    • simatec
      simatec Developer Most Active @sigi234 last edited by
      @sigi234
      Denke im Windows unter Eigenschaften der Datei ... Bin mehr Linux 😋
        passuff @simatec last edited by passuff
        Wie kann ich manuell ein influxdb backup anstoßen? Ich möchte meine Konfiguration testen.
        EDIT: wird beim normalen iobroker backup angestoßen.
        • simatec
          simatec Developer Most Active @passuff last edited by
          @passuff
          Genau ... alle Feature Backups werden mit dem iobroker Backup ausgeführt
          • David G.
            seit ein paar Tagen läuft das Backup nicht mehr.
            Folgendes steht im Log:
            backitup.0
             close	Zeit
            debug
            Meldung
            backitup.0	2021-02-07 11:00:31.338	error	--- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix"
            backitup.0	2021-02-07 11:00:31.338	error	| index 0 -> object with constructor 'DailyRotateFile'
            backitup.0	2021-02-07 11:00:31.338	error	| property 'pipes' -> object with constructor 'Array'
            backitup.0	2021-02-07 11:00:31.338	error	| property '_readableState' -> object with constructor 'ReadableState'
            backitup.0	2021-02-07 11:00:31.338	error	--> starting at object with constructor 'DerivedLogger'
            backitup.0	2021-02-07 11:00:31.338	error	(780) [iobroker] error on backup process: Script "umount" TypeError: Converting circular structure to JSON
            backitup.0	2021-02-07 11:00:31.185	error	(780) [iobroker] error on backup process: Script "history" SyntaxError: Unexpected token u in JSON at position 0 Please check the config of backitup and execute "iobroker fix"
            backitup.0	2021-02-07 11:00:31.183	error	(780) [iobroker] cannot parse config for history!!
            backitup.0	2021-02-07 11:00:30.880	error	(780) [iobroker] error on backup process: Script "telegram" SyntaxError: Unexpected token u in JSON at position 0 Please check the config of backitup and execute "iobroker fix"
            backitup.0	2021-02-07 11:00:30.878	error	(780) [iobroker] cannot parse config for telegram!!
            backitup.0	2021-02-07 11:00:20.725	error	--- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix"
            backitup.0	2021-02-07 11:00:20.725	error	| index 0 -> object with constructor 'DailyRotateFile'
            backitup.0	2021-02-07 11:00:20.725	error	| property 'pipes' -> object with constructor 'Array'
            backitup.0	2021-02-07 11:00:20.725	error	| property '_readableState' -> object with constructor 'ReadableState'
            backitup.0	2021-02-07 11:00:20.725	error	--> starting at object with constructor 'DerivedLogger'
            backitup.0	2021-02-07 11:00:20.725	error	(780) [iobroker] error on backup process: Script "cifs" TypeError: Converting circular structure to JSON
            backitup.0	2021-02-07 11:00:10.172	error	--- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix"
            backitup.0	2021-02-07 11:00:10.172	error	| index 0 -> object with constructor 'DailyRotateFile'
            backitup.0	2021-02-07 11:00:10.172	error	| property 'pipes' -> object with constructor 'Array'
            backitup.0	2021-02-07 11:00:10.172	error	| property '_readableState' -> object with constructor 'ReadableState'
            backitup.0	2021-02-07 11:00:10.172	error	--> starting at object with constructor 'DerivedLogger'
            backitup.0	2021-02-07 11:00:10.172	error	(780) [iobroker] error on backup process: Script "iobroker" TypeError: Converting circular structure to JSON
            backitup.0	2021-02-07 11:00:10.017	error	--- property 'parent' closes the circle Please check the config of backitup and execute "iobroker fix"
            backitup.0	2021-02-07 11:00:10.017	error	| index 0 -> object with constructor 'DailyRotateFile'
            backitup.0	2021-02-07 11:00:10.017	error	| property 'pipes' -> object with constructor 'Array'
            backitup.0	2021-02-07 11:00:10.017	error	| property '_readableState' -> object with constructor 'ReadableState'
            backitup.0	2021-02-07 11:00:10.017	error	--> starting at object with constructor 'DerivedLogger'
            backitup.0	2021-02-07 11:00:10.017	error	(780) [iobroker] error on backup process: Script "mount" TypeError: Converting circular structure to JSON
            Hat jemand eine Idee, woran das liegen kann?
