    4. IoBroker down - Cannot read system
      Prince3k @wendy2702 last edited by
      @wendy2702 said in IoBroker down - Cannot read system:
      @prince3k Kleinen Fehler gemacht beim installieren JS Controller:
      so wäre richtig
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      auch hiernach kommt immer die selbe Fehlermeldung:
      Cannot read system.config: null (OK when migrating or restoring)
      Cannot find view "system" for search "host"
      pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.11
      > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      object 0_userdata.0.example_state created
      object 0_userdata.0 created
      object alias.0 created
      object system.certificates created
      object system.repositories created
      object system.config created
      object enum.functions created
      object enum.rooms created
      object system.group.user created
      object system.group.administrator created
      object _design/system created
      Renamed repository "default to "stable"
      Renamed repository "latest to "beta"
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + iobroker.js-controller@3.2.16
      added 1 package from 1 contributor and updated 12 packages in 46.366s
      22 packages are looking for funding
        run `npm fund` for details
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      • wendy2702
        wendy2702 @Prince3k last edited by
        @prince3k
        iobroker list instances
        iobroker list adapters
          @wendy2702
          pi@raspberrypi4-iob:/opt/iobroker $ iobroker list instances
          + instance is alive
          pi@raspberrypi4-iob:/opt/iobroker $ iobroker list adapters
          system.adapter.admin                   : admin          - v4.1.13
          • wendy2702
            wendy2702 @Prince3k last edited by wendy2702
            @prince3k Ich hoffe für dich das du ein Backup hast.
            Wie es aussieht ist dein Installation schlicht und ergreifend weg.
            EDIT: BITTE DAS FILE "package.json" mal hochladen. Liegt in /opt/iobroker/
            wenn du jetzt
            iobroker add admin
            machst, dann
            iobroker start admin
            Wirst du wahrscheinlich nur eine leere Admin Seite sehen.
            Kannst du mal
            ls -la /opt/iobroker/node_modules/
            machen
            P 2 Replies Last reply Reply Quote 0
              @wendy2702 package.json
              • wendy2702
                @prince3k Auch noch bitte den Inhalt von:
                ls -la /opt/iobroker/iobroker-data/
                  @wendy2702
                  Ich habe mal was mit Backitup auf meiner Google Drive gesichert, aber noch nie wiederhergestellt, schau ich mir gleich mal an, denn du hast Recht. Nachdem ich die Schritte gemacht habe, hatte ich leider eine leere Adminseite.
                  pi@raspberrypi4-iob:/opt/iobroker $ ls -la /opt/iobroker/node_modules/
                  insgesamt 4048
                  drwxrwxrwx+ 999 iobroker iobroker 36864 Mär  2 17:47 .
                  drwxrwxrwx+   9 iobroker iobroker  4096 Mär  2 13:52 ..
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 abbrev
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 abort-controller
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 accepts
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 acme-http-01-standalone
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 after
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 agent-base
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 ajv
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgblack
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgblue
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgcyan
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bggreen
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgmagenta
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgred
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgwhite
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgyellow
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-black
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-blue
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bold
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-colors
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-cyan
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-dim
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-gray
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-green
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-grey
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-hidden
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-inverse
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-italic
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-magenta
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-red
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-regex
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-reset
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-strikethrough
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jan  8 19:29 ansi-styles
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-underline
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-white
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-wrap
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-yellow
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 anymatch
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 @apollon
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 append-field
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 aproba
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 archy
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 are-we-there-yet
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 arraybuffer.slice
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 array-each
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 30  2019 array-ext
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 array-find
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 array-find-index
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 array-flatten
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 array-slice
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 array-sort
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 array-unique
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 arr-diff
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 arr-flatten
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 arrify
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 arr-swap
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 arr-union
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 21  2020 asap
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 ascli
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 asn1
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 assert-plus
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 assign-symbols
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 async
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 asynckit
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 async-limiter
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 async-retry
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez  5 21:35 at-least-node
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 atob
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 authenticate-pam
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 autobind-decorator
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 aws4
                  drwxrwxrwx+  10 iobroker iobroker  4096 Sep 28  2019 aws-sdk
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 aws-sign2
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 axios
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 babel
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 backo2
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 balanced-match
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 base
                  drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 20:58 base-64
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 base64-arraybuffer
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 base64id
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 base64-js
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 basic-auth
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 bcrypt-pbkdf
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 better-assert
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 bignumber.js
                  drwxrwxrwx+   2 iobroker iobroker  4096 Mär  2 17:47 .bin
                  drwxrwxrwx+   6 iobroker iobroker  4096 Okt  2  2019 binary-data
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 binary-extensions
                  drwxrwxr-x+   2 iobroker iobroker  4096 Feb 20  2020 bindings
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 bl
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 blob
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez 13  2019 bluebird
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 body-parser
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 bottlejs
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 brace-expansion
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 braces
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:04 bring-shopping
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jul 13  2020 buffer
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-alloc
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-alloc-unsafe
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez  2 19:06 buffer-crc32
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-equal-constant-time
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-fill
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-from
                  drwxrwxr-x+   6 iobroker iobroker  4096 Dez  5 21:38 bufferutil
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 buffer-xor
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 busboy
                  drwxrwxrwx+   8 iobroker iobroker  4096 Okt  3  2019 bytebuffer
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 bytes
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb  3 22:08 cacheable-lookup
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 cacheable-request
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 cache-base
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 callback-stream
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 call-bind
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 callsite
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 camelcase
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 camelcase-keys
                  drwxrwxr-x+   8 iobroker iobroker  4096 Jun  6  2020 canvas
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jul 13  2020 capitalize
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 caseless
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 castv2
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 castv2-client
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 castv2-player
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 cert-info
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 charenc
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 choices-separator
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 chokidar
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 chownr
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 circular-json
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 class-utils
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 cli
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cliui
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 clone-deep
