    4. Tr-064 adapter kann icht installiert werden
    UNSOLVED Tr-064 adapter kann icht installiert werden
      Goldenbaum @haselchen last edited by Goldenbaum
      @haselchen Ja es läuft jetzt ...```
      das Problem des updaten habe ich zwar immer noch, aber evtl. löst sich das problem mit der zeit von selbst...
      $ ./iobroker upgrade tr-064
      Update tr-064 from @4.0.1 to @4.0.9
      NPM version: 6.14.4npm install iobroker.tr-064@4.0.9 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/nodenpm ERR! errno -13npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node']npm ERR! stack:npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node'',npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'access',npm ERR! path:npm ERR! '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-11-06T10_01_06_289Z-debug.log
      ERROR: host.ioBrokerCT Cannot install iobroker.tr-064@4.0.9: 243
      ERROR: process exited with code 25
      haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @Goldenbaum last edited by
        @Goldenbaum
        Das ist ein Rechteproblem .
        Da ist @Thomas-Braun der Experte.
          Thomas Braun Most Active @Goldenbaum last edited by
          @Goldenbaum sagte in Tr-064 adapter kann icht installiert werden:
          An spontane Selbstheilung glaubt keiner.
          Da musst du mal ran.
          iobroker fix
          im Terminal ausführen.
            Goldenbaum @Thomas Braun last edited by
            @Thomas-Braun sagte in Tr-064 adapter kann icht installiert werden:
            iobroker fix
            /opt/iobroker$ iobroker fix
            library: loaded
            Library version=2020-06-12
            ioBroker or some processes are still running:
            io.discovery.0
            io.info.0
            io.tankerkoenig.0
            io.terminal.0
            io.pollenflug.0
            io.ping.0
            io.backitup.0
            io.fritzbox.0
            io.sql.0
            io.sonoff.0
            io.fullybrowser.0
            io.trashschedule.0
            io.shelly.0
            io.history.0
            io.proxmox.0
            io.web.0
            io.text2command.0
            io.telegram.1
            io.telegram.0
            io.cloud.0
            io.upnp.0
            io.unifi.0
            io.harmony.0
            io.javascript.0
            io.mihome.0
            io.alexa2.0
            io.admin.0
            Please stop them first and try again!
            /opt/iobroker$
              Thomas Braun Most Active @Goldenbaum last edited by Thomas Braun
              @Goldenbaum
              iobroker stop
              iobroker fix
              iobroker update
              iobroker upgrade
              iobroker start
                crunchip Forum Testing Most Active @Thomas Braun last edited by
                @Thomas-Braun weiß nicht aus dem Kopf, welche im stable ist, nutze selbst 4.1.0 latest
                @haselchen sagte in Tr-064 adapter kann icht installiert werden:
                Gibt mal in den Einstellungen des Adapters die IP Deiner Box ein.
                @Goldenbaum
                davon bin ich ausgegangen, steht ja auch so in der Instanz
                ebenfalls hatte ich das oben schon geschrieben...IP/Benutzer/Passwort....erneut eintragen
                  Thomas Braun Most Active @crunchip last edited by
                  @crunchip
                  Ich auch nicht. Ich schau immer hier nach:
                  http://download.iobroker.net/list.html
                    @Thomas-Braun vielen dank, alle fehler beseitigt, danke allen beteiligten
                      crunchip Forum Testing Most Active last edited by crunchip
                      ich hänge mich hier mal dran.
                      Wollte gerade ein update des tr-64 machen, scheitert jedoch, siehe Screen
                      @apollon77 Fehler vom Adapter oder vom Controller? (3.2.16)
                      nochmal als logAusgabe
                      2021-02-19 18:32:15.430 - info: host.IoBroker iobroker upgrade tr-064
                      2021-02-19 18:32:20.571 - error: host.IoBroker iobroker /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674 res.forEach(aliveState => { ^TypeError: Cannot read property 'forEach' of undefined at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674:21) at processImmediate (internal/timers.js:463:21)
                      2021-02-19 18:32:20.579 - info: host.IoBroker iobroker exit 1
                        apollon77 @crunchip last edited by apollon77
                        @crunchip Sehr interessant ... Kann es sein das du hosts hast die gerade offline sind oder so?
                        Wobei dein Fehler was ganz anderes ist wie oben und so ... nicht einfach Threads kapern 😉
                        EDIT: geht es von Kommandozeile?
                          crunchip Forum Testing Most Active @apollon77 last edited by crunchip
                          @apollon77 ich kaper doch nichts, Thema heisst doch...kann nicht installieren werden.
                          Such mal den "offiziellen" Thread für den Adapter, z.b. über Tags😁
                          Wie meinst du, host, die offline sind, nicht das ich wüsste, es läuft alles.
                          Einzigstes was mir heute mittag aufgefallen war, das keine Ansage kam, beim Eingehenden Anruf kam.
                          Daher wollt ich das Update mal anstoßen.
                          Nein über Kommandozeile noch nicht probiert, dachte ich warte erst mal auf Antwort.
                            @crunchip sagte in Tr-064 adapter kann icht installiert werden:
                            Versuch bitte mal kommandozeile. Falls das nicht tut bitte mal iobroker beenden und dann kommdozeile. WO tut es?
                            crunchip 2 Replies Last reply Reply Quote 0
                              @apollon77 probier ich in der Früh, bin noch arbeiten, geb dir dann Bescheid.
                                @apollon77 sagte in Tr-064 adapter kann icht installiert werden:
                                das hat fehlerfrei funktioniert
                                  @crunchip komisch. Bitte mal beobachten ob’s nochmal passiert
                                    @apollon77 gestern Abend das gleiche Problem beim backitup Adapter, siehe https://forum.iobroker.net/post/599226
                                    Auf der Kommandozeile hab ich noch nicht versucht zu installieren.
                                    Desweiteren bestand dieses Problem, siehe
                                    https://forum.iobroker.net/post/598602
                                      @crunchip Dann versuch bitte mal kommandozeile. Du bist bisher immer noch der einzige der das berichtet 😞
                                        @apollon77 wollte wieder erst auf Antwort warten, bevor ich auf Kommandozeile...
                                        falls es irgendwas zum prüfen/ nachschauen/ testen gibt.
                                        hat mal wieder Fehlerfrei funktioniert
                                        Edit:
                                        Dieses Problem besteht aber nicht immer, hatte zwischenzeitlich schon mehrere Adapter, ohne Probleme upgedatet
                                        tr-064 error
                                        1719
