAll(Handle<Object> exports) {      |                           ^
                                    ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope   18 | void InitAll(Handle<Object> exports) {      |                             ^~~~~~~
                                    In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope   23 | NODE_MODULE(BluetoothSerialPort, InitAll)      |                                  ^~~~~~~/home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:737:36: note: in definition of macro ‘NODE_MODULE_X’  737 |       (node::addon_register_func) (regfunc),                          \      |                                    ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’   23 | NODE_MODULE(BluetoothSerialPort, InitAll)      | ^~~~~~~~~~~
                                    make: *** [BluetoothSerialPort.target.mk:117: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1make: Leaving directory '/opt/iobroker/node_modules/node-bluetooth/build'
                                    gyp ERR! build error
                                    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.4.0-66-genericgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.21.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                    + iobroker.sainlogic@0.6.6
                                    updated 1 package in 26.423s
                                    40 packages are looking for funding  run `npm fund` for details
                                    upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                                    upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                                    upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                                    upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                                    upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                                    process exited with code 0
                                    bin für jede Idee offen
                                    LG
                                    • Fogg
                                      Fogg @Jackson_White last edited by
                                      @jackson_white das klingt nicht nach einer Meldung des Adapters. Hier scheint noch ein Bluetooth Modul nicht sauber zu laufen bei Dir. Das braucht mein Adapter soweit ich weiss nicht. Kannst Du andere Adapter installieren?
                                        Sender @Fogg last edited by
                                        Hallo @fogg,
                                        das stammt ja nicht von mir, sondern von @Neo110.
                                        Ehre, wem Ehre gebührt! 😉
                                        Grüße...
                                          Jackson_White @Fogg last edited by
                                          @fogg Ja, alle anderen Adapter lassen sich ohne Probleme installieren. Nur bei dem kommen die Fehler Meldungen beim Versuch, ihn zu installieren. Das Komische, es ist egal ob auf dem Pi oder einen anderen Server. Immer kommt das mit Bluetooth, habe ja nicht mal was angeschlossen, was Bluetooth hat,... bin für Tipps offen.
                                          LG
                                            Sender @Fogg last edited by Sender
                                            @fogg Ich habe gerade gesehen, dass Du das auch auf GitHub verlinkt hast. Deshalb das Ganze hier nochmal "reday 4 import", so muss man es im Bedarfsfall nicht mühsam nachbauen. Es gibt noch mehr Werte die bei einigen Stationen offenbar nicht zurückgesetzt werden, wenn deren Wert "0" ist, UVraw z.Bsp. da ich die aber nicht nutze, habe ich sie auch nicht berücksichtigt. Im Bedarfsfall müssten diese auch noch "behandelt" werden.
                                              <block type="on" id="LNyTQS.BvTh-Rt9==?Kp" x="-62" y="13">
                                                <field name="OID">sainlogic.0.info.last_update</field>
                                                  <block type="comment" id="an=XANa/0LYB%mYk%~~%">
                                                    <field name="COMMENT">rain</field>
                                                      <block type="controls_if" id="6czyxJR+2pq9EHlr/f6A">
                                                          <block type="logic_compare" id="$bBmCt.uvpR!XD[dM*.D">
                                                            <field name="OP">GT</field>
                                                              <block type="math_arithmetic" id="w5(18=Tt2d@5U_|QQ9@$">
        <field name="OP">DIVIDE</field>
        <shadow type="math_number" id="j3m$h0ULcH}t:!hbfO9O">
        <field name="NUM">1</field>
        <block type="math_arithmetic" id="oAu|pY%s2_^WoBbv0Qvh">
        <shadow type="math_number" id="TV~:P}@+u:n$rZnU$,l;">
        <block type="get_value" id="?o)vRNl+D.{/3Z5}~Uxc">
        <field name="ATTR">ts</field>
        <shadow type="math_number" id="o!i~UuUlu7BTw/=lu%DT">
        <block type="get_value" id="l+UPcH1_Ia.$Nxt?xll-">