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cloneextend
                  drwxrwxrwx+   4 iobroker iobroker  4096 Mai 20  2020 clone-response
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 cluster-key-slot
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jul 13  2020 coap
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 coap-packet
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 code-point-at
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 coffee-compiler
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 coffee-script
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 collection-visit
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 color
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 color-convert
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 color-name
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 colors
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 colorspace
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 color-string
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 color-support
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt  3  2019 colour
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 combined-stream
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 commander
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 commist
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 component-bind
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 component-emitter
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 component-inherit
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 compose-middleware
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 compressible
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 compression
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 concat-map
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 concat-stream
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 connect
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 connect-flash
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 console-control-strings
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 content-disposition
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 content-type
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cookie
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cookie-parser
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cookie-signature
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 copy-descriptor
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 copy-props
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 core-util-is
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 crc
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt  3  2019 cron
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 cron-parser
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 cross-spawn
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 crypt
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 crypto-js
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 currently-unhandled
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cycle
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 d
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jul  7  2020 @dabh
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 daemonize2
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 dashdash
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez  2 19:06 debounce
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 debug
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 decache
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 decamelize
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 decamelize-keys
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 decode-uri-component
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 decompress-response
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 16  2020 deep-clone
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 deep-equal
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 deep-extend
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 deep-is
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 default-compare
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 default-gateway
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 defer-to-connect
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 define-properties
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 define-property
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 delayed-stream
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 delegates
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 denque
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 depd
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 @destinationstransfers
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 destroy
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 detect-file
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 detect-libc
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 dev-null
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 dgram
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 dicer
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 dijkstrajs
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 diskusage
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 dns-packet
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 dns-socket
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 doorbot
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 dotenv
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb 22 20:58 dropbox-v2-api
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 duplexer
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 duplexer3
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 duplexify
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 each-props
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ecc-jsbn
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ecdsa-sig-formatter
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 eckles
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ee-first
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:57 emoji-regex
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 enabled
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 encodeurl
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 end-of-stream
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 engine.io
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 engine.io-client
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 engine.io-parser
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 ent
                  drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 epoll
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 error-ex
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 error-symbol
                  drwxrwxrwx+  17 iobroker iobroker  4096 Sep 28  2019 es5-ext
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 es6-iterator
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 es6-map
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 es6-promise
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 es6-promisify
                  drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 es6-set
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 es6-symbol
                  drwxrwxr-x+   4 iobroker iobroker  4096 Dez  5 21:57 escalade
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 escape-html
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 escodegen
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 esm
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 esprima
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 estraverse
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 esutils
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 etag
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 event-emitter
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:57 eventemitter3
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 events
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt 13  2019 event-stream
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 event-target-shim
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 execa
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 exit
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 expand-brackets
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 expand-template
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 expand-tilde
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 express
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 express-basic-auth
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 express-dynamic-middleware
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 expresse
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 express-fileupload
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 express-list-endpoints
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 express-rate-limit
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 express-session
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 extend
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 extend-shallow
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 extglob
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 extsprintf
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 eyes
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 fancy-log
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fast-deep-equal
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 fast-json-stable-stringify
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 fast-levenshtein
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 fast-safe-stringify
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jul 13  2020 fastseries
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez  5 21:35 fast-text-encoding
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 fast-xml-parser
                  drwxrwxr-x+   4 iobroker iobroker  4096 Jul  7  2020 fecha
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 ffmpeg-for-homebridge
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 20  2020 file-stream-rotator
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 file-uri-to-path
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 fill-range
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 finalhandler
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 find-up
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 findup-sync
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 fined
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 flagged-respawn
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 fn.name
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 follow-redirects
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 forever-agent
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 for-in
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 form-data
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 for-own
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 forwarded
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 fragment-cache
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fresh
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 from
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fs-constants
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 fs-extra
                  drwxrwxr-x+   2 iobroker iobroker  4096 Feb 20  2020 fs-minipass
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fs.realpath
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 ftp
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ftp-response-parser
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 function-bind
