    4. Betatester für Backitup 2.0.0 gesucht
      Rushmed Most Active @simatec last edited by
      @simatec Habs gecheckt: selbes Ergebnis.
      • simatec
        simatec Developer Most Active @Rushmed last edited by
        @rushmed
        Wie sieht denn nun der Inhalt des grafana_tmp aus?
          @simatec
          • simatec
            @rushmed
            Kannst du bitte nochmal den vollständigen Log vom Backup aus der Logdatei posten
              Rushmed Most Active @simatec last edited by Negalein
              @simatec
              backitup.3	2021-02-20 01:04:27.617	debug	(1471) [iobroker/grafana] start Grafana backup compress ...
              backitup.3	2021-02-20 01:04:27.593	debug	(1471) [iobroker/grafana] found Dashboard: master
              backitup.3	2021-02-20 01:04:27.559	debug	(1471) [iobroker/grafana] found Dashboard: wall-tab-1-countdown
              backitup.3	2021-02-20 01:04:27.530	debug	(1471) [iobroker/grafana] found Dashboard: wall-tab-1
              backitup.3	2021-02-20 01:04:27.507	debug	(1471) [iobroker/grafana] found Dashboard: wetterstation-crunchip
              backitup.3	2021-02-20 01:04:27.474	debug	(1471) [iobroker/grafana] found Dashboard: wall-tab-1-copy
              backitup.3	2021-02-20 01:04:27.376	debug	(1471) [iobroker/grafana] found Dashboard: sun-and-moon-datasource
              backitup.3	2021-02-20 01:04:26.858	debug	(1471) [iobroker/grafana] Grafana is available ... Status: 200
              backitup.3	2021-02-20 01:04:26.820	debug	(1471) [iobroker/grafana] start Grafana request ...
              backitup.3	2021-02-20 01:04:26.820	debug	(1471) [iobroker/grafana] Created datasource directory
              backitup.3	2021-02-20 01:04:26.819	debug	(1471) [iobroker/grafana] Created dashboards_manually_restore directory
              backitup.3	2021-02-20 01:04:26.818	debug	(1471) [iobroker/grafana] Created dashboard directory
              backitup.3	2021-02-20 01:04:26.817	debug	(1471) [iobroker/grafana] Created grafana_tmp directory
              backitup.3	2021-02-20 01:04:26.816	debug	(1471) [iobroker/grafana] old grafana_tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
              backitup.3	2021-02-20 01:04:26.806	debug	(1471) [iobroker/grafana] Try deleting the old grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
              backitup.3	2021-02-20 01:04:26.805	debug	(1471) [iobroker/grafana] Start Grafana Backup ...
              backitup.3	2021-02-20 01:04:26.653	debug	(1471) [iobroker/zigbee] done
              backitup.3	2021-02-20 01:04:26.652	debug	(1471) [iobroker/zigbee] found zigbee database: zigbee.0
              backitup.3	2021-02-20 01:04:25.747	debug	(1471) [iobroker/iobroker] done
              backitup.3	2021-02-20 01:04:24.671	debug	(1471) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_02_20-01_04_10_backupiobroker.tar.gz
              backitup.3	2021-02-20 01:04:15.973	debug	(1471) [iobroker/iobroker] host.Smartazamba 8342 objects saved
              backitup.3	2021-02-20 01:04:15.743	debug	(1471) [iobroker/iobroker] host.Smartazamba 11631 states saved
              backitup.3	2021-02-20 01:04:10.824	debug	(1471) Backup has started ...
              An der Stelle bleibt es stehen.
              simatec 2 Replies Last reply Reply Quote 0
              • Homer.J.
                Homer.J. @simatec last edited by
                @simatec Guten Morgen habe alles gelöscht.
                • simatec
                  simatec Developer Most Active @Homer.J. last edited by
                  @homer-j
                  Was sagt nun der Log?
                  • simatec
                    simatec Developer Most Active @Rushmed last edited by simatec
                    @rushmed
                    Ich schaue mir das mal heute an.
                    Dein Api-Key ist aber als Admin angelegt oder?
