    4. ZigBee neue Version 1.4.4
    • gelberlemmy
      gelberlemmy @Thomas Braun last edited by
      @thomas-braun danke
      schaue ich einmal
      • gelberlemmy
        gelberlemmy @Asgothian last edited by
        @asgothian so jetzt ist der Adapter wieder grün. Habe den Haken unter Einstellungen "Zigbee-herdsman Debug-Info " ausversehen gesetzt. Aber das der dann gar nicht mehr läuft ? Jetzt ist der Adapter wieder grün. Kann aber keine Geräte anmelden. Aus dem LOG werde ich nicht schlau.
        2021-02-24 21_25_50-instances - ioBroker.jpg 2021-02-24 21_21_48-instances - ioBroker.jpg
        zigbee.0	2021-02-24 21:33:01.283	debug	(30770) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:33:01.282	debug	(30770) getBinding result: []
        zigbee.0	2021-02-24 21:33:01.244	debug	(30770) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:33:01.236	debug	(30770) getExclude result: []
        zigbee.0	2021-02-24 21:33:01.111	debug	(30770) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:33:01.111	debug	(30770) getDevices result: [{"_id":"0x00124b00219fba18","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b00219fba18","_network
        zigbee.0	2021-02-24 21:33:01.098	debug	(30770) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:33:01.097	debug	(30770) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyACM2"},{"comName":"/dev/ttyAMA0"}]
        zigbee.0	2021-02-24 21:33:01.047	debug	(30770) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:33:01.046	debug	(30770) getMap result: {"lqis":[],"routing":[]}
        zigbee.0	2021-02-24 21:33:01.046	debug	(30770) Get map succeeded []
        zigbee.0	2021-02-24 21:33:01.046	debug	(30770) Routing table succeeded for 'Coordinator'
        zigbee.0	2021-02-24 21:33:01.045	debug	(30770) Routing for 'Coordinator': {"table":[]}
        zigbee.0	2021-02-24 21:33:01.038	debug	(30770) LQI succeeded for 'Coordinator'
        zigbee.0	2021-02-24 21:33:01.037	debug	(30770) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:33:01.036	debug	(30770) getGroups result: {}
        zigbee.0	2021-02-24 21:33:01.035	debug	(30770) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:33:01.034	debug	(30770) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.4","channel":"14","port":"/dev/ttyACM0","type":"zStack3x0","revision":20210120,"version":"2-1.2.7.1."}
        zigbee.0	2021-02-24 21:33:01.023	debug	(30770) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:32:59.264	debug	(30770) system.adapter.admin.0: logging true
        zigbee.0	2021-02-24 21:31:03.800	debug	(30770) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:31:03.745	debug	(30770) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:31:03.744	debug	(30770) getBinding result: []
        zigbee.0	2021-02-24 21:31:03.742	debug	(30770) getExclude result: []
        zigbee.0	2021-02-24 21:31:03.641	debug	(30770) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:31:03.640	debug	(30770) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyACM2"},{"comName":"/dev/ttyAMA0"}]
        zigbee.0	2021-02-24 21:31:03.530	debug	(30770) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:31:03.528	debug	(30770) getDevices result: [{"_id":"0x00124b00219fba18","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b00219fba18","_networ
        zigbee.0	2021-02-24 21:31:03.505	debug	(30770) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:31:03.504	debug	(30770) getMap result: {"lqis":[],"routing":[]}
        zigbee.0	2021-02-24 21:31:03.504	debug	(30770) Get map succeeded []
        zigbee.0	2021-02-24 21:31:03.503	debug	(30770) Routing table succeeded for 'Coordinator'
        zigbee.0	2021-02-24 21:31:03.502	debug	(30770) Routing for 'Coordinator': {"table":[]}
        zigbee.0	2021-02-24 21:31:03.496	debug	(30770) LQI succeeded for 'Coordinator'
        zigbee.0	2021-02-24 21:31:03.494	debug	(30770) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:31:03.493	debug	(30770) getGroups result: {}
        zigbee.0	2021-02-24 21:31:03.493	debug	(30770) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:31:03.492	debug	(30770) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.4","channel":"14","port":"/dev/ttyACM0","type":"zStack3x0","revision":20210120,"version":"2-1.2.7.1."}
        zigbee.0	2021-02-24 21:31:03.486	debug	(30770) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:30:49.362	debug	(30770) system.adapter.admin.0: logging false
        zigbee.0	2021-02-24 21:28:35.401	debug	(30770) system.adapter.admin.0: logging true
        zigbee.0	2021-02-24 21:28:27.651	debug	(30770) User stateChange zigbee.0.info.pairingMode {"val":false,"ack":false,"ts":1614198507640,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1614095083475}
        zigbee.0	2021-02-24 21:28:27.596	info	(30770) Zigbee: stop joining
        zigbee.0	2021-02-24 21:27:27.809	debug	(30770) system.adapter.admin.0: logging false
        zigbee.0	2021-02-24 21:27:26.333	debug	(30770) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
        zigbee.0	2021-02-24 21:27:26.331	info	(30770) Zigbee: allowing new devices to join.