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 gauge
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 gaxios
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 gcp-metadata
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 generate-function
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 get-caller-file
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 get-intrinsic
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 getpass
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 get-port
                  drwxrwxrwx+   2 iobroker iobroker  4096 Dez 25  2019 get-stream
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 get-value
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 github-from-package
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 glob
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 global-modules
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 global-prefix
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 glob-parent
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 glob-stream
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 glogg
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 glossy
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:59 googleapis
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 googleapis-common
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:59 google-auth-library
                  drwxrwxrwx+   6 iobroker iobroker  4096 Okt  3  2019 @google-cloud
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 google-gax
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 google-p12-pem
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 google-proto-files
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 got
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 graceful-fs
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 @greenlock
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 greenlock
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 greenlock-express
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 greenlock-manager-fs
                  drwxrwxr-x+   2 iobroker iobroker  4096 Nov  6  2019 greenlock-store-fs
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 @grpc
                  drwxrwxrwx+   6 iobroker iobroker  4096 Okt  3  2019 grpc
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 grpc-gcp
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 gtoken
                  drwxrwxr-x+   6 iobroker iobroker  4096 Okt 23  2019 gulp-cli
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 gulplog
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 @harmonyhub
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 harmonyhubws
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 har-schema
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 har-validator
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 has
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 has-binary
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 has-binary2
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 has-cors
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 has-symbols
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 has-unicode
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 has-value
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 has-values
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 he
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 help-me
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 hoek
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 homedir-polyfill
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 hosted-git-info
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 hot-patcher
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb  3 22:08 http2-wrapper
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 http-cache-semantics
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 http-errors
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 http-headers
                  drwxrwxr-x+   7 iobroker iobroker  4096 Dez  5 21:57 http-mitm-proxy
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 http-signature
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 https-proxy-agent
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez 25  2019 human-signals
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 i
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 iconv-lite
                  drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 icy
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 13  2019 ieee754
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 ignore-walk
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 immediate
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 indent-string
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 indexof
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 inflight
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 info-symbol
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 inherits
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ini
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 interpret
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 invert-kv
                  drwxrwxrwx+  10 iobroker iobroker  4096 Feb 12 18:34 @iobroker
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 iobroker
                  drwxrwxr-x+   8 iobroker iobroker  4096 Jan  8 21:51 iobroker.admin
                  drwxrwxr-x+   7 iobroker iobroker  4096 Feb 22 20:59 iobroker.backitup
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 17:04 iobroker.bring
                  drwxrwxr-x+   7 iobroker iobroker  4096 Okt 23  2019 iobroker.chromecast
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan  8 19:27 iobroker.cloud
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:05 iobroker.denon
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 17:09 iobroker.discovery
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:11 iobroker.dwd
                  drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 iobroker.feiertage
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 iobroker.fritzbox
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan  8 18:32 iobroker.fritzdect
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:10 iobroker.fronius
                  drwxrwxrwx+   6 iobroker iobroker  4096 Okt  3  2019 iobroker.gardena
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 iobroker.harmony
                  drwxrwxr-x+   8 iobroker iobroker  4096 Feb 22 21:49 iobroker.history
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:59 iobroker.ical
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jul 13  2020 iobroker.info
                  drwxrwxr-x+   8 iobroker iobroker  4096 Jan 11 21:04 iobroker.iqontrol
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 01:00 iobroker.javascript
                  drwxrwxr-x+   6 iobroker iobroker  4096 Mär  2 18:50 iobroker.js-controller
                  drwxrwxr-x+   5 iobroker iobroker  4096 Dez  5 21:38 iobroker.lgtv
                  drwxrwxr-x+   7 iobroker iobroker  4096 Feb  9 21:58 iobroker.mihome
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb 22 21:09 iobroker.mihome-vacuum
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 01:02 iobroker.mobile
                  drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.moma
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jul 13  2020 iobroker.mqtt
                  drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.mqtt-client
                  drwxrwxr-x+   8 iobroker iobroker  4096 Feb  3 22:08 iobroker.nuki-extended
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jul 12  2020 iobroker.ping
                  drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 iobroker.pushover
                  drwxrwxr-x+   9 iobroker iobroker  4096 Jul 12  2020 iobroker.ring
                  drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.rpi2
                  drwxrwxr-x+   9 iobroker iobroker  4096 Jan  8 18:30 iobroker.sayit
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 16:54 iobroker.schoolfree
                  drwxrwxr-x+   8 iobroker iobroker  4096 Feb 22 21:11 iobroker.shelly
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:12 iobroker.shuttercontrol
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jul 13  2020 iobroker.simple-api
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jul 13  2020 iobroker.socketio
                  drwxrwxr-x+   5 iobroker iobroker  4096 Dez 13  2019 iobroker.sonoff
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jan  8 19:29 iobroker.statistics
                  drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.tankerkoenig
                  drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 iobroker.terminal
                  drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 16:58 iobroker.tesla-motors
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb  9 22:00 iobroker.tuya
                  drwxrwxr-x+   8 iobroker iobroker  4096 Jan 23 17:00 iobroker.vis
                  drwxrwxr-x+   7 iobroker iobroker  4096 Dez 12  2019 iobroker.vis-bars
                  drwxrwxr-x+   7 iobroker iobroker  4096 Dez  5 21:42 iobroker.vis-hqwidgets
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan  8 19:47 iobroker.vis-map
                  drwxrwxr-x+   7 iobroker iobroker  4096 Dez 12  2019 iobroker.vis-material
                  drwxrwxr-x+   7 iobroker iobroker  4096 Dez 12  2019 iobroker.vis-metro
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 17:02 iobroker.web
                  drwxrwxr-x+   7 iobroker iobroker  4096 Mai 20  2020 iobroker.wifilight
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt  6  2019 iobroker.wlanthermo-nano
                  drwxrwxr-x+   7 iobroker iobroker  4096 Dez 13  2019 iobroker.yeelight-2
                  drwxrwxr-x+  10 iobroker iobroker  4096 Feb 26 22:19 iobroker.zigbee
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mär  2 17:47 ioredis
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 ip
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 ip2buf
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ipaddr.js
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 ip-regex
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-absolute
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-accessor-descriptor
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 isarray
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-arrayish
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 is-binary-path
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-buffer
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-data-descriptor
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-descriptor
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 isemail
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 isexe
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-extendable
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-extglob
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-fullwidth-code-point
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-glob
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-ip
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-nan
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-negated-glob
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-number
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 isobject
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-plain-obj
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-plain-object
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-property
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-relative
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 is-ssh
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 is-stream
