    4. Test Adaper Tado v0.1.x
    • Slowman
      Slowman last edited by
      @hglab
      Danke für die Info.
      Wie bekomme ich dies Installiert?
      Terminal -->
      cd /opt/iobroker
      npm install https://github.com/HGlab01/ioBroker.tado/archive/v0.2.6-2.tar.gz
        HGlab @Slowman last edited by
        @slowman said in Test Adaper Tado v0.1.x:
        @hglab
        Danke für die Info.
        Terminal -->
        cd /opt/iobroker
        https://github.com/iobroker-community-adapters/ioBroker.tado/issues/164#issuecomment-781861535
        Grothesk242 created this issue in iobroker-community-adapters/ioBroker.tado
        closed (1505) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false #164
        Slowman 1 Reply Last reply Reply Quote 1
        • Slowman
          Slowman @HGlab last edited by
          @hglab
          Oh, man so einfach und ich habe Google Löcher in den Bauch gefragt, wie ich dies mache 😊
            canim last edited by
            ich kann es auch über die Katze nicht installieren =(..
            tado.0	2021-02-21 13:35:13.864	warn	(25413) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
            host.raspberrypi	2021-02-21 13:34:47.861	info	Updating repository "Beta (latest)" under "http://download.iobroker.net/sources-dist-latest.json"
            host.raspberrypi	2021-02-21 13:34:43.228	info	iobroker exit 0
            host.raspberrypi	2021-02-21 13:34:41.939	info	iobroker upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
            host.raspberrypi	2021-02-21 13:34:41.691	info	iobroker upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
            host.raspberrypi	2021-02-21 13:34:41.297	info	iobroker upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
            host.raspberrypi	2021-02-21 13:34:41.231	info	iobroker upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
            host.raspberrypi	2021-02-21 13:34:40.979	info	iobroker upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
            host.raspberrypi	2021-02-21 13:34:40.884	info	iobroker upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
            host.raspberrypi	2021-02-21 13:34:40.828	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-02-21T12_34_40_809Z-debug.log
            host.raspberrypi	2021-02-21 13:34:40.826	info	iobroker
            host.raspberrypi	2021-02-21 13:34:40.805	info	iobroker npm ERR! error: Pfadspezifikation 'v0.2.6-2.tar' stimmt mit keinen git-bekannten Dateien überein.npm ERR!
            host.raspberrypi	2021-02-21 13:34:40.804	info	iobroker npm ERR! Command failed: git checkout v0.2.6-2.tar
            host.raspberrypi	2021-02-21 13:34:40.792	info	iobroker npm ERR! code 1
              Thomas Braun Most Active @canim last edited by
              @canim Über Kommandozeile funktioniert es.
                canim @Thomas Braun last edited by
                @thomas-braun sorry wirklich zu doof :D, habs jetzt per zeile installieren können danke!
                  MarkusMac last edited by
                  Hi, ich hab seit einigen Wochen Probleme mit dem Tado-Adapter - sieht so aus, als würden einige Datenpunkte gelöscht. Nach einem Neustart des Adapters sind sie dann wieder da und alles läuft normal für ein paar Stunden.