        <field name="OID">sainlogic.0.weather.current.rain</field>
        <shadow type="math_number" id="q`i17?|VKYfE5x}o8;;y">
        <field name="NUM">6000</field>
                                                              <block type="math_number" id="oS;a*H;^CR@64BMaH3`q">
        <field name="NUM">30</field>
                                                          <block type="control" id=";3M$F_}:rOPw3mOuCX}k">
                                                              <block type="math_number" id="Q~dANYB]^-!CPjuTUjeR">
        <field name="NUM">0</field>
                                                          <block type="comment" id="Bqv-5+*nVvus6lBXw=X?">
                                                            <field name="COMMENT">solarradiation</field>
                                                              <block type="controls_if" id="|$h7nWjAd]~Yf6|:O2![">
        <block type="logic_compare" id="wx849liGGz4$n;f|RGoX">
        <block type="math_arithmetic" id="~vy)ql0l(O%)U3hiLAn7">
        <shadow type="math_number">
        <block type="math_arithmetic" id="|lbR7]J)cv342Nzsu4Ao">
        <block type="get_value" id="*b~/DPrhimdCGtAA-0=e">
        <block type="get_value" id="h?aHx;TG5VU]S)*hL()j">
        <field name="OID">sainlogic.0.weather.current.solarradiation</field>
        <shadow type="math_number" id="7jRQv.z8^tBy8li9nsDq">
        <block type="math_number" id="*)%H}!$JWY!L.x8D;}2_">
        <block type="control" id="65zKOm(}=f8=3/Dt*Ilb">
        <block type="math_number" id="7-|M{G^ZY]zEgVjNWA:6">
        <block type="comment" id="b;qGCpF7OdY1Y1k@t$C?">
        <field name="COMMENT">uvi</field>
        <block type="controls_if" id="YAPB9uywFoW*;q$v)5=o">
        <block type="logic_compare" id="%ID+[Zla|9E7-PQ^;Uw=">
        <block type="math_arithmetic" id="$41u^tf!uv2|rlc.;3j)">
        <block type="math_arithmetic" id="]jj_|f=M8}aP?R$.jF@s">
        <block type="get_value" id="hq5g3BaqWe:K(hE/@*.8">
        <block type="get_value" id="El-m(h~{Nw{6ixL;kd*_">
        <field name="OID">sainlogic.0.weather.current.uvi</field>
        <shadow type="math_number" id="OmzN*u?+k7Ko{zcA;aq[">
        <block type="math_number" id="jmLtbc$N+)@IHu0sw.HA">
        <block type="control" id="K9qy/]Rq;O6UF.%CKfdE">
        <block type="math_number" id="[}vEL{=l2Y`=7~EjWGMv">
                                                  <block type="schedule" id="LN%,Hr1oMT:faAwx,ow@">
                                                    <field name="SCHEDULE">1 0 * * *</field>
                                                      <block type="comment" id="+TM^s,iYmWV;;*x(L$3A">
                                                        <field name="COMMENT">dailyrain</field>
                                                          <block type="control" id="dnRQaJeg6I$GbKId071^">
                                                            <field name="OID">sainlogic.0.weather.current.dailyrain</field>
                                                              <block type="math_number" id="O-)w`IJXLZLj544/L8ZI">
                                                      <block type="schedule" id="si?OSYOI=rQz;ngXZ,VM">
                                                        <field name="SCHEDULE">1 0 * * 0</field>
                                                          <block type="comment" id="kDgZBec{YNRvZZt;w.%r">
                                                            <field name="COMMENT">weeklyrain</field>
                                                              <block type="control" id="[A1f?l6+(NuSV/:-;*w*">
        <field name="OID">sainlogic.0.weather.current.weeklyrain</field>
        <block type="math_number" id="q^AI(ML=L3wQWs3/1r(X">
                                                          <block type="schedule" id="IbYvVtndr:oD)GuPQ8%h">
                                                            <field name="SCHEDULE">1 0 1 * *</field>
                                                              <block type="comment" id="X#2Pd,4PWUq-(mC(ohrC">
        <field name="COMMENT">monthlyrain</field>
        <block type="control" id="Lh#UdC(++.^mNP6T[@.L">
        <field name="OID">sainlogic.0.weather.current.monthlyrain</field>
        <block type="math_number" id="isDgIA!h{:es/tEB(.#e">
                                                              <block type="schedule" id="5Y,$op`8rIpNpC**;WRm">
        <field name="SCHEDULE">1 0 1 1 *</field>
        <block type="comment" id="m:W!([@Pr`r-NdJ:[SLO">
        <field name="COMMENT">yearlyrain</field>
        <block type="control" id=".0+;eGUs2NfBax.ws2{M">
        <field name="OID">sainlogic.0.weather.current.yearlyrain</field>
        <block type="math_number" id="hV#u:T;7q1S7f8dr{?To">
                                            Grüße und DANKE für Deine Arbeit! 👍
                                            1.2k
                                            adapter froggit wh4000sh sainlogic wetterstation ws980wifi
                                            60
                                            326
                                            73742
