    4. Mysensors/rflink/modbus Serial tester verfügbar?
      apollon77 last edited by
      schon dabei … warte mal noch ne halbe Stunde 🙂
        Nimm mal https://github.com/Apollon77/iobroker.lacrosse :-))
          simpixo last edited by
          Wenn ich den schon installiert habe und jetzt aus deinem FORK installiere wird der installierte aktualisiert, oder!?
            As I know ja … weil der Name der gleiche ist
              Also hab es installiert! Die Daten kommen weiterhin rein, hab beim installieren die folgende Meldung erhalten! Adapter läuft wunderbar!!! [emoji1303]
              exit 0
              iobroker	2016-12-15 22:49:42.035	info	upload [0] lacrosse.admin /opt/iobroker/node_modules/iobroker.lacrosse/admin/index.html index.html text/html
              iobroker	2016-12-15 22:49:41.943	info	upload [1] lacrosse.admin /opt/iobroker/node_modules/iobroker.lacrosse/admin/lacrosse.png lacrosse.png image/png
              iobroker	2016-12-15 22:49:41.917	info	got /opt/iobroker/node_modules/iobroker.lacrosse/admin
              iobroker	2016-12-15 22:49:41.466	info	which is version 2.4.4
              iobroker	2016-12-15 22:49:41.466	info	unmet dependency
              iobroker	2016-12-15 22:49:41.466	info	npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/node_modules/debug,npm WARN
              iobroker	2016-12-15 22:49:41.465	info	unmet dependency /opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load
              iobroker	2016-12-15 22:49:41.464	info	npm WARN
              iobroker	2016-12-15 22:49:41.436	info	which is version 2.4.4
              iobroker	2016-12-15 22:49:41.436	info	unmet dependency
              iobroker	2016-12-15 22:49:41.433	info	WARN
              iobroker	2016-12-15 22:49:41.433	info	npm
              iobroker	2016-12-15 22:49:41.433	info	/opt/iobroker/node_modules/iobroker.lacrosse/node_modules/serialport/node_modules/debug,
              iobroker	2016-12-15 22:49:41.432	info	unmet dependency
              iobroker	2016-12-15 22:49:41.432	info	WARN
              iobroker	2016-12-15 22:49:41.431	info	npm
              iobroker	2016-12-15 22:49:41.430	info	WARN unmet dependency /opt/iobroker/node_modules/iobroker.lacrosse/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load
              iobroker	2016-12-15 22:49:41.428	info
              iobroker	2016-12-15 22:49:41.422	info	npm
              iobroker	2016-12-15 22:49:23.719	info	npm install https://github.com/Apollon77/iobroker.lacrosse/tarball/master --production --prefix "/opt/iobroker" (System call)
              iobroker	2016-12-15 22:49:23.618	info	install https://github.com/Apollon77/iobroker.lacrosse/tarball/master
              iobroker	2016-12-15 22:49:23.280	info	url "https://github.com/Apollon77/iobroker.lacrosse"
              Adrian
              Gesendet von iPad mit Tapatalk
                Hey, das ist nur ne Warnung … kommt von der serielport Library ...
                Also tut alles ?! Cool ... dann mache ich mirgen mal offizielle updates für alle 3 Adapter
                Ingo F
                  Also Sensorwerte kommen rein! Als wäre alles beim Alten!
                  Muss also funktionieren! [emoji6]
                    Danke für Deine Hilfe!!
                    Ich reiche die Änderungen mal offiziell ein
                      @apollon77:
                      Ich reiche die Änderungen mal offiziell ein `
                      Hallo apollon77
                      Kann das Update irgendwelche Auswirkungen auf andere Adapter haben!?
                      Irgendwie habe ich momentan mit paar Adaptern Probleme! Ich weiß aber nicht woran das liegt
                      Adrian
                        da jeder Adapter für sich läuft kann das eigentlich keine Nebenwirkungen haben …
                        2340
