    4. [ESPHome] Beta release
    • FredF
      FredF Most Active Forum Testing @Dutchman last edited by
      @dutchman Nope, gleiches Verhalten/Fehlermeldung
      • Dutchman
        Dutchman Developer Most Active Administrators @FredF last edited by
        @fredf sagte in [ESPHome] Beta release:
        @apollon77 hast du eventuell ne idee ?
        apollon77 FredF 2 Replies Last reply Reply Quote 0
          Markus_ @liv-in-sky last edited by
          @liv-in-sky @Dutchman
          Ich kann das Problem Bestätigen. Bei mir werden auch 2 Amazon Geräte gefunden
          esphome.0	2021-02-28 19:59:03.324	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 127.0.0.1:6053
          esphome.0	2021-02-28 19:59:03.322	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 127.0.0.1:6053
          esphome.0	2021-02-28 19:59:03.320	info	(21729) Initiate 192.168.0.229
          esphome.0	2021-02-28 19:59:03.318	info	(21729) Initiate 192.168.0.166
          esphome.0	2021-02-28 19:58:33.322	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 127.0.0.1:6053
          esphome.0	2021-02-28 19:58:33.320	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 127.0.0.1:6053
          esphome.0	2021-02-28 19:58:33.316	info	(21729) Initiate 192.168.0.229
          esphome.0	2021-02-28 19:58:33.315	info	(21729) Initiate 192.168.0.166
          esphome.0	2021-02-28 19:58:03.322	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 127.0.0.1:6053
          esphome.0	2021-02-28 19:58:03.317	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 127.0.0.1:6053
          esphome.0	2021-02-28 19:58:03.311	info	(21729) Initiate 192.168.0.229
          esphome.0	2021-02-28 19:58:03.303	info	(21729) Initiate 192.168.0.166
          esphome.0	2021-02-28 19:57:33.498	error	(21729) ESPHome client 192.168.0.229 Error: connect ECONNREFUSED 192.168.0.229:6053
          esphome.0	2021-02-28 19:57:33.487	info	(21729) Initiate 192.168.0.229
          esphome.0	2021-02-28 19:57:33.486	info	(21729) [AutoDiscovery] New ESPHome device found at IP 192.168.0.229
          esphome.0	2021-02-28 19:57:33.480	info	(21729) ESPHome client test on ip 192.168.0.179 initialized
          esphome.0	2021-02-28 19:57:33.398	info	(21729) ESPHome Device info received for test
          esphome.0	2021-02-28 19:57:33.386	error	(21729) ESPHome client 192.168.0.166 Error: connect ECONNREFUSED 192.168.0.166:6053
          esphome.0	2021-02-28 19:57:33.382	info	(21729) ESPHome client 192.168.0.179 connected
          esphome.0	2021-02-28 19:57:33.375	info	(21729) Initiate 192.168.0.166
          esphome.0	2021-02-28 19:57:33.373	info	(21729) [AutoDiscovery] New ESPHome device found at IP 192.168.0.166
          esphome.0	2021-02-28 19:57:33.296	info	(21729) Initiate 192.168.0.179
          esphome.0	2021-02-28 19:57:33.183	info	(21729) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.esphome, node: v12.20.2, js-controller: 3.2.16
          esphome.0	2021-02-28 19:57:22.693	warn	(6761) ESPHome client 192.168.0.179 disconnected
          esphome.0	2021-02-28 19:57:22.692	warn	(6761) ESPHome client 192.168.0.179 disconnected
          esphome.0	2021-02-28 19:57:22.683	info	(6761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          esphome.0	2021-02-28 19:57:22.681	info	(6761) terminating
          esphome.0	2021-02-28 19:57:22.675	info	(6761) Got terminate signal TERMINATE_YOURSELF
          esphome.0	2021-02-28 19:50:09.656	info	(6761) ESPHome client test on ip 192.168.0.179 initialized
          esphome.0	2021-02-28 19:50:09.604	info	(6761) ESPHome Device info received for test
          esphome.0	2021-02-28 19:50:09.586	info	(6761) ESPHome client 192.168.0.179 connected
          esphome.0	2021-02-28 19:50:09.467	info	(6761) Initiate 192.168.0.179
          esphome.0	2021-02-28 19:50:09.449	info	(6761) [AutoDiscovery] New ESPHome device found at IP 192.168.0.179
            apollon77 @Dutchman last edited by
            @dutchman Was ist die Frage? Install läuft ja durch, dann crasht der Adapter ...