                    • simatec
                      @rushmed
                      Installiere mal bitte die Version von Github aus dem Dev-Branch
                      Also über die Katze und dann "beliebig" und folgenden Link einfügen
                      https://github.com/simatec/ioBroker.backitup/tarball/dev
                      Im Anschluss dann noch ein Upload
                        sigi234 Forum Testing Most Active @simatec last edited by sigi234
                        @simatec
                        Hallo, ccu Größe wird nicht angezeigt?
                        Kann man auch die anderen ( Jarvis+JS) in der History anzeigen lassen oder sind die in iobroker drinnen?
                        [{"date":"20. Februar 2021 um 10:17 Uhr","type":"ccu","storage":["NAS / Kopieren"],"error":"none","timestamp":1613812643256},{"date":"20. Februar 2021 um 09:44 Uhr","type":"ccu","storage":["NAS / Kopieren"],"error":"none","timestamp":1613810687115},{"date":"20. Februar 2021 um 09:44 Uhr","name":"iobroker_2021_02_20-09_44_09_backupiobroker.tar.gz","type":"iobroker","storage":["NAS / Kopieren"],"filesize":"29MB","error":"none","timestamp":1613810665638},{"date":"20. Februar 2021 um 09:43 Uhr","type":"ccu","storage":["NAS / Kopieren"],"error":"none","timestamp":1613810635300},{"date":"20. Februar 2021 um 09:41 Uhr","name":"iobroker_2021_02_20-09_41_33_backupiobroker.tar.gz","type":"iobroker","storage":["NAS / Kopieren"],"filesize":"29MB","error":"none","timestamp":1613810511937},{"date":"20. Februar 2021 um 09:40 Uhr","name":"homematic_2021_02_20-09_40_48_3.55.10_backupiobroker.tar.sbk","type":"ccu","storage":["NAS / Kopieren"],"filesize":"0MB","error":"none","timestamp":1613810452037},{"date":"20. Februar 2021 um 09:36 Uhr","name":"iobroker_2021_02_20-09_36_33_backupiobroker.tar.gz","type":"iobroker","storage":["NAS / Kopieren"],"filesize":"29MB","error":"none","timestamp":1613810210194},{"date":"20. Februar 2021 um 09:29 Uhr","type":"ccu","storage":["NAS / Kopieren"],"error":"none","timestamp":1613809793546},{"date":"20. Februar 2021 um 09:29 Uhr","name":"iobroker_2021_02_20-09_29_15_backupiobroker.tar.gz","type":"iobroker","storage":["NAS / Kopieren"],"filesize":"29MB","error":"none","timestamp":1613809774344},{"date":"20. Februar 2021 um 09:20 Uhr","type":"ccu","storage":["NAS / Kopieren"],"error":"none","timestamp":1613809257824},{"date":"20. Februar 2021 um 09:20 Uhr","type":"ccu","storage":["NAS / Kopieren"],"error":"none","timestamp":1613809228322},{"date":"20. Februar 2021 um 05:08 Uhr","name":"iobroker_2021_02_20-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":["NAS / Kopieren"],"filesize":"29MB","error":"none","timestamp":1613794105424},{"date":"19. Februar 2021 um 05:08 Uhr","name":"iobroker_2021_02_19-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"25MB","error":"none"},{"date":"19. Februar 2021 um 01:30 Uhr","name":"homematic_2021_02_19-01_30_11_3.55.10_backupiobroker.tar.sbk","type":"ccu","storage":"NFS / CIFS-Mount: Ja","filesize":"0MB","error":"none"},{"date":"18. Februar 2021 um 05:08 Uhr","name":"iobroker_2021_02_18-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"25MB","error":"none"},{"date":"16. Februar 2021 um 05:08 Uhr","name":"iobroker_2021_02_16-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"23MB","error":"none"},{"date":"16. Februar 2021 um 01:30 Uhr","name":"homematic_2021_02_16-01_30_11_3.55.10_backupiobroker.tar.sbk","type":"ccu","storage":"NFS / CIFS-Mount: Ja","filesize":"0MB","error":"none"},{"date":"15. Februar 2021 um 05:08 Uhr","name":"iobroker_2021_02_15-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"21MB","error":"none"},{"date":"14. Februar 2021 um 19:26 Uhr","name":"iobroker_2021_02_14-19_25_50_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"18MB","error":"none"},{"date":"14. Februar 2021 um 05:08 Uhr","name":"iobroker_2021_02_14-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"Nur lokal gesichert","filesize":"18MB","error":"none"},{"date":"24. Januar 2021 um 05:08 