        zigbee.0	2021-02-24 21:27:24.113	debug	(30770) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:24.048	debug	(30770) getExclude result: []
        zigbee.0	2021-02-24 21:27:24.045	debug	(30770) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:24.045	debug	(30770) getBinding result: []
        zigbee.0	2021-02-24 21:27:24.022	debug	(30770) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:24.021	debug	(30770) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyACM2"},{"comName":"/dev/ttyAMA0"}]
        zigbee.0	2021-02-24 21:27:23.868	debug	(30770) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:23.867	debug	(30770) getDevices result: [{"_id":"0x00124b00219fba18","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b00219fba18","_networ
        zigbee.0	2021-02-24 21:27:23.833	debug	(30770) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:23.831	debug	(30770) getMap result: {"lqis":[],"routing":[]}
        zigbee.0	2021-02-24 21:27:23.830	debug	(30770) Get map succeeded []
        zigbee.0	2021-02-24 21:27:23.829	debug	(30770) Routing table succeeded for 'Coordinator'
        zigbee.0	2021-02-24 21:27:23.827	debug	(30770) Routing for 'Coordinator': {"table":[]}
        zigbee.0	2021-02-24 21:27:23.812	debug	(30770) LQI succeeded for 'Coordinator'
        zigbee.0	2021-02-24 21:27:23.808	debug	(30770) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:23.807	debug	(30770) getGroups result: {}
        zigbee.0	2021-02-24 21:27:23.805	debug	(30770) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:23.803	debug	(30770) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.4","channel":"14","port":"/dev/ttyACM0","type":"zStack3x0","revision":20210120,"version":"2-1.2.7.1."}
        zigbee.0	2021-02-24 21:27:23.788	debug	(30770) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2021-02-24 21:27:04.643	debug	(30770) system.adapter.admin.0: logging true
        zigbee.0	2021-02-24 21:27:00.401	info	(30770) Zigbee started
        zigbee.0	2021-02-24 21:27:00.399	info	(30770) Currently no devices.
        zigbee.0	2021-02-24 21:27:00.391	info	(30770) --> transmitPower : high
        zigbee.0	2021-02-24 21:27:00.390	info	(30770) Unable to disable LED, unsupported function.
        zigbee.0	2021-02-24 21:27:00.388	debug	(30770) Zigbee network parameters: {"panID":6562,"extendedPanID":"0xaddddfddcddddddc","channel":14}
        zigbee.0	2021-02-24 21:27:00.380	info	(30770) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210120}}
        zigbee.0	2021-02-24 21:27:00.379	debug	(30770) zigbee-herdsman started
        zigbee.0	2021-02-24 21:26:58.607	debug	(30770) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_02_24-21_26_57.tar.gz success
        zigbee.0	2021-02-24 21:26:58.595	info	(30770) Installed Version: iobroker.zigbee@1.4.4
        zigbee.0	2021-02-24 21:26:58.047	debug	(30770) Starting zigbee-herdsman...