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 isstream
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 is-stream-ended
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-stun
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-typedarray
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-unc-path
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-utf8
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-windows
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 jmespath
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 joi
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 jsbn
                  drwxrwxrwx+   4 iobroker iobroker  4096 Jan  8 18:29 jsftp
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jul 13  2020 jshashes
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 json3
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 23 00:59 jsonata
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 json-bigint
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 json-buffer
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 jsonfile
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 json-parse-better-errors
                  drwxrwxrwx+   8 iobroker iobroker  4096 Okt  3  2019 jsonpath
                  drwxrwxrwx+   9 iobroker iobroker  4096 Sep 28  2019 json-schema
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 json-schema-traverse
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 json-stable-stringify-without-jsonify
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 json-stringify-safe
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 jsonwebtoken
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 jsprim
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb 12 18:34 jszip
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 jwa
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 jws
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 keychain
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 keypairs
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 keyv
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 kind-of
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 koalas
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 kuler
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 layerr
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lazy-cache
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lcid
                  drwxrwxrwx+   5 iobroker iobroker  4096 Jan 22 23:02 le-acme-core
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 le-challenge-fs
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 le-sni-auto
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 leven
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 levn
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:38 lgtv2
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 lie
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 liftoff
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 loadavg-windows
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 load-json-file
                  drwxrwxr-x+   9 iobroker iobroker  4096 Sep 18 22:55 localforage
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 locate-path
                  drwxrwxrwx+   3 iobroker iobroker 20480 Sep 28  2019 lodash
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.assign
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.at
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.camelcase
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.clone
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.compose
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 lodash.defaults
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.first
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.flatten
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.has
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.includes
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isboolean
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isfunction
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isinteger
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isnumber
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isobject
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isplainobject
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isstring
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.mapkeys
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.merge
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.once
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 logform
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 log-ok
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 log-utils
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 long
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 long-timeout
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 loud-rejection
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 lowercase-keys
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jul 13  2020 lru-cache
                  drwxrwxr-x+   2 iobroker iobroker  4096 Nov 25  2019 lru_map
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 luxon
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 make-iterator
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 map-cache
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 map-obj
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt 13  2019 map-stream
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 map-visit
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 matchdep
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 md5
                  drwxrwxr-x+  10 iobroker iobroker  4096 Jan  8 18:29 mdns
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 mdns-discovery
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 media-typer
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 meow
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 merge-descriptors
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 merge-stream
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 methods
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 micromatch
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 mime
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 mime-db
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 mime-types
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 mimic-fn
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 mimic-response
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 minimatch
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 minimist
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 minimist-options
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 16  2020 minipass
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 minizlib
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 mixin-deep
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 mixin-object
                  drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 mkdirp
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 mkdirp-classic
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 moment
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 moment-timezone
                  drwxrwxrwx+  10 iobroker iobroker  4096 Sep 28  2019 mqtt
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 mqtt-connection
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 mqtt-packet
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ms
                  drwxrwxr-x+   5 iobroker iobroker  4096 Feb 22 21:28 multer
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 multicast-dns
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 mute-stdout
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 mute-stream
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 nan
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 nanomatch
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 napi-build-utils
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 nat-puncher
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 ncp
                  drwxrwxr-x+   8 iobroker iobroker  4096 Feb  9 21:59 needle
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 negotiator
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 nested-property
                  drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 netmask
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 next-line
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 next-tick
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez 22  2019 node-abi
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 node.extend
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 node-fetch
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 node-forge
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 node-gyp-build
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 node-ical
                  drwxrwxr-x+   5 iobroker iobroker  4096 Dez 25  2019 node-machine-id
                  drwxrwxr-x+   4 iobroker iobroker  4096 Jan 23 17:08 node-mndp
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jun  6  2020 node-pre-gyp
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 node-record-lpcm16
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 node-rest-client
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 node-schedule
                  drwxrwxrwx+   8 iobroker iobroker  4096 Sep 28  2019 node-ssdp
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 node-wol
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 noop-logger
                  drwxrwxr-x+   4 iobroker iobroker  4096 Jun  6  2020 nopt
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 normalize-package-data
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 normalize-path
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 normalize-url
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 npm-bundled
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 npmlog
                  drwxrwxr-x+   4 iobroker iobroker  4096 Jun  6  2020 npm-normalize-package-bin
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 npm-packlist
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 npm-run-path
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb  3 22:08 nuki-bridge-api
                  drwxrwxr-x+   5 iobroker iobroker  4096 Feb  3 22:08 nuki-web-api
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 number-is-nan
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 oauth-sign
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 object-assign
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 object-component
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 object-copy
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 object.defaults
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 object-hash
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 object-keys
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 object.map
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 object.pick
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 object-visit
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 once
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 one-time
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 onetime
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 on-finished
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 on-headers
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 optimist
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 16  2020 optionator
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 options
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 optjs
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ordered-read-streams
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 osenv
