    4. [How-to] Node.js für ioBroker richtig updaten
      Thomas Braun Most Active @MyMeyer last edited by
      @mymeyer
      Versuch mal das
      cd /opt/iobroker/node_modules/@serialport
      npm install --production
        MyMeyer @Thomas Braun last edited by
        @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
        @mymeyer
        Versuch mal das
        pi@iobroker-slave:/opt/iobroker/node_modules/iobroker.js-controller $ cd /opt/iobroker/node_modules/@serialport
        pi@iobroker-slave:/opt/iobroker/node_modules/@serialport $ npm install --production
        > iobroker.inst@2.0.3 install /opt/iobroker
        > node lib/checkVersions.js
        NPM version: 6.14.11
        > iobroker.inst@2.0.3 postinstall /opt/iobroker
        > node lib/install.js
        │ Manual installation of ioBroker is no longer supported  │
        │ on Linux, OSX and FreeBSD!                              │
        │ Please refer to the documentation on how to install it! │
        │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
        npm ERR! code ELIFECYCLE
        npm ERR! errno 100
        npm ERR! iobroker.inst@2.0.3 postinstall: `node lib/install.js`
        npm ERR! Exit status 100
        npm ERR!
        npm ERR! Failed at the iobroker.inst@2.0.3 postinstall script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2021-02-20T11_26_12_890Z-debug.log
        Und nun ?
          @mymeyer
          Mach mal den cache leer
          cd /optI/iobroker
          npm cache clear --force
          Dann installier dien smartmeter-Adapter nochmal neu.
            @mymeyer
            cd /optI/iobroker
            Gemacht aber er läßt sich unten dem Master nicht löschen und somit auch nicht neu installieren.
            Das kommt dabei raus:
            Done with error: internal/modules/cjs/loader.js:818 throw err; ^Error: Cannot find module './_copyObject'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/lib/yargs.js- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/yargs.js- /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15) at Function.Module._load (internal/modules/cjs/loader.js:667:27) at Module.require (internal/modules/cjs/loader.js:887:19) at require (internal/modules/cjs/helpers.js:74:18) at Object. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js:1:18) at Module._compile (internal/modules/cjs/loader.js:999:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14) at Module.require (internal/modules/cjs/loader.js:887:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/lib/yargs.js', '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/yargs.js', '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]}
            Dann habe ich ihn auf dem Master per "./iobroker del smartmeter.0" gelöscht. Aber in der Web Übersicht steht er immer noch. Und der Slave läuft ja noch nicht korrekt. Laut Iobroker status:
            pi@iobroker-slave:/opt/iobroker $ iobroker status
              throw err;
            Require stack:
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n/index.js:1:18)
              requireStack: [
            Interesse an einer TeamViever Session ?
              @mymeyer sagte in [How-to] Node.js für ioBroker richtig updaten:
              Nein.
                Nein.
                🙂 Und nun ... ?
                  @thomas-braun Hmm...also nachdem ich "npm install iobroker.js-controller@3.1.6 --production" gemacht habe, läuft der Slave wieder . Zumindest sagt es der Status und der Adapter läßt sich verbinden "grün" . Hmm... komisch. Bevor ich npm install gemacht hatte, habe ich noch das Verzeichnis /node_modules komplett gelöscht.
                  Der Smartmeter überträgt Daten und es sind keine Fehler im Log.
                  Ich würde sagen mit dem JS-controller 3.2.16 lasse ich mir jetzt noch etwas Zeit 🙂
                    apollon77 @MyMeyer last edited by
                    @mymeyer noch Zeit lassen? Neeee. Sorry das ich jetzt „am Ende“ hier klugscheisse ;-))
                    Das mir @serialport war fast richtig ... man hätte nur das richtige unterverzeichnis nehmen müssen. Das wäre (wie es auch in der Fehlermeldung kryptisch zu sehen war: @serialport/bindings
                    Dann wäre alles ohne den ganzen hassle gegangen 😉
                    Also Controller 3.2 ist easy im Vergleich dazu.
                      Thomas Braun Most Active @apollon77 last edited by
                      @apollon77 @MyMeyer
                      Oh, das mit bindings hatte ich übersehen.
                        ps1304 @Stabilostick last edited by
                        @stabilostick Hallo - gibts es schon einen Updater für Windows? HAbe iobroker mit dem Windows Installer installiert - scheitere aber immer am Update der node.js bzw. der js-controller Versionen.
