    4. js-controller 3.2 jetzt im STABLE!
      apollon77 last edited by
      FAQ Platzhalter
      M1cS0w 1 Reply Last reply Reply Quote 0
      • M1cS0w
        M1cS0w @apollon77 last edited by M1cS0w
        @apollon77 Danke für die Info, leider läuft nach der Umstellung Zigbee nicht mehr: (auch mit fixer keine Abhilfe)
        zigbee.0	2021-02-18 22:50:05.929	error	(10153) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/a
        zigbee.0	2021-02-18 22:50:05.928	error	(10153) Failed to start Zigbee
        und
        zigbee.0	2021-02-18 22:50:24.622	error	(10153) Cannot read property 'getEntries' of null
        zigbee.0	2021-02-18 22:50:24.621	error	(10153) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/
        zigbee.0	2021-02-18 22:50:24.620	error	(10153) unhandled promise rejection: Cannot read property 'getEntries' of null
        zigbee.0	2021-02-18 22:50:24.620	error	(10153) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2021-02-18 22:50:24.620	info	(10153) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0	2021-02-18 22:50:24.620	info	(10153) terminating
        zigbee.0	2021-02-18 22:50:24.619	error	(10153) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman
        zigbee.0	2021-02-18 22:50:24.619	info	(10153) Zigbee: disabling joining new devices.
        zigbee.0	2021-02-18 22:50:24.618	info	(10153) cleaned everything up...
        zigbee.0	2021-02-18 22:50:24.617	info	(10153) Got terminate signal TERMINATE_YOURSELF
        Merkwürdig. Nach längerem Warten, ohne dass der Adapter von sich aus was hinbekommen hat, habe ich testweise nochmal neugestartet den Adapter und siehe da, aber wie kann das so plötzlich sein?
        zigbee.0	2021-02-18 22:54:27.960	warn	(16886) Failed to ping 0x7cb03eaa0a089c88 Plug 01
        zigbee.0	2021-02-18 22:54:04.783	info	(16886) Zigbee started
        zigbee.0	2021-02-18 22:54:04.783	info	(16886) 0x7cb03eaa0a0811ae (addr 41820): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:54:04.783	info	(16886) 0x000d6f000f83fdfc (addr 3170): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        zigbee.0	2021-02-18 22:54:04.782	info	(16886) 0x00158d00057b1828 (addr 52965): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2021-02-18 22:54:04.782	info	(16886) 0x00158d00053e7d88 (addr 18601): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2021-02-18 22:54:04.782	info	(16886) 0x00158d00044a15c1 (addr 62008): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2021-02-18 22:54:04.781	info	(16886) 0x00158d000445854a (addr 10435): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2021-02-18 22:54:04.781	info	(16886) 0xec1bbdfffec29d0f (addr 14513): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
        zigbee.0	2021-02-18 22:54:04.781	info	(16886) 0xbc33acfffe1510bf (addr 35016): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.0	2021-02-18 22:54:04.780	info	(16886) 0x04cf8cdf3c7d2ce0 (addr 21518): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
        zigbee.0	2021-02-18 22:54:04.780	info	(16886) 0x00158d000315b5db (addr 59562): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
        zigbee.0	2021-02-18 22:54:04.780	info	(16886) 0x00158d000355e582 (addr 21414): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
        zigbee.0	2021-02-18 22:54:04.779	info	(16886) 0x00158d0003132a08 (addr 970): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
        zigbee.0	2021-02-18 22:54:04.779	info	(16886) 0x7cb03eaa0a089c88 (addr 31999): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:54:04.779	info	(16886) 0xf0d1b80000133294 (addr 48522): AC10691 - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:54:04.778	info	(16886) 0x7cb03eaa0a0aafed (addr 35615): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:54:04.778	info	(16886) 0x7cb03eaa0a0aa382 (addr 6258): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:54:04.778	info	(16886) 0x7cb03eaa0a08a32e (addr 17499): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:54:04.777	info	(16886) 0x680ae2fffed62080 (addr 50928): GL-C-008P - Gledopto Zigbee LED Controller RGB+CCT (pro) (Router)
        zigbee.0	2021-02-18 22:54:04.777	info	(16886) 0x7cb03eaa0a0593f6 (addr 63108): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
        zigbee.0	2021-02-18 22:54:04.777	info	(16886) 0x84182600000f4a89 (addr 27339): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
        zigbee.0	2021-02-18 22:54:04.776	info	(16886) 0x7cb03eaa00ae16db (addr 8236): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
        zigbee.0	2021-02-18 22:54:04.776	info	(16886) 0x7cb03eaa00aa70c8 (addr 11160): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
        zigbee.0	2021-02-18 22:54:04.775	info	(16886) 0x000d6f000bb28d2b (addr 52301): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        zigbee.0	2021-02-18 22:54:04.775	info	(16886) 0x7cb03eaa00b117ce (addr 46981): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
        zigbee.0	2021-02-18 22:54:04.774	info	(16886) 0x7cb03eaa00aaf663 (addr 19580): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
        zigbee.0	2021-02-18 22:54:04.763	info	(16886) Currently 25 devices are joined:
        zigbee.0	2021-02-18 22:54:04.758	info	(16886) --> transmitPower : high
        zigbee.0	2021-02-18 22:54:04.757	info	(16886) Unable to disable LED, unsupported function.