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 os-homedir
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 os-locale
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 os-tmpdir
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb 20  2020 pako
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 parse-filepath
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 parse-json
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parsejson
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 parse-listing
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 parse-node-version
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 parse-passwd
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 parse-path
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parseqs
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parseuri
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 parse-url
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parseurl
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 pascalcase
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22  2020 passport
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 passport-local
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 passport.socketio
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 passport-strategy
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-dirname
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-exists
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-is-absolute
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 path-key
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-parse
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 path-posix
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 path-root
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 path-root-regex
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-to-regexp
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-type
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pause
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 pause-stream
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 p-cancelable
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 performance-now
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 27  2020 persist-path
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 p-finally
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 16  2020 picomatch
                  drwxrwxr-x+   4 iobroker iobroker  4096 Jan 22 23:02 pidusage
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pify
                  drwxrwxr-x+   5 iobroker iobroker  4096 Feb 22 21:11 ping
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pinkie
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pinkie-promise
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 playlist-parser
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 23 17:14 p-limit
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 p-locate
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 p-map
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 pngjs
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pointer-symbol
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 posix-character-classes
                  drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:57 p-queue
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 28  2019 prebuild-install
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 prelude-ls
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 prepend-http
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 p-retry
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 pretty-hrtime
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 process-nextick-args
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 promirepl
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 promiscuous
                  drwxrwxr-x+   7 iobroker iobroker  4096 Mai 21  2020 promise
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 promisify-child-process
                  drwxrwxr-x+   8 iobroker iobroker  4096 Jan 22 23:02 prompt
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-actions
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 prompt-base
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-checkbox
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 prompt-choices
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-list
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 prompt-question
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-radio
                  drwxrwxrwx+  12 iobroker iobroker  4096 Sep 28  2019 @protobufjs
                  drwxrwxrwx+  10 iobroker iobroker  4096 Sep 28  2019 protobufjs
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 protocols
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 proxy-addr
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 psl
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 p-timeout
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 p-try
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 public-ip
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 28  2019 pump
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 28  2019 pumpify
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 punycode
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 pushover-notifications
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 q
                  drwxrwxr-x+   7 iobroker iobroker  4096 Nov 25  2019 qrcode
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 qs
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 querystring
                  drwxrwxr-x+   2 iobroker iobroker  4096 Feb  3 22:08 querystringify
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 quick-lru
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 radio-symbol
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 random-bytes
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 range-parser
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 rasha
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 raw-body
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 rc
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 read
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 readable-stream
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 readdirp
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 readline-sync
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 readline-ui
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 readline-utils
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 read-pkg
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 read-pkg-up
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 rechoir
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 redent
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 redirect-https
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb 12 18:34 redis-commands
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 redis-errors
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 redis-parser
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 regex-not
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 reinterval
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 remove-trailing-separator
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 repeat-element
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 repeat-string
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 replace-homedir
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 request
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb  3 22:08 request-promise
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 17:04 request-promise-core
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jan 23 17:04 request-promise-native
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 require-directory
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 require-main-filename
                  drwxrwxr-x+   2 iobroker iobroker  4096 Feb  3 22:08 requires-port
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 resolve
                  drwxrwxr-x+   2 iobroker iobroker  4096 Feb  3 22:08 resolve-alpn
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 resolve-dir
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 resolve-url
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 respjs
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 responselike
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 ret
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 retry
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 retry-request
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 revalidator
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 rimraf
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 ring-api
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 ring-client-api
                  drwxrwxrwx+  13 iobroker iobroker  4096 Jan 22 23:02 @root
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 rpi-gpio
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 rrule
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan 22 23:02 rsa-compat
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 rtsp-server
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 rtsp-stream
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 rtsp-streaming-server
                  drwxrwxr-x+  20 iobroker iobroker  4096 Mai 20  2020 rxjs
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 safe-buffer
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 safer-buffer
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 safe-regex
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 safe-replace
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 sax
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 @schmupu
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 sdp
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 semaphore
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 semver
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 semver-greatest-satisfied-range
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 send
                  drwxrwxr-x+  10 iobroker iobroker  4096 Mär  2 17:47 @sentry
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 seq-logging
                  drwxrwxrwx+  13 iobroker iobroker  4096 Jan 23 17:08 @serialport
                  drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 serialport
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 serve-static
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-blocking
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-getter
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-immediate-shim
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 setprototypeof
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-value
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 shallow-clone
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 shebang-command
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 shebang-regex
                  drwxrwxr-x+   3 iobroker iobroker  4096 Nov 29 20:49 shelly-iot
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 signal-exit
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 simple-concat
                  drwxrwxrwx+   3 iobroker iobroker  4096 Mai 20  2020 simple-get
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 simple-swizzle
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 @sindresorhus
                  drwxrwxrwx+   7 iobroker iobroker  4096 Okt  2  2019 sip
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 sip.js
                  drwxrwxr-x+   5 iobroker iobroker  4096 Mai 19  2020 slip
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 snapdragon
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 snapdragon-node