                        Gruß peter
                          sigi234 Forum Testing Most Active @ps1304 last edited by sigi234
                          @ps1304 sagte in [How-to] Node.js für ioBroker richtig updaten:
                          Gruß peter
                          https://forum.iobroker.net/post/446928
                          Node Update:
                          1: Konsole: iobroker stop
                          2: Sicherung des Ordners: C:\Program Files\iobroker\deinhostname\nodejs auf dem Desktop
                          3: Download der benötigten Node.js Version unter https://nodejs.org als Archiv nicht als msi Datei
                          4: Entpacken des Downloads und kopieren den Gesamten Ordners über den vorhandenen C:\Program Files\iobroker\deinhostname\nodejs Ordner.
                          5: Kopiere aus der Sicherungskopie des Desktops die Datei nodevars.bat in den Ordner C:\Program Files\iobroker\deinhostname\nodejs
                          6: Konsole: iobroker start
                            klassisch Most Active @sigi234 last edited by
                            @sigi234 Bist Du schon auf dem neuen JS-controller "stable" ?
                            Wie bist Du dorthin gekommen?
                            Direkt aus der aktiven Instanz oder erst mit dem Installer eine neuen Instanz erzeugt, damit man noch eine Rückfallösung hat?
                              sigi234 Forum Testing Most Active @klassisch last edited by sigi234
                              @klassisch sagte in [How-to] Node.js für ioBroker richtig updaten:
                              Via Konsole im iob Verzeichnis des Host
                              iobroker stop
                              iobroker update
                              iobroker upgrade self
                              iobroker start
                                @sigi234 sagte in [How-to] Node.js für ioBroker richtig updaten:
                                iobroker stop
                                iobroker update
                                iobroker start
                                vielen Dank! Habe das jetzt auch mal getestet. Sieht so weit ganz gut aus:
                                C:\Program Files\iobroker\ioBrMain026>iobroker upgrade self
                                Update js-controller from @3.1.6 to @3.2.16
                                NPM version: 6.11.3
                                npm install iobroker.js-controller@3.2.16 --loglevel error --unsafe-perm (System call)
                                node-aead-crypto not needed on this system, since all ciphers are natively supported
                                Starting node restart.js
                                C:\Program Files\iobroker\ioBrMain026>iobroker start
                                2021-02-27 01:34:12,418 INFO  - Starting the service with id 'iobroker(ioBrMain026)'
                                scheint so weit funktioniert zu haben. Alle Instanzen grün.
                                • FriHu
                                  FriHu last edited by
                                  ich bin neu hier und auch neu bei iobroker auf Windows, ioBroker auf Raspi läuft seit einem Jahr stabil.
                                  Ich habe die Installation nach den Angaben hier richtig erstellt, leider öffnet sich das Skriptmenue nicht.
                                  Festgestellt habe ich, daß in der Info angezeigt wird: Nodejs V10.17.0 sei installiert, empfohlen sei V12.21.0 und mit der Konsole habe ich festgestellt, daß tatsächlich 14.6.0 installiert ist.
                                  Liegt hier der Fehler und wie kann ich ihn beheben? Die Javascriptinstanz ist V5.1.1
                                  Weiß jemand einen Rat?
                                    Thomas Braun Most Active @FriHu last edited by
                                    @frihu sagte in [How-to] Node.js für ioBroker richtig updaten:
                                    Ist eine Beta-Version, bei der durch das Beta-Testing aufgefallen ist das da ein Fehler drin ist. Installier die Stabile Version 5.0.4.
                                    Dein node solltest du allerdings auch mal dringend anschauen. Mir ist aber nicht ganz klar ob da bei dir nun Windows oder Linux läuft.
                                    FriHu 1 Reply Last reply Reply Quote 0
                                    • FriHu
                                      FriHu @Thomas Braun last edited by
                                      Habe gerade die beiden JS-Adapter verglichen und festgestellt, daß der eine V5.1.1 ist und der andere 5.0.14. Habe den neuen auf 5.0.14 zurückgedreht und schon funktioniert es bestens!
                                      Vielen Dank für den Hinweis.
                                      @thomas-braun said in [How-to] Node.js für ioBroker richtig updaten:
                                      FriHu apollon77 2 Replies Last reply Reply Quote 0
                                      • FriHu
                                        FriHu @FriHu last edited by
                                        @frihu said in [How-to] Node.js für ioBroker richtig updaten:
                                          apollon77 @FriHu last edited by
                                          @frihu 5.1.2 sollte es fixen
                                            Exile82 last edited by
                                            Hi guys! I am quite new to iobroker but really like how it works and how flexible it is. I am driving an VW ID.3 so this adapter is the best thing that happened since I picked up my car.
                                            I have one concern though, and it is probably more connected to VW API etc. I would most of all be able to fetch the current mileage of the car. This seems not to be possible in the adapter. I know that VWs own app is a bit poor when it comes to this, but are there any possibilities to open for this? Also, lock state for the doors would be nice to integrate with the smart home.
                                            Thanks for reading!
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            733897