        zigbee.0	2021-02-18 22:54:04.752	info	(16886) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20201113}}
        zigbee.0	2021-02-18 22:54:02.732	info	(16886) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
        zigbee.0	2021-02-18 22:54:02.633	info	(16886) Starting Zigbee npm ...
        zigbee.0	2021-02-18 22:54:02.599	info	(16886) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.2, js-controller: 3.2.16
        zigbee.0	2021-02-18 22:53:59.354	info	(16256) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0	2021-02-18 22:53:59.354	info	(16256) terminating
        zigbee.0	2021-02-18 22:53:58.854	info	(16256) Zigbee: disabling joining new devices.
        zigbee.0	2021-02-18 22:53:58.853	info	(16256) cleaned everything up...
        zigbee.0	2021-02-18 22:53:58.853	info	(16256) Got terminate signal TERMINATE_YOURSELF
        zigbee.0	2021-02-18 22:53:41.793	info	(16256) Zigbee started
        zigbee.0	2021-02-18 22:53:41.793	info	(16256) 0x7cb03eaa0a0811ae (addr 41820): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:53:41.792	info	(16256) 0x000d6f000f83fdfc (addr 3170): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        zigbee.0	2021-02-18 22:53:41.792	info	(16256) 0x00158d00057b1828 (addr 52965): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2021-02-18 22:53:41.792	info	(16256) 0x00158d00053e7d88 (addr 18601): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2021-02-18 22:53:41.791	info	(16256) 0x00158d00044a15c1 (addr 62008): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2021-02-18 22:53:41.791	info	(16256) 0x00158d000445854a (addr 10435): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2021-02-18 22:53:41.791	info	(16256) 0xec1bbdfffec29d0f (addr 14513): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
        zigbee.0	2021-02-18 22:53:41.790	info	(16256) 0xbc33acfffe1510bf (addr 35016): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        zigbee.0	2021-02-18 22:53:41.790	info	(16256) 0x04cf8cdf3c7d2ce0 (addr 21518): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
        zigbee.0	2021-02-18 22:53:41.790	info	(16256) 0x00158d000315b5db (addr 59562): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
        zigbee.0	2021-02-18 22:53:41.789	info	(16256) 0x00158d000355e582 (addr 21414): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
        zigbee.0	2021-02-18 22:53:41.789	info	(16256) 0x00158d0003132a08 (addr 970): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
        zigbee.0	2021-02-18 22:53:41.789	info	(16256) 0x7cb03eaa0a089c88 (addr 31999): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:53:41.788	info	(16256) 0xf0d1b80000133294 (addr 48522): AC10691 - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:53:41.788	info	(16256) 0x7cb03eaa0a0aafed (addr 35615): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:53:41.788	info	(16256) 0x7cb03eaa0a0aa382 (addr 6258): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:53:41.787	info	(16256) 0x7cb03eaa0a08a32e (addr 17499): AB3257001NJ - OSRAM Smart+ plug (Router)
        zigbee.0	2021-02-18 22:53:41.787	info	(16256) 0x680ae2fffed62080 (addr 50928): GL-C-008P - Gledopto Zigbee LED Controller RGB+CCT (pro) (Router)
        zigbee.0	2021-02-18 22:53:41.787	info	(16256) 0x7cb03eaa0a0593f6 (addr 63108): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
        zigbee.0	2021-02-18 22:53:41.786	info	(16256) 0x84182600000f4a89 (addr 27339): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
        zigbee.0	2021-02-18 22:53:41.786	info	(16256) 0x7cb03eaa00ae16db (addr 8236): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
        zigbee.0	2021-02-18 22:53:41.785	info	(16256) 0x7cb03eaa00aa70c8 (addr 11160): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