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 snapdragon-util
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 socket.io
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 socket.io-adapter
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 socket.io-client
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 socket.io-parser
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 sorted-array-functions
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 source-map
                  drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 source-map-resolve
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 source-map-support
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 source-map-url
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 sparkles
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-correct
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-exceptions
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-expression-parse
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-license-ids
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt 13  2019 split
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 split2
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 split-string
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 sprintf-js
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 sshpk
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 stackback
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stack-trace
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 standard-as-callback
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 static-eval
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 static-extend
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 statuses
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stealthy-require
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stream-combiner
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 stream-events
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 streamifier
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stream-parser
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 streamsearch
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 stream-shift
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 string_decoder
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 string-width
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-ansi
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-bom
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-color
                  drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 strip-final-newline
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 strip-indent
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-json-comments
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 strip-lines
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 stubs
                  drwxrwxrwx+   6 iobroker iobroker  4096 Okt  2  2019 stun
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 success-symbol
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 suncalc2
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 sver-compat
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 sync-exec
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 systeminformation
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 @szmarczak
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 tableify
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 tar
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 tar-fs
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 targz
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 tar-stream
                  drwxrwxr-x+   2 iobroker iobroker  4096 Nov 29 20:49 tcp-ping
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 terminal-paginator
                  drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 16:58 teslajs
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 text-hex
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 through
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 through2
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 through2-filter
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 thunky
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 time-constants
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 timeout-as-promise
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 time-stamp
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-absolute-glob
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-array
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-buffer
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 toggle-array
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 toidentifier
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-object-path
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 topo
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 to-readable-stream
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 to-regex
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 to-regex-range
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 tough-cookie
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 treemap-js
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 trim-newlines
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 triple-beam
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 tslib
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 tunnel-agent
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 turbo-crc32
                  drwxrwxr-x+   4 iobroker iobroker  4096 Feb  9 22:00 tuyapi
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 tweetnacl
                  drwxrwxrwx+  26 iobroker iobroker  4096 Sep 28  2019 type
                  drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 type-check
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 typedarray
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 27  2020 typedarray-to-buffer
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 type-is
                  drwxrwxrwx+  15 iobroker iobroker  4096 Feb 22 21:28 @types
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 00:59 typescript
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 uid-number
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 uid-safe
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ultron
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 unc-path-regex
                  drwxrwxr-x+   5 iobroker iobroker  4096 Nov 29 20:49 underscore
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 union-value
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 unique-stream
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 universalify
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb 20  2020 unix-dgram
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 unorm
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 unpipe
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 unset-value
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 uri-js
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 urix
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 url
                  drwxrwxr-x+   5 iobroker iobroker  4096 Feb 22 20:58 url-join
                  drwxrwxr-x+   3 iobroker iobroker  4096 Feb  3 22:08 url-parse
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 url-parse-lax
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 url-template
                  drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 ursa-optional
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 use
                  drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 utf-8-validate
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 util
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 util-deprecate
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 utile
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 utils-merge
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 uuid
                  drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 v8flags
                  drwxrwxr-x+  12 iobroker iobroker  4096 Feb 22 21:28 valetudo
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 validate-npm-package-license
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 vary
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 verror
                  drwxrwxr-x+   4 iobroker iobroker  4096 Jan 23 00:59 virtual-tsc
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 19  2020 vm2
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wake_on_lan
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 walkdir
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 warning-symbol
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 weak-daemon
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb 22 20:59 webdav
                  drwxrwxr-x+   5 iobroker iobroker  4096 Dez  5 21:38 websocket
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 websocket-stream
                  drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 which
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 which-module
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 which-pm-runs
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 why-is-node-running
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wide-align
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 window-size
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jul  7  2020 winston
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jul  7  2020 winston-daily-rotate-file
                  drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 winston-seq-updated
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 winston-syslog
                  drwxrwxr-x+   5 iobroker iobroker  4096 Jul  7  2020 winston-transport
                  drwxrwxr-x+   2 iobroker iobroker  4096 Mai 16  2020 word-wrap
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 wordwrap
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wrap-ansi
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wrappy
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ws
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wtf-8
                  drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 xml2js
                  drwxrwxr-x+   2 iobroker iobroker  4096 Jul 12  2020 xml2json-light
                  drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 xmlbuilder
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 xmldom
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 xmlhttprequest
                  drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 xmlhttprequest-ssl
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 xregexp
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 xtend
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 y18n
                  drwxrwxr-x+   3 iobroker iobroker  4096 Mai 27  2020 yaeti
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 yallist
                  drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 yargs
                  drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 yargs-parser
                  drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 yeast
                  drwxrwxr-x+   6 iobroker iobroker  4096 Feb 26 22:19 zigbee-herdsman
                  drwxrwxr-x+   5 iobroker iobroker  4096 Feb 26 22:19 zigbee-herdsman-converters
                  drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 zlib
                    Prince3k @wendy2702 last edited by
                    @wendy2702
                    pi@raspberrypi4-iob:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/
                    insgesamt 6720
                    drwxrwxrwx+ 10 iobroker iobroker    4096 Mär  2 18:55 .
                    drwxrwxrwx+  9 iobroker iobroker    4096 Mär  2 13:52 ..
