    4. Unifi Adapter angeblich falscher Benutzer/Passwort
    UNSOLVED Unifi Adapter angeblich falscher Benutzer/Passwort
    • Negalein
      soeben sind mir diese Errors aufgefallen.
      host.iobroker	2021-02-21 00:48:14.730	info	Restart adapter system.adapter.unifi.0 because enabled
      host.iobroker	2021-02-21 00:48:14.730	info	instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
      host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
      host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93872
      host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68
      host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72
      host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: Error: Not exists
      host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
      host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
      host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
      unifi.0	2021-02-21 00:48:14.105	info	(14126) Terminated (NO_ERROR): Without reason
      unifi.0	2021-02-21 00:48:14.105	debug	(14126) Plugin sentry destroyed
      unifi.0	2021-02-21 00:48:14.103	info	(14126) terminating
      unifi.0	2021-02-21 00:48:13.897	error	(14126) Error: Not exists at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68 at /opt/iobr
      unifi.0	2021-02-21 00:48:13.879	error	(14126) unhandled promise rejection: Not exists
      unifi.0	2021-02-21 00:48:13.878	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      unifi.0	2021-02-21 00:48:13.869	debug	(14126) fetchNetworks: 1
      unifi.0	2021-02-21 00:48:13.842	info	(14126) cleaned everything up...
      unifi.0	2021-02-21 00:48:13.841	error	(14126) ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt
      unifi.0	2021-02-21 00:48:13.834	error	(14126) unhandled promise rejection: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
      unifi.0	2021-02-21 00:48:13.831	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.iobroker	2021-02-21 00:48:13.807	warn	Objects 127.0.0.1:43616 Error from InMemDB: Error: ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
      S crunchip 2 Replies Last reply Reply Quote 0
        saeft_2003 Most Active @Negalein last edited by
        Was habt ihr bei polling time im Adapter eingestellt?
        • Negalein
          Negalein Global Moderator @saeft_2003 last edited by
          @saeft_2003 sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
          schon verschiedene Zeiten probiert.
          20 Sek.
          30 Sek.
          36 Sek.
          200 Sek.
          60 Sek.
          Bringt keine Änderung
            crunchip Forum Testing Most Active @Negalein last edited by
            @negalein
            und vor deiner "erneuten" Eingabe von Benutzer und Passwort ging der Adapter noch? Eventuell vertippt?
            in welchem Netzwerk läuft denn iobroker
            Starte mal den Js-Controller neu und schau ob die Meldung wieder kommt
            Negalein 2 Replies Last reply Reply Quote 0
            • Negalein
              Negalein Global Moderator @crunchip last edited by
              @crunchip sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
              Ja und Nein
              War vorher auch schon ab und zu (Meldung Error: Login required. Check username and password.).
              Aber nicht mit den Errors wie gerade.
              Passwort 1000%ig richtig
              Im selben wie der Controller
              ioBroker: 10.0.1.200
              Controller: 10.0.1.151
              Hab noch keine VLAN laufen.
              mach ich noch 👍
                @negalein sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
                stimmt eventuell etwas mit deiner Voucher config nicht
                • Negalein
                  die hab ich noch garnicht aktiv.
                  Läuft derzeit noch ohne USG.
                  • Negalein
                    Meldung kommt trotzdem
                      @negalein hmm, du könntest noch node.js aktualisieren
                      • Negalein
                        komisch ist ja, dass es immer lief.
                        War nur der Fehler mit Password.
                        Der Adapter wurde ist aktuell seitdem ich ihn nutze.
                        crunchip F 2 Replies Last reply Reply Quote 0
                          crunchip Forum Testing Most Active @Negalein last edited by crunchip
                          @negalein aber den Js-Controller haste ja zwischenzeitlich angehoben, redis läuft auch schon immer, oder hast das auch erst umgestellt?
                          Redis war Blödsinn, haste ja gar nicht
                          • Negalein
                            Negalein Global Moderator @crunchip last edited by Negalein
                            Nein, der ist schon lange auf 3.1.6
                            Den aktuellen verwende ich noch nicht
                            Nein, hatte ich nie
                              Frank579 @Negalein last edited by
                              @negalein ich hatte kürzlich auch ein Problem mit dem Unifi Adapter, hatte damals eine beta vom Javascript installiert, frag aber bitte nicht welche 🙈.... Weiß auch nicht ob es die Fehlermeldung war, aber evtl. ein Versuch .Hab aktuell die 4.10.15 damit läuft es.
                                @negalein hast du den Unifi Controller selbst mal neu gestartet?
                                Was hast du alles aktiv in den Settings beim Unifi Adapter?, vllt mal bei allen die Aktualisierung deaktivieren und mal schauen, was dann im log erscheint.
                                  Controller 6.0.28
                                  hast du bewusst diese Version, aktuell ist v6.0.45
                                  • Negalein
                                    Negalein Global Moderator @Frank579 last edited by
                                    @frank579 sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
                                    Danke! Nach downgrade auf 4.10.15 sind die host Meldungen weg.
                                    auch schon neu gestartet.
                                    Werde mal alles deaktivieren und dann schaun.
                                    Ja, da am Anfang Meldungen auf FB waren, dass noch Fehler sind.
                                    unifi
                                    1346
