    4. [ESPHome] Beta release
    • Dutchman
      Dutchman Developer Most Active Administrators @mtaxer last edited by Dutchman
      @bigd-73 sagte in [ESPHome] Beta release:
      @dutchman "Not supported" kann ich im Log leider nicht finden. Ist auf "debug" gestellt.
      Die Config der Licht Komponente wird bereits richtig in den Objekten angezeigt.
      SG
      Mario
      jup config ja aber states fehlen 🙂
      Starte mal bitte den adapter neu, es sollte dan eine warn melding kommen (debug nicht noetig, zuviel info !)
      DeviceType >TypenName< not yet supported
      Please submit git issue with all information from next line
      DeviceType >TypenName< | State-Keys >ArrayOfKey< | [entityStateConfig] >informationen<
      ich brauchte mal die komplette warn log Ausgabe was da kommt, bitte dafuer nicht aus dem admin kopieren (Zeile ist abgeschnitten) sondern log runterladen
      Thanks !
        mtaxer @Dutchman last edited by mtaxer
        @dutchman ... hier der Auszug aus dem Log für RGBW
        2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light not yet supported
        2021-03-01 15:53:06.241 - warn: esphome.0 (11603) Please submit git issue with all information from next line
        2021-03-01 15:53:06.241 - warn: esphome.0 (11603) DeviceType Light | State-Keys {"key":3048698813,"state":false,"brightness":1,"red":1,"green":1,"blue":1,"white":1,"colorTemperature":0,"effect":"None"} | [entityStateConfig] {"config":{"objectId":"quinled_quad","key":3048698813,"name":"QuinLED_Quad","uniqueId":"esphome_developer_qlquad_dev4lightquinled_quad","supportsBrightness":true,"supportsRgb":true,"supportsWhiteValue":true,"supportsColorTemperature":false,"minMireds":0,"maxMireds":0,"effectsList":["None","My Slow Random Effect","My Fast Random Effect","My Insane Random Effect","Totally loco","Strobe Effect With Custom Values"]},"name":"Light","type":"Light","unit":""}
        SG
        Mario
        • Dutchman
          SG
          Mario
          danke fuer die Details und git issue :), na dan probier mal 0.1.1
          0.1.1 (2021-03-02)
          • (DutchmanNL) Type Fan added
          • (DutchmanNL) Type Light added
          • (DutchmanNL) Error messages optimized
          • (DutchmanNL) Device reconnect handling improved
          • (DutchmanNL) [Breaking!] Change state name to default "state" for type BinarySensor / Climate / Sensor / TextSensor & Switch
          • (DutchmanNL) Autodiscovery improved, non-ESPHome devices excluded
            @dutchman Danke für die Einbindung. Die Licht Komponente konnte ich schon mal testen.
            In den Objekten erscheint ein "state". Dieser nimmt den richtigen Wert des Stripes an, true oder false (ein/aus).
            Allerdings nur wenn ich den Stripes von der ESPHome Weboberfläche schalte. Der State selber ist in den Objekten
            nicht "setzbar/schreibbar". Einen State für die Farbe, Helligkeit und Farbtemperatur konnte ich noch nicht finden.
            SG
            Mario
            • Dutchman
              danke ! Tippfehler, bitte nochmal neu von git ziehen jetzt sollte alles kommen 🙂
              • Dutchman
                Dutchman Developer Most Active Administrators @Dutchman last edited by
                @dutchman sagte in [ESPHome] Beta release:
                @markus_ sagte in [ESPHome] Beta release:
                Ich kann das Problem Bestätigen. Bei mir werden auch 2 Amazon Geräte gefunden
                ok thanks kan es reproduzieren und beheben
                ist jetzt auch behoben 😉
                  @dutchman Alle States erscheinen jetzt in den Objekten, sehr gut.
                  Kurz zusammengefasst:
                  • state (true/false - Ein/Aus) - funktioniert
                  • brightness - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                  • blue - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                  • green - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                  • red - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 0 bis 255 sein
                  • colorTemperature - es kann nur der Wert 0 und 1 eingegeben werden, sollte aber 153 bis 500 sein (Mired)
                  Ich sehe gerade Kommawerte funktionieren (0 bis 0.99). Allerdings ist diese Eingabe eher untypisch bei Helligkeits- und Farbangaben, denke ich zumindest.
                  Optimal wäre noch ein zusätzlicher State der Hex Werte entgegen nimmt, also z.B. #00ff00. Eine Funktion im Adapter zerlegt den Wert in die RGB Werte und gibt es an ESPHome weiter. Ich habe das bis jetzt immer extern mit einem Skript gelöst.
                  function hexToRgb(hex) {
                    // Expand shorthand form (e.g. "03F") to full form (e.g. "0033FF")
                    var shorthandRegex = /^#?([a-f\d])([a-f\d])([a-f\d])$/i;
                    hex = hex.replace(shorthandRegex, function(m, r, g, b) {
                      return r + r + g + g + b + b;
                    var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                    return result ? {
                      r: parseInt(result[1], 16),
                      g: parseInt(result[2], 16),
                      b: parseInt(result[3], 16)
                    } : null;
                  return (hexToRgb(hex).r) + "," + (hexToRgb(hex).g) + "," + (hexToRgb(hex).b);
                  Vielen Dank nochmal ...
                  SG
                  Mario
                  Dutchman 3 Replies Last reply Reply Quote 0
                  • Dutchman
                    cool ! dan hab ich ja doch nicht al zuviel mist gebaut im framework 🙂
                    hmm ok ich muss mal sehe wie das reinkommt, kannste mal bitte den adapter auf debug stellen.
                    Ich brauche dan fuer die device alles hinter log Eintrag "entityStateData".
