    4. Test Adapter Z-Wave 2 (v1.8.x)
    • AlCalzone
      AlCalzone Developer @wellknownasmax last edited by AlCalzone
      @wellknownasmax Kannst du das Logfile mal herunterladen und hier posten?
      Und kannst du bitte mal eine ZWave-Logdatei erstellen, das Problem herbeiführen und ebenfalls hier posten?
      ==> https://github.com/AlCalzone/ioBroker.zwave2/blob/master/docs/de/bei-problemen.md#notwendige-informationen-für-ein-issue
        wellknownasmax @AlCalzone last edited by
        @alcalzone
        16:59:37.918 CNTRLR   [Node 013] [~] [Multilevel Switch] currentValue: 26 => 24         [Endpoint 0]
        16:59:37.919 SERIAL » [ACK]        (0x06)
        16:59:37.920 DRIVER « [Node 013] [REQ] [ApplicationCommand]
                              └─[MultilevelSwitchCCReport]
                                  current value: 24
        16:59:48.990 SERIAL « 0x010a00040011028407c100a0                                          (12 bytes)
        16:59:48.991 SERIAL » [ACK]        (0x06)
        16:59:48.991 DRIVER « [Node 017] [REQ] [ApplicationCommand]
                              └─[WakeUpCCWakeUpNotification]
        16:59:48.992 CNTRLR « [Node 017] received wakeup notification
        16:59:48.993 CNTRLR   [Node 017] The node is now awake.
        16:59:49.993 CNTRLR » [Node 017] Sending node back to sleep...
        16:59:50.000 SERIAL » 0x0109001311028408252877                                            (11 bytes)
        16:59:50.001 DRIVER » [Node 017] [REQ] [SendData]
                              │ transmit options: 0x25
                              │ callback id:      40
                              └─[WakeUpCCNoMoreInformation]
        16:59:50.003 SERIAL « [ACK]        (0x06)
        16:59:50.009 SERIAL « 0x0104011301e8                                                       (6 bytes)
        16:59:50.010 SERIAL » [ACK]        (0x06)
        16:59:50.010 DRIVER « [RES] [SendData]
                                was sent: true
        16:59:50.029 SERIAL « 0x011800132800000200c17f7f7f7f00000300000000030100001e              (26 bytes)
        16:59:50.030 SERIAL » [ACK]        (0x06)
        16:59:50.030 DRIVER « [REQ] [SendData]
                                callback id:     40
                                transmit status: OK
        16:59:50.034 CNTRLR   [Node 017] The node is now asleep.
        17:00:49.995 SERIAL « 0x010a00040012029840c300fa                                          (12 bytes)
        17:00:49.997 SERIAL » [ACK]        (0x06)
        17:00:49.998 DRIVER « [Node 018] [REQ] [ApplicationCommand]
                              └─[SecurityCCNonceGet]
        17:00:50.010 SERIAL » 0x01110013120a9880c6f8737c0d7062240529db                            (19 bytes)
        17:00:50.011 DRIVER » [Node 018] [REQ] [SendData]
                              │ transmit options: 0x05
                              │ callback id:      41
                              └─[SecurityCCNonceReport]
                                  nonce: 0xc6f8737c0d706224
        17:00:50.014 SERIAL « [ACK]        (0x06)
        17:00:50.019 SERIAL « 0x0104011301e8                                                       (6 bytes)
        17:00:50.020 SERIAL » [ACK]        (0x06)
        17:00:50.021 DRIVER « [RES] [SendData]
                                was sent: true
        17:00:50.185 SERIAL « 0x011800132900001101c47f7f7f7f0001030f0000000201000007              (26 bytes)
        17:00:50.186 SERIAL » [ACK]        (0x06)
        17:00:50.186 DRIVER « [REQ] [SendData]
                                callback id:     41
                                transmit status: OK
        17:00:50.313 SERIAL « 0x0125000400121d9881e1deb84cae0e94dad241faba87797f9d59fbc69e99edb65 (39 bytes)
                              7fcfb76c400f8
        17:00:50.315 SERIAL » [ACK]        (0x06)
        17:00:50.318 DRIVER « [Node 018] [REQ] [ApplicationCommand]
                              └─[SecurityCCCommandEncapsulation]
                                │ sequenced: false
                                └─[NotificationCCReport]
                                    notification type:   Access Control
                                    notification status: 255
                                    notification event:  Keypad lock operation
        17:00:50.456 SERIAL « 0x010a00040012029840c400fd                                          (12 bytes)
