    4. Plötzliche adapter fehler
      Thomas Braun Most Active @Billy 0 last edited by Thomas Braun
      @billy-0
      iobroker stop
      iobroker update
      iobroker upgrade self
      iobroker upgrade
      iobroker start
        @billy-0
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          Billy 0 @Thomas Braun last edited by
          zu spät, update läuft schon ohne iobroker stop
            @billy-0
            Das macht nix.
            Nur das
            erfordert zuvor den Stop des Servers.
              Billy 0 @Thomas Braun last edited by Negalein
              Adapter "fritzbox"       is not installed.
              Adapter "fritzdect"      is up to date.
              (node:12578) UnhandledPromiseRejectionWarning: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                  at parse (<anonymous>)
                  at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
                  at Module.load (internal/modules/cjs/loader.js:863:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                  at Module.require (internal/modules/cjs/loader.js:887:19)
                  at require (internal/modules/cjs/helpers.js:74:18)
                  at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:237:27)
                  at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:50:14)
                  at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:57:41)
                  at processImmediate (internal/timers.js:461:21)
              (node:12578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              (node:12578) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
              scheinabgebrochen zu haben
                Billy 0 @Billy 0 last edited by
                @billy-0
                Adapter "foobar2000"     is not installed.
                Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                    at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
                    at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
                    at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
                pi@raspberrypi:~ $
                dasselbe...
                  @billy-0
                    pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v12.20.1
                    /usr/bin/node
                    v12.20.1
                    /usr/bin/npm
                    7.5.4
                    nodejs:
                      Installed: 12.20.1-1nodesource1
                      Candidate: 12.20.2-1nodesource1
                      Version table:
                         12.20.2-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     *** 12.20.1-1nodesource1 100
                            100 /var/lib/dpkg/status
                         10.23.1~dfsg-1~deb10u1 500
                    pi@raspberrypi:~ $
                    npm hab ich eben ausversehen update gemacht
                      @billy-0 sagte in Plötzliche adapter fehler:
                      Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
                      sudo apt update
                      sudo apt upgrade
                        @thomas-braun Ok ist durchgelaufen
                        /usr/bin/nodejs
                        v12.20.2
                        /usr/bin/node
                        v12.20.2
                        /usr/bin/npm
                        6.14.11
                        nodejs:
                          Installed: 12.20.2-1nodesource1
                          Version table:
                         *** 12.20.2-1nodesource1 500
                        pi@raspberrypi:~ $
                          @billy-0 log vom broker
                          host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
                            @billy-0 beim upgrade self bleibts beim fehler
                            Thomas Braun B 2 Replies Last reply Reply Quote 0
                              @billy-0
                              Lösch den Adapter mal und installier den danach neu.
                                Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                                  @thomas-braun finde nix zum neu installieren!?
                                    @billy-0
                                    iobroker del iobroker.fronius
                                    iobroker restart
                                    iobroker add iobroker.fronius
                                      pi@raspberrypi:~ $ iobroker del iobroker.fronius
                                      Delete adapter "fronius"
                                      host.raspberrypi Counted 1 instances of fronius
                                      host.raspberrypi Counted 1 meta of fronius
                                      host.raspberrypi Counted 1 adapter for fronius
                                      host.raspberrypi Counted 4 channels of fronius
                                      host.raspberrypi Counted 27 states of fronius
                                      host.raspberrypi Counted 14 states of system.adapter.fronius
                                      host.raspberrypi Counted 27 states (io.fronius.*) from states
                                      host.raspberrypi Counted 14 states (system.adapter.fronius.*) from states
                                      host.raspberrypi file fronius.admin deleted
                                      host.raspberrypi object fronius deleted
                                      host.raspberrypi object fronius.admin deleted
                                      host.raspberrypi Deleting 48 object(s).
                                      host.raspberrypi Deleting 41 state(s).
                                      Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                                      You might have to delete it yourself!
                                      pi@raspberrypi:~ $ iobroker restart
                                      pi@raspberrypi:~ $ iobroker add iobroker.fronius
                                      host.raspberrypi install adapter fronius
                                      host.raspberrypi error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                                      Uncaught Rejection: TypeError: Cannot read property 'common' of undefined
                                          at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:728:25)
                                          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:842:29)
                                          at processImmediate (internal/timers.js:463:21)
                                      pi@raspberrypi:~ $
                                        Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931 You might have to delete it yourself!
                                        Dann mach das mal.
                                          Im broker werden mir gar keine adapter mehr zum installieren angezeigt.
                                          Keine ahnung wie ich das lösche, sorry
                                            @billy-0
                                            iobroker stop
                                            iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                            iobroker restart
                                            807