        zigbee.0	2021-02-24 21:26:58.045	info	(30770) Starting Zigbee npm ...
        zigbee.0	2021-02-24 21:26:57.990	debug	(30770) Using zigbee-herdsman with settings: {"network":{"panID":6562,"extendedPanID":[220,221,221,205,221,223,221,173],"channelList":[14],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"datab
        zigbee.0	2021-02-24 21:26:57.944	info	(30770) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.15.4, js-controller: 3.2.16
        zigbee.0	2021-02-24 21:26:57.402	debug	(30770) statesDB connected
        zigbee.0	2021-02-24 21:26:57.401	debug	(30770) States connected to redis: 127.0.0.1:9000
        zigbee.0	2021-02-24 21:26:57.362	debug	(30770) States create User PubSub Client
        zigbee.0	2021-02-24 21:26:57.360	debug	(30770) States create System PubSub Client
        zigbee.0	2021-02-24 21:26:57.287	debug	(30770) Redis States: Use Redis connection: 127.0.0.1:9000
        zigbee.0	2021-02-24 21:26:57.284	debug	(30770) objectDB connected
        zigbee.0	2021-02-24 21:26:57.269	debug	(30770) Objects connected to redis: 127.0.0.1:9001
        zigbee.0	2021-02-24 21:26:57.039	debug	(30770) Objects client initialize lua scripts
        zigbee.0	2021-02-24 21:26:57.037	debug	(30770) Objects create User PubSub Client
        zigbee.0	2021-02-24 21:26:57.035	debug	(30770) Objects create System PubSub Client
        zigbee.0	2021-02-24 21:26:56.928	debug	(30770) Objects client ready ... initialize now
        zigbee.0	2021-02-24 21:26:56.747	debug	(30770) Redis Objects: Use Redis connection: 127.0.0.1:9001
        zigbee.0	2021-02-24 21:26:51.936	info	(30389) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0	2021-02-24 21:26:51.934	info	(30389) terminating
        zigbee.0	2021-02-24 21:26:51.596	info	(30389) Zigbee: disabling joining new devices.
        zigbee.0	2021-02-24 21:26:51.594	info	(30389) cleaned everything up...
        zigbee.0	2021-02-24 21:26:51.592	info	(30389) Got terminate signal TERMINATE_YOURSELF
        Danke für Euren Support André
        gelberlemmy 1 Reply Last reply Reply Quote 0
          Mr.X last edited by
          Hallo zusammen (nochmal),
          ich habe das Problem, dass bei mir plötzlich die Gruppen nicht mehr funktionieren. Ist für mich aber Essentiell, da ich eine Leuchte mit 5 Birnen haben. Wie auch immer.
          ich habe Broker, JS-controller auf stand gebracht, 1.4.4 probiert und auch auf 1.4.1 down gegradet. Alle Gruppen im Adapter gelöscht und neue mit komplett neuem Namen vergeben. Es bleiben aber immer die Gruppen ohne Funktion.
          Woran könnte das liegen?
            klassisch Most Active last edited by klassisch
            Hatte eben wieder einen dunklen Moment.
            Alles dunkel, Leuchten gehen nicht mehr an.
            Wieder hat der Adapter die Verbindung zum COM-Port verloren.
            COM4-Port war aber lt. Geräte Manager i.O. und verbunden.
            Derzeit hängt der Controller an einem USB Hub, an dem auch noch 2 Drucker hängen, auf die ich problemlos zugreifen kann. Ich gehe also davon aus, daß der OS-seitige Teil der Verbindung stabil ist.
            Bin in die Einstellungen der Zigbee Instanz. Dort war COM4 angezeigt. Habe im Drop down Menue COM4 erneut ausgewählt. und abgespeichert.
            Zigbee wird wieder grün.
            Lichter reagieren wieder auf Schalter und Bewegungsmelder.