        17:00:50.456 SERIAL » [ACK]        (0x06)
        17:00:50.459 DRIVER « [Node 018] [REQ] [ApplicationCommand]
        17:00:50.467 SERIAL » 0x01110013120a9880d6177db2dc4338f6052a8d                            (19 bytes)
        17:00:50.468 DRIVER » [Node 018] [REQ] [SendData]
                              │ callback id:      42
                                  nonce: 0xd6177db2dc4338f6
        17:00:50.470 SERIAL « [ACK]        (0x06)
        17:00:50.475 SERIAL « 0x0104011301e8                                                       (6 bytes)
        17:00:50.475 SERIAL » [ACK]        (0x06)
        17:00:50.476 DRIVER « [RES] [SendData]
                                was sent: true
        17:00:50.607 SERIAL « 0x011800132a00000d01c47f7f7f7f0001030f0000000201000018              (26 bytes)
        17:00:50.608 SERIAL » [ACK]        (0x06)
        17:00:50.608 DRIVER « [REQ] [SendData]
                                callback id:     42
                                transmit status: OK
        17:00:50.701 SERIAL « 0x0123000400121b9881dff663b9c1a0e9eddb2963a18708f083d61466ddc0eb6bb (37 bytes)
                              ed6c40007
        17:00:50.702 SERIAL » [ACK]        (0x06)
        17:00:50.703 CNTRLR   [Node 018] [~] [Door Lock] currentMode: 0 => 255                  [Endpoint 0]
        17:00:50.704 CNTRLR   [Node 018] [~] [Door Lock] outsideHandlesCanOpenDoor: true,false, [Endpoint 0]
                              false,false => true,false,false,false
        17:00:50.704 CNTRLR   [Node 018] [~] [Door Lock] insideHandlesCanOpenDoor: true,false,f [Endpoint 0]
        17:00:50.705 CNTRLR   [Node 018] [~] [Door Lock] latchStatus: "open" => "closed"        [Endpoint 0]
        17:00:50.705 CNTRLR   [Node 018] [~] [Door Lock] boltStatus: "unlocked" => "locked"     [Endpoint 0]
        17:00:50.706 CNTRLR   [Node 018] [~] [Door Lock] doorStatus: "open" => "closed"         [Endpoint 0]
        17:00:50.707 DRIVER « [Node 018] [REQ] [ApplicationCommand]
                                │ sequenced: false
                                └─[DoorLockCCOperationReport]
                                    current mode:           Secured
                                    active outside handles: true, false, false, false
                                    active inside handles:  true, false, false, false
                                    latch status:           closed
                                    bolt status:            locked
                                    door status:            closed
        17:01:23.630 SERIAL « 0x010a00040012029840c300fa                                          (12 bytes)
        17:01:23.631 SERIAL » [ACK]        (0x06)
        17:01:23.631 DRIVER « [Node 018] [REQ] [ApplicationCommand]
        17:01:23.637 SERIAL » 0x01110013120a98805b9aa75aa55d67bd052bcd                            (19 bytes)
        17:01:23.638 DRIVER » [Node 018] [REQ] [SendData]
                              │ callback id:      43
                                  nonce: 0x5b9aa75aa55d67bd
        17:01:23.640 SERIAL « [ACK]        (0x06)
        17:01:23.646 SERIAL « 0x0104011301e8                                                       (6 bytes)
        17:01:23.646 SERIAL » [ACK]        (0x06)
        17:01:23.647 DRIVER « [RES] [SendData]
                                was sent: true
        17:01:23.770 SERIAL « 0x011800132b00000c01c47f7f7f7f0001030f0000000201000018              (26 bytes)
        17:01:23.770 SERIAL » [ACK]        (0x06)
        17:01:23.771 DRIVER « [REQ] [SendData]
                                callback id:     43
                                transmit status: OK
        17:01:23.897 SERIAL « 0x012d00040012259881a8a4d273dbd4b29918e39697599383ac38dfc6596743940 (47 bytes)
                              ee3625b56a3cf7a98279721c400ff
        17:01:23.898 SERIAL » [ACK]        (0x06)
        17:01:23.902 CNTRLR   [Node 018] [~] [User Code] userIdStatus[2]: 1 => 1                [Endpoint 0]
        17:01:23.903 CNTRLR   [Node 018] [~] [User Code] userCode[2]: "5397" => "5397"          [Endpoint 0]
        17:01:23.904 DRIVER « [Node 018] [REQ] [ApplicationCommand]
                                │ sequenced: false
                                    notification event:  Keypad unlock operation
                                    event parameters:    [object Object]
        17:01:23.955 DRIVER   destroying driver instance...