            An den Settings habe ich nichts geändert.
            EDIT:
            Hab grad iobroker fix drüber laufen lassen.
            Das manuelle Backup hat jetzt geklappt, morgen mal das automatische Backup abwarten.
            Was das wohl war, wenn es dann klappt....
            • simatec
              simatec Developer Most Active @David G. last edited by
              @david-g
              Gast du eventuell ein js-controller Update gefahren?
              • David G.
                David G. @simatec last edited by
                @simatec
                Nein, hab ich nicht.
                • simatec
                  @david-g
                  iobroker fix behebt in der Regel alle Probleme mit Rechten.
                  • simatec
                    Ab sofort steht die Version 2.0.0 auf Github und in Kürze auch im latest (Beta) bereit.
                    Changelog
                    2.0.0 (31.01.2021)
                    • (simatec) BugFix detect last backup
                    • (simatec) WebDAV added
                    • (simatec) BugFix Zigbee
                    • (simatec) stop/start Instances on restore
                    • (simatec) Download Icon for Cloud Restore added
                    • (simatec) javscript Backup added
                    • (simatec) Grafana Backup added
                    • (simatec) Restore added for some types without restart
                    • (simatec) timestamp for history-json added
                    • (simatec) Source code rewritten
                    • (simatec) Restore revised
                    • (simatec) fixed many small bugs
                    • (simatec) Added warning messages
                    • (simatec) Fixed cloud restore
                    • JB_Sullivan
                      JB_Sullivan last edited by
                      Vielen Dank für diese neue Version - funktioniert sehr gut. Geil finde ich auch das Grafana mit dabei ist 👍 👍 👍 👍
                      • simatec
                        simatec Developer Most Active @JB_Sullivan last edited by
                        @jb_sullivan
                        Dankeschön... viel Spaß damit
                        • Diginix
                          Diginix last edited by Diginix
                          @simatec
                          Seit v2 erhalte ich keine Telegram Benachrichtigung nach erfolgreichem Backup.
                          Meine Einstellungen sehen so aus und habe bis einschl. v1.8 immer funktioniert:
                          Wenn ich das Empfänger Dropdown aufklappe sehe ich merkwürdige "firstname" Einträge. Eigentlich gibt es nur 2 Telegram Kontakte. Der 2 fehlt komplett.
                          Im Log sehe ich dann:
                          telegram.0	2021-02-24 00:30:32.996	warn	(3670) 1 of 1 recipients are unknown!
                          Ich habe extra in Telegram den Empfänger gelöscht und wieder neu angelegt.
                          Hilft aber nicht.
                          Nur wenn ich "alle Empfänger" wähle, bekomme ich eine Benachrichtigung.
                          • simatec
                            simatec Developer Most Active @Diginix last edited by
                            @diginix
                            Das liegt nicht an Backitup.
                            Backitup holt sich deine angelegten User aus dem Objekt "telegram.0.communicate.users"
                            Hier sollte der Wert wie folgt aussehen:
                            {"12345678":"username"}
                            • Diginix
                              Diginix @simatec last edited by
                              @simatec Soweit klar, aber da passt mMn alles. Ich kann in Skripten alle oder einen der 2 Empfänger auswählen und die Nachrichten werden korrekt zugestellt.
                              {"123456789":{"firstName":"Tom","userName":"Diginix"},"987654321":{"firstName":"Martina","userName":""}}
                              Hat sich seit Telegram 1.8 da vllt was geändert und backitup muss das anders Parsen?