            Log mit Serial Port error:
            zigbee.0	2021-02-25 01:05:56.929	warn	(8816) Failed to ping 0xbc33acfffe9769ab FLOALT panel WS 60x60
            zigbee.0	2021-02-25 01:03:43.012	warn	(8816) Failed to ping 0xbc33acfffed7b833 FLOALT panel WS 60x60
            zigbee.0	2021-02-25 00:58:40.170	error	at binding.open.then.err (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:242:12)
            zigbee.0	2021-02-25 00:58:40.170	error	at SerialPort._error (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:198:14)
            zigbee.0	2021-02-25 00:58:40.170	error	at SerialPort.serialPort.open (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:134:49)
            zigbee.0	2021-02-25 00:58:40.170	error	at __awaiter (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:23:12)
            zigbee.0	2021-02-25 00:58:40.170	error	at new Promise (<anonymous>)
            zigbee.0	2021-02-25 00:58:40.170	error	at C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:27:71
            zigbee.0	2021-02-25 00:58:40.170	error	at Generator.next (<anonymous>)
            zigbee.0	2021-02-25 00:58:40.170	error	at Znp.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:136:32)
            zigbee.0	2021-02-25 00:58:40.170	error	(8816) Error: Error while opening serialport 'Error: Opening COM4: Access denied'
            zigbee.0	2021-02-25 00:58:40.169	error	(8816) Failed to start Zigbee
            zigbee.0	2021-02-25 00:58:40.169	info	(8816) Installed Version: iobroker.zigbee@1.4.4
            zigbee.0	2021-02-25 00:58:40.159	info	(8816) Starting Zigbee npm ...
            zigbee.0	2021-02-25 00:58:40.157	info	(8816) Try to reconnect. 0 attempts left
            zigbee.0	2021-02-25 00:58:38.652	error	at binding.open.then.err (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:242:12)
            zigbee.0	2021-02-25 00:58:38.652	error	at SerialPort._error (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:198:14)
            zigbee.0	2021-02-25 00:58:38.652	error	at SerialPort.serialPort.open (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:134:49)
            zigbee.0	2021-02-25 00:58:38.652	error	at __awaiter (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:23:12)
            zigbee.0	2021-02-25 00:58:38.652	error	at new Promise (<anonymous>)
            zigbee.0	2021-02-25 00:58:38.652	error	at C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:27:71
            zigbee.0	2021-02-25 00:58:38.652	error	at Generator.next (<anonymous>)
            zigbee.0	2021-02-25 00:58:38.652	error	at Znp.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:136:32)
            zigbee.0	2021-02-25 00:58:38.652	error	(8816) Error: Error while opening serialport 'Error: Opening COM4: Access denied'
            zigbee.0	2021-02-25 00:58:38.652	error	(8816) Failed to start Zigbee
            zigbee.0	2021-02-25 00:58:38.652	info	(8816) Installed Version: iobroker.zigbee@1.4.4
            zigbee.0	2021-02-25 00:58:38.649	info	(8816) Starting Zigbee npm ...
