    4. Plötzliche adapter fehler
      Billy 0 @Billy 0 last edited by
      Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
        Billy 0 @Thomas Braun last edited by
        @thomas-braun finde nix zum neu installieren!?
          Thomas Braun Most Active @Billy 0 last edited by Thomas Braun
          @billy-0
          iobroker del iobroker.fronius
          iobroker restart
          iobroker add iobroker.fronius
            pi@raspberrypi:~ $ iobroker del iobroker.fronius
            Delete adapter "fronius"
            host.raspberrypi Counted 1 instances of fronius
            host.raspberrypi Counted 1 meta of fronius
            host.raspberrypi Counted 1 adapter for fronius
            host.raspberrypi Counted 4 channels of fronius
            host.raspberrypi Counted 27 states of fronius
            host.raspberrypi Counted 14 states of system.adapter.fronius
            host.raspberrypi Counted 27 states (io.fronius.*) from states
            host.raspberrypi Counted 14 states (system.adapter.fronius.*) from states
            host.raspberrypi file fronius.admin deleted
            host.raspberrypi object fronius deleted
            host.raspberrypi object fronius.admin deleted
            host.raspberrypi Deleting 48 object(s).
            host.raspberrypi Deleting 41 state(s).
            Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
            You might have to delete it yourself!
            pi@raspberrypi:~ $ iobroker restart
            pi@raspberrypi:~ $ iobroker add iobroker.fronius
            host.raspberrypi install adapter fronius
            host.raspberrypi error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
            Uncaught Rejection: TypeError: Cannot read property 'common' of undefined
                at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:728:25)
                at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:842:29)
                at processImmediate (internal/timers.js:463:21)
            pi@raspberrypi:~ $
              @billy-0 sagte in Plötzliche adapter fehler:
              Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931 You might have to delete it yourself!
              Dann mach das mal.
                Im broker werden mir gar keine adapter mehr zum installieren angezeigt.
                Keine ahnung wie ich das lösche, sorry
                Thomas Braun B 2 Replies Last reply Reply Quote 0
                  @billy-0
                  iobroker stop
                  iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                  iobroker restart
                    Halt kommando zurück, adapter werden angezeigt, aber installieren kommt derselbe fehler
                      pi@raspberrypi:~ $ iobroker stop
                      pi@raspberrypi:~ $ iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                      Error: Not exists
                          at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
                          at ObjectsInMemoryServerClass._rm (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1391:30)
                          at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      pi@raspberrypi:~ $
                        Dann
                        sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                          pi@raspberrypi:~
                            Ok es installiert
                              @thomas-braun danke dir, das hat geholfen.
                              Kannst du mir sagen wie sowas passieren kann oder wie ich abhilfe schaffe?
                                @billy-0 Nein, so genau weiß ich das nicht.
                                Kann aber sein, dass die Syntaxprüfung in aktuellen Versionen des js-controllers, von nodeJS und/oder des javaskript-Adapters da genauer prüfen und Dinge, die in früheren Versionen okay waren jetzt angemeckert werden.
                                  @thomas-braun Ok danke dir für deine schnelle Hilfe, die anderen beiden adapter versuche ich mal alleine 😉
                                    @billy-0
                                    Ich vermute da ähnliches.
                                    807
