    4. js-controller 3.2 jetzt im STABLE!
      TechMo @apollon77 last edited by
      @apollon77
      Ist jetzt ein anderer Fehler:
      2021-02-21 21:21:06.123  - debug: admin.0 (31084) Adding to Greenlock: anstoots.ddns.net with alternative names anstoots.ddns.net
      2021-02-21 21:21:06.380  - info: admin.0 (31084) Challenge server listening on port 80
      2021-02-21 21:21:06.382  - info: admin.0 (31084) If something is not working and your adapter is not reachable anymore you can turn off HTTPS with executing "iobroker admin.0 set --secure false" in your shell.
      2021-02-21 21:21:06.453  - info: admin.0 (31084) https server listening on port 8081
      2021-02-21 21:21:06.454  - info: admin.0 (31084) Use link "https://localhost:8081" to configure.
      2021-02-21 21:21:06.647  - debug: admin.0 (31084) Subscribe OBJECTS: *
      2021-02-21 21:21:16.886  - debug: admin.0 (31084) [LE] certificate_order: {"account":{"key":{"kid":"https://acme-v02.api.letsencrypt.org/acme/acct/113314436"}},"subject":"mydomain.net","altnames":["mydomain.net"],"challengeTypes":["http-01"]}
      2021-02-21 21:21:19.306  - debug: admin.0 (31084) [LE] challenge_select: {"altname":"mydomain.net","type":"http-01","keyAuthorization":"SZxIO3ip2CRhSFFNCsIKhbsJL5rNL-IuuKtQoRzsvCE.x5SIlyfhEmleea795fCKMguyqnZwCQZOs7-BVkyoLeQ"}
      2021-02-21 21:21:25.662  - debug: admin.0 (31084) [LE] challenge_status: {"status":"pending","type":"http-01","altname":"mydomain.net"}
      2021-02-21 21:21:28.068  - debug: admin.0 (31084) [LE] challenge_status: {"status":"valid","type":"http-01","altname":"mydomain.net"}
      2021-02-21 21:21:28.072  - info: admin.0 (31084) Received new certificate for mydomain.net via http-01
      2021-02-21 21:21:30.451  - debug: admin.0 (31084) [LE] certificate_status: {"subject":"mydomain.net","status":"valid"}
      2021-02-21 21:21:31.478  - debug: admin.0 (31084) [LE] cert_issue: {"renewAt":1617822156264,"subject":"mydomain.net","altnames":["mydomain.net"]}
      2021-02-21 21:21:31.479  - info: admin.0 (31084) Certificate for mydomain.net is valid till 2021-04-07T19:02:36.264Z
      2021-02-21 21:21:38.021  - error: admin.0 (31084) [LE] {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"mydomain","context":"cert_issue","subject":"mydomain","altnames":["mydomain"]}
      2021-02-21 21:21:38.025  - error: admin.0 (31084) [LE] {"length":0}
      2021-02-21 21:21:38.026  - error: admin.0 (31084) [LE] {"length":0}
      apollon77 UncleSam 3 Replies Last reply Reply Quote 0
        apollon77 @TechMo last edited by
        @techmo sagte in js-controller 3.2 jetzt im STABLE!:
        mydomain.net
        really?? Ist das deine domain? Du scheinst Sie in der Konfig aber eingetragen zu haben ..
          @apollon77
          Nein ich habe die Domain im Log ersetzt.
          Wo sie ohne .net steht ist sie auch im Original ohne net.
          Bei den anderen eben mit.
            @techmo Also es sieht an sich gut aus. Das Zertifikat wurde geholt. starte admin mal neu ( hätte eigentlich gedacht der Startet sich automatisch neu ... aber ok). Und durufst es danach EXAKT MIT DEM Domainnamen auch auf für den Du das Zertifikat geholt hast?
            • UncleSam
              UncleSam Developer @TechMo last edited by
              @techmo Für mich scheint es, dass du Admin mit https://mydomain/ aufrufst anstatt mit https://mydomain.net/. Da greenlock den Domainnamen überprüft und damit das Zertifikat auswählt, wird das nicht funktionieren. Du musst die Admin-Seite exakt mit demselben Domainnamen aufrufen. Wenn du das lokal nicht kannst oder willst, dann verwende lokal eine zweite Admin Instanz ohne HTTPS.