        Node ID des Danalock ist 018
        AlCalzone 2 Replies Last reply Reply Quote 0
        • AlCalzone
          @wellknownasmax Super, danke! Jetzt bräuchte ich noch deinen Netzwerkschlüssel. Kannst du mir per PN schicken.
          • AlCalzone
            @wellknownasmax Sollte in der nächsten Version gefixt sein. Bin grade noch an nem anderen Problem dran, danach kann ich releasen.
            • AlCalzone
              1.8.11 auf dem Weg - Changelog oben!
                Rolf_KA @AlCalzone last edited by
                @alcalzone
                Du bist einfach perfekt 👌 ☺
                  @alcalzone
                  funktioniert jetzt fehlerfrei!
                  Vielen Dank!!
                    Schlumpf last edited by
                    Hallo an alle,
                    ich hab mal ein kleines Problem. 😂
                    Warscheinlich wurde es schon irgendwo beantwortet oder es ist selbsterklähren und ich komm nur einfach nicht drauf. Ich habe bei mir mehrere Fibaro Rauchmelder und diese in ein Skript eingebunden. Gestern, nachdem ich mal ein "Netzwerk heilen" durchlaufen ließ, sind diese Skripte ausgelöst worden.
                    Bisher haben ich mich als Auslöser auf den Parameter zwave2.0.Node_013.Notification.smokeAlarm_alarmStatus gestützt und hier die abfrage auf "= 0" aufgebaut. Scheinbar hat sich der Wert der hier geschrieben wird geändert oder ich habe, warum auch immer, hier eine falsche annahme getroffen und das ganze falsch abgefragt.
                    Meine Frage: Wo und wie wird mir denn ein Rauchmelderalarm angezeigt bzw. wo rufe ich diesen ab?
                    Jan
                    • Troya
                      Troya last edited by
                      Nabend in die Runde,
                      Ich muss nochmal mit den currentvalue und targetvalue nerven. Ich meine die sollten doch mittlerweile ohne den Haken in den Optionen den gleichen Status behalten, aber bei mir ist das immernoch nicht der Fall.
                      Z. B. Bei meinem erneut frisch inkludiertem Asus Schloss, aber auch bei einem vor langen inkludierten Fibaro FGS223:
                      Schalte ich per Hand den Lichtschalter ein, wird der currentvalue Wert auf ON gesetzt, der targetvalue Wert bleibt aber bei OFF.
                      Oder soll das so sein, dass quasi der currentvalue den Hardware Zustand zeigt und der targetvalue den Software Zustand?
                      • AlCalzone
                        AlCalzone Developer @Troya last edited by
                        @troya sagte in Test Adapter Z-Wave 2 (v1.8.x):
                        Wie kommst du drauf, dass sich da was geändert hat?
                        An sich heißt currentValue "hier bin ich" und targetValue "hier will ich hin".
                        Wenn Geräte den targetValue nicht berichten, was vor allem ältere Geräte tun, dann kann der Wert in ioBroker nicht aktualisiert werden. Dafür ist die Option da.
                        • AlCalzone
                          AlCalzone Developer last edited by AlCalzone
                          Version 1.8.12 ist auf dem Weg - kurzer Changelog wieder oben.