        zigbee.0	2021-02-18 22:53:41.785	info	(16256) 0x000d6f000bb28d2b (addr 52301): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
        zigbee.0	2021-02-18 22:53:41.784	info	(16256) 0x7cb03eaa00b117ce (addr 46981): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
        zigbee.0	2021-02-18 22:53:41.784	info	(16256) 0x7cb03eaa00aaf663 (addr 19580): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
        zigbee.0	2021-02-18 22:53:41.774	info	(16256) Currently 25 devices are joined:
        zigbee.0	2021-02-18 22:53:41.768	info	(16256) --> transmitPower : high
        zigbee.0	2021-02-18 22:53:41.768	info	(16256) Unable to disable LED, unsupported function.
        zigbee.0	2021-02-18 22:53:41.762	info	(16256) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20201113}}
        zigbee.0	2021-02-18 22:53:39.733	info	(16256) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
        zigbee.0	2021-02-18 22:53:39.675	info	(16256) Starting Zigbee npm ...
        zigbee.0	2021-02-18 22:53:39.641	info	(16256) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.2, js-controller: 3.2.16
        zigbee.0	2021-02-18 22:53:35.957	error	(11248) Cannot read property 'getEntries' of null
        zigbee.0	2021-02-18 22:53:35.957	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
        zigbee.0	2021-02-18 22:53:35.957	error	at Zigbee.emit (events.js:314:20)
        zigbee.0	2021-02-18 22:53:35.957	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:513:41)
        zigbee.0	2021-02-18 22:53:35.957	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:307:20)
        zigbee.0	2021-02-18 22:53:35.957	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:190:42)
        zigbee.0	2021-02-18 22:53:35.957	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:210:43)
        zigbee.0	2021-02-18 22:53:35.957	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:204:49)
        zigbee.0	2021-02-18 22:53:35.957	error	at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:273:31)
        zigbee.0	2021-02-18 22:53:35.957	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
        zigbee.0	2021-02-18 22:53:35.957	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
        zigbee.0	2021-02-18 22:53:35.957	error	(11248) TypeError: Cannot read property 'getEntries' of null
        zigbee.0	2021-02-18 22:53:35.956	error	(11248) unhandled promise rejection: Cannot read property 'getEntries' of null
        zigbee.0	2021-02-18 22:53:35.956	error	(11248) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2021-02-18 22:53:35.955	info	(11248) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0	2021-02-18 22:53:35.955	info	(11248) terminating
        zigbee.0	2021-02-18 22:53:35.955	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:311:33))
        zigbee.0	2021-02-18 22:53:35.955	error	at Controller.stop (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:219:16)
        zigbee.0	2021-02-18 22:53:35.955	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
        zigbee.0	2021-02-18 22:53:35.955	error	at new Promise (<anonymous>)
        zigbee.0	2021-02-18 22:53:35.955	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
        zigbee.0	2021-02-18 22:53:35.955	error	at Generator.next (<anonymous>)
        zigbee.0	2021-02-18 22:53:35.955	error	at Controller.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:221:18)
        zigbee.0	2021-02-18 22:53:35.955	error	at Controller.databaseSave (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:240:45)
        zigbee.0	2021-02-18 22:53:35.955	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
        zigbee.0	2021-02-18 22:53:35.955	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
        zigbee.0	2021-02-18 22:53:35.955	error	(11248) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
        zigbee.0	2021-02-18 22:53:35.954	info	(11248) Zigbee: disabling joining new devices.