Uhr","name":"iobroker_2021_01_24-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"Nur lokal gesichert","filesize":"18MB","error":"none"},{"date":"23. Januar 2021 um 05:08 Uhr","name":"iobroker_2021_01_23-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"Nur lokal gesichert","filesize":"18MB","error":"none"},{"date":"22. Januar 2021 um 05:08 Uhr","name":"iobroker_2021_01_22-05_08_10_backupiobroker.tar.gz","type":"iobroker","storage":"Nur lokal gesichert","filesize":"18MB","error":"none"},{"date":"22. Januar 2021 um 01:30 Uhr","name":"homematic_2021_01_22-01_30_11_3.55.5_backupiobroker.tar.sbk","type":"ccu","storage":"Nur lokal gesichert","filesize":"0MB","error":"none"}]
                        Platform: Windows
                        RAM: 16 GB
                        Node.js: 12.20.2
                        NPM: 6.14.10
                        JS Controler: 3.2.16
                        Admin: 4.2.1
                        Web: 3.3.0
                        Socket.io: 3.1.4
                        Script Engine: 4.10.15
                        IOT: 1.8.13
                        VIS: 1.3.7
                        HM-Rega: 3.0.16
                        HM-RPC: 1.14.35
                        Jarvis: 2.2.0-beta.39
                        Backitup: 2.0.0
                        Cloud: 4.0.9
                        ICal: 1.9.1
                        iQontrol: 1.5.7
                        ERLEDIGT!!!
                        Habe im Adapter das Passwort für die CCU neu gesetzt.
                        • Homer.J.
                          Homer.J. last edited by Homer.J.
                          @simatec gleiche Problem
                          [ERROR] [iobroker] - host.Iobroker Backup not created: Error: host.Iobroker /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/.json is not a valid json file
                            @simatec sagte in Betatester für Backitup 2.0.0 gesucht:
                            Vielen Dank, jetzt gehts.
                            Backup läuft durch. Archiv wird erstellt und is unbeschädigt.
                            • simatec
                              @homer-j
                              Du musst in deinem System noch dem fehlerhaften json suchen.
                              Da hat dir der benannte Adapter was kaputt gemacht
                              Homer.J. 1 Reply Last reply Reply Quote 0
                              • Homer.J.
                                @simatec ja ich hab jetzt alles neu aufgesetzt, und es läuft wieder rund.
                                • simatec
                                  @rushmed sagte in Betatester für Backitup 2.0.0 gesucht:
                                  Kannst du eventuell nochmal die Dev Version testen? Hab noch ein wenig umgebaut
                                    Läuft.
                                    • simatec
                                      @rushmed
                                      Auch mit Upload nach dem Update alles OK?
                                        @simatec Ich verstehe die Frage nicht.
                                        Habe die dev version neu installiert. Backup durgeführt und beobachtet. Lief durch und Archive lassen sich öffnen.
                                        Soll ich nochmal ein Upload machen?
                                        • simatec
                                          @rushmed Ja einfach nochmal zur Sicherheit, damit alle Änderungen übernommen werden
                                            MCU @simatec last edited by
                                            @simatec Im html Datenpunkt ist für eine neue Zeile der Befehl & nbsp; (Leerzeichen sonst keine Anzeige) verwendet worden. Dies führt bei jarvis nicht zu einer neuen Zeile.
                                            Erste habe ich ein <br> eingesetzt.
                                            Bitte ersetzen durch den html-Befehl: <br>
                                            Vielen Dank.
                                            293
                                            33530
