    4. Test Adapter tvprogram
      MCU @OliverIO last edited by MCU
      @oliverio Ist mir gerade aufgefallen:
      Auswahl vom 11.02.2021 12:00 bis 12.02.2021 00:00
      Anzeige: 11.11.2021 ?
      Auch mit anderen Einstellungen:
      Knallochse OliverIO 2 Replies Last reply Reply Quote 0
      • Knallochse
        Knallochse @MCU last edited by Knallochse
        @mcu das Feld Till:
        gibt es seit der Version 0.0.30 nicht mehr. Musst bestimmt einen Upload durchführen.
          MCU last edited by MCU
          @knallochse
          pi@raspberrypi:/opt/iobroker $ iobroker upload tvprogram
          upload [20] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/style.css style.css text/css
          upload [19] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/index.jsx src/index.jsx text/jsx
          upload [18] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/zh-cn.json src/i18n/zh-cn.json application/json
          upload [17] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/ru.json src/i18n/ru.json application/json
          upload [16] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/pt.json src/i18n/pt.json application/json
          upload [15] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/pl.json src/i18n/pl.json application/json
          upload [14] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/nl.json src/i18n/nl.json application/json
          upload [13] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/it.json src/i18n/it.json application/json
          upload [12] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/i18n.d.ts src/i18n/i18n.d.ts video/mp2t
          upload [11] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/fr.json src/i18n/fr.json application/json
          upload [10] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/es.json src/i18n/es.json application/json
          upload [9] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/en.json src/i18n/en.json application/json
          upload [8] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/de.json src/i18n/de.json application/json
          upload [7] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/components/settingslist.jsx src/components/settingslist.jsx text/jsx
          upload [6] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/components/settings.jsx src/components/settings.jsx text/jsx
          upload [5] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/app.jsx src/app.jsx text/jsx
          upload [4] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/index_m.html index_m.html text/html
          upload [3] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.js.map build/index.js.map application/json
          upload [2] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.js build/index.js application/javascript
          upload [1] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.css.map build/index.css.map application/json
          upload [0] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.css build/index.css text/css
          Adapter "system.adapter.vis.0" restarted.
          • OliverIO
            OliverIO @MCU last edited by OliverIO
            @mcu said in Test Adapter tvprogram:
            b
            ne der Fehler war echt auch in der aktuellen Version.
            da sieht man, das genau eine Klammer an der falschen Stelle, so etwas verursachen kann
            Fehler habe ich gerade behoben und auf github geladen, aber ohne neue Versionsnummer
            einfachnochmal neu runterladen
            iobroker upload tvprogram oder
            iobroker upload all
            musst trotzdem durchführen
              @oliverio Ja funktioniert. Super. Danke.
              Kleinigkeit noch: Farbe hinter den Logos ist dort noch grau, einheitlich weiß wäre schöner. Hast du ja auch beim Control geändert.
              • OliverIO
                Ich gebe selbst keine Farben vor, allerdings setze ich die Hintergrundfarbe des widgets, bzw. was weiter oben im HTML-Hierarchiebaum als Hintergrundfarbe gefunden wird.
                ich schau mal ob ich bei search noch etwas anderes mache wie bei control
                Edit: Hab grade nachgeschaut. Bei channel setze ich die Hintergrundfarbe. prüfe mal deine Widgeteinstellung, bo die gleich ist wie bei control
                  @oliverio Ja , das war es. Prima. Danke.
                  • OliverIO
                    und was machen wir nun?
                    Fehlt noch was?
                    Weitere Ideen`?
                    Chaot O 2 Replies Last reply Reply Quote 0
                    • Chaot
                      Chaot @OliverIO last edited by
                      @oliverio Waschmaschine vom Nachbarn deaktivieren wenn die Lieblingssendung läuft? 😀
                      Ne, ernsthaft: Alles läuft schön rund und ich kann bisher auch keine Fehler finden. Die Funktionen sind umfangreicher als ich ursprünglich erwartet habe. Ich verwende zwar die Aufnahmefunktion nicht, aber als Reminder ist das doch klasse aufgebaut.
                      Der Adapter hat das Script vollwertig ersetzt 👏 👏 Gute Arbeit.
                        McOnno last edited by McOnno
                        Ich habe gerade auf die 0.31 upgedatet und bekomme im Control keine Anzeige in der Vis!?
                        Im Vis-Editor sehe ich die Einträge allerdings.