        zigbee.0	2021-02-18 22:53:35.953	info	(11248) cleaned everything up...
        zigbee.0	2021-02-18 22:53:35.952	info	(11248) Got terminate signal TERMINATE_YOURSELF
        zigbee.0	2021-02-18 22:50:58.125	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
        zigbee.0	2021-02-18 22:50:58.125	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        zigbee.0	2021-02-18 22:50:58.125	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
        zigbee.0	2021-02-18 22:50:58.125	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
        zigbee.0	2021-02-18 22:50:58.125	error	at new Promise (<anonymous>)
        zigbee.0	2021-02-18 22:50:58.125	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
        zigbee.0	2021-02-18 22:50:58.125	error	at Generator.next (<anonymous>)
        zigbee.0	2021-02-18 22:50:58.125	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
        zigbee.0	2021-02-18 22:50:58.125	error	(11248) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
        zigbee.0	2021-02-18 22:50:58.124	error	(11248) Failed to start Zigbee
        zigbee.0	2021-02-18 22:50:58.022	info	(11248) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
        zigbee.0	2021-02-18 22:50:58.015	info	(11248) Starting Zigbee npm ...
        zigbee.0	2021-02-18 22:50:58.014	info	(11248) Try to reconnect. 1 attempts left
        zigbee.0	2021-02-18 22:50:48.012	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
        zigbee.0	2021-02-18 22:50:48.012	error	at Generator.throw (<anonymous>)
        zigbee.0	2021-02-18 22:50:48.012	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
        zigbee.0	2021-02-18 22:50:48.012	error	(11248) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
        zigbee.0	2021-02-18 22:50:48.012	error	(11248) Failed to start Zigbee
        zigbee.0	2021-02-18 22:50:28.466	info	(11248) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
        zigbee.0	2021-02-18 22:50:28.409	info	(11248) Starting Zigbee npm ...
        zigbee.0	2021-02-18 22:50:28.374	info	(11248) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.2, js-controller: 3.2.16
        zigbee.0	2021-02-18 22:50:24.621	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
        zigbee.0	2021-02-18 22:50:24.621	error	at Zigbee.emit (events.js:314:20)
        zigbee.0	2021-02-18 22:50:24.621	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:513:41)
        zigbee.0	2021-02-18 22:50:24.621	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:307:20)
        zigbee.0	2021-02-18 22:50:24.621	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:190:42)
        zigbee.0	2021-02-18 22:50:24.621	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:210:43)
        zigbee.0	2021-02-18 22:50:24.621	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:204:49)
        zigbee.0	2021-02-18 22:50:24.621	error	at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:273:31)
        zigbee.0	2021-02-18 22:50:24.621	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
        zigbee.0	2021-02-18 22:50:24.621	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
        zigbee.0	2021-02-18 22:50:24.619	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:311:33))
        zigbee.0	2021-02-18 22:50:24.619	error	at Controller.stop (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:219:16)
        zigbee.0	2021-02-18 22:50:24.619	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
        zigbee.0	2021-02-18 22:50:24.619	error	at new Promise (<anonymous>)
        zigbee.0	2021-02-18 22:50:24.619	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
        zigbee.0	2021-02-18 22:50:24.619	error	at Generator.next (<anonymous>)
        zigbee.0	2021-02-18 22:50:24.619	error	at Controller.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:221:18)
        zigbee.0	2021-02-18 22:50:24.619	error	at Controller.databaseSave (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:240:45)
        zigbee.0	2021-02-18 22:50:24.619	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
        zigbee.0	2021-02-18 22:50:24.619	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
        zigbee.0	2021-02-18 22:50:16.060	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
        zigbee.0	2021-02-18 22:50:16.060	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        zigbee.0	2021-02-18 22:50:16.060	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
        zigbee.0	2021-02-18 22:50:16.060	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
        zigbee.0	2021-02-18 22:50:16.060	error	at new Promise (<anonymous>)
        zigbee.0	2021-02-18 22:50:16.060	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
        zigbee.0	2021-02-18 22:50:16.060	error	at Generator.next (<anonymous>)
        zigbee.0	2021-02-18 22:50:16.060	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
        zigbee.0	2021-02-18 22:50:16.060	error	(10153) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
        zigbee.0	2021-02-18 22:50:16.060	error	(10153) Failed to start Zigbee
        zigbee.0	2021-02-18 22:50:15.936	info	(10153) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
        zigbee.0	2021-02-18 22:50:15.930	info	(10153) Starting Zigbee npm ...