                          Die detaillierte (englische) Liste findet sich hier - manches davon trifft aber nicht direkt auf den Adapter zu:
                          https://github.com/zwave-js/node-zwave-js/blob/master/CHANGELOG.md (6.4.0 und 6.5.0)
                          • Z
                            Zuki last edited by Zuki
                            Ich habe letztens meine ioBroker Instanz von einem Synology Docker zu einer Proxmox VM umgezogen. Mit Backup und Restore kein Problem. Allerdings lies sich per Z-Wave 2 Adapter danach keine Geräte mehr steuern. Nicht so wild, ich habe nicht so viele Z-Wave Geräte. Also alle vom Aeon Z-Stick entkoppelt und neu gekoppelt. Leider keine Änderung. Also habe ich den Z-Stick und alle Geräte resettet um quasi wieder bei Null anzufangen.
                            Jetzt habe ich aber zwei Probleme die im Docker nicht auftraten:
                            1. Meine Schalter und die Fibaro Zwischenstecker funktionieren einwandfrei. Nur zum Fibaro Rollershutter 2 der die Projektorleinwand steuert lässt sich keine Verbindung mehr aufbauen. Ich kann den Aktor normal anlernen aber der Gerätetyp wird von Z-Wave Adapter auch nach längerer Wartezeit nicht erkannt. Der Log zeigt folgendes, und zwar durchgehend. Node 5 ist dabei natürlich der Rolladenaktor.
                              Wie gesagt, die anderen Geräte funktionieren.
                            2. Problem: Das Anlernen (egal ob verschlüsselt oder unverschlüsselt) lässt sich nicht mehr vom Adapter aus starten. Somit musste ich aller Geräte per Hardwarebutton auf dem Z-Stick anlernen. Was natürlich unverschlüsselt stattfindet...
                              Wenn ich den Stick per Adapter in den Anlernmodus schalte, findet einfach kein Paring statt.
                            Hat jemand Tipps für mich was falsch laufen könnte?
                            • AlCalzone
                              AlCalzone Developer @Zuki last edited by
                              @zuki sagte in Test Adapter Z-Wave 2 (v1.8.x):
                              Die Verbindung bzw. Route zu/von Node 5 ist schlecht - versuch es mal mit Netzwerk heilen. Hast du beim Umzug die physische Position des Sticks geändert?
                              Hast du Logs? ==> https://github.com/AlCalzone/ioBroker.zwave2/blob/master/docs/de/bei-problemen.md#notwendige-informationen-für-ein-issue
                              • Z
                                Zuki @AlCalzone last edited by
                                @alcalzone Danke für die Hilfe.
                                Ich habe noch einen zusätzlichen Z-Wave Zwischenstecker installiert. Das scheint das Netz so stabilisiert zu haben das nun alles funktioniert. Danke für den Tipp.
                                Dabei habe ich auch nochmal den Z-Wave stick ausgesteckt, resettet und in einen anderen USB Port gesteckt. Keine Ahnung was nun geholfen hat aber nun funktioniert auch das Anlernen wieder 👍
                                • Thomas Jansen
                                  Thomas Jansen last edited by Thomas Jansen
                                  @AlCalzone Huhu, ich habe mein Zwave Netzwerk jetzt komplett auf Deinen Adapter umgestellt. Ein Aktor jedoch ist unter dem alten Zwave Adapter funktionsfähig mit Datenpunkten, in Deinem Adapter jedoch findet er nur einige wenige. Es handelt sich um die Zwave Innensirene von VISION. Kennst Du die? Ich bekomme keinen Datenpunkt bezüglich der Auslösung auch nicht um den Alarm zurückzustellen?Vision.JPG
                                  HAT SICH ERLEDIGT GEFUNDEN!!! MEIN FEHLER!!! 😉
                                  • gelberlemmy
                                    gelberlemmy @AlCalzone last edited by
                                    @alcalzone guten Morgen, nachdem bei einem Bewegungsmelder die Batterie für einen Tag leer war,
                                    war dieser nach Austausch nicht mehr im Netz registriert. Da ich glücklicherweise mit Alias arbeite,
                                    ja kein Thema. Neu anlernen und gut. Nun hat er eine andere Node Nr. bekommen. Auch kein Problem. Aber warm ist bei den Node Nr, so eine groß Lücke ? Ich habe dort keine Geräte mehr anlernen wollen, was dieses Verhalten erklären könnte. Wobei mich diese große Lücke jetzt nicht stört,
                                    Aber was ist, wenn ich irgendwann das Maximum der Anzahlen erreiche ? Wie bekomme ich die bereits fehlenden Nummern wieder zurück ? Gibt es da einen Tipp ?