                TechMo @UncleSam last edited by
                @unclesam
                @apollon77
                Ja das habe ich bei dem Log auch gedacht, aber ich rufe immer genau die Domain auf, die auch als Domain eingetragen ist.
                Deswegen frage ich mich was da los ist.
                Safari auf dem iPhone sagt auch noch:
                Malformed HTTP Header: 'Host:mydomain.net:8081'
                Ging bis zur Umstellung mit dem alten js-Controller immer ohne Probleme.
                  @techmo Na da haben wirs schon.
                  Das "Neue "Letsencrypt unterstützt aktuell nur "Standard https", also Port 443
                    @apollon77
                    Jap das ist es tatsächlich.
                    Steht das irgendwo?
                    8081 ist ja der StandardPort für Admin.0, deswegen läuft es bei mir dort.
                    Habs jezt geändert und es läuft wieder.
                    Vielen Dank.
                      Michi68 last edited by Michi68
                      ich bekomme seit dem Update auf js-controller 3.2.16 ab und zu folgende Fehlermeldungen
                      2021-02-24 15:30:43.411 - error: host.iobroker-Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                      2021-02-24 16:00:36.149 - error: host.iobroker-Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/objects.json' -> '/opt/iobroker/iobroker-data/objects.json.bak'
                      Backups der Datei werden aber gemacht
                      hatte das Update schon Freitag gemacht und auch diese Fehlermeldungen bekommen, hab es dann Gestern noch mal neu gemacht, ist aber immer noch das selbe mit denn Fehlermeldungen.
                      Aufgefallen ist mir das sich die Datei Attribute geändert haben von
                      objects.json.bak, objects.json, states.json.bak, states.json
                      unter js-controller 3.1.6 wahren die noch
                      Datei Attribute 674
                      -rw-rwxr--
                      und unter js-controller 3.2.16 sind die
                      Datei Attribute 664
                      -rw-rw-r--
                      habe dann nochmal iobroker fix ausgefürt, Datei Attribute wurden auch geändert
                      Datei Attribute 674
                      -rw-rwxr--
                      nach dem Start von iobroker haben sich die Datei Attribute aber wieder geändert
                      Datei Attribute 664
                      -rw-rw-r--
                      das hab ich dann auch mal getestet
                      pi@iobroker:~ $ cd /opt/iobroker/iobroker-data
                      pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 objects.json
                      der Modus von 'objects.json' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                      pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 objects.json.bak
                      der Modus von 'objects.json.bak' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                      pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 states.json
                      der Modus von 'states.json' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                      pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 states.json.bak
                      der Modus von 'states.json.bak' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                      nur ändern sich die Datei Attribute wieder wenn die Dateien sich ändern
                      und unter /opt/iobroker/iobroker-data/backup-objects haben sich die Datei Attribute auch geändert
                      Raspbeery 4
                      nodejs 12.20.2
                      node 12.20.2
                      npm 6.14.11
                      admin 4.2.1
                      javascript 4.8.4
                      Update habe ich wie folgt gemacht
                      cd /opt/iobroker
                      iobroker stop
                      ps auxww|grep io
                      iobroker update
                      iobroker upgrade self
                      iobroker fix
                      iobroker start
                      alles ohne Fehler
                      und nu hab ich keine idee mehr
                      Gruß Michael
                      Edit: log angehangen
                      log0.txt
                        Thomas Braun Most Active @Michi68 last edited by
                        @michi68 sagte in js-controller 3.2 jetzt im STABLE!:
                        .json
                        sind keine ausführbaren Dateien. Darüber hinaus sind die Dateien per ACL angelegt, dir fehlen also Informationen über die Attribute.
                        Jag da mal wieder den Fixer drüber.
