    4. trådfri nach Update Fehlermeldungen?
      Michaelnorge last edited by
      Hallo
      Ich habe Fehlermeldungen des Trådfri-Adapters im Log entdeckt.
      Die tauchen beim Start des Adapters auf sowie wenn ich die Rolläden steuere.
      Beim Öffnen der Handyapp wurde ich informiert daß das Gateway einen Update bekommen hat.
      Version Gateway: 1.13.21
      Version Rolläden: 2.2.009
      Version Signalverstärker: 2.2.005
      Kann diese Fehlermeldungen jemand bestätigen?
      Liegt es am Update des Gateways?
      Viele Grüße
      Michael
      2021-02-22 18:56:30.689 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.690 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"TRADFRI Signal Repeater","2":"","3":"2.2.005","6":1,"7":4354}
      2021-02-22 18:56:30.707 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.707 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":94}
      2021-02-22 18:56:30.720 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.721 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":94}
      2021-02-22 18:56:30.732 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.732 - warn: tradfri.0 (15441) object was: {"0":"\u0002KE","1":"TRADFRI open/close remote","2":"","3":"2.2.010","6":3,"7":4549,"9":47}
      2021-02-22 18:56:30.743 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.744 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":98}
      2021-02-22 18:56:30.755 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.755 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":95}
      2021-02-22 18:56:30.767 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.768 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"KADRILJ roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":97}
      2021-02-22 18:56:30.782 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.782 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":96}
      2021-02-22 18:56:30.795 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.796 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":97}
      2021-02-22 18:56:30.807 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.808 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":99}
      2021-02-22 18:56:30.823 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.823 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":98}
      2021-02-22 18:56:30.841 - warn: tradfri.0 (15441) found unknown property with key 7
      2021-02-22 18:56:30.841 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":99}
      Thomas Braun 2 Replies Last reply Reply Quote 1
        Thomas Braun Most Active @Michaelnorge last edited by Thomas Braun
        @michaelnorge
        Ja, habe ich auch. Dürfte am Update des Gateways liegen.
        Kannst mal ein issue beim Adapter dazu aufmachen, ich bin noch nicht dazu gekommen.
        BTW: Keine Fehlermeldungen, lediglich warnings.
          @michaelnorge
          Ich habs für dich übernommen...
          https://github.com/AlCalzone/ioBroker.tradfri/issues/546
          Grothesk242 created this issue in AlCalzone/ioBroker.tradfri
          closed After new Firmware on Gateway unknown properties keep popping up in log #546
          Lashandan 1 Reply Last reply Reply Quote 0
          • Lashandan
            Lashandan @Thomas Braun last edited by Lashandan
            Kann den Fehler (Die Warnung) bestätigen, habe ihn auch entdeckt und bin grade bei der Suche auf deinen Eintrag gestoßen 😉
            Super das ihr gleich nen Issue erstellt habt.
              Thomas Braun Most Active @Lashandan last edited by Thomas Braun
              @aaron-körtge
              Vielleicht kannst du mal schauen, ob du Meldungen/Geräte hast, die noch nicht im Issue verhanden sind und dann ggf. dort ergänzen.
              • AlCalzone
                Kann hier jemand nachvollziehen, was "5849": 0 bedeutet?
                Das sind die Einstellungen nach einem Stromausfall, ich habe aber nur AN (2) und letzte Einstellung (4) in der App. Anscheinend gibt es auch 0. (AUS?)
                  Thomas Braun Most Active @AlCalzone last edited by
                  @alcalzone
                  Zumindest im GUI der App sind es ja auch nur die beiden Optionen.
                  Ich habe allerdings eine Birne, die auf einem alten Firmwarestand ist (<2) und noch kein zigbee3 kann. Für diese gibt es keine Einstellungen zum Status nach Stromausfall. Vielleicht ist das die Null?
                  • AlCalzone
                    AlCalzone Developer @Thomas Braun last edited by
                    @thomas-braun Könnte sein
                    • AlCalzone
                      AlCalzone Developer last edited by AlCalzone
                      Bitte v2.7.0 probieren
                        Thomas Braun Most Active @AlCalzone last edited by Thomas Braun
                        @alcalzone So auf den ersten Blick bleibt das log jetzt ruhig. Muss ich mal was länger beobachten. Log Level : Info
                        [Edit:] Nach ein paar Stunden herumspielen: Alles ruhig im Log.
                          MarkusP last edited by
                          v.2.7.0 funktioniert bei mir leider nicht. Erhalte die gleichen Warnmeldungen im Log und zusätzlich lassen sich die Lampen aber nicht mehr Schalten bzw. beim Versuch zu Schalten geht der Adapter auf gelb. Bin daher wieder auf v2.6.5 zurück. Seit dem gibt es aber auch keine Warnmeldungen mehr im Log.
                          • Lashandan
                            Lashandan last edited by Lashandan
                            @alcalzone Ich wollte die Version 2.7.0 installieren und testen.
                            Ich kann im Änderungsprotokoll des Adapters auch die Version 2.7.0 sehen allerdings nicht installieren.
                            Was mache ich falsch?
                              @aaron-körtge
                              Diese Version ist über das Latest/Beta-Repositroy verfügbar.
                                Homoran Global Moderator Administrators @AlCalzone last edited by Homoran
                                @alcalzone sagte in trådfri nach Update Fehlermeldungen?:
                                @thomas-braun sagte in trådfri nach Update Fehlermeldungen?:
                                cool
                                Hab die 2.6.5 im stable installiert, dann auf latest umgestellt um zu sehen, ob da schon die 2.7.0 ist - wird nur die 2.6.3 angeboten 😂
                                tradfri.0	2021-02-25 21:14:30.808	warn	(27370) object was: {"5706":"ebb63e","5707":4711,"5708":62138,"5709":36155,"5710":25932,"5849":2,"5850":1,"5851":101,"9003":0}
                                tradfri.0	2021-02-25 21:14:30.808	warn	(27370) found unknown property with key 5849
                                tradfri.0	2021-02-25 21:14:30.808	warn	(27370) object was: {"0":"IKEA of Sweden","1":"TRADFRI bulb E27 CWS opal 600lm","2":"","3":"1.3.013","6":1,"7":10241}
                                tradfri.0	2021-02-25 21:14:30.807	warn	(27370) found unknown property with key 7
                                werde morgen in aller Ruhe dann mal die 2.7.0 testen, wenn die Lampen nicht mehr gebraucht werden
                                  Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                  Müsste heute reingetropft sein:
                                  github:	2.7.0
                                  latest:	2.7.0 for 0 days
                                  stable:	2.6.5 for 87 days
                                  Homoran M 2 Replies Last reply Reply Quote 0
                                    war es gerade eben nicht.
                                    Muss mal den anderen Pfad probieren. - aber erst morgen
                                      Michaelnorge @Thomas Braun last edited by
                                      Ich benutze die 2.7.0 seit vorgestern, der Adapter ist soweit ruhig und schmeisst keine Meldungen mehr ins Log.
                                      • AlCalzone
                                        AlCalzone Developer @MarkusP last edited by
                                        @markusp Wenn das bestehen bleibt, bitte mal 2.7.0 mit loglevel debug starten und mir schicken.
                                        Vermutlich hast du mit 2.6.5 jetzt auch die neue Version der node-tradfri-client library, die die geänderten Kommandos wenigstens versteht.
                                        1262
