    4. Plötzliche adapter fehler
      Thomas Braun Most Active @Billy 0 last edited by Thomas Braun
      @billy-0
      dmesg | grep -i ext4
      sagt?
        Billy 0 @Thomas Braun last edited by
        pi@raspberrypi:~ $ dmesg | grep -i ext4
        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:50:FA:7C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=115200 console=tty1 root=PARTUUID=fee304eb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [    1.383751] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [    1.383841] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [    4.899179] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        pi@raspberrypi:~ $
          @billy-0
          Okay, das ist sauber.
          iobroker -v
          iobroker status
          iobroker update
          iobroker upgrade
            pi@raspberrypi:~ $ iobroker -v
            3.1.6
            pi@raspberrypi:~ $ iobroker status
            At least one iobroker host is running.
            Objects type: file
            States  type: file
              @billy-0
              iobroker stop
              iobroker update
              iobroker upgrade self
              iobroker upgrade
              iobroker start
                @billy-0
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  zu spät, update läuft schon ohne iobroker stop
                    @billy-0
                    Das macht nix.
                    Nur das
                    erfordert zuvor den Stop des Servers.
                      Billy 0 @Thomas Braun last edited by Negalein
                      Adapter "fritzbox"       is not installed.
                      Adapter "fritzdect"      is up to date.
                      (node:12578) UnhandledPromiseRejectionWarning: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                          at parse (<anonymous>)
                          at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
                          at Module.load (internal/modules/cjs/loader.js:863:32)
                          at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                          at Module.require (internal/modules/cjs/loader.js:887:19)
                          at require (internal/modules/cjs/helpers.js:74:18)
                          at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:237:27)
                          at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:50:14)
                          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:57:41)
                          at processImmediate (internal/timers.js:461:21)
                      (node:12578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      (node:12578) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      scheinabgebrochen zu haben
                        Billy 0 @Billy 0 last edited by
                        @billy-0
                        Adapter "foobar2000"     is not installed.
                        Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                            at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
                            at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
                        pi@raspberrypi:~ $
                        dasselbe...
                          @billy-0
                            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v12.20.1
                            /usr/bin/node
                            v12.20.1
                            /usr/bin/npm
                            7.5.4
                            nodejs:
                              Installed: 12.20.1-1nodesource1
                              Candidate: 12.20.2-1nodesource1
                              Version table:
                                 12.20.2-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                             *** 12.20.1-1nodesource1 100
                                    100 /var/lib/dpkg/status
                                 10.23.1~dfsg-1~deb10u1 500
                            pi@raspberrypi:~ $
                            npm hab ich eben ausversehen update gemacht
                              @billy-0 sagte in Plötzliche adapter fehler:
                              Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
                              sudo apt update
                              sudo apt upgrade
                                @thomas-braun Ok ist durchgelaufen
                                /usr/bin/nodejs
                                v12.20.2
                                /usr/bin/node
                                v12.20.2
                                /usr/bin/npm
                                6.14.11
                                nodejs:
                                  Installed: 12.20.2-1nodesource1
                                  Version table:
                                 *** 12.20.2-1nodesource1 500
                                pi@raspberrypi:~ $
                                  @billy-0 log vom broker
                                  host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
                                    @billy-0 beim upgrade self bleibts beim fehler
                                    Thomas Braun B 2 Replies Last reply Reply Quote 0
                                      @billy-0
                                      Lösch den Adapter mal und installier den danach neu.
                                        Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                                          @thomas-braun finde nix zum neu installieren!?
                                            @billy-0
                                            iobroker del iobroker.fronius
                                            iobroker restart
                                            iobroker add iobroker.fronius
                                            807