                  tado.0	2021-02-22 13:56:18.031	info	(2145) state tado.0.328596.Rooms.3.openWindow.durationInSeconds deleted
                  tado.0	2021-02-22 13:56:17.935	info	(2145) state tado.0.328596.Rooms.3.setting.power deleted
                  tado.0	2021-02-22 13:56:17.934	info	(2145) state tado.0.328596.Rooms.3.overlay.termination.typeSkillBasedApp deleted
                  tado.0	2021-02-22 13:56:17.822	info	(2145) state tado.0.328596.Rooms.3.overlay.clearZoneOverlay deleted
                  tado.0	2021-02-22 13:56:17.721	info	(2145) state tado.0.328596.Rooms.2.setting.power deleted
                  tado.0	2021-02-22 13:56:17.721	info	(2145) state tado.0.328596.Rooms.2.openWindow.durationInSeconds deleted
                  tado.0	2021-02-22 13:56:17.237	info	(2145) state tado.0.328596.Rooms.1.setting.power deleted
                  tado.0	2021-02-22 13:56:17.217	info	(2145) state tado.0.328596.Rooms.4.overlay.clearZoneOverlay deleted
                  tado.0	2021-02-22 13:56:17.127	info	(2145) state tado.0.328596.Rooms.2.overlay.clearZoneOverlay deleted
                  tado.0	2021-02-22 13:56:17.115	info	(2145) state tado.0.328596.Rooms.2.overlay.termination.typeSkillBasedApp deleted
                  tado.0	2021-02-22 13:56:17.020	info	(2145) state tado.0.328596.Rooms.1.overlay.termination.typeSkillBasedApp deleted
                  tado.0	2021-02-22 13:56:16.911	info	(2145) state tado.0.328596.Rooms.1.openWindow.durationInSeconds deleted
                  tado.0	2021-02-22 13:56:16.408	info	(2145) state tado.0.328596.Rooms.1.overlay.clearZoneOverlay deleted
                  tado.0	2021-02-22 13:56:16.253	info	(2145) state tado.0.328596.Rooms.4.setting.power deleted
                  tado.0	2021-02-22 13:56:16.252	info	(2145) state tado.0.328596.Rooms.4.overlay.termination.typeSkillBasedApp deleted
                  Das passiert so zwischen 1-4 mal am Tag. Momentan behelfe ich mir, dass ich einen der gelöschten Werte alle 5 Minuten prüfe und, wenn er nicht mehr da ist, den Adapter neu starte. Aber das ist ja keine Dauerlösung. Hat jemand eine Idee, was der Grund für das Löschen der States sein könnte?
                  Ich nutze die derzeit aktuelle Version des Tado-Adapters (0.2.5).
                    Fuxsism last edited by
                    @Dutchman
                    Leider habe ich auch seit Tagen Probleme mit dem Tado Adapter... das hier läuft bei mir einmal jede Minute durch das Log:
                    tado.0	2021-02-27 09:33:57.646	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:51.020	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:44.416	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:37.770	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:31.274	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:24.782	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:18.030	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:11.419	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    tado.0	2021-02-27 09:33:05.075	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
                    Und ich hab auch den Eindruck das manche Steuerungen irgendwie nicht mehr funktionieren...
                    Seit ihr da noch an dem Problem dran oder habt schon eine Lösung dafür???
                    Thomas Braun H 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @Fuxsism last edited by
                      @fuxsism Vom tado wird die Tage vermutlich ein Update kommen. In einer Beta ist die Meldung bereits gefixt.
                        Fuxsism @Thomas Braun last edited by
                        @thomas-braun wo bekomm ich denn die Beta??
                          HGlab @Fuxsism last edited by
                          @fuxsism
                          Bzgl. warning: Die Änderung wartet auf den Merge des PRs (https://github.com/iobroker-community-adapters/ioBroker.tado/pull/117). Daher einstweilen nur über den Link https://github.com/HGlab01/ioBroker.tado/archive/v0.2.6-2.tar.gz
                          Bzgl. "manche Steuerungen irgendwie nicht mehr funktionieren": kann ich nicht bestätigen und auf Basis dieser Fuzzy-Aussage auch ein wenig schwer einzuordnen
                          HGlab01 created this issue in iobroker-community-adapters/ioBroker.tado
                          closed Implement pool handling for setZoneOverlay & add cleaning function for existing timer 'polling' #117
                            Fuxsism @HGlab last edited by
                            @hglab
                            wie kann ich denn die 2.6.2 installieren????
                              HGlab @MarkusMac last edited by
                              @markusmac said in Test Adaper Tado v0.1.x:
                              welches Refresh-Invervall ist eingestetllt?
                              Das Löschen eines States erfolgt eigentlich nur dann, wenn nach der 3- oder 5-fachen Refreshtime (weiß gerade nicht auswendig wann genau) der Wert NIE mehr von Tado geliefert wurde. setting.power wird aber von der Tado-API immer geliefert daher ist es bei dir ein Verhalten dass es eigentlich nicht geben dürfte....
