    4. Plötzliche adapter fehler
      Thomas Braun Most Active @Billy 0 last edited by Thomas Braun
      @billy-0
      iobroker del iobroker.fronius
      iobroker restart
      iobroker add iobroker.fronius
        Billy 0 @Thomas Braun last edited by
        pi@raspberrypi:~ $ iobroker del iobroker.fronius
        Delete adapter "fronius"
        host.raspberrypi Counted 1 instances of fronius
        host.raspberrypi Counted 1 meta of fronius
        host.raspberrypi Counted 1 adapter for fronius
        host.raspberrypi Counted 4 channels of fronius
        host.raspberrypi Counted 27 states of fronius
        host.raspberrypi Counted 14 states of system.adapter.fronius
        host.raspberrypi Counted 27 states (io.fronius.*) from states
        host.raspberrypi Counted 14 states (system.adapter.fronius.*) from states
        host.raspberrypi file fronius.admin deleted
        host.raspberrypi object fronius deleted
        host.raspberrypi object fronius.admin deleted
        host.raspberrypi Deleting 48 object(s).
        host.raspberrypi Deleting 41 state(s).
        Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
        You might have to delete it yourself!
        pi@raspberrypi:~ $ iobroker restart
        pi@raspberrypi:~ $ iobroker add iobroker.fronius
        host.raspberrypi install adapter fronius
        host.raspberrypi error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
        Uncaught Rejection: TypeError: Cannot read property 'common' of undefined
            at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:728:25)
            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:842:29)
            at processImmediate (internal/timers.js:463:21)
        pi@raspberrypi:~ $
          @billy-0 sagte in Plötzliche adapter fehler:
          Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931 You might have to delete it yourself!
          Dann mach das mal.
            Im broker werden mir gar keine adapter mehr zum installieren angezeigt.
            Keine ahnung wie ich das lösche, sorry
            Thomas Braun B 2 Replies Last reply Reply Quote 0
              @billy-0
              iobroker stop
              iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
              iobroker restart
                Billy 0 @Billy 0 last edited by
                Halt kommando zurück, adapter werden angezeigt, aber installieren kommt derselbe fehler
                  pi@raspberrypi:~ $ iobroker stop
                  pi@raspberrypi:~ $ iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                  Error: Not exists
                      at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
                      at ObjectsInMemoryServerClass._rm (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1391:30)
                      at processTicksAndRejections (internal/process/task_queues.js:97:5)
                  pi@raspberrypi:~ $
                    Dann
                    sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                      pi@raspberrypi:~
                        Ok es installiert
                          @thomas-braun danke dir, das hat geholfen.
                          Kannst du mir sagen wie sowas passieren kann oder wie ich abhilfe schaffe?
                            @billy-0 Nein, so genau weiß ich das nicht.
                            Kann aber sein, dass die Syntaxprüfung in aktuellen Versionen des js-controllers, von nodeJS und/oder des javaskript-Adapters da genauer prüfen und Dinge, die in früheren Versionen okay waren jetzt angemeckert werden.
                              @thomas-braun Ok danke dir für deine schnelle Hilfe, die anderen beiden adapter versuche ich mal alleine 😉
                                @billy-0
                                Ich vermute da ähnliches.
                                729
