    4. [How-to] Node.js für ioBroker richtig updaten
      Thomas Braun Most Active @MyMeyer last edited by
      @mymeyer Im Verzeichnis des angemeckerten Moduls.
        MyMeyer @Thomas Braun last edited by
        @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
        Jetzt kommt das raus:-(
        pi@iobroker-slave:/opt/iobroker $ cd node_modules/iobroker.js-controller/
        pi@iobroker-slave:/opt/iobroker/node_modules/iobroker.js-controller $ pwd
        pi@iobroker-slave:/opt/iobroker/node_modules/iobroker.js-controller $ npm install --production
        > iobroker.js-controller@3.1.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.11
        npm WARN deprecated istanbul@0.4.5: This module is no longer maintained, try this instead:
        npm WARN deprecated   npm i nyc
        npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated debug@3.2.6: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
        npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
        npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
        npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
        > unix-dgram@2.0.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../../nan/nan.h:56,
                         from ../src/unix_dgram.cc:5:
        /home/iobroker/.cache/node-gyp/12.20.2/include/node/node.h:737:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to  node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/12.20.2/include/node/node.h:771:3: note: in expansion of macro 'NODE_MODULE_X'
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
         NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@1.1.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/diskusage
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/diskusage/build'
          CXX(target) Release/obj.target/diskusage/src/main.o
                         from ../src/main.cpp:3:
        ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
         NODE_MODULE(diskusage, Init)
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/diskusage/build'
        > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/iobroker.js-controller/node_modules/acme-v2
        > node scripts/postinstall
        Greenlock and ACME.js v3 are on the way!
        Watch for updates at https://indiegogo.com/at/greenlock
        > iobroker.js-controller@3.1.6 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        internal/modules/cjs/loader.js:818
          throw err;
        Error: Cannot find module './_copyObject'
        Require stack:
        - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js
        - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/lib/yargs.js
        - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/yargs.js
        - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.js
        - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
            at Function.Module._load (internal/modules/cjs/loader.js:667:27)
            at Module.require (internal/modules/cjs/loader.js:887:19)
            at require (internal/modules/cjs/helpers.js:74:18)
            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js:1:18)
            at Module._compile (internal/modules/cjs/loader.js:999:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
            at Module.load (internal/modules/cjs/loader.js:863:32)
            at Function.Module._load (internal/modules/cjs/loader.js:708:14)
            at Module.require (internal/modules/cjs/loader.js:887:19) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/lib/yargs.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/yargs.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! iobroker.js-controller@3.1.6 install: `node iobroker.js setup first`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the iobroker.js-controller@3.1.6 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2021-02-20T11_07_58_610Z-debug.log
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
          @mymeyer
          Versuch mal das
          cd /opt/iobroker/node_modules/@serialport
            @mymeyer
            Versuch mal das
            pi@iobroker-slave:/opt/iobroker/node_modules/iobroker.js-controller $ cd /opt/iobroker/node_modules/@serialport
            pi@iobroker-slave:/opt/iobroker/node_modules/@serialport $ npm install --production
            > iobroker.inst@2.0.3 install /opt/iobroker
            > node lib/checkVersions.js
            > iobroker.inst@2.0.3 postinstall /opt/iobroker
            > node lib/install.js
            │ Manual installation of ioBroker is no longer supported  │
            │ on Linux, OSX and FreeBSD!                              │
            │ Please refer to the documentation on how to install it! │
            │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
            npm ERR! errno 100
            npm ERR! iobroker.inst@2.0.3 postinstall: `node lib/install.js`
            npm ERR! Exit status 100
            npm ERR!
            npm ERR! Failed at the iobroker.inst@2.0.3 postinstall script.
            npm ERR!     /home/iobroker/.npm/_logs/2021-02-20T11_26_12_890Z-debug.log
            Und nun ?
              @mymeyer
              Mach mal den cache leer
              cd /optI/iobroker
              npm cache clear --force
              Dann installier dien smartmeter-Adapter nochmal neu.
                @mymeyer
                cd /optI/iobroker
                Gemacht aber er läßt sich unten dem Master nicht löschen und somit auch nicht neu installieren.
                Das kommt dabei raus:
                Done with error: internal/modules/cjs/loader.js:818 throw err; ^Error: Cannot find module './_copyObject'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/lib/yargs.js- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/yargs.js- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15) at Function.Module._load (internal/modules/cjs/loader.js:667:27) at Module.require (internal/modules/cjs/loader.js:887:19) at require (internal/modules/cjs/helpers.js:74:18) at Object. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js:1:18) at Module._compile (internal/modules/cjs/loader.js:999:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14) at Module.require (internal/modules/cjs/loader.js:887:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/lib/yargs.js', '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/yargs.js', '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]}
                Dann habe ich ihn auf dem Master per "./iobroker del smartmeter.0" gelöscht. Aber in der Web Übersicht steht er immer noch. Und der Slave läuft ja noch nicht korrekt. Laut Iobroker status:
                pi@iobroker-slave:/opt/iobroker $ iobroker status
                  throw err;
                Require stack:
                  requireStack: [
                Interesse an einer TeamViever Session ?
                  @mymeyer sagte in [How-to] Node.js für ioBroker richtig updaten:
                  Nein.
                    Nein.
                    🙂 Und nun ... ?
                      @thomas-braun Hmm...also nachdem ich "npm install iobroker.js-controller@3.1.6 --production" gemacht habe, läuft der Slave wieder . Zumindest sagt es der Status und der Adapter läßt sich verbinden "grün" . Hmm... komisch. Bevor ich npm install gemacht hatte, habe ich noch das Verzeichnis /node_modules komplett gelöscht.