                              • simatec
                                @diginix sagte in Test Adapter Backitup v2.0.x:
                                editiere mal deinen Datenpunkt wie folgt:
                                {"123456789":"Tom","987654321":"Martina"}
                                Ich denke so sollte es wieder passen
                                • Diginix
                                  Diginix @simatec last edited by Diginix
                                  @simatec Ich kann doch die "neue" Telegram Struktur nicht manuell überschreiben.
                                  Ich habe mal alle Empfänger gelöscht, danach ist der DP leer. Wenn ich mich per /start im Bot wieder hinzufüge, steht sofort:
                                  {"123456789":{"firstName":"Tom","userName":"Diginix"}}
                                  im DP.
                                  Ich editiere doch da jetzt nicht immer dran rum, nur damit backitup klar kommt. Das ist doch die falsche Herangehensweise.
                                  In Telegram ist folgendes eingestellt, war aber auch schon vor Monaten so und funktionierte damals mit backitup. In Skripten nutze ich auch schon immer Vornamen. Will das also nicht nur für backitup nun alles ändern müssen.
                                  Backitup hat in der Kontaktauswahl ja den username "Diginix" stehen, übergibt den aber vllt mittlerweile falsch an Telegram?
                                  Anders kann ich mir "1 of 1 recipients are unknown!" im Log nicht erklären.
                                  simatec 2 Replies Last reply Reply Quote 0
                                  • simatec
                                    Das hat auch keiner gesagt ... Backitup braucht da keine spezielle Struktur, sondern nutzt die Daten aus Telegram.
                                    Keine Ahnung, was du da genau machst, aber bei anderen Usern funktioniert es ja auch ohne editieren
                                    • simatec
                                      @diginix
                                      Anbei mal Screenshots, wie es bei mir ausschaut und problemlos funktioniert
                                      Telegram:
                                      Backitup:
                                      Da ist nirgends was editiert oder sonstiges ...
                                      • Diginix
                                        @simatec Du hast ja auch den Haken "Username statt Vornamen" aktiv. Das will ich aber nicht und war bisher auch nicht nötig. Ich möchte in Skripten die Vornamen als Empfänger bei sendto Telegram nutzen.
                                        D.h. backitup setzt zwingend diese Einstellung in Telegram voraus und ist dahin gehend nicht neutral, kommt also mit dem anderen JSON nicht klar und dieser Bug wird auch nicht gefixt?
                                        • simatec
                                          @simatec Du hast ja auch den Haken "username statt Vornamen" aktiv. Das will ich aber nicht und war bisher auch nicht nötig.
                                          D.h. backitup setzt zwingend diese Einstellung in Telegram voraus und ist dahin gehend nicht neutral?
                                          Auch das habe ich nicht geschrieben ... Das sind lediglich meine Settings ... Interpretiere doch hier bitte nicht irgendwas rein.
                                          Backitup liest lediglich die vorhandenen Daten aus dem Objekt des Telegram Adapters aus und verwendet diese
                                          Backitup setzt nichts voraus ...
                                          • Diginix
                                            @simatec Sorry, aber das war von mir nur eine konsequente Schlussfolgerung.
                                            Mit Einstellung "Vornamen" geht es nicht, mit "username" schon.
                                            Demnach funktioniert es aktuell nicht generisch. Du gehst ja bisher wenig analytisch auf meine Inhalte ein. Ein Satz wie "ich prüfe das" oder ähnliches würde mir schon helfen. Wenn du keine Zeit hast, auch ok. Aber bisher ist immer noch unklar ob es ein rein lokales Problem bei mir ist oder doch ein Bug. Irgend etwas scheint beim Auslesen des Objektes nicht zu passen wenn dort nicht nur "username:value" enthalten ist. Dein Vorschlag war, das hart zu editieren. Das ist aber bei DP von Adaptern eine eher unsaubere Art und auch nicht persistent.
                                            Ich kann gern auch ein issue auf git öffnen aber auch da würde ich auf einen Satz mehr von dir warten.
                                            170
                                            2780
                                            2343928