                        iobroker fix
                          Michi68 @Thomas Braun last edited by
                          iobroker fix gemacht
                          nach dem start dann wieder
                          2021-02-24 22:44:49.947 - error: host.iobroker-Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                          Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                            @michi68
                            pi@raspberrypi:~ $ getfacl /opt/iobroker/iobroker-data/iobroker.json
                            getfacl: Entferne führende '/' von absoluten Pfadnamen
                            # file: opt/iobroker/iobroker-data/iobroker.json
                            # owner: iobroker
                            # group: iobroker
                            user::rw-
                            group::r--
                            group:iobroker:rwx
                            mask::rwx
                            other::r--
                            Gut, bei der Gruppe iobroker ruder ich zurück, iobroker hat das x-bit.
                              apollon77 @Michi68 last edited by apollon77
                              @michi68 Ist das auf ner synology? Da gabs ja weiter oben ähnliche berichte ... ich weiss aber nicht was das issue sein soll ...
                              Das interessante ist auch das beim "nach dem Start"-Screenshot die objects.bak fehlt.
                              EDIT: Ok ich habs gefunden ... Der Fehler bedeutet (meeh unglücklich formuliert) erstmal nur das kein objects.json existiert und daher dieses auch nicht in "objects.json.bak" umbenannt werden kann. Es wird danach trotzdem das objects.json neu geschrieben . Beim nächsten Speichern sollte an sich dann wieder alles klappen und der Fehler nicht nochmals vorkommen.
                              Falls doch ist die Frage was da bei Dir passiert das das File verschwindet
                                Michi68 @apollon77 last edited by
                                @apollon77
                                jo fehlt hatte ich auch noch nicht bemerkt, 😁 ist aber wieder da
                                ist Raspbian buster
                                  ich hatte auch mal die objects.json, states.json gelöscht und aus denn .gz wiederhergestellt, geht.
                                  Also Backups werden gemacht nur ab und zu meckert er das er die objects.json.bak nicht findet
                                  dann kann ich die aber schon mal verstehen
                                    Marty56 @apollon77 last edited by
                                    @apollon77 Nach Neustart bisher nicht mehr aufgetreten
                                      @michi68 nee das ist es ja. Er meckert das keine objects.json da ist. Heißt davor hätte er die wegkopiert aber nicht neu geschrieben. Dann müsste von davor noch eine zweite/andere logzeile gewesen sein wo er sagt das er die objects.Jain nicht hat schreiben können. Sonst kann der Fall an sich nicht auftreten
                                        @apollon77
                                        sorry das ich jetzt erst antworte, war Heute etwas im Stress.
                                        Ja aber beim Start meckert er doch erst mal das die objects.json.bak nicht da ist und kopiert die objects.json die er dann in objects.json.bak umbennent oder sehe ich das falsch?
                                        und dann im Betrieb fehlt ab und zu die objects.json die er nicht zur objects.json.bak kopieren kann, ich bin verwirrt
                                        host.iobroker-Server	2021-02-25 22:00:59.000	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                                        aber davon abgesehen hat er die Macke immer noch 🤔 😁
                                          @michi68 Ne am Ende sind beide Fälle ein" ich finde objects.json nicht" ... ich blicks net
                                            klassisch Most Active @apollon77 last edited by
                                            @apollon77 sagte in js-controller 3.2 jetzt im STABLE!:
                                            Windows
                                            Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden weiss ich gerade nicht wie der aktuelle Prozess ist, da der Windows Installer nicht ganz aktuell ist. Bitte hier berichten dann kann ich ergänzen.
                                            Für alle "alten manuellen" Installationen gilt
                                            • ioBroker muss gestoppt sein.
                                            • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
                                            • iobroker update
                                            • iobroker upgrade self
                                            • ioBroker starten
                                            @sigi234 hat mich ermutigt es genau so wie oben beschrieben zu tun und auch bei mir hat es so funktioniert. Mein Win-System wurde mit dem Installer von @Stabilostick aufgesetzt und mit dem Workaround von @AlCalzone upgedatet.
                                            Bin jetzt auf js-controller 3.2.16, node-js v10.17.0, npm v6.11.3 und soweit scheint alles zu funktionieren.
                                            Q 1 Reply Last reply Reply Quote 1
                                            275
                                            77136