            zigbee.0	2021-02-25 00:58:38.648	info	(8816) Try to reconnect. 1 attempts left
            zigbee.0	2021-02-25 00:58:30.152	error	at fulfilled (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\controller\controller.js:24:58)
            zigbee.0	2021-02-25 00:58:30.152	error	at Generator.next (<anonymous>)
            zigbee.0	2021-02-25 00:58:30.152	error	at Controller.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\controller\controller.js:136:52)
            zigbee.0	2021-02-25 00:58:30.152	error	at ZStackAdapter.getCoordinator (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\adapter\zStackAdapter.js:132:16)
            zigbee.0	2021-02-25 00:58:30.152	error	at __awaiter (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\adapter\zStackAdapter.js:23:12)
            zigbee.0	2021-02-25 00:58:30.152	error	at new Promise (<anonymous>)
            zigbee.0	2021-02-25 00:58:30.152	error	at C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\adapter\zStackAdapter.js:27:71
            zigbee.0	2021-02-25 00:58:30.152	error	at ZStackAdapter.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\adapter\zStackAdapter.js:133:31)
            zigbee.0	2021-02-25 00:58:30.152	error	(8816) TypeError: Cannot read property 'execute' of undefined
            zigbee.0	2021-02-25 00:58:30.146	error	(8816) Failed to start Zigbee
            zigbee.0	2021-02-25 00:58:28.645	error	at binding.open.then.err (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:242:12)
            zigbee.0	2021-02-25 00:58:28.645	error	at SerialPort._error (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:198:14)
            zigbee.0	2021-02-25 00:58:28.645	error	at SerialPort.serialPort.open (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:134:49)
            zigbee.0	2021-02-25 00:58:28.645	error	at __awaiter (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:23:12)
            zigbee.0	2021-02-25 00:58:28.645	error	at new Promise (<anonymous>)
            zigbee.0	2021-02-25 00:58:28.645	error	at C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:27:71
            zigbee.0	2021-02-25 00:58:28.645	error	at Generator.next (<anonymous>)
            zigbee.0	2021-02-25 00:58:28.645	error	at Znp.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:136:32)
            zigbee.0	2021-02-25 00:58:28.645	error	(8816) Error: Error while opening serialport 'Error: Opening COM4: Access denied'
            zigbee.0	2021-02-25 00:58:28.645	error	(8816) Failed to start Zigbee
            zigbee.0	2021-02-25 00:58:28.644	info	(8816) Installed Version: iobroker.zigbee@1.4.4
            zigbee.0	2021-02-25 00:58:28.640	info	(8816) Starting Zigbee npm ...
            zigbee.0	2021-02-25 00:58:28.640	info	(8816) Try to reconnect. 2 attempts left
            zigbee.0	2021-02-25 00:58:28.637	info	(8816) Starting Zigbee npm ...
            zigbee.0	2021-02-25 00:58:28.636	info	(8816) Try to reconnect. 3 attempts left
            zigbee.0	2021-02-25 00:58:18.641	error	at binding.open.then.err (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:242:12)
            zigbee.0	2021-02-25 00:58:18.641	error	at SerialPort._error (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:198:14)
            zigbee.0	2021-02-25 00:58:18.641	error	at SerialPort.serialPort.open (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:134:49)
            zigbee.0	2021-02-25 00:58:18.641	error	at __awaiter (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:23:12)
            zigbee.0	2021-02-25 00:58:18.641	error	at new Promise (<anonymous>)
            zigbee.0	2021-02-25 00:58:18.641	error	at C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:27:71
            zigbee.0	2021-02-25 00:58:18.641	error	at Generator.next (<anonymous>)
            zigbee.0	2021-02-25 00:58:18.641	error	at Znp.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:136:32)
            zigbee.0	2021-02-25 00:58:18.641	error	(8816) Error: Error while opening serialport 'Error: Opening COM4: File not found'
            zigbee.0	2021-02-25 00:58:18.640	error	(8816) Failed to start Zigbee
            zigbee.0	2021-02-25 00:58:18.638	info	(8816) Installed Version: iobroker.zigbee@1.4.4
            zigbee.0	2021-02-25 00:58:18.636	error	at binding.open.then.err (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:242:12)
            zigbee.0	2021-02-25 00:58:18.636	error	at SerialPort._error (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\node_modules\@serialport\stream\lib\index.js:198:14)
            zigbee.0	2021-02-25 00:58:18.636	error	at SerialPort.serialPort.open (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:134:49)
            zigbee.0	2021-02-25 00:58:18.636	error	at __awaiter (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:23:12)
            zigbee.0	2021-02-25 00:58:18.636	error	at new Promise (<anonymous>)
            zigbee.0	2021-02-25 00:58:18.636	error	at C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:27:71
            zigbee.0	2021-02-25 00:58:18.636	error	at Generator.next (<anonymous>)
            zigbee.0	2021-02-25 00:58:18.636	error	at Znp.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\znp.js:136:32)
            zigbee.0	2021-02-25 00:58:18.636	error	(8816) Error: Error while opening serialport 'Error: Opening COM4: File not found'
            zigbee.0	2021-02-25 00:58:18.636	error	(8816) Failed to start Zigbee
            zigbee.0	2021-02-25 00:58:18.616	info	(8816) Starting Zigbee npm ...