                    drwxrwxrwx+  2 iobroker iobroker    4096 Mär  2 17:56 backup-objects
                    drwxrwxrwx+ 68 iobroker iobroker    4096 Feb 22 21:49 files
                    drwxrwxr-x+  2 iobroker iobroker    4096 Feb 22 21:51 history
                    -rwxrwxrwx+  1 iobroker iobroker    3931 Okt 23  2019 iobroker.json
                    drwxrwxr-x+  2 iobroker iobroker    4096 Mai 27  2020 lgtv_0
                    -rw-rwxr--+  1 iobroker iobroker     110 Mär  2 13:38 notifications.json
                    -rw-rw-r--+  1 iobroker iobroker 2020884 Mär  2 18:51 objects.json
                    -rw-rw-r--+  1 iobroker iobroker 2019897 Mär  2 18:51 objects.json.bak
                    drwxrwxr-x+  2 iobroker iobroker    4096 Jan  8 18:30 sayit
                    -rw-rw-r--+  1 iobroker iobroker 1391842 Mär  2 18:55 states.json
                    -rw-rw-r--+  1 iobroker iobroker 1391846 Mär  2 18:54 states.json.bak
                    drwxrwxr-x+  4 iobroker iobroker    4096 Okt 23  2019 tuya_0
                    drwxrwxrwx+  2 iobroker iobroker    4096 Feb 28 23:20 zigbee_0
                    drwxrwxr-x+  2 iobroker iobroker    4096 Feb 26 22:27 zigbee_1
                    • wendy2702
                      wendy2702 @Prince3k last edited by
                      @prince3k
                      Kannst du mal ein
                      iobroker upload all
                      probieren was dann kommt?
                        @wendy2702
                        Gerne, biete mich auch als Versuchskannichnen an 🙂
                        Vielen vielen Dank schon einmal vorab für die Hilfe und Unterstützung.
                        pi@raspberrypi4-iob:/opt/iobroker $ iobroker upload all
                        upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                        upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                        upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                        upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                        upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                        upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                        upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                        upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                        upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                        upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                        upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                        upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                        upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                        upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                        upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                        upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                        upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                        upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                        upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                        upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                        upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                        upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                        upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                        upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                        upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                        upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                        upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                        Totalausfall wendy2702 2 Replies Last reply Reply Quote 0
                        • Totalausfall
                          Totalausfall @Prince3k last edited by
                          @prince3k
                          Ich hatte vorhin genau das gleiche Problem. Von jetzt auf gleich ging gar nichts mehr.
                          Hab IoBroker aus Verzweifelung dann gelöscht, neu installiert und das Backup über den Adapter eingespielt.
                          Allerdings ist da immer noch was im argen. Bspw. werden mir unter "Adapter" nur meine installierten Adapter angezeigt, weiter nichts.
                          Hab von Linux, bzw. was Programmierung angeht, absolut keinen Plan, also werd ich leider nicht hilfreich sein^^ Finds nur interessant, dass wir beide ungefähr zu gleichen Zeit das selbe Problem bekommen haben 😕
                            Homoran Global Moderator Administrators @Totalausfall last edited by
                            @danny-killig sagte in IoBroker down - Cannot read system:
                            dann hast du (oder dein provider) wahrscheinlich ein Netzwerkproblem.
                            nochmal den reload button anklicken und sehen was im log steht
                            Totalausfall 1 Reply Last reply Reply Quote 0
                            • Totalausfall
                              Totalausfall @Homoran last edited by
                              okay, hat jetzt funktioniert. Danke!
                              Hab schon mehrfach aktualisiert und neu gestartet aber bislang hat sich nichts getan. Kurios manchmal...
                              • wendy2702
                                @prince3k sagte in IoBroker down - Cannot read system:
                                Kannst du mal schauen ob du unter
                                ls -la iobroker-data/backup-objects/
                                was liegen hast?
                                  @wendy2702
                                  ich hatte nun das backup wieder eingespielt und gleich zu Beginn kam folgendes:
                                  [DEBUG] [iobroker] Start ioBroker Restore ...
                                  [DEBUG] [iobroker] iobroker controller daemon is not running
                                  [DEBUG] [iobroker] host.raspberrypi4-iob OK.
                                  [DEBUG] [iobroker] host.raspberrypi4-iob Clear all objects and states...
                                  [DEBUG] [iobroker] clean 545 objects...
                                  [DEBUG] [iobroker] Server Objects 127.0.0.1:37894 Error from InMemDB: Error: Object is marked as non deletable
                                  [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
                                  [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
                                  [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
                                  [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
                                  [ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
                                  [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
                                  Danach lief alles durch.
                                  ls -la iobroker-data/backup-objects/ spuckt folgendes aus:
                                  pi@raspberrypi4-iob:/opt/iobroker $ ls -la iobroker-data/backup-objects/
                                  insgesamt 38640
                                  drwxrwxrwx+  2 iobroker iobroker    4096 Mär  2 19:32 .
                                  drwxrwxrwx+ 10 iobroker iobroker    4096 Mär  2 19:54 ..