            • Dutchman
              Dutchman Developer Most Active Administrators @apollon77 last edited by
              @apollon77 sagte in [ESPHome] Beta release:
              ging hierum :
              @malaus sagte in [ESPHome] Beta release:
              Bei mir kommt ebenfalls die Fehlermeldung 25:
              $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.esphome"
              Info: Can not get current GitHub commit, we remember master branch only. Status: 422 (No commit found for SHA: master)
              install https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master
              NPM version: 6.14.11
              npm install https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
              npm
               ERR! code E404
              npm
               ERR!
              404 Not Found - GET https://codeload.github.com/iobroker-community-adapters/ioBroker.esphome/legacy.tar.gz/master
              npm ERR!
               404
              npm ERR!
               404  'https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master' is not in the npm registry.
              npm ERR!
               404 Your package name is not valid, because
              npm ERR!
              404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-28T11_14_11_035Z-debug.log
              ERROR: host.raspberrypi Cannot install https://github.com/iobroker-community-adapters/ioBroker.esphome/tarball/master: 1
              ERROR: process exited with code 25
              • Dutchman
                Dutchman Developer Most Active Administrators @Markus_ last edited by
                @markus_ sagte in [ESPHome] Beta release:
                ok thanks kan es reproduzieren und beheben
                  @dutchman js-controller 3.2??
                  FredF 1 Reply Last reply Reply Quote 1
                  • FredF
                    FredF Most Active Forum Testing @apollon77 last edited by
                    @apollon77 Ja.
                    https://forum.iobroker.net/topic/42741/esphome-beta-release/28?_=1614580980648
                      apollon77 @FredF last edited by
                      @fredf Dann bitte dafürmal js.controller issue anlegen. müssen wir da ansehen.
                        mtaxer last edited by
                        @dutchman Vielen Dank für die Integration. Ist geplant die "Light" Komponente mit einzubauen?
                        SG
                        Mario
                        • Dutchman
                          Dutchman Developer Most Active Administrators @mtaxer last edited by Dutchman
                          @bigd-73 sagte in [ESPHome] Beta release:
                          SG
                          Mario
                          Kan ich einbauen sobald ich ein Beispiel dafür bekomme.
                          Der Adapter sollte ne Meldung geben “type Not supporters. Und Dan Informationen geben die dem Entwickler geschickt werden müssen
                            mtaxer last edited by mtaxer
                            @dutchman Danke für die schnelle Antwort ...
                            Hier ein Link für einige Beispielkonfigurationen: QuinLED-Quad
                            Für mich persönlich wäre die "1x RGBW" Led Strip Variante aus diesen Beispielen interessant.
                            Log kann ich erst später analysieren ...
                            SG
                            Mario
                              @dutchman "Not supported" kann ich im Log leider nicht finden. Ist auf "debug" gestellt.
                              Die Config der Licht Komponente wird bereits richtig in den Objekten angezeigt.
                              SG
                              Mario
                              • Dutchman
                                SG
                                Mario
                                jup config ja aber states fehlen 🙂
                                Starte mal bitte den adapter neu, es sollte dan eine warn melding kommen (debug nicht noetig, zuviel info !)
                                DeviceType >TypenName< not yet supported
                                Please submit git issue with all information from next line
                                DeviceType >TypenName< | State-Keys >ArrayOfKey< | [entityStateConfig] >informationen<
                                ich brauchte mal die komplette warn log Ausgabe was da kommt, bitte dafuer nicht aus dem admin kopieren (Zeile ist abgeschnitten) sondern log runterladen
                                Thanks !