            zigbee.0	2021-02-25 00:58:18.614	info	(8816) Try to reconnect. 4 attempts left
            zigbee.0	2021-02-25 00:58:18.613	info	(8816) Starting Zigbee npm ...
            zigbee.0	2021-02-25 00:58:18.611	info	(8816) Try to reconnect. 5 attempts left
            zigbee.0	2021-02-25 00:58:08.602	error	(8816) Adapter disconnected, stopping
            zigbee.0	2021-02-25 00:58:08.598	error	(8816) Adapter disconnected, stopping
            Asgothian mickym 2 Replies Last reply Reply Quote 0
            • Asgothian
              Asgothian Developer @klassisch last edited by
              @klassisch Bitte geh durch das log und finde den Punkt wo der zigbee Adapter das erste mal beendet wird, und warum. In dem gelisteten Teil ist das nicht mit drin
              A.
                klassisch Most Active @Asgothian last edited by klassisch
                @asgothian Danke für Aufnehmen.
                Der letzte "Zigbee" Eintrag im log von gestern war
                2021-02-24 18:56:37.792 - warn: zigbee.0 (8816) Failed to read state '"color_temp_startup"'of '0xbc33acfffe9769ab' after query with '{"code":134}'
                Das ist ja der bekannte Fehler mit der falschen Bedatung der Komponenten
                Die ersten Einträge mit "zgbee" heute morgen sind die um 00:58.08 von obigem log-Eintrag
                2021-02-25 00:58:08.602	error	(8816) Adapter disconnected, stopping zigbee.0
                Oder habe ich was übersehen, was falsch verstanden? soll ich nach anderen Stichwörtern suchen?
                Hatte ja jetzt 2 solcher disconnects in dieser direkten USB-Konfguration (die ser2lan Konfig lasse ich ma aussen vor). Jedes Mal nach einigen Stunden Ruhe im Zigbbe Imperium, also mut maßlich Sendepause.
                Könnte es sein, daß die Connection bei Nichtgebrauch "abfault"? Dann könnte ich z.B. alle 2 Stunden prüfen, ob der Leuchtenstatus geändert wurde und falls nicht, die Leuchte anpingen. Dann wäre die Connection wieder "refresht".
                • mickym
                  mickym Most Active @klassisch last edited by
                  @klassisch Ich kann nur davon abraten, den Stick an einem USB-Hub zu betreiben. Ich hatte dasselbe Phänomen, das es manchmal 1 Tag durch lief, manchmal verlor man die Verbindung alle paar Stunden mehrmals am Tag.
                  Das habe ich damals auch hier dokumentiert: https://github.com/ioBroker/ioBroker.zigbee/issues/792
                  In meinen Augen hat das aber nichts mit der Adapterversion zu tun. Jedenfalls seitdem ich den Stick nun wieder direkt am PI betreibe, bleibt die Verbindung stabil. Bei mir war das nicht unter Windows sondern eben am Raspi. Auch wenn das 2 unterschiedliche Systeme sind. Aus den Logs konnte ich damals auch nichts entnehmen.
                  Vielleicht probierst Du es auch mal, den Stick direkt am PC zu betreiben. Ich kann Dir zwar keine Erklärung dafür liefern, aber seitdem habe ich zumindest, wenn nach dem Booten der Controller gefunden wird, keine Probleme mehr. Es kann jedoch passieren (wenn ich nicht den Stick manuell abziehe), dass ich mehrmals booten muss, damit die Verbindung klappt. Also deshalb mein Tipp - versuche es mal ohne den USB Hub.
                  • mickym
                    Nein es sind genau exakt die gleichen Einträge die ich auch hatte und das sind die ersten beiden die das Ende ankündigen. Und bei mir war alles auf Debug gestellt. Mehr Infos kamen bei mir damals auch nicht raus.
