      JCB last edited by
      Hello,
      I'm trying to add sensor measurements, which are posted by tasmota devices via MQTT.
      in ioBroker they do not appear as separated values (like temperature and humidity) but as json in the mqtt.0.tele.DVES_F5C6DC.SENSOR value:
      {"Time":"2021-02-15T17:09:43","BME280":{"Temperature":20.6,"Humidity":26.9,"DewPoint":0.9,"Pressure":1009.7},"PressureUnit":"hPa","TempUnit":"C"}
      I have to say, that currently ioBroker's MQTT instance is installed as client for fhem (I'm still in a testing stage). How can I access these values in the jarvis UI? I've tried "mqtt.0.tele.DVES_F5C6DC.SENSOR.BME280.Temperature" as "Datenpunkt" but it does not work. Any hints?
      Thanks
        MCU @JCB last edited by MCU
        @jcb I only have the german edition, so I hope you find the right in yours.
        So my testwert is your mqtt.0.tele.DVES_F5C6DC.SENSOR
        And my test is your temperature.
        So you make your own Datapoints for Temperature and so on, and so you can use it with jarvis.
          JCB @MCU last edited by
          @mcu
          Thank you for your quick help. Then I need to have a try with blocky. I thought I can access it directly.
          Cheers,
          Jens
            @jcb In javascript
            createState('0_userdata.0.temperature','',false, {read: true, write: true, name: "Temperature", type: "string", role: "text", def: "" });
            on({id: '0_userdata.0.testwert', change: "any"}, function (obj) {
                var test = JSON.parse(getState('0_userdata.0.testwert').val);
                var temp = String(test.BME280.Temperature);
                setState('0_userdata.0.temperature',temp);
              @mcu
              Thank You
                RkcCorian @MCU last edited by
                @mcu Vielen Dank für Deine Antwort! Leider nein, da ich daraus nicht sehe wie die Umsetzung gemacht wird 😞
                  abase21 last edited by
                  Custom HTML
                  ..habe derzeit ein Problem HTML in Jarvis darzustellen - ich generiere über ein Script eine Tabelle in html, diese wird dann auf einen Datenpunkt gelegt.
                  Wenn ich nun den Datenpunkt als CustomHtml einbinde, wird nur der Text angezeigt, dass HTML ist futsch.
                  Was habe ich übersehen?
                  RAW-Datenpunkt:
                  "user": "system.user.admin",
                  "ts": 1613042957410,
                  "common": {
                  "name": "Lampen-sind-An",
                  "role": "html",
                  "type": "mixed",
                  "desc": "Manuell erzeugt",
                  "def": "",
                  "read": true,
                  "write": true
                  "native": {},
                  "acl": {
                  "object": 1636,
                  "owner": "system.user.admin",
                  "state": 1636
                  "_id": "0_userdata.0.Lampen-sind-An",
                  "type": "state"
                  A 1 Reply Last reply Reply Quote -1
                    abase21 @abase21 last edited by abase21
                    @abase21 ..es funktioniert jetzt! Es lag an einem Script, dass ich mit dem HTML abgespeichert hatte. Das Script funktionierte - aber verursachte einige Effekte in Jarvis. Was ich beim Custom HTML gerne hätte, dass man das Modul trotzdem an einem Datenpunkt binden kann und etwas ausführen. Zum Beispiel habe ich nun meine Lampenliste (Lampen an) und möchte die Lampen nun ausschalten (Trigger an einem Datenpunkt gebunden). Das funktioniert alles prima, nur das ich hierzu 2 Widget anlegen muss, das sieht unschön aus. Das script das mir den Button angelegt hatte, hat zu komischen effekten in der Darstellung und laden des HTMLs geführt.
                      MCU last edited by
                      @zefau 2.2.0 beta-42
                      Sortierreihenfolge beim Kalender durcheinander:
                        MCU @RkcCorian last edited by
                        @markus-2 Und das?
                        https://forum.iobroker.net/topic/30668/jarvis-v2-1-0-just-another-remarkable-vis/3568
                          halbewurst last edited by
                          Hi Zusammen,
                          seit vorgestern stimmt irgendwas mit der synchronisation mit google nicht mehr. Hab mir schon einen Wolf gesucht aber ohne erfolg...
                          Ich habe 2 google kalender über den ical adapter eingebunden, jetzt sind auf einmal in Jarvis die Geburtstage alle einen Tag früher als diese wirklich sind. Gehe ich in VIS wird es korrekt angezeigt. Der Adapter denke ich mal kann es somit nicht sein. Der Google Kalender auch nicht. Ich vermute Jarvis aber hab keine Ahnung was dort nicht mehr passt.
                          Hat jemand ne Idee?
                          A Zefau 2 Replies Last reply Reply Quote 0
                            Ash2k @halbewurst last edited by
                            @halbewurst sagte in jarvis v2.1.0 - just another remarkable vis:
                            Hi Zusammen,
                            Hat jemand ne Idee?
                            https://github.com/Zefau/ioBroker.jarvis/issues/663
                            lies dich mal hier durch, vielleicht gleiches bzw. ähnliches Problem? Nicht vom Titel irritieren lassen, weiter unten im Beitrag steht was wegen Geburtstagen usw.
