    4. Test Adapter Shelly v4.0.6 (latest)
    • Amnesia1211
      Amnesia1211 @Stuebi last edited by Amnesia1211
      @stuebi
      Nein es ist kein Passwort gesetzt. Hier die Einstellungen:
      Nach einer komplett neuen Einbindung kommt jetzt die Meldung:
      shelly.0	2021-02-21 23:18:31.139	error	(7339) Error in function httpIoBrokerState for state SHMOS-01#60A4239A67C0#1.name and request{"url":"http://192.168.178.35/settings","timeout":5000,"headers":{"Authorization":"Basic Um9iZXJ0S3JpdHpsZX
      shelly.0	2021-02-21 23:18:31.126	error	(7339) Error in function httpIoBrokerState for state SHMOS-01#60A4239A67C0#1.rssi and request{"url":"http://192.168.178.35/status","timeout":5000,"headers":{"Authorization":"Basic Um9iZXJ0S3JpdHpsZXJA
      shelly.0	2021-02-21 23:18:31.125	error	(7339) Error in function httpIoBrokerState for state SHMOS-01#60A4239A67C0#1.uptime and request{"url":"http://192.168.178.35/status","timeout":5000,"headers":{"Authorization":"Basic Um9iZXJ0S3JpdHpsZX
      shelly.0	2021-02-21 23:17:30.897	error	(7339) Error in function httpIoBrokerState for state SHMOS-01#60A4239A67C0#1.name and request{"url":"http://192.168.178.35/settings","timeout":5000,"headers":{"Authorization":"Basic Um9iZXJ0S3JpdHpsZX
      shelly.0	2021-02-21 23:17:30.882	error	(7339) Error in function httpIoBrokerState for state SHMOS-01#60A4239A67C0#1.rssi and request{"url":"http://192.168.178.35/status","timeout":5000,"headers":{"Authorization":"Basic Um9iZXJ0S3JpdHpsZXJA
      shelly.0	2021-02-21 23:17:30.881	error	(7339) Error in function httpIoBrokerState for state SHMOS-01#60A4239A67C0#1.uptime and request{"url":"http://192.168.178.35/status","timeout":5000,"headers":{"Authorization":"Basic Um9iZXJ0S3JpdHpsZX
      shelly.0	2021-02-21 23:17:30.854	error	(7339) Error in function setMqttPrefixHttp() for request{"url":"http://192.168.178.35/settings","timeout":5000,"headers":{"Authorization":"Basic Um9iZXJ0S3JpdHpsZXJAd2ViLmRlOlZhbmVzc2ExMjEx"}} for 192
      Erkannt wird er jetzt wie es aus sieht, leider nur ohne Werte
      • da_Woody
        da_Woody @Stuebi last edited by
        @stuebi ohoh, ich bin nicht mehr der einzige...
        https://www.shelly-support.eu/forum/index.php?thread/7382-shellys-aktualisieren-sich-nicht-mehr-im-iobroker-adapter/
        Stuebi 1 Reply Last reply Reply Quote 0
        • Stuebi
          Stuebi @da_Woody last edited by
          @da_woody , steht eigentlich etwas im Logfile? Meldet sich der Shelly dort ab?
          • da_Woody
            @stuebi nein, da meldet sich nichts ab. blinkt ja auch regelmässig grün auf. nach dem adapter neustart:
            alles funktioniert, ich kann über iqontrol licht ein/ausschalten, switch state wird danach schwarz -> korrekt. auch in der shelly app wird richtig angezeigt.
            nach ca. 4 minuten, alles wird aktualisiert, (bis auf switch und input) wird zwar korrekt geschalten, der switch state wird aber rot. somit kein korrektes ergebniss.
            funktioniert zwar ioBroker intern, wird auch in der app angezeigt, sobald ich dann in der app schalte, stimmt der state nicht mehr überein.
            wenn ich dann in iqontrol 2x schalte stimmen zwar die anzeigen wieder in iqontrol und app, der switch bleibt aber bei rot.
            gerade noch mit alexa getestet. das selbe spiel. nach adapter neustart alles ok, nach 4 minuten das selbe.
            wenn es an meine netzwerkverkabelung liegen würde, dann dürfte das IMHO auch die 4 minuten nicht funktionieren.
            für mich absolut unlogisch das ganze.