                                  -rw-rwxr--+  1 iobroker iobroker 1802812 Feb 27 16:32 2021-02-27_16-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1802810 Feb 27 18:32 2021-02-27_18-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1802809 Feb 27 20:32 2021-02-27_20-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803544 Feb 27 22:32 2021-02-27_22-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803557 Feb 28 00:32 2021-02-28_00-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803561 Feb 28 02:32 2021-02-28_02-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343303 Feb 28 02:45 2021-02-28_02-45_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803550 Feb 28 04:32 2021-02-28_04-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343258 Feb 28 04:45 2021-02-28_04-45_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803601 Feb 28 06:32 2021-02-28_06-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343413 Feb 28 06:46 2021-02-28_06-46_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803559 Feb 28 08:32 2021-02-28_08-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343086 Feb 28 08:46 2021-02-28_08-46_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803524 Feb 28 10:32 2021-02-28_10-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343412 Feb 28 10:47 2021-02-28_10-47_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803506 Feb 28 12:32 2021-02-28_12-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343333 Feb 28 12:47 2021-02-28_12-47_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803505 Feb 28 14:32 2021-02-28_14-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343362 Feb 28 14:47 2021-02-28_14-47_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803495 Feb 28 16:32 2021-02-28_16-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343043 Feb 28 16:48 2021-02-28_16-48_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803541 Feb 28 18:32 2021-02-28_18-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343621 Feb 28 18:48 2021-02-28_18-48_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1803534 Feb 28 20:32 2021-02-28_20-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343259 Feb 28 20:49 2021-02-28_20-49_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker 1804845 Feb 28 22:32 2021-02-28_22-32_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343315 Feb 28 22:49 2021-02-28_22-49_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker    3515 Feb 28 23:55 2021-02-28_23-55_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343377 Mär  1 21:58 2021-03-01_21-58_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker    3518 Mär  1 22:14 2021-03-01_22-14_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  343412 Mär  1 22:18 2021-03-01_22-18_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker    3518 Mär  1 22:21 2021-03-01_22-21_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  342361 Mär  1 22:22 2021-03-01_22-22_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker  342358 Mär  1 23:11 2021-03-01_23-11_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker  342358 Mär  2 13:06 2021-03-02_13-06_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker   11306 Mär  2 13:18 2021-03-02_13-18_objects.j                       son.gz
                                  -rw-rwxr--+  1 iobroker iobroker  342362 Mär  2 13:18 2021-03-02_13-18_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker  342347 Mär  2 13:40 2021-03-02_13-40_states.js                       on.gz
                                  -rw-rwxr--+  1 iobroker iobroker  342347 Mär  2 13:46 2021-03-02_13-46_states.js                       on.gz
                                  -rw-rw-r--+  1 iobroker iobroker   11307 Mär  2 13:55 2021-03-02_13-55_objects.j                       son.gz
                                  -rw-rw-r--+  1 iobroker iobroker  342342 Mär  2 13:56 2021-03-02_13-56_states.js                       on.gz
                                  -rw-rw-r--+  1 iobroker iobroker  342363 Mär  2 15:56 2021-03-02_15-56_states.js                       on.gz
                                  -rw-rw-r--+  1 iobroker iobroker   14327 Mär  2 17:47 2021-03-02_17-47_objects.j                       son.gz
                                  -rw-rw-r--+  1 iobroker iobroker  342375 Mär  2 17:56 2021-03-02_17-56_states.js                       on.gz
                                  -rw-rw-r--+  1 iobroker iobroker  612535 Mär  2 19:26 2021-03-02_19-26_objects.j                       son.gz
                                  -rw-rw-r--+  1 iobroker iobroker  344607 Mär  2 19:27 2021-03-02_19-27_states.js                       on.gz
                                  -rw-rw-r--+  1 iobroker iobroker 1725614 Mär  2 19:32 2021-03-02_19-32_objects.j                       son.gz
                                  -rw-rw-r--+  1 iobroker iobroker  343410 Mär  2 19:32 2021-03-02_19-32_states.js                       on.gz
                                  • wendy2702
                                    @prince3k Schon ewig kein restore mehr benötigt (klopfe auf Holz), keine Ahnung ob das beim restore normale Errors sind weil er ja von der leeren ioBroker installation auf dein Backup umbaut.
                                    Wenn du nochmal ein Problem wie heute bekommst kann man versuchen aus dem Backup in diesem Ordner das System wieder herzustellen.
                                      @wendy2702 ich sehe aber nach dem restore immer jedoch nur die 3 instanzen : admin, backitup und info, was mache ich falsch ?
                                      • wendy2702
                                        @prince3k wie machst du den restore?
                                        Backitup Adapter oder manuel?
                                          @wendy2702
                                          Ich habe es über den backitup Adapter gemacht.
                                          • wendy2702
                                            @prince3k Wie lange hast du nach dem ausführen des restore gewartet?
                                            Ja nach Systemleistung, Anzahl der zu installieren Adapter und Instanzen kann das schon etwas dauern.
                                            Am besten verfolgt man das im iobroker log und lässt das System in dieser Zeit in Ruhe.
                                            tail -f /opt/iobroker/log/iobroker.current.log
                                            Hast du das log nach dem restore? Sollte eigentlich im Ordner:
                                            /opt/iobroker/log/
                                            liegen. Da mal schauen ob Adapter installiert wurden.
                                            Was kommt denn nach dem restore der jetzt ja durch sein sollte bei:
                                            iobroker list instances
                                            iobroker list adapters
                                            P 2 Replies Last reply Reply Quote 0
                                            berechtigungen cannot read system iobroker startet nicht
                                            3180