                      @mickym Vielen Dank für Deinen HInweis.
                      Im Windows sehe ich ja keinerlei Auffälligkeit. Und Win kann ja mit USB stabil umgehen. Und ich hatte auch mal bei einer ser2lan Verbindung Abbrüche, aber da ist ja wieder so ein Linux SBC in der Kette.
                      Habe jetzt mal Deinem Hinweis folgend den Hub abgesteckt und verzichte mal auf den Zugriff auf die beiden Drucker. Die COM-Port Nummer wurde dadurch natürlich gewechselt. Werde beobachten, ob es jetzt stabiler ist.
                      • JackDaniel
                        JackDaniel last edited by
                        könnt ihr bitte die bilder beim TRADFRI ON/OFF switch und bei der TRADFRI open/close remote gegen die tauschen?
                        (sind von https://www.zigbee2mqtt.io/)E1743.jpg E1766.jpg
                          Mr.X @Mr.X last edited by
                          @mr-x sagte in ZigBee neue Version 1.4.4:
                          Und zu dem Gruppenfehler hätte niemand einen Rat für mich?
                          • Asgothian
                            Asgothian Developer @Mr.X last edited by
                            @mr-x Bitte den Adapter in Debug stellen und schauen ob es Log Einträge gibt die erklären warum die Gruppen nicht schalten.
                            Bei mir gehen die Gruppen ohne Probleme.
                            A.
                              A Former User @arteck last edited by
                              Hat einer von euch ein automatisierter Failover für Zigbee eingerichtet?
                              Bei mir läuft der Zigbee-Adapter auf einem Raspi3 als iobroker-client, das gleiche habe ich nochmal, mit gleicher Hardware ( ebenfalls ein TICC26X2R1 dran ).
                              Mein Vorhaben:
                              Auf dem zweiten ist der Adapter gleich konfiguriert, ich kopiere mir bei Änderungen das Zigbee-Verzeichnis rüber, ein Script überwacht den ersten Host, ist diese nicht mehr länger erreichbar, wird der Adapter Instanz 0 gestoppt und die andere Instanz gestartet.
                              Habt ihr sowas oder andere Ideen ?
                                klassisch Most Active @Guest last edited by
                                @ilovegym Ich verstehe den Antrieb. Wenn man essentielle Steuerungen wie Licht o.ä. mit Zigbee macht, will man hone Verfügbarkeit.
                                Als Zigbeeneuling verstehe ich aber nicht genug davon.
                                Ich vermite, daß Deine beiden Controller arbeiten, sobald sie bestromt und bedatet sind.
                                Also ich glaube nicht, daß man beide gleichzeitig im eingeschalteten und bedateten Zustand parallel bereiben kann. Oder hast Du das schon einmal getestet?
                                Also würde ich eher an eine kalte Redundanz denken. Der zweite Client läuft zwar und bekommt das Zigbee Verzeichnis upgedatet (wenn das reicht) und überwacht die Zigbee-Instanz des Hauptpfades. Sobald diese Instanz nicht mehr grün ist, schaltet die kalte Redundanz die Cntrollerplatine ein und startet dann seinen Zigbee-Adapter.
                                Wenn die kalte Redundanz einen anderen Standort hat, wird das Netze einige Zeit/Events brauchen, um sich neu zu konfigurieren.
                                Solange die kalte Redundanz aktiv ist, muß man den Hauptpafad abschalten.
                                Das Zurückschalten wird man dann wohl manuell machen.
                                Aber mit dem Controller alleine ist es nicht getan. Man muß dann auch einen Javascript Adapter, email Client (o.ä) auf der kalten Redundanz vorhalten und die entsprechenden Zigbee Scripte starten. Und die sollten auch einigermaßen up to date sein.
                                Da ich bisher die Komplexität eines Multihost-Systems vermieden habe, weiß ich nicht, wie dabei die Objekte aussehen. Aber ich vermute, daß die einen anderen Prefix bekommen, z.B. zigbee.1. Das muß dann in den Skripten berücksichtigt sein.