                    Vermute mal muss einfach die Sachen * 100 machen, wen du 0.5 einstellst geht zb die brightness auch auf 50% ?
                    Ich habe etwas vergleichbares im WLED adapter drin, ist bissl komplizierte dafuer bitte git issue 🙂
                    • Dutchman
                      hast du die function zufällig auch andersrum, RGB to hex ?
                      Edit : hab schon das war ja noch einfacher :/, baue ich heut abend ein 🙂
                      function rgbToHex(r, g, b) {
                        return "#" + componentToHex(r) + componentToHex(g) + componentToHex(b);
                        @dutchman jetzt warst du schneller 😁
                        das hätte ich gefunden ...
                        function componentToHex(c) {
                        var hex = c.toString(16);
                        return hex.length == 1 ? "0" + hex : hex;
                        SG
                        Mario
                        Dutchman 1 Reply Last reply Reply Quote 1
                          Diesen Befehl sende ich via mqtt (so löste/löse ich die Sache bevor du begonnen hast den Adapter zu entwickeln)
                          Stripe ein, Helligkeit 100% (255), Farbe grün, kein Effekt
                          {"effect":"None","state":"ON","brightness":255,"color":{"r":0,"g":255,"b":0},"white_value":0}
                          Das kommt im Log rein
                          [entityStateData] {"key":801952849,"state":true,"brightness":1,"red":0,"green":1,"blue":0,"white":0,"colorTemperature":0,"effect":"None"}
                          weiteres Beispiel (mqtt):
                          Stripe ein, Helligkeit ca. 50% (127), Farbe lila, kein Effekt
                          {"effect":"None","state":"ON","brightness":127,"color":{"r":136,"g":0,"b":255},"white_value":0}
                          [entityStateData] {"key":801952849,"state":true,"brightness":0.49803921580314636,"red":0.5333333611488342,"green":0,"blue":1,"white":0,"colorTemperature":0,"effect":"None"}
                          SG
                          Mario
                            genau ...
                            EDIT:
                            ich denke die Umrechnung lautet so: Value (Dezimalwert für ESPHome = x (Hex Value für eine Grundfarbe)/255 ---> zB.: 136/255 = 0.5333333611488342 (für obiges Beispiel aus dem Log)
                            Gilt natürlich auch für die Helligkeit ...
                            SG
                            Mario
                              mtaxer last edited by mtaxer
                              @dutchman ... weil ich gerade beim Wünschen bin 😀
                              Optimal wäre dann noch eine weitere Funktion bzw. Abfrage im Adapter. Falls via Hex Value #ffffff (weiss) bzw. RGB Value jeweils 255 (weiss) eingegeben wird, automatisch der White Channel (State "white" in den Objekten) auf 1 geht und RGB jeweils auf 0. Das ganze natürlich auch umgekehrt. Wird eine Farbe eingegeben (nicht weiss), soll der White Channel wieder auf 0 und die RGB bzw. Hex Werte gesetzt werden.
                              Hintergrund ---> Ein "weiss" mit den drei Grundfarben gemischt ist nie ein richtig sauberes "weiss", sondern eher blaustichig. Diese Funktion sollte vielleicht über einen State in den Objekten Ein/Aus geschaltet werden können. Dann kann jeder die Farbmischung lösen wie er möchte. Hab das bisher extern über ein Script gelöst.
                              So jetzt ist schluss, zumindest vorerst ... 😇
                              SG
                              Mario
                              Dutchman 2 Replies Last reply Reply Quote 1
                              • Dutchman
                                Sollte möglich sein auch dafür bitte ein GIT issue
                                • FredF
                                  FredF Most Active Forum Testing @Dutchman last edited by
                                  @dutchman Die aktuellste Version 0.1.2 gerade nochmal probiert und siehe da, nun ging es. Das soll einer verstehen...
                                  • Dutchman
                                    probier mal 0.1.3 bitte
                                    • Dutchman
                                      hmm ja kan man machen, aber was wuerde passieren wen man nur RGB hat geht ESPHome da dan richtig mit um ?
                                      Den wen ich bei RGB (nicht RGBW) den RGB auf 0 mache geht alles aus ?
                                      • Dutchman
                                        Mario
                                        falls es mal jemand gebrauchen kan, RGB > HEX und HEX > RGB :
                                        (baue es morgen im adapter ein....)
                                            const shorthandRegex = /^#?([a-f\d])([a-f\d])([a-f\d])$/i;
                                            hex = hex.replace(shorthandRegex, function (m, r, g, b) {
                                            const result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                                            return result ? {
                                                red: parseInt(result[1], 16),
                                                green: parseInt(result[2], 16),
                                                blue: parseInt(result[3], 16)
                                            } : null;
                                            function componentToHex(color) {
                                                const hex = color.toString(16);
                                                return hex.length == 1 ? '0' + hex : hex;
                                            const hex = '#' + componentToHex(r) + componentToHex(g) + componentToHex(b);
                                            return hex;
                                        const rgb = hexToRgb(`ff4000`)
                                        console.log(rgb)
                                        const hex = rgbToHex(rgb.red,rgb.blue,rgb.green)
                                        console.log(hex)
                                          Guten Morgen, in der Regel wird die Anzahl der Kanäle in ESPHome in der Light Komponente definiert. Über die Config Objekte in den States könnte man den Typ abfangen. Bei RGBW müsste dann false stehen. In diesen Fall müsste man die Funktion deaktivieren. Komme leider erst heute Abend zum Testen. Screenshots reiche ich dann nach ...
                                          SG
                                          Mario
                                          • Dutchman
                                            Moin!
                                            Super danke dir genau was ich brauche dafür!
                                            Ich habe nicht alle Typen in Betrieb da hilft es sehr die Infos zu bekommen man kan nicht alles selber testen 😂👍
                                            591
                                            153200