                                HGlab @Fuxsism last edited by HGlab
                                @fuxsism said in Test Adaper Tado v0.1.x:
                                @hglab
                                Das steht in den letzten 5 Posts direkt über deinem Post; hier
                                https://forum.iobroker.net/topic/25723/test-adaper-tado-v0-1-x/753
                                beginnend
                                  @hglab krass unglaublich... es scheint echt geklappt zu haben und es werden nicht mehr ständig warn Meldungen ausgegeben... sehr geil!!!!
                                  Danke dir für die Hilfe!!!!!
                                    @hglab
                                    jetzt kommt allerdings dieser Blog:
                                    tado.0	2021-02-27 10:21:56.945	info	(12560) state tado.0.575448.Rooms.3.openWindow.durationInSeconds deleted
                                    tado.0	2021-02-27 10:21:56.919	info	(12560) state tado.0.575448.Rooms.3.overlay.termination.typeSkillBasedApp deleted
                                    tado.0	2021-02-27 10:21:56.893	info	(12560) state tado.0.575448.Rooms.3.overlay.clearZoneOverlay deleted
                                    tado.0	2021-02-27 10:21:56.878	info	(12560) state tado.0.575448.Rooms.3.setting.power deleted
                                    tado.0	2021-02-27 10:21:56.025	info	(12560) state tado.0.575448.Rooms.2.openWindow.durationInSeconds deleted
                                    tado.0	2021-02-27 10:21:56.006	info	(12560) state tado.0.575448.Rooms.2.overlay.termination.typeSkillBasedApp deleted
                                    tado.0	2021-02-27 10:21:55.940	info	(12560) state tado.0.575448.Rooms.2.overlay.clearZoneOverlay deleted
                                    tado.0	2021-02-27 10:21:55.931	info	(12560) state tado.0.575448.Rooms.2.setting.power deleted
                                    tado.0	2021-02-27 10:21:55.112	info	(12560) state tado.0.575448.Rooms.1.openWindow.durationInSeconds deleted
                                    tado.0	2021-02-27 10:21:55.087	info	(12560) state tado.0.575448.Rooms.1.overlay.termination.typeSkillBasedApp deleted
                                    tado.0	2021-02-27 10:21:55.056	info	(12560) state tado.0.575448.Rooms.1.overlay.clearZoneOverlay deleted
                                    tado.0	2021-02-27 10:21:55.050	info	(12560) state tado.0.575448.Rooms.1.setting.power deleted
                                    Is das okay so??
                                      @hglab
                                      Is das okay so??
                                      nein, sollte eigentlich nicht.
                                      Du kannst aber gerne mal den Adapter im debug-modus starten und auf Github ein Issue mit dem Log anlegen. Dann sehe ich mir das mal an.
                                      Offensichtlich hast du und @MarkusMac das selbe bzw. ähnliche Problem.
                                      Ich kann es bei meinen zwei Installationen nicht nachvollziehen aber vielleicht rollt Tado gerade einen API-Change in Wellen aus. Leider sind die Tado-APIs im Sinne breaking changes alles andere als stabil.
                                        @hglab hmmm kann es denn wirklich etwas mit der Polling Zeit zu tun haben???
                                        Ich hatte die bei mir auf 2 Sekunden stehen... hab sie jetzt hoch gestellt auf 5 und da scheint es zu laufen???
                                          @fuxsism
                                          ja, 2 Sekunden wird sicher nicht funktonieren. Da wird dir die Tado-API ein DDoS (denial of service) unterstellen und dich blockieren.
                                          Alles was unter 30 Sekunden ist würde ich tunlichst vermeiden!
                                          Ich denke das sollten wir im Adapter in Zukunft abfedern damit nichts unter 30 Sekunden akzeptiert wird
                                          F C 2 Replies Last reply Reply Quote 0
                                            @hglab okay... also du meinst ich soll es sogar lieber auf 30 hoch stellen???
                                            H Thomas Braun 2 Replies Last reply Reply Quote 0
                                            adapter tado testing team
                                            62
                                            868
                                            202406