        zigbee.0	2021-02-18 22:50:15.929	info	(10153) Try to reconnect. 1 attempts left
        zigbee.0	2021-02-18 22:50:05.929	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
        zigbee.0	2021-02-18 22:50:05.929	error	at Generator.throw (<anonymous>)
        zigbee.0	2021-02-18 22:50:05.929	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
        zigbee.0	2021-02-18 22:49:46.367	info	(10153) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
        zigbee.0	2021-02-18 22:49:46.310	info	(10153) Starting Zigbee npm ...
        zigbee.0	2021-02-18 22:49:46.280	info	(10153) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.2, js-controller: 3.2.16
          apollon77 @M1cS0w last edited by
          @m1cs0w Da musst Du dich leider an die Devs vom Zigbee Adapter wenden, der Fehler kommt irgendwo "tief" aus einer Lib des zigbee adapters und hat für mich gerade wenig mit dem Controller zu tun!
          • M1cS0w
            @apollon77 oh ok alles klar danke. Hatte bislang dieses rebuild überhaupt nicht vernommen. Daher nach dem Update zufällig erst jetzt feststellen müssen.
            Danke für die prompte Rückmeldung.
            • Nashra
              Danke für die gute Arbeit an @apollon77 und alle anderen Beteiligten, es läuft 👍
                Ahnungsbefreit @apollon77 last edited by
                @apollon77 said in js-controller 3.2 jetzt im STABLE!:
                Guten Morgen,
                ich konnte das Update soweit komplett problemlos durchführen, es scheint auch alles zu laufen, vielen Dank für die tolle Arbeit! Nur bekomme ich jetzt alle paar Minuten die folgende Meldung im Log:
                18073) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
                Setup:
                VM unter Proxmox auf NUC:
                Node.js v12.20.2
                NPM 6.14.11
                Was will mir das sagen? Ignorieren?
                Thomas
                  apollon77 @Ahnungsbefreit last edited by
                  @ahnungsbefreit hast Du oben den Text gelesen? 😉
                  Schau mal ob es ein hm-rega update gibt
                    @apollon77 hm-rega update habe ich auch gemacht und ja, den Text oben habe ich gelesen aber scheinbar den entscheidenden Hinweis übersehen. Soll ich jetzt ein Issue für den hm-rega (oder hm-rpc?) aufmachen, willst Du mir das damit sagen?
                    O apollon77 2 Replies Last reply Reply Quote 0
                    • O
                      oFbEQnpoLKKl6mbY5e13 @Ahnungsbefreit last edited by oFbEQnpoLKKl6mbY5e13
                      @ahnungsbefreit
                      Das war zu erwarten. Der JS-Controller wird zu Stable und die angepassten Adapter sind noch in Latest...
                      Das Problem ist behoben, nur wird dir die korrigierte Version nicht angeboten.
                      Edit:
                      Der zweite Satz kann so verstanden werden, dass ich grundsätzlich das Vorgehen kritisiere. Das war unglücklich formuliert. Natürlich kann es immer mal sein, dass ein Adapter mal nicht zur rechten Zeit im Stable landet. So war es gemeint.
                      A apollon77 2 Replies Last reply Reply Quote -1
                        Ahnungsbefreit @oFbEQnpoLKKl6mbY5e13 last edited by
                        @ofbeqnpolkkl6mby5e13 ok danke, dann übe ich mich in Geduld 🙂
                          apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
                          @ofbeqnpolkkl6mby5e13 Das ist nicht wahr. Ich habe gestern einen ganzen Satz Adapter die "Bekannt" waren mit ins Stable geschoben. Sorry aber keinen Blödsinn erzählen 😉
                            @ahnungsbefreit Naja entweder hm-rpc oder hm-rega - jendachdem was im log steht, das hast Du leider abgeschnitten gehabt.