                            SWE1008 created this issue in Zefau/ioBroker.jarvis
                            closed Kalender Widget aktualisiert nicht #663
                            • Zefau
                              Zefau @halbewurst last edited by
                              Hat jemand ne Idee?
                              auch mit v2.2.0-beta.42?
                                @mcu
                                Danke für deine Hilfe. Das hat super geklappt.
                                • the-masterplan
                                  the-masterplan @Schaxxe last edited by the-masterplan
                                  @schaxxe said in jarvis v2.1.0 - just another remarkable vis:
                                  Entweder hab ich es überlesen oder nicht gefunden: Gibt es einen Trick, wie man Jarvis beibringen kann iFrames oder auch das Wetter auf die Ganze Breite eines iPads anzuzeigen? Bei mir wird das immer gequtescht und ich verliere Platz...Beim Wetter könnte ich auf Vollbild gehen, dann kann ich aber aufgrund des DarkMode nix mehr lesen.
                                  Bei meiner Stauansicht von Google Maps sehe ich auch nur ein kleines Fenster, das vielleicht 25% des Bildschirms nutzt..Wetter.jpg
                                  Ich habe jetzt auch eine Zeit lang mit der vernünftigen Einbindung von Google-Maps-Routen gehadert, habe es jetzt aber hinbekommen. Hatte es zunächst über iFrame eingebunden, aber dann wurde es wie bei dir nur in einem kleinen Mini-Streifen angezeigt. Dabei waren auch teilweise die Zeiten nicht zu sehen. Dann habe ich es über Custom-HTML versucht mit einem Datenpunkt, der den iframe aus google-maps enthält. Damit war dann die Anzeige super, aber bei Custom-HTML kann man leider keinen automatischen Refresh einstellen und somit musste man den Browser immer Refreshen, um die aktuellen Verkehrsdaten zu bekommen. Dann habe ich es noch einmal mit dem iframe probiert und alle möglichen Kombinationen ausprobiert und nun funktioniert es endlich wie ich es wollte inklusive Zoomen etc.:
                                  Dazu muss man unter Mindesthöhe eine feste Pixel-Anzahl eintragen. Die relative Festlegung der Höhe mit vh funktioniert hier irgendwie nicht und es wird immer nur dieser schmale Streifen einblendet, egal wie hoch das Widget selbst auch ist:
                                  So sieht das Ganze nun aus:
                                  Vielleicht hilft es ja jemandem, der wie ich fast dran verzewifelt wäre 🙂
                                  Zefau Schaxxe 2 Replies Last reply Reply Quote 1
                                  • the-masterplan
                                    the-masterplan @Zefau last edited by the-masterplan
                                    @zefau said in jarvis v2.1.0 - just another remarkable vis:
                                    @saibot1981 sagte in jarvis v2.1.0 - just another remarkable vis:
                                    Ist es geplant das man Videostreams der Kameras irgendwie als livestream angezeigt bekommt? Als iframe ist es ja leider immer so abgehackt.
                                    DisplayImage geht nicht? Was für einen Stream Video-Typ hast du denn?
                                    Nur mal zur Info und auch in der Hoffnung jemandem ein paar Stunden zu ersparen: ich nutze zwei Netatmo Presence Kameras. Der Stream dieser Kameras läuft über m3u8. Diesen Typ kann man über DisplayImage nicht einbinden. Ich habe das über ein Custom-HTML-Widget gelöst mit einem Zeichenketten-Datenpunkt der folgenden HTML-Code als Wert zugewiesen hat:
                                    <html>
                                    <head>
                                    <meta charset=utf-8 />
                                    <title>Your title</title>
                                      <link href="https://unpkg.com/video.js/dist/video-js.css" rel="stylesheet">
                                      <script src="https://unpkg.com/video.js/dist/video.js"></script>
                                      <script src="https://unpkg.com/videojs-contrib-hls/dist/videojs-contrib-hls.js"></script>
                                    </head>
                                    <body>
                                      <video height="500" id="Stellplatz" class="video-js vjs-fluid vjs-default-skin" controls preload="auto"
                                      data-setup='{}'>
                                        <source src="http://Lokale_IP_der_Kamera/erster_langer_Serial_code_hinter_der_IP_im_Stream_Datenpunkt/live/files/high/index.m3u8" type="application/x-mpegURL">
                                      </video>
                                    <script>
                                    var player = videojs('my_video_1');
                                    player.play();
                                    </script>
                                    </body>
                                    </html>
                                    Unter Source müssen dann nur die IP und der Schlüssel angepasst werden
                                    • Zefau
                                      Zefau @MCU last edited by
                                      @mcu sagte in jarvis v2.1.0 - just another remarkable vis:
                                      sollte mit v2.2.0-beta.43 passen
                                      • Zefau
                                        Zefau @the-masterplan last edited by
                                        @maximilian-garbe ich glaube wir sind (fast) Nachbarn 🙂
                                        the-masterplan 1 Reply Last reply Reply Quote 1
                                          MCU @Zefau last edited by
                                          @zefau Leider nein.
                                            Ash2k @MCU last edited by
                                            @zefau Leider nein.
                                            2.2.0-beta.43:
                                            Kalender auch bei mir falsche Sortierung:
                                            Scheinbar sortiert er jetzt genau andersrum als vorher bei z.B. 2.2.0-beta.39.
                                            316
                                            6126
                                            4115160