                        Hier das Bild von der VIS: Vis-Anzeige.png
                        man sieht nur den Bereich der Favoriten, rechts ist gar nichts zu sehen...
                        Weiterhin wäre in der Suche ein Eintrag für Formel-1 ganz gut!
                        • O
                          Oli @OliverIO last edited by
                          @oliverio
                          ich bin vom Adapter voll begeistert, wenn du mir jetzt noch sagst, wie ich die Daten (Beginn, Ende, Beschreibung, Bild) des aktuell ausgewählten Programm, in extra Datenpunkte zum weiterverarbeiten bekomme. Bin ich wunschlos glücklich 🙂
                          Eigentlich fehlt nur noch eine zusätzliche Datenquelle, um die fehlenden TV Programme zu integrieren.
                          OliverIO 1 Reply Last reply Reply Quote 1
                          • OliverIO
                            OliverIO @McOnno last edited by
                            @mconno sagte in Test Adapter tvprogram:
                            bitte adapter (nicht nur die instanz) einmal komplett deinstallieren,
                            dann wieder installieren.
                            zur sicherheit auf der console
                            iobroker upload all
                            eingeben
                            bei allen widgets prüfen, ob der datenpunkt mit cmd des jeweiligen tvs am ende richtig ausgewählt wurde.
                            falls dann immer noch nicht, dann benötige ich die fehler aus der browser console
                            • OliverIO
                              OliverIO @Oli last edited by
                              @oli sagte in Test Adapter tvprogram:
                              @oliverio
                              was ist das aktuell ausgewählte Programm?
                              Über den javascript-Adapter kannst du alles abrufen:
                              https://github.com/oweitman/iobroker.tvprogram#getserverbroadcastnow
                              und in datenpunkte schreiben.
                                spaceduck last edited by
                                Ich hab mir gerade mal das Such-Widget eingerichtet... Wenn ich das Suchfeld antippe, dann kommt kurz das on-screen-keyboard hoch, verschwindet nach 1-2 sekunden und ich lande auf einem anderen view. Sehr komisch das ganze - ich vermute jedoch das liegt am System, nicht am Adapter. Ich verwende ein Xoro Megapad 2154 mit Android 7.1
                                Hat irgendwer hier noch so einen Effekt?
                                • OliverIO
                                  OliverIO @spaceduck last edited by
                                  @spaceduck sagte in Test Adapter tvprogram:
                                  mach mal zur sicherheit auf der konsole
                                  iobroker upload all
                                  evtl. hat sich da etwas verhakt. aber das er automatisch den view wechselt ist nicht normal
                                  • O
                                    @oliverio
                                    irgendwie mache ich hier was falsch und stoße als Laie wieder mal an meine Grenzen.
                                    Ich versuche per Script Daten aus deiner Liste für das aktuelle Programm in einen Datenpunkt zu schreiben
                                    let sender = getState("tvprogram.0.tv1.show").val
                                    sendTo("tvprogram.0","getServerBroadcastNow",[4],(data)=> setState("javascript.0.TV.Steuerung.Aktuelle Beschreibung",data.events.content.texts.VeryShort.value));
                                    sendTo("tvprogram.0","getServerBroadcastNow",[sender],(data)=>console.log(data));
                                    Wenn ich die Sendernummer durch eine Variable ersetze wird gar nichts angezeigt
                                    20:20:46.626	info	javascript.0 (22208) script.js.TV_Programm.Test: []
                                    Wenn ich versuche die Beschreibung in einen Datenpunkt zu schreiben, bekomme ich folgende Warnung
                                    20:20:46.625	warn	javascript.0 (22208) TypeError: Cannot read property 'content' of undefined at Object.sendTo [as cb] (script.js.TV_Programm.Test:2:130) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5297:71) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:234:41) at runCallback (timers.js:705:18) at tryOnImmediate (timers.js:676:5) at processImmediate (timers.js:658:5) at process.topLevelDomainCallback (domain.js:126:23)
                                    Was mache ich falsch?
                                    • OliverIO
                                      OliverIO @Oli last edited by OliverIO
                                      @oliverio
                                      ok,
                                      man muss ein array von channelids übergeben, soweit schon mal richtig.
                                      es müssen gültige channelids sein. soweit auch ok.