                                  mtaxer @Dutchman last edited by mtaxer
                                  @dutchman ... hier der Auszug aus dem Log für RGBW
                                  2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light not yet supported
                                  2021-03-01 15:53:06.241 - warn: esphome.0 (11603) Please submit git issue with all information from next line
                                  2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light | State-Keys {"key":3048698813,"state":false,"brightness":1,"red":1,"green":1,"blue":1,"white":1,"colorTemperature":0,"effect":"None"} | [entityStateConfig] {"config":{"objectId":"quinled_quad","key":3048698813,"name":"QuinLED_Quad","uniqueId":"esphome_developer_qlquad_dev4lightquinled_quad","supportsBrightness":true,"supportsRgb":true,"supportsWhiteValue":true,"supportsColorTemperature":false,"minMireds":0,"maxMireds":0,"effectsList":["None","My Slow Random Effect","My Fast Random Effect","My Insane Random Effect","Totally loco","Strobe Effect With Custom Values"]},"name":"Light","type":"Light","unit":""}
                                  SG
                                  Mario
                                  • Dutchman
                                    SG
                                    Mario
                                    danke fuer die Details und git issue :), na dan probier mal 0.1.1
                                    0.1.1 (2021-03-02)
                                    • (DutchmanNL) Type Fan added
                                    • (DutchmanNL) Type Light added
                                    • (DutchmanNL) Error messages optimized
                                    • (DutchmanNL) Device reconnect handling improved
                                    • (DutchmanNL) [Breaking!] Change state name to default "state" for type BinarySensor / Climate / Sensor / TextSensor & Switch
                                    • (DutchmanNL) Autodiscovery improved, non-ESPHome devices excluded
                                      @dutchman Danke für die Einbindung. Die Licht Komponente konnte ich schon mal testen.
                                      In den Objekten erscheint ein "state". Dieser nimmt den richtigen Wert des Stripes an, true oder false (ein/aus).
                                      Allerdings nur wenn ich den Stripes von der ESPHome Weboberfläche schalte. Der State selber ist in den Objekten
                                      nicht "setzbar/schreibbar". Einen State für die Farbe, Helligkeit und Farbtemperatur konnte ich noch nicht finden.
                                      SG
                                      Mario
                                      • Dutchman
                                        danke ! Tippfehler, bitte nochmal neu von git ziehen jetzt sollte alles kommen 🙂
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators @Dutchman last edited by
                                          @dutchman sagte in [ESPHome] Beta release:
                                          ist jetzt auch behoben 😉
                                            @dutchman Alle States erscheinen jetzt in den Objekten, sehr gut.
                                            Kurz zusammengefasst:
                                            • state (true/false - Ein/Aus) - funktioniert
                                            • brightness - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                            • blue - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                            • green - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                            • red - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                                            • colorTemperature - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 153 bis 500 sein (Mired)
                                            Ich sehe gerade Kommawerte funktionieren (0 bis 0.99). Allerdings ist diese Eingabe eher untypisch bei Helligkeits- und Farbangaben, denke ich zumindest.
                                            Optimal wäre noch ein zusätzlicher State der Hex Werte entgegen nimmt, also z.B. #00ff00. Eine Funktion im Adapter zerlegt den Wert in die RGB Werte und gibt es an ESPHome weiter. Ich habe das bis jetzt immer extern mit einem Skript gelöst.
                                            function hexToRgb(hex) {
                                              // Expand shorthand form (e.g. "03F") to full form (e.g. "0033FF")
                                              var shorthandRegex = /^#?([a-f\d])([a-f\d])([a-f\d])$/i;
                                              hex = hex.replace(shorthandRegex, function(m, r, g, b) {
                                                return r + r + g + g + b + b;
                                              var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                                              return result ? {
                                                r: parseInt(result[1], 16),
                                                g: parseInt(result[2], 16),
                                                b: parseInt(result[3], 16)
                                              } : null;
                                            return (hexToRgb(hex).r) + "," + (hexToRgb(hex).g) + "," + (hexToRgb(hex).b);
                                            Vielen Dank nochmal ...
                                            SG
                                            Mario
                                            Dutchman 3 Replies Last reply Reply Quote 0
                                            591
                                            152465
