    4. JavaScript
    5. [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
      MrLee last edited by
      Moin!
      Habe leider auch das Problem auf meinem Hauptsystem mi-home zum laufen zu bekommen...
      • mi-home im JavaScript Adapter eingefügt, Script gestartet
      -> Fehler im Log:
      javascript.0	2021-02-15 10:20:24.169	error	(179) script.js._Testing.mihome: Error: Cannot find module '/usr/local/iobroker/node_modules/iobroker.javascript/lib/../../node-mihome'
      mi-home liegt bei mir allerdings unter:
      '/usr/local/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome
      Kann man den Pfad umbiegen?
      Danke Euch!
      Mr.Lee
      M Thomas Braun 2 Replies Last reply Reply Quote 0
        MrLee @MrLee last edited by
        Nachtrag:
        Wenn ich den pfad im require auf:
        const mihome = require('iobroker.javascript/node_modules/node-mihome/');
        dann kommt im log:
        javascript.2	2021-02-15 10:40:12.688	error	(7570) at Object.<anonymous> (/usr/local/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/models.js:6:54)
        javascript.2	2021-02-15 10:40:12.688	error	(7570) at Array.forEach (<anonymous>:null:null)
        javascript.2	2021-02-15 10:40:12.688	error	(7570) at glob.sync.forEach.modelPath (/usr/local/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/models.js:9:23)
        javascript.2	2021-02-15 10:40:12.687	error	(7570) at require (internal/modules/cjs/helpers.js:25:18)
        javascript.2	2021-02-15 10:40:12.687	error	(7570) at Module.require (internal/modules/cjs/loader.js:692:17)
        javascript.2	2021-02-15 10:40:12.687	error	(7570) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        javascript.2	2021-02-15 10:40:12.686	error	(7570) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        javascript.2	2021-02-15 10:40:12.686	error	(7570) at Module.load (internal/modules/cjs/loader.js:653:32)
        javascript.2	2021-02-15 10:40:12.686	error	(7570) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        javascript.2	2021-02-15 10:40:12.685	error	(7570) script.js._Testing.mihome: /usr/local/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices/deerma.humidifier.jsq.js:5```
        Christian Maurer 1 Reply Last reply Reply Quote 0
        • Christian Maurer
          Christian Maurer @MrLee last edited by
          @mrlee
          Habe leider das gleiche Problem. Testweise habe ich eine neue VM aufgesetzt und iobroker frisch installiert, dann gehts ohne Probleme. Meine Installation hat schon einige Zeit auf dem Buckel, kann es vielleicht ein das durch die ganzen Updates irgend wo mal was "hängen" geblieben ist?
          Vielleicht kommt ja hier noch eine Lösung, ich denke ich werd aber jetzt mal versuchen wie es sich verhält wenn man ein Backup vom nicht funktionierenden System in die VM einspielt.
            Pittini Developer @Christian Maurer last edited by
            @christian-maurer Wie schon erwähnt, weder kann ichs reproduzieren noch isses ein Skriptfehler an sich. Ich hab absolut keine Ahnung warum das bei einigen vollkommen problemlos geht und bei anderen son Gedöns ist, evtl. hat @apollon77 oder @Dutchman ne spontane Idee dazu?
            Aber wir können ja derweil mal ne blöde Idee ausprobieren, was passiert denn wenn Du meine Fork, statt der orig. node-mihome im Adapteradmin angibst?
            W 2 Replies Last reply Reply Quote 0
              Wildbill @Pittini last edited by
              @pittini Ich habe es eben mal getestet, weil es mich genervt hat, immer wieder die devices von hand zu kopieren. in Deinem fork sind sie ja drin. Wusste gar nicht, dass das geht. ich habe im JS-Adapter dann aber den kompletten Pfad zu Github eintragen müssen.