                                      die 4 steht für Radio Bremen
                                      Ansonsten kann man die channelids hier nachsehen
                                      sendTo("tvprogram.0","getServerData","channels",(data)=>console.log(data));
                                      Die Abfrage der Programmbeschreibung ist dann wie folgt
                                      sendTo("tvprogram.0","getServerBroadcastNow",[4],(data)=> console.log(data[0].events[0].content.texts.VeryShort.value))
                                      Da ich diverse Datenstrukturen immer wieder verwende, ist das Array die Auflistung der verschiedenen Sender und das zweite Array die Auflistung der verschiedenen Events/Sendungen. Bei dieser Funktion sollte da aber immer nur ein event enthalten sein.
                                      je nachdem wieviel channelids ich übergebe, können im ersten array auch mehrere elemente enthalten sein.
                                      Auch sind bei texts.VeryShort.value und texts.Long.value nicht immer Werte enthalten, so das das auch undefined sein kann. das muss man vorher prüfen.
                                      Manchmal gibt es nur VeryShort, manchmal nur Long, manchmal beides, manchmal keins.
                                      Zum prüfen kannst du folgenden Ausdruck verewenden:
                                      var content=(event.content.texts.Long.value) ? event.content.texts.Long.value:(event.content.texts.VeryShort.value)?event.content.texts.VeryShort.value:"";
                                      In der Variable event, muss natürlich auch das event enthalten sein.
                                      Wenn du eine Variable verwendest, dann muss diese auch eine echte Zahl sein und nicht ein String der eine Zahl enthält.
                                      Zur Sicherheit am besten so machen:
                                      sendTo("tvprogram.0","getServerBroadcastNow",[parseInt(sender)],(data)=>console.log(data));
                                      Man kann auch gern in den code der widgets reinschauen.
                                      Der ist hier zu finden:
                                      https://github.com/oweitman/ioBroker.tvprogram/blob/master/widgets/tvprogram/js/tvprogram.js
                                      Noch ein tip: zum besseren Verständnis von JSON-Datenstrukturen kann man das JSON kopieren und direkt in die Developer-Konsole im Browser kopieren. Man muss nur aufpassen, das man richtig kopiert, weil er falsche JSONS dann auch gleich anmeckert. Chrome zumindest zeigt dann die Datenstruktur dann schön zum klicken an. Wenn man das dann noch einer Variable zuweist, dann kann man dort auch den Propertypfad direkt ausprobieren. Das erspart einem einige Edit/Run/Fail/Repeat Schleifen
                                        Ash2k last edited by
                                        @oliverio sagte in Test Adapter tvprogram:
                                        1. time wird mit Uhrzeit im 24h-Format belegt, bspw 20:15:
                                          Es werden die Sendungen die zu dieser Uhrzeit laufen angezeigt.
                                          Ist die aktuelle Uhrzeit nach dieser Zeit, werden die Sendungen des nächsten Tages zu dieser Uhrzeit angezeigt. auch hier erfolgt automatisch die Aktualisierung.
                                        Wäre es möglich das anpassbar zu machen das er nach der aktuellen Zeit nicht direkt den nächsten Tag anzeigt?
                                        Ich habe eine Übersicht für 20:15 auf meiner Startseite, alle anderen Zeiten wie z.B. was läuft Jetzt, auf einer extra-Seite.
                                        Gehe ich nun um 20:16 auf die VIS seh ich auf der Startseite logischerweise schon den nächsten Tag und müsste dann erst auf die nächste Seite wechseln um zu sehen was jetzt gerade läuft.
                                        • OliverIO
                                          OliverIO @Ash2k last edited by
                                          @ash2k sagte in Test Adapter tvprogram:
                                          hm stimmt.
                                          ich würde ungern dafür ein weiteres Einstellfeld hinzufügen.
                                          mir würden 2 Möglichkeiten einfallen:
                                          1. folgende Notation
                                            20:15/120
                                            Bedeutet Anzeige für 20:15 für 120 Minuten
                                            Wenn diese Angabe fehlt, werden automatisch 120 Minuten angenommen
                                          Eingabe wie bisher, aber ab 00:00 Uhr wechselt es erst.
                                          Nachteil daran ist, wenn man hier bspw 10:00 Uhr einstellt, dann werden sehr lang die alten Sendungen noch angezeigt.
                                          ich bin für Variante 1)
                                          A 2 Replies Last reply Reply Quote 0
                                            Ash2k @OliverIO last edited by
                                            Ich auch 🙂
                                            Geht das jetzt schon so oder musst du es noch anpassen?
                                            adapter tvprogram vis widget
                                            51
                                            911
                                            258376