            • Stuebi
              Stuebi @da_Woody last edited by Stuebi
              @da_woody , kannst du mal folgendes tun.
              Test 1:
              Wenn nach den 4 Minuten der State Relay.Switchsich rot ist, d.h. die Änderungen von der App nicht mehr mitbekommt, ändere dann den State name des Gerätes in der Shelly App (nicht in ioBroker!!). Ändert sich dann der Name in ioBroker?
              Test 2:
              Jetzt einmal die ioBroker Instanz stoppen und das coaptest.js Programm aufrufen und nur auf den einen Shelly Switch welcher Probleme bereitet ein grep ausführen. Wie das geht steht oben. Du solltest jetzt CoAP Nachrichten für den Shelly Switch sehen. Du solltest die Änderungen durch die Shelly App hier sehen. 1101 -> 0 und 1101 -> 1. Das sollte funktionieren, wenn nicht rufst Du das Testprogramm falsch auf. Wenn das funktioniert, wartest du 5-10 Minuten und schaltest wieder über die App. Du solltest dann hoffentlich immer noch die Änderungen von 1101 -> 0 auf 1101 -> 1 sehen. Wenn nicht, kommen wir dem Fehler näher.
              • da_Woody
                @stuebi said in Test Adapter Shelly v4.0.6 (latest):
                Test 1:
                jup, das funktioniert. aber nur, wenn ich die ip im browser aufrufe zum ändern.
                Test 2:
                der erste:
                2021-02-23T19:05:43.257Z - 192.168.1.227:5683 - P>'3citsm
        SHSW-1#98F4ABF32C58#2R{"G":[[0,9103,4],[0,1101,1],[0,2101,0],[0,2102,""],[0,2103,0]]}
                2021-02-23T19:05:44.292Z - 192.168.1.227:5683 - P>(3citsm
        SHSW-1#98F4ABF32C58#2R{"G":[[0,9103,4],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                der zweite:
                2021-02-23T19:18:32.903Z - 192.168.1.227:5683 - P>u3citsm
                2021-02-23T19:18:34.002Z - 192.168.1.227:5683 - P>v3citsm
                15 min später... durchgehend deaktivierte instanz. warum zum geier hat die schrift da andere farben???
                allerdings wurde von synology vorgeschlagen:
                "Falls ja können SIe mit dem Befehl "synoctf -r test" das NSS auf Ihrem CAP (Hauptrouter) deaktivieren. Bitte verbinden SIe im Anschluss das IoT-Gerät mit Ihrem CAP und testen das ganze erneut."
                hat allerdings nichts geholfen...
                • Stuebi
                  @da_woody , was meinst Du mit deaktivierter Instanz bei dem CoAP Test (Test 2)?
                  • da_Woody
                    da_Woody @Stuebi last edited by da_Woody
                    @stuebi instanz gestoppt! sonst würds ja nicht funktionieren.
                    • Stuebi
                      @da_woody , ich verstehe es nicht. Du schaltest für Test 2 die Shelly Instanz in ioBroker aus und startest dann coaptest.js. Was bedeutet dann "15 min später... durchgehend deaktivierte instanz"? Wenn Du die Instanz ausstellst, dann ist sie aus 🙂
                      • da_Woody
                        @stuebi ok, ich hab für Test 2, vor dem der erste die instanz gestoppt, um 19:05 den test gemacht, bis 19:18 gewartet, der zweite gemacht. also zwischendurch die instanz nicht gestartet. jetzt verständlicher?
                        das alte ösi -> germanisch problem... 😄
                        • Stuebi
                          @da_woody , hast Du zwischen 19:05 und 19:18 das script coaptest.js gestoppt?
                          • da_Woody
                            @stuebi nein, das war durchgehend gestoppt!
                            • Stuebi
                              @da_woody , ??? Du sollst aber die Shelly Instanz stoppen, dann den coaptest.js starten. Das lässt Du jetzt ohne es zu stoppen mindestens 10 Minuten laufen. Nach dem Start des coaptest.js bedienst du den Shelly Switch über App . Dann wartest du 5 min. ohne das coaptest.js script zu stoppen und bedienst nochmals die Shelly App. Mich interessiert der Output am Anfang und nach mindestens 5 min.