              Es funktioniert, er holt sich beim Starten des JS-Adapters sauber alle devices. Allerdings habe ich dann jedesmal uch einen Error im log:
              javascript.0	2021-02-22 14:31:24.034	info	(6240) received all states
              javascript.0	2021-02-22 14:31:23.801	info	(6240) received all objects
              javascript.0	2021-02-22 14:31:21.471	info	(6240) requesting all objects
              javascript.0	2021-02-22 14:31:21.470	info	(6240) requesting all states
              javascript.0	2021-02-22 14:31:21.433	error	(6240) Cannot install npm packet: https://github.com/Pittini/node-mihome
              javascript.0	2021-02-22 14:31:21.378	info	(6240) found 0 vulnerabilities
              javascript.0	2021-02-22 14:31:21.298	info	(6240) + node-mihome@0.0.32 updated 1 package and audited 43 packages in 5.238s
              javascript.0	2021-02-22 14:31:15.284	info	(6240) npm install https://github.com/Pittini/node-mihome --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
              javascript.0	2021-02-22 14:31:15.257	info	(6240) found 0 vulnerabilities
              javascript.0	2021-02-22 14:31:15.183	info	(6240) + node-mihome@0.0.32 updated 1 package and audited 43 packages in 5.396s
              javascript.0	2021-02-22 14:31:09.171	info	(6240) npm install https://github.com/Pittini/node-mihome --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
              javascript.0	2021-02-22 14:31:09.144	info	(6240) found 0 vulnerabilities
              javascript.0	2021-02-22 14:31:09.055	info	(6240) + node-mihome@0.0.32 updated 1 package and audited 43 packages in 5.941s
              javascript.0	2021-02-22 14:31:02.479	info	(6240) npm install https://github.com/Pittini/node-mihome --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
              javascript.0	2021-02-22 14:31:02.458	info	(6240) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.20.2, js-controller: 3.2.16
              host.iobroker-vlan100	2021-02-22 14:31:00.878	info	instance system.adapter.javascript.0 started with pid 6240
              Keine Ahnung, warum die meldung kommt, das npm packet könne nicht installiert werden. Die devices habe ich drin (bis auf die 3 airpurifier nutze ich nichts anderes aus node-mihome) und alles in Javascript scheint korrekt zu laufen. Auch das Script für Xiaomi. Steuern und auslesen problemlos.
              Hast Du einen Tipp wegen des error?
              Gruss, Jürgen
                Pittini Developer @Wildbill last edited by Pittini
                @wildbill sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                Leider nein. Das is Systemebene, da hab ich wenig Ahnung von. Evtl. hat @apollon77 oder @Dutchman nen Tipp oder ne Idee?
                  Thomas Braun Most Active @MrLee last edited by
                  @mrlee sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                  Das riecht wieder nach einer 'krummen' node-Installation.
                  which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  anschauen.
                  Oder bei der Installation im falschen Verzeichnis gestanden.
                  • Christian Maurer
                    Christian Maurer @Thomas Braun last edited by
                    @pittini hat leider nix gebracht, gleicher Fehler, aber der tipp von @thomas-braun wars, ich weis nicht warum, aber apt hat anscheinend mein nodejs nicht aktualisiert (ist bei version 10 stehen geblieben).
                    iobroker gestoppt, nodejs mit apt purge runter geschmissen und anschließend neu installiert, dann iobroker wieder gestartet = funktioniert einwandfrei.
                    DANKE, vielleicht hilfts anderen ja auch.
                      Thomas Braun Most Active @Christian Maurer last edited by
                      @christian-maurer sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                      Dann ist dein Quellen-Verzeichnis nicht richtig.
                      Das Update von node via Paketmanager ist eigentlich absolut narrensicher.
                      • Christian Maurer
                        @thomas-braun said in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                        dachte ich bis jetzt auch, wie oben mal erwähnt ist es ein uraltes system das schon über zig debian versionen geupdatet wurde, ich kann mir nur vorstellen das da irgend wo mal was "hängen" geblieben ist. Habs grad nochmal kontroliert und das nodejs installscript hat die Dateien sauber bereinigt/neu angelegt.
                          Wie schaut denn das nun da aus bei dir?