                      Der Smartmeter überträgt Daten und es sind keine Fehler im Log.
                      Ich würde sagen mit dem JS-controller 3.2.16 lasse ich mir jetzt noch etwas Zeit 🙂
                        apollon77 @MyMeyer last edited by
                        @mymeyer noch Zeit lassen? Neeee. Sorry das ich jetzt „am Ende“ hier klugscheisse ;-))
                        Das mir @serialport war fast richtig ... man hätte nur das richtige unterverzeichnis nehmen müssen. Das wäre (wie es auch in der Fehlermeldung kryptisch zu sehen war: @serialport/bindings
                        Dann wäre alles ohne den ganzen hassle gegangen 😉
                        Also Controller 3.2 ist easy im Vergleich dazu.
                          Thomas Braun Most Active @apollon77 last edited by
                          @apollon77 @MyMeyer
                          Oh, das mit bindings hatte ich übersehen.
                            ps1304 @Stabilostick last edited by
                            @stabilostick Hallo - gibts es schon einen Updater für Windows? HAbe iobroker mit dem Windows Installer installiert - scheitere aber immer am Update der node.js bzw. der js-controller Versionen.
                            Gruß peter
                              sigi234 Forum Testing Most Active @ps1304 last edited by sigi234
                              @ps1304 sagte in [How-to] Node.js für ioBroker richtig updaten:
                              Gruß peter
                              https://forum.iobroker.net/post/446928
                              Node Update:
                              1: Konsole: iobroker stop
                              2: Sicherung des Ordners: C:\Program Files\iobroker\deinhostname\nodejs auf dem Desktop
                              3: Download der benötigten Node.js Version unter https://nodejs.org als Archiv nicht als msi Datei
                              4: Entpacken des Downloads und kopieren den Gesamten Ordners über den vorhandenen C:\Program Files\iobroker\deinhostname\nodejs Ordner.
                              5: Kopiere aus der Sicherungskopie des Desktops die Datei nodevars.bat in den Ordner C:\Program Files\iobroker\deinhostname\nodejs
                              6: Konsole: iobroker start
                                klassisch Most Active @sigi234 last edited by
                                @sigi234 Bist Du schon auf dem neuen JS-controller "stable" ?
                                Wie bist Du dorthin gekommen?
                                Direkt aus der aktiven Instanz oder erst mit dem Installer eine neuen Instanz erzeugt, damit man noch eine Rückfallösung hat?
                                  sigi234 Forum Testing Most Active @klassisch last edited by sigi234
                                  @klassisch sagte in [How-to] Node.js für ioBroker richtig updaten:
                                  Via Konsole im iob Verzeichnis des Host
                                  iobroker stop
                                  iobroker update
                                  iobroker upgrade self
                                  iobroker start
                                    @sigi234 sagte in [How-to] Node.js für ioBroker richtig updaten:
                                    iobroker stop
                                    iobroker update
                                    iobroker start
                                    vielen Dank! Habe das jetzt auch mal getestet. Sieht so weit ganz gut aus:
                                    C:\Program Files\iobroker\ioBrMain026>iobroker upgrade self
                                    Update js-controller from @3.1.6 to @3.2.16
                                    NPM version: 6.11.3
                                    npm install iobroker.js-controller@3.2.16 --loglevel error --unsafe-perm (System call)
                                    node-aead-crypto not needed on this system, since all ciphers are natively supported
                                    Starting node restart.js
                                    C:\Program Files\iobroker\ioBrMain026>iobroker start
                                    2021-02-27 01:34:12,418 INFO  - Starting the service with id 'iobroker(ioBrMain026)'
                                    scheint so weit funktioniert zu haben. Alle Instanzen grün.
                                    • FriHu
                                      FriHu last edited by
                                      ich bin neu hier und auch neu bei iobroker auf Windows, ioBroker auf Raspi läuft seit einem Jahr stabil.
                                      Ich habe die Installation nach den Angaben hier richtig erstellt, leider öffnet sich das Skriptmenue nicht.
                                      Festgestellt habe ich, daß in der Info angezeigt wird: Nodejs V10.17.0 sei installiert, empfohlen sei V12.21.0 und mit der Konsole habe ich festgestellt, daß tatsächlich 14.6.0 installiert ist.
                                      Liegt hier der Fehler und wie kann ich ihn beheben? Die Javascriptinstanz ist V5.1.1
                                      Weiß jemand einen Rat?
                                        Thomas Braun Most Active @FriHu last edited by
                                        @frihu sagte in [How-to] Node.js für ioBroker richtig updaten:
                                        Ist eine Beta-Version, bei der durch das Beta-Testing aufgefallen ist das da ein Fehler drin ist. Installier die Stabile Version 5.0.4.
                                        Dein node solltest du allerdings auch mal dringend anschauen. Mir ist aber nicht ganz klar ob da bei dir nun Windows oder Linux läuft.
                                        FriHu 1 Reply Last reply Reply Quote 0
                                        • FriHu
                                          FriHu @Thomas Braun last edited by
                                          Habe gerade die beiden JS-Adapter verglichen und festgestellt, daß der eine V5.1.1 ist und der andere 5.0.14. Habe den neuen auf 5.0.14 zurückgedreht und schon funktioniert es bestens!
                                          Vielen Dank für den Hinweis.
                                          @thomas-braun said in [How-to] Node.js für ioBroker richtig updaten:
                                          FriHu apollon77 2 Replies Last reply Reply Quote 0
                                          • FriHu
                                            FriHu @FriHu last edited by
                                            @frihu said in [How-to] Node.js für ioBroker richtig updaten:
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            733948