                                    Gruß André
                                    • AlCalzone
                                      AlCalzone Developer @gelberlemmy last edited by
                                      @gelberlemmy sagte in Test Adapter Z-Wave 2 (v1.8.x):
                                      Das kann nicht sein. Da ist irgendwas anderes passiert, z.B. am Gerät zurückgesetzt.
                                      Kann ich mir auch nicht. Hast du zufällig einen Stick, bei dem man auch am Stick per Knopfdruck Geräte selbst an- und ablernen kann?
                                      Sehr mysteriös, aber ich fürchte ohne dass du zufällig ein Log laufen hattest, finden wir das nicht mehr raus.
                                      Dann fängt es bei der ersten freien Zahl wieder an. Du könntest den BWM noch 112 mal ab- und anlernen, dann hast du diesen Zustand erreicht 😵
                                      gelberlemmy 1 Reply Last reply Reply Quote 0
                                      • gelberlemmy
                                        gelberlemmy @AlCalzone last edited by gelberlemmy
                                        @alcalzone sagte in Test Adapter Z-Wave 2 (v1.8.x):
                                        Du wirst es mir nicht glauben, aber ich habe einen Log 😊
                                        Also ich habe einmal geschaut, das Gerät ist nicht zurückgesetzt, Dort sind noch die geänderten Einstellungen von mir enthalten. Nein ich habe keinen Taster auf dem Stick.
                                        Hmmm.. Schicke Dir einmal den Log. Das Gerät war früher Node 073.
                                        Habe aber gesehen, hatte den Node 073 vor neu anlernen nicht gelöscht....👮‍♀️
                                        Gruß André
                                        • AlCalzone
                                          @gelberlemmy
                                          Um 7:21 (ich weiß nicht welcher Tag) hast du Ausgefallenes Gerät entfernen geklickt. Daraufhin wurde Node 73 aus dem Netzwerk entfernt (Logzeile 111210).
                                          07:21:21.919 DRIVER » [REQ] [RemoveFailedNode]
        payload: 0x496b
                                          Node 121 scheint aber schon wesentlich länger Teil des Netzwerks zu sein (Logzeile 7288) - zumindest glaubt er das. Der Controller (Stick) kennt ihn nicht. Entweder ist das ein anderer, oder Node 73 ist eigentlich schon ewig 121 ohne dass du ihn je angelernt hast... 😮
                                          21:42:28.489 DRIVER « [Node 121] [REQ] [ApplicationCommand]
                                          21:42:28.491 DRIVER     the node is unknown or not initialized yet, discarding...
                                          In Zeile 108249 hast du ihn dann eingelernt, wobei er die von ihm genutzte ID behalten hat:
                                          07:16:52.480 CNTRLR   finished adding node 121:
                                          Ich weiß zwar nicht, warum der überhaupt glaubt, Teil des Netzwerks zu sein, wenn der Stick ihn nicht kennt. Aber das erklärt zumindest den ID-Sprung.
                                          • Fred Freund
                                            Fred Freund last edited by
                                            ich haette eine Frage zu meinen Fibaro Motion Sensor Fibargroup FGMS001 , wenn ich die Konfiguration aendern will bekomme ich
                                            does not support the Command Class Configuration!
                                            Dh ich kann die LED nicht abdrehen oder dergleichen.
                                            Koennt Ihr bitte einen Tipp geben wo ich den Fehler suchen koennte.
                                            Vielen Dank
                                            31.7k
                                            79.8k
                                            test z-wave zwave
                                            32
                                            325
                                            44395