                          sudo apt update
                          • Christian Maurer
                            sudo apt update
                            denke so wies sein sollte
                            OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                            Ign:2 http://deb.debian.org/debian stretch InRelease
                            OK:3 http://deb.debian.org/debian stretch-updates InRelease
                            OK:4 http://deb.debian.org/debian stretch Release
                            OK:5 https://repos.influxdata.com/debian stretch InRelease
                            OK:6 https://deb.nodesource.com/node_12.x stretch InRelease
                            Alle Pakete sind aktuell.
                              @christian-maurer
                              Ja, sollte passen.
                              Überleg dir aber in Kürze den Sprung weg von Stretch zu Buster zu tun.
                              Stretch lebt nicht mehr ewig lange.
                              • Christian Maurer
                                @christian-maurer
                                Ja, sollte passen.
                                schon erledigt, das ist halt das "Problem" mit solch stabilen systemen, so lange es läuft schaut man nicht nach ...
                                bin jetzt aber echt gespannt ob den anderen mit dem gleichen problem auch eine neuinstallation von nodejs hilft
                                Thomas Braun W 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @Christian Maurer last edited by Thomas Braun
                                  Beim @MrLee bin ich fast 100% sicher, dass da bei nodeJS was krumm ist.
                                  Ich hab das node-mihome nämlich bei mir auch laufen. Das liegt aber keines falls in /usr/local/ herum sondern das Ding wohnt schön sauber in /opt/iobroker/node_modules/node-mihome
                                    Wildbill @Christian Maurer last edited by Wildbill
                                    @christian-maurer
                                    Sollte man nicht tun. Das Grundsystem sollte immer aktuell gehalten werden. Erstens sieht man ja den einen Grund bei Dir, aber schon auch weil doch hin und wieder sicherheitsrelevante Dinge mit rein kommen. Ab und an mal das System updaten hat noch nie geschadet (OK vielleicht bei Windows schon... 😊 )
                                    Gruss, Jürgen
                                      Thomas Braun Most Active @Wildbill last edited by
                                      @wildbill
                                      Bei einem reinen Debian sind updates eigentlich ausschließlich aus der Sicherheitsecke, da wird ja in einer releasten Version eigentlich so gut wie nie eine neue Version einer Software rausgehauen, da backportet man eher nur den security relevanten Teil eines Updates und lässt vom Rest die Finger.
                                      Serverzentrierte Distribution halt.
                                        Wildbill @Thomas Braun last edited by
                                        @thomas-braun Hi, ist mir bekannt, nutze ich ja selbst unter anderem. Ich wollte nur @christian-maurer aufzeigen, warum es sinnvoll ist, das Grundsystem aktuell zu halten. Ersetzte das "hin und wieder" durch "fast ausschliesslich" und dann passt es.
                                        Aber die Grundaussage gilt für jedes System, sei es ein Linux, Windows, oder was auch immer. Es ist besser, das System aktuell zu halten, als sich zu sagen, läuft grad so gut, da mache ich nix dran. Auch wenn Windows da anscheinend wohl schon viele eines besseren belehrt hat?! Und ja, ich mag es einfach nicht. Reicht mir auf dem Geschäfts-Rechner, muss ich privat nicht auch noch haben...
                                        Gruss, Jürgen
                                          @pittini sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                                          kann davon nur abraten. Ich musste heute Morgen ein Backup (Proxmox macht es Gottseidank einfach) einspielen. Ich bekam beim Installieren von Adaptern und auch beim Aktualisieren nur noch Fehler, die alle immer auf Mihome-038 irgendwas hinwiesen. habe sie mir leider nicht aufgeschrieben und das Backup hat die alten Logs gelöscht. Auch Entfernen aus dem JS-Adapter und manuelles Löschen des Mihome-Ordners hat da nichts geholfen. Irgendwas hatte sich da verbogen.
                                          Das System ief ansonsten problemlos.
                                          Gruss, Jürgen
                                            Das ist natürlich doof wenn das daran lag. Setz Dich doch bitte mal mit dem "Erfinder" der Idee hier auseinander, evtl. kann der was dazu sagen: https://github.com/Pittini/iobroker-nodemihome/issues/12
                                            ylmzdev created this issue in Pittini/iobroker-nodemihome
                                            closed Use forked Repo until PR is merged at node-mihome #12
                                            458
                                            91998
