    4. ZigBee neue Version 1.4.4
    • amg_666
      amg_666 @FredF last edited by
      @fredf ??? ich arbeite nicht über Konsole und versuche grade das Update über die Admin Oberfläche zu machen
      arteck FredF Thomas Braun 3 Replies Last reply Reply Quote 0
        arteck Developer Most Active @amg_666 last edited by
        @amg_666 hmmm.... starte mal die kiste komplett neu.. ich werd aus dem LOG nicht schlau
        • FredF
          FredF Most Active Forum Testing @amg_666 last edited by
          @amg_666 Ok, mich hat das iobroker upgrade zigbee irritiert
            Thomas Braun Most Active @amg_666 last edited by
            @amg_666
            cd /opt/iobroker
            npm cache clean --force
            iobroker update
            • amg_666
              amg_666 @arteck last edited by
              @arteck Muss ich das verstehen? Ich glaube ich muss das nicht verstehen 🙂
              Raspi neu gestartet (sudo shutdown -r 0), zigbee update angestoßen, update lief durch...
              Danke für den Support.
              $ ./iobroker upgrade zigbee
              Update zigbee from @1.4.2 to @1.4.4
              host.iomaster Adapter "system.adapter.zigbee.0" is stopped.
              NPM version: 6.14.10
              npm install iobroker.zigbee@1.4.4 --loglevel error --prefix "/opt/iobroker" (System call)
              ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:78:69: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:135:71: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:175:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:215:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
              ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:270:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
              ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:314:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
              ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:363:76: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:409:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^In file included from ../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:771:3: note: in expansion of macro 'NODE_MODULE_X'   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(serialport, init); ^~~~~~~~~~~
              ../src/serialport_unix.cpp: In function 'int setup(int, OpenBaton*)':../src/serialport_unix.cpp:176:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: 'snprintf' output 20 or more bytes (assuming 1043) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
              ../src/serialport_unix.cpp: In function 'void EIO_Open(uv_work_t*)':
              ../src/serialport_unix.cpp:86:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: 'snprintf' output 22 or more bytes (assuming 1045) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
              Update "system.adapter.zigbee.0"
              upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smart9_ts0043.png img/smart9_ts0043.png image/png
              upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_LCT002.png img/philips_hue_LCT002.png image/png
              upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_water-sensor.png img/lifecontrol_water-sensor.png image/png
              upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
              upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_spot.png img/gledopto_spot.png image/png
              upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e27_rgbw.png img/flair_viyu_e27_rgbw.png image/png
              upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ecozy.png img/ecozy.png image/png
              upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln1.png img/ctrl_ln1.png image/png
              upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
              upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZS232000178.png img/ZS232000178.png image/png
              upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_79809.png img/Paulmann_79809.png image/png
              upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
              upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
              upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
              upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
              upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
              upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
              upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
              upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
              upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
              upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
              upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
              upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
              upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
              upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
              upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
              upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
              upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
              upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
              upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
              upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
              upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
              Adapter "zigbee" updated
              host.iomaster Adapter "system.adapter.zigbee.0" is started
              process exited with code 0
              Thomas Braun arteck 2 Replies Last reply Reply Quote 0
                @amg_666 Biste sicher das da ein Linux läuft? 😄
                • amg_666
                  amg_666 @Thomas Braun last edited by
                  @thomas-braun Eben, bei meinem Windows PC hätt ich sowas garnicht erst gepostet sondern gleich aus/eingeschaltet....
                    @amg_666 ich vermute da lief noch ein zombie process .. deshalb der neustart.. schön
                      Mr.X @Mr.X last edited by
                      @mr-x sagte in ZigBee neue Version 1.4.4:
                      Hi, habe folgende Ledvance Smart+ "Kerzenlampen" mit E14 Sockel.
                      Die werden als Spots erkannt. Kachel zeigt auch die falsche Lampe an. also das Bilchen.
                      ON/OFF und Brightness gehen, aber die Farbtemperatur ändert sich nicht.
                      Auch kann ich die nicht über eine angelegte Gruppe gemeinsam steuern.
                      Adapter war vorhin auf 1.4 und habe ist nun auf 1.4.4. Bei beiden Versionen gleichen Bild.
                      All das ging mit "ähnlichen" Osram Birnen, aber die haben voll laut gefiept, wenn sie gedimmt waren.
                      Kann sich jemand hieraus einen Reim machen?
                        Holzlenkrad @arteck last edited by
                        @arteck sagte in ZigBee neue Version 1.4.4:
                        @Asgothian verbesserung des Pingprozesses - hier ist auch ein Button in den Objecten dazugekommen
                        Das Feature zum pullen der aktuellen Datenpunkte ist cool, danke dafür!
                        Kannst du einbauen, dass das in bestimmten Intervallen automatisch gemacht wird? Oder ist das nicht sinnvoll?
                        In jedem Fall finde ich aber dass es automatisch gemacht werden sollte, wenn Geräte über Zigbee-Gruppen geschaltet werden. Danach stimmen die Datenpunkte der Geräte der Gruppen leider nie (Tradfri Lampen bei mir).
                        Übrigens, kannst du dir noch mal den TS0121_plug angucken? Da wird weiterhin nur ein Endpoint (von zwei) verwendet.
                          arteck Developer Most Active @Holzlenkrad last edited by
                          @holzlenkrad sagte in ZigBee neue Version 1.4.4:
                          die Geräte melden sich immer automatisch .. damit kannst du es manuell antrigern..
                          an den Gruppen sind wir noch dran.. steht auf der Liste
                          was meinst du damit ?