                            Und wie es oben im text steht ein Issue anlegen beim Adapter wenn eine solche Meldung kommt
                              Ahnungsbefreit @apollon77 last edited by Ahnungsbefreit
                              @apollon77 Die Meldung kam vom hm-rpc. Dann lege ich mal ein Issue an..
                              Edit: Siehe https://github.com/ioBroker/ioBroker.hm-rpc/issues/309
                              ahnungsbefreit created this issue in ioBroker/ioBroker.hm-rpc
                              closed Error 'State "hm-rpc.1.CENTRAL.0.PONG" has no existing object' since update to js-controller 3.2 #309
                                loi83 @Ahnungsbefreit last edited by
                                @ahnungsbefreit ich hab das selbe Problem. Mit dem Update aus dem Latest ist das Problem erstmal weg.
                                • O
                                  oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                                  @apollon77 sagte in js-controller 3.2 jetzt im STABLE!:
                                  Wieso Blödsinn?
                                  Der HM-RPC ist in Stable bei 1.14.24. Muss für den JS-Controller aber mindestens
                                  1.14.29 (2021-01-09) (foxriver76) do not set PONG state anymore
                                  haben.
                                    @ofbeqnpolkkl6mby5e13 In dam Fall nehme ich alles zurück ... Wir hatten gestern die Devs abgefragt was ins Stable muss und da wurde der wohl übersehen 🙂
                                    O A 2 Replies Last reply Reply Quote -1
                                    • O
                                      @apollon77
                                      Kein Problem! 👍
                                        @apollon77 ...und schon ist das Update in Stable! Jungs, Ihr seid der Hammer!!!
                                          sandro_gera @apollon77 last edited by sandro_gera
                                          @apollon77
                                          Sorry wenn ich mal so dumm frage, aber ich will nichts falsch machen. Ich habe nach dem Stoppen das ioBrokers und der Überprüfung mit den Befehlen ps auxww|grep io , ps auxww|grep backup folgende Ausgabe erhalten.
                                          pi@RaspBerry4BioBroker:~ $ ps auxww|grep io
                                          root        13  0.0  0.0      0     0 ?        S    14:40   0:00 [migration/0]
                                          root        16  0.0  0.0      0     0 ?        S    14:40   0:00 [migration/1]
                                          root        21  0.0  0.0      0     0 ?        S    14:40   0:00 [migration/2]
                                          root        26  0.0  0.0      0     0 ?        S    14:40   0:00 [migration/3]
                                          root        58  0.0  0.0      0     0 ?        I<   14:40   0:00 [blkcg_punt_bio]
                                          root        62  0.0  0.0      0     0 ?        I<   14:40   0:00 [rpciod]
                                          root        64  0.0  0.0      0     0 ?        I<   14:40   0:00 [xprtiod]
                                          root        66  0.0  0.0      0     0 ?        I<   14:40   0:00 [nfsiod]
                                          root        72  0.0  0.0      0     0 ?        I<   14:40   0:00 [DWC Notificatio]
                                          message+   354  0.0  0.0   6548  3000 ?        Ss   14:40   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                          avahi      372  0.0  0.0   5904  2528 ?        Ss   14:40   0:00 avahi-daemon: running [RaspBerry4BioBroker.local]
                                          root       724  0.0  0.0      0     0 ?        I<   14:40   0:00 [cifsiod]
                                          pi        1825  0.0  0.0   7360   492 pts/0    S+   14:51   0:00 grep --color=auto io
                                          pi@RaspBerry4BioBroker:~ $ ps auxww|grep backup
                                          pi        1827  0.0  0.0   7360   508 pts/0    S+   14:51   0:00 grep --color=auto backup
                                          Jetzt bin ich nicht sicher ob wirklich alles gestoppt ist.
                                          Wenn nicht was muß ich noch machen damit alle Prozesse gestopt werden?
                                            apollon77 @sandro_gera last edited by
                                            @sandro_gera ist alles gestoppt
                                            S 2 Replies Last reply Reply Quote 1
                                            275
                                            77000