                                Und ehrlich gesagt, ist das die zweitbeste Lösung. Ein rocksolid-zuverlässiger Hauptpfad wäre mir lieber.
                                Ein interessanter Ansatz
                                  A Former User @klassisch last edited by
                                  @klassisch stimmt, der andere Adapter ist die nächste Instanz, also stimmen die Pfade nicht mehr.. 😞
                                  Gut, dann kommt Plan B dran 🙂
                                  Ich clone den Raspi, lass den zweiten ausgeschaltet mit absolut gleicher Config wie der erste, wenn der erste ausfällt, dann wird beim ersten das Netzteil vom Strom getrennt, und beim zweiten das Netzteil mit Strom versorgt.
                                  Somit startet der zweite dann mit gleichem Namen ( ok die Mac und IP ist anders..) und mit der gleichen instanz.
                                  Klar, die beiden sollten dann nebeneinander stehen, das ist von den Örtlichkeiten kein Problem.
                                  K Thomas Braun Asgothian 3 Replies Last reply Reply Quote 0
                                  • gelberlemmy
                                    gelberlemmy @gelberlemmy last edited by
                                    @gelberlemmy sagte in ZigBee neue Version 1.4.4:
                                    Guten Morgen,
                                    so nach ein paar Tests, habe Ich festgestellt, dass zum Teil ein anlernen nur noch mit dem einen Taster auf dem Cc26x2r1 funktioniert. How ever. Hat das jemand schon einmal gehabt. Nach dem anlernen kann ich die Geräte nur ab und an Steuern. Auch sind sie irgendwann ohne Verbindung. Wobei sie direkt neben dem Cc26x2r1. Auch passiert es gelegentlich, dass der ComPort belegt ist und der Adapter nicht funktioniert. Neues flashen des Cc26x2r1 hat auch nichts gebracht. Ich habe mich entschieden den Cc26x2r1 umzutauschen, da ich nicht glauben kann, das es woanders dran liegt. Grundeinstellung in dem Adapter sind jetzt ja recht einfach. Er hat ja am Anfang tadellos funktioniert. Auch Adapter Neuinstallation hatte nichts gebracht.
                                    ? arteck 2 Replies Last reply Reply Quote 0
                                      @ilovegym sagte in ZigBee neue Version 1.4.4:
                                      das könnte man vielleicht sogar richten. Ich würde es über eine globale Variable versuchen, die bei beiden Slaves gleich heißt aber einen anderen Inhalt hat. Wobei ich nicht genau weiß, wie sich das mit den globalen Variablen bei multihost Systemen verhält.
                                      Ja, geht in Richtung kalte Redundanz. Wie will man in dieser Konfiguration die beiden gleich halten? Während der Sync müssen beide Raspis eingeschaltet sein. Aber wahrscheinlich dürfen nicht beide Controller eingeschaltet sein. Also wird das wieder etwas komplexer.
                                      Dann muß aber auch das Starten und die Zuordnung der USB-Ports zuverlässig funktionieren.
                                        A Former User @gelberlemmy last edited by
                                        @gelberlemmy USB Probleme kann man im Log gut erkennen...
                                        schau dir mal vom booten an alle Meldungen mit dmesg an... da hab ich auch schon viele Fehler gefunden..
                                          @klassisch Gut.. ja.. und danke dir. Ich spiel mal etwas mit rum.. und berichte meine Erfahrungen.
                                          Sonst versauen wir hier den Thread 🙂
                                          • gelberlemmy
                                            gelberlemmy @Guest last edited by
                                            Super danke für den Tipp. Com Port Probleme schaue ich mir mal an. Aber all die anderen Probleme dürften da eventuell nicht von stammen, oder? Das teste ich noch einmal.
                                            Sagt mal, wenn ich den Adapter Zigbee vorab lösche, werden alle Daten des Adapters im System auf meinem Raspi gelöscht? Würde dann alles komplett frisch aufsetzen wollen.
                                            neue version zigbee zigbee neue version 1.4.0
                                            35
                                            302
                                            48276
