    4. Plötzliche adapter fehler
      Billy 0 @Thomas Braun last edited by
      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v12.20.1
      /usr/bin/node
      v12.20.1
      /usr/bin/npm
      7.5.4
      nodejs:
        Installed: 12.20.1-1nodesource1
        Candidate: 12.20.2-1nodesource1
        Version table:
           12.20.2-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
       *** 12.20.1-1nodesource1 100
              100 /var/lib/dpkg/status
           10.23.1~dfsg-1~deb10u1 500
      pi@raspberrypi:~ $
      npm hab ich eben ausversehen update gemacht
        Thomas Braun Most Active @Billy 0 last edited by Thomas Braun
        @billy-0 sagte in Plötzliche adapter fehler:
        Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
        sudo apt update
        sudo apt upgrade
          @thomas-braun Ok ist durchgelaufen
          /usr/bin/nodejs
          v12.20.2
          /usr/bin/node
          v12.20.2
          /usr/bin/npm
          6.14.11
          nodejs:
            Installed: 12.20.2-1nodesource1
            Version table:
           *** 12.20.2-1nodesource1 500
          pi@raspberrypi:~ $
            Billy 0 @Billy 0 last edited by
            @billy-0 log vom broker
            host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
              @billy-0 beim upgrade self bleibts beim fehler
              Adapter "fritzbox"       is not installed.
              Adapter "fritzdect"      is up to date.
              Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                  at parse (<anonymous>)
                  at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
                  at Module.load (internal/modules/cjs/loader.js:863:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                  at Module.require (internal/modules/cjs/loader.js:887:19)
                  at require (internal/modules/cjs/helpers.js:74:18)
                  at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
                  at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
                  at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
                  at processImmediate (internal/timers.js:461:21)
              Thomas Braun B 2 Replies Last reply Reply Quote 0
                @billy-0
                Lösch den Adapter mal und installier den danach neu.
                  Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                    @thomas-braun finde nix zum neu installieren!?
                      @billy-0
                      iobroker del iobroker.fronius
                      iobroker restart
                      iobroker add iobroker.fronius
                        pi@raspberrypi:~ $ iobroker del iobroker.fronius
                        Delete adapter "fronius"
                        host.raspberrypi Counted 1 instances of fronius
                        host.raspberrypi Counted 1 meta of fronius
                        host.raspberrypi Counted 1 adapter for fronius
                        host.raspberrypi Counted 4 channels of fronius
                        host.raspberrypi Counted 27 states of fronius
                        host.raspberrypi Counted 14 states of system.adapter.fronius
                        host.raspberrypi Counted 27 states (io.fronius.*) from states
                        host.raspberrypi Counted 14 states (system.adapter.fronius.*) from states
                        host.raspberrypi file fronius.admin deleted
                        host.raspberrypi object fronius deleted
                        host.raspberrypi object fronius.admin deleted
                        host.raspberrypi Deleting 48 object(s).
                        host.raspberrypi Deleting 41 state(s).
                        Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                        You might have to delete it yourself!
                        pi@raspberrypi:~ $ iobroker restart
                        pi@raspberrypi:~ $ iobroker add iobroker.fronius
                        host.raspberrypi install adapter fronius
                        host.raspberrypi error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                        Uncaught Rejection: TypeError: Cannot read property 'common' of undefined
                            at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:728:25)
                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:842:29)
                            at processImmediate (internal/timers.js:463:21)
                        pi@raspberrypi:~ $
                          Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931 You might have to delete it yourself!
                          Dann mach das mal.
                            Im broker werden mir gar keine adapter mehr zum installieren angezeigt.
                            Keine ahnung wie ich das lösche, sorry
                              @billy-0
                              iobroker stop
                              iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                              iobroker restart
                                Halt kommando zurück, adapter werden angezeigt, aber installieren kommt derselbe fehler
                                  pi@raspberrypi:~ $ iobroker stop
                                  pi@raspberrypi:~ $ iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                  Error: Not exists
                                      at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
                                      at ObjectsInMemoryServerClass._rm (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1391:30)
                                      at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                  pi@raspberrypi:~ $
                                    Dann
                                    sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                      pi@raspberrypi:~
                                        Ok es installiert
                                          @thomas-braun danke dir, das hat geholfen.
                                          Kannst du mir sagen wie sowas passieren kann oder wie ich abhilfe schaffe?
                                            @billy-0 Nein, so genau weiß ich das nicht.
                                            Kann aber sein, dass die Syntaxprüfung in aktuellen Versionen des js-controllers, von nodeJS und/oder des javaskript-Adapters da genauer prüfen und Dinge, die in früheren Versionen okay waren jetzt angemeckert werden.
                                            807