                              Das Testscript darf zwischendurch nicht beendet werden. Die Shelly Instanz darf während des ganzen Tests nicht aktiv sein
                              • da_Woody
                                @stuebi axo! das was anderes! klar hab ich den test gestoppt. das problem ist das bei mir der grep weder mit der is noch der IP funktioniert. aber gut, ich suchs dann raus...
                                • Stuebi
                                  @da_woody , Hintergrund des Tests ist, dass wir mit dem Script den ioBroker Shelly Adapter simulieren. Deswegen muss das Script durchgehend laufen.
                                  Wir wollen schauen ob die CoAP Werte nach mindestens 5 min (gerne auch nach 10 min), sich immer noch ändern. D.h. 1101 -> 0 ändert sich 1101 -> 1 oder umgekehrt. Bitte nicht vor 5 min ein zweitesmal mit der Shelly App schalten!
                                  Ist das nicht der Fall, dann liegt der Fehler in der CoAP Library oder am Shelly. Wir wollen den Fehler damit eingrenzen.
                                  • da_Woody
                                    @stuebi so, nach 5 minuten:
                                    2021-02-23T21:05:15.323Z - 192.168.1.227:5683 - P@3citsm
        SHSW-1#98F4ABF32C58#2RC{"G":[[0,9103,4],[0,1101,1],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    2021-02-23T21:05:16.906Z - 192.168.1.227:5683 - P@3citsm
        SHSW-1#98F4ABF32C58#2RC{"G":[[0,9103,4],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    nach 10 minuten mit 2 shelly1:
                                    2021-02-23T21:19:52.284Z - 192.168.1.221:5683 - Pk3citsm
        lSHSW-1#B8DF91#2RC{"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    2021-02-23T21:19:54.510Z - 192.168.1.221:5683 - Pk3citsm
        lSHSW-1#B8DF91#2RC{"G":[[0,9103,1],[0,1101,1],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    2021-02-23T21:19:56.089Z - 192.168.1.221:5683 - Pk3citsm
                                    2021-02-23T21:19:57.865Z - 192.168.1.221:5683 - Pk3citsm
                                    2021-02-23T21:19:51.804Z - 192.168.1.227:5683 - P@<3citsm
                                    2021-02-23T21:19:53.493Z - 192.168.1.227:5683 - P@=3citsm
                                    2021-02-23T21:19:55.303Z - 192.168.1.227:5683 - P@>3citsm
                                    2021-02-23T21:19:56.958Z - 192.168.1.227:5683 - P@?3citsm
                                    • Dominik F.
                                      Dominik F. @Stuebi last edited by
                                      @stuebi
                                      Hallo, ich habe folgendes Problem mit der Version 4.06 /4.07 Beta.
                                      Habe einen Powerline Adapter dem Mesh hinzugefügt ( zusätzlich zu einem weiteren Powerline Adapter und einem Repeater, alles von Fritzbox), da ein Shelly fast keinen Empfang hatte und nur sporadisch funktionierte.
                                      Effekt war, dass alle Shellys die mit einem Powerline Adapter verbunden waren, auch mit dem der bereits vorhanden war, nicht mehr vom Adapter erkannt wurden. Nach entfernen des Adapters waren alle sofort wieder da.
                                      Hast du eine Ahnung woran es liegen könnte?
                                      • Stuebi
                                        Stuebi @Dominik F. last edited by
                                        @dominik-f , ich denke der Powerline Adapter reicht keine CoAP Nachrichten weiter. Du musst einmal schauen ob am Powerline Adapter irgendetwas mit igmpv3 oder Multicast einstellen kannst.
                                        Dominik F. 1 Reply Last reply Reply Quote 0
                                        • Dominik F.
                                          @stuebi
                                          Es gibt nur sowas hier : Multiple Input Multiple Output (MIMO)
                                          Das habe ich aktiviert und bei dem, der das Problem verursacht auch.
                                          • Stuebi
                                            Stuebi @Dominik F. last edited by Stuebi
                                            Shelly Motion und Firmware 1.1.0 im CoAP Modus
                                            Wenn ihr den Shelly Motion mit CoAP nutzt, müsst Ihr umbedingt unter dem Punkt Internet & Security -> COIOT die IP Adresse mit dem Port 5683 vom ioBroker eintragen. Bsp. 192.168.20.30:5683
                                            da_Woody Latzi 2 Replies Last reply Reply Quote 0
                                            79.9k
                                            shelly
                                            34
                                            360
                                            45770