                            Holzlenkrad @arteck last edited by Holzlenkrad
                            Ne, ich habe durchaus auch Geräte, die melden ihren Status gar nicht, wenn ich ihn nicht abfrage. Z.B. die genannten Tradfri-Lampen, wenn sie über Gruppen oder Fernbedienung geschaltet werden 😞
                            Dieser Zwischenstecker BW-SHP13 bzw. TS0121 hat ja zwei Switches eingebaut. Einen für die Steckdose (Nr. 1) und einen für die USB-Ports (Nr.2). Leider kann man derzeit nur den ersten Switch schalten.
                              klassisch Most Active @amg_666 last edited by
                              @amg_666 sagte in ZigBee neue Version 1.4.4:
                              Mein Win PC hat den zigbee Adapter ohne Probs und ohne Neustart oder Power reset upgedatet.
                              Und auch der "refresh" button funktioniert bei ikea Floalt Panels.
                              Herzlichen Dank dafür, kann ich sehr gut gebrauchen! Die Symfonisk rotary encoder arbeiten gut mit den Floalt, aber bisher halt undercover.
                                hast du es mit dem Tab "Ausschliessen" versucht...
                                  Ja, so funktioniert es. Danke.
                                  Fügst du denn für neue Hardware gar keine eigene Beschreibungen mehr hinzu, sodass man die Funktion "Ausschliessen" dann immer nutzen soll? Oder pflegst du den Zwischenstecker noch irgendwann ein?
                                  • Asgothian
                                    Asgothian Developer @Holzlenkrad last edited by
                                    Wie es bei genau diesem Zwischenstecker ist ist noch offen. Generell wollen wir möglichst wenig Geräte explizit bei uns definieren. Sofern die States bei in beiden Fällen vergleichbar sind (die die in beiden Fällen existieren) würde ich hier eher die vorhandene Definition im Adapter eliminieren wollen so das ein Eintrag in die Ausschlussliste nicht notwendig wird.
                                    A.
                                      beim pingen auf ein ikea Floalt L1529 bekomme ich eine Warnmeldung
                                      	warn	(3444) Failed to read state '"color_temp_startup"'of '0xbc33acfffed57c9d' after query with '{"code":134}'
                                      Der stat color_temp_startup steht auch nicht in der Objektliste
                                      • Asgothian
                                        Asgothian Developer @klassisch last edited by
                                        @klassisch
                                        Damit wirst Du (erst einmal) leben müssen. Die Implementierung des Floalt im Zigbee-Herdsman gibt an das das Panel diesen Parameter unterstützt, daher versucht die Funktion diesen auszulesen. Die Meldung "Code:134" kommt vom Gerät selber, und bedeutet "unsupported attribute", i.e. das Panel meldet das es diesen Wert nicht unterstützt.
                                        Es ist denkbar das in der Zukunft bestimmte Meldungen heraus gefiltert und dann nicht als Warnungen ausgegeben werden.
                                        A.
                                          Mr.X @Asgothian last edited by
                                          Funktioniert bei allen die Gruppenbildung?
                                          Mit meinen Ledvance Smart+ "Kerzenlampen" mit E14 Sockel. geht das nicht.
                                          und umwege über eine Gruppe in Alexa führt zu Diskolicht und/oder zu einzelnen Aussetzern.
                                          • Wieger Daniel
                                            Wieger Daniel last edited by Wieger Daniel
                                            sorry das ich euch hier evtl jetzt nerve 😕
                                            Mein setup: Mini PC mit Proxmox, iobroker in ner VM, CC26XXX Board
                                            Alle Adapter und das System selbst aktuell.
                                            Da der SOnoff Mini in der Stable Version als ??? angezeigt wurde und somit nicht erkant wurde, habe ich mir nun die Beta 1.4.4 geladen.
                                            Der Sonof wird erkannt.
                                            ABER...
                                            Ohne an der Hardware etwas geändert zu (der Sonof kam dazu!) sind nun einige meiner Lampen (Tradfri + Osram) nicht mehr erreichbar.
                                            Ein anlernen war möglich, danach aber nicht mehr erreichbar.
                                            Die Lampen wurden dort angelernt wo sie jetzt auch sind. - 1 Lampe ist ungefähr 3m vom Koordinator entfernt.
                                            Ja ich weis, der Screenshot bzw die Sendequalität ist nicht unbedingt korrekt, allerdings hatte ich mit 1.3.1 keine "Empfangsprobeme" und nun werden mir viele Geräte Orange und rot angezeigt?!
                                            Schalter Katze + Bett sowie die Lampe Katze liegen nebeneinander. Lampe funktioniert nicht - nicht erreichbar, Schalter aber schon?
                                            Platzl Licht ist eine Osram und macht Probleme (seit dem Update) liegt ca 6 Meter entfernt vom Koordinator
                                            Aromastudio Platzl ist eine Tradfri und liegt ungefähr 8 Meter NACH der Platzl Licht (ca 14Meter vom Koordinator entfernt) und macht derzeit keine Problem.. 😞
                                            evtl noch zu erwähnen: Gestern noch mit 1.3.1 war Kanal 11 mit 10% der beste kanal - alle andren lagen bei 50-80%
                                            Heute nach dem Update habe gar keinen Kanal mehr unter 70% - in einer 300 Einwohner Gemeinde mit alterdurchschnitt 70+
                                            Ich wäre dankbar, für hilfe um dieses Problem lösen zu können 🙂
                                            Wieger Daniel 1 Reply Last reply Reply Quote 0
                                            neue version zigbee zigbee neue version 1.4.0
                                            35
                                            302
                                            48023
