    4. Gelöst | IoBroker nach Stromausfall nicht mehr erreichbar
      Philipp.Schlegel @Thomas Braun last edited by
      Folgende Fehlermeldung liegt im log - kannst Du hier supporten?
      596 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
      597 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      598 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
      598 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
      598 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
      598 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
      599 verbose stack Error: Invalid tag name "node-mihome@0.0.32": Tags may not have any characters that encodeURIComponent encodes.
      599 verbose stack     at invalidTagName (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:91:15)
      599 verbose stack     at fromRegistry (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:296:13)
      599 verbose stack     at Function.resolve (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:81:12)
      599 verbose stack     at childDependencySpecifier (/usr/lib/node_modules/npm/lib/install/deps.js:105:14)
      599 verbose stack     at addDependency (/usr/lib/node_modules/npm/lib/install/deps.js:577:19)
      599 verbose stack     at /usr/lib/node_modules/npm/lib/install/deps.js:525:5
      599 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:35
      599 verbose stack     at Array.forEach (<anonymous>)
      599 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:11
      599 verbose stack     at asyncMap (/usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:51:8)
      599 verbose stack     at loadDeps (/usr/lib/node_modules/npm/lib/install/deps.js:523:3)
      599 verbose stack     at Array.<anonymous> (/usr/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
      599 verbose stack     at LOOP (/usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:15:14)
      599 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:18:7
      599 verbose stack     at /usr/lib/node_modules/npm/lib/install/and-finish-tracker.js:8:8
      600 verbose cwd /opt/iobroker
      601 verbose Linux 5.4.83-v7l+
      602 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller"
      603 verbose node v12.21.0
      604 verbose npm  v6.14.11
      605 error code EINVALIDTAGNAME
      606 error Invalid tag name "node-mihome@0.0.32": Tags may not have any characters that encodeURIComponent encodes.
      607 verbose exit [ 1, true ]
      Danke und Grüße,
      Phil
        Philipp.Schlegel @wendy2702 last edited by
        @wendy2702
        Ich schaue mal eben nach, es müssten auch vollständige vorliegen. Ich melde mich 🙂
        • wendy2702
          @philipp-schlegel
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            @wendy2702
            pi@RaspberryPi4IoBroker-Main:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.21.0
            /usr/bin/node
            v12.21.0
            /usr/bin/npm
            6.14.11
            nodejs:
              Installiert:           12.21.0-1nodesource1
              Installationskandidat: 12.21.0-1nodesource1
              Versionstabelle:
             *** 12.21.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
                    500 https://archive.raspbian.org/raspbian buster/main armhf Packages
            • wendy2702
              @philipp-schlegel sagte in IoBroker nach Stromausfall nicht mehr erreichbar:
              node-mihome@0.0.32
              an welcher Stelle bzw. bei welcher Aktion kommt dieser Eintrag eigentlich ?
                @wendy2702
                Kommt bei einem Versuch, den JS-Controller zu reparieren:
                pi@RaspberryPi4IoBroker-Main:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                npm ERR! code EINVALIDTAGNAME
                npm ERR! Invalid tag name "node-mihome@0.0.32": Tags may not have any characters that encodeURIComponent encodes.
                npm ERR!     /home/iobroker/.npm/_logs/2021-03-02T12_22_23_964Z-debug.log
                • wendy2702
                  wendy2702 @Philipp.Schlegel last edited by
                  @philipp-schlegel was kommt den aktuell bei:
                  iobroker list instances
                  iobroker list adapters
                  iobroker status
                    @wendy2702 said in IoBroker nach Stromausfall nicht mehr erreichbar:
                    iobroker status
                    pi@RaspberryPi4IoBroker-Main:~ $ iobroker list instances
                     Cannot read system.config: null (OK when migrating or restoring)
                     Cannot find view "system" for search "host"
                    + instance is alive
                    pi@RaspberryPi4IoBroker-Main:~ $ iobroker list adapters
                    pi@RaspberryPi4IoBroker-Main:~ $ iobroker status
                    Objects type: file
                    States  type: file
                    • wendy2702
                      @philipp-schlegel
                      ls -la /opt/iobroker/iobroker-data/backup-objects/
                        Philipp.Schlegel @wendy2702 last edited by Philipp.Schlegel
                        Hilft Dir das?
                        pi@RaspberryPi4IoBroker-Main:~ $ ls -la /opt/iobroker/iobroker-data/backup-objects/
                        insgesamt 62744
                        drwxrwxr-x+ 2 iobroker iobroker    4096 Mär  2 21:44 .
                        drwxrwxr-x+ 8 iobroker iobroker    4096 Mär  2 22:45 ..
                        -rw-rwxr--+ 1 iobroker iobroker 2312594 Feb 28 12:03 2021-02-28_12-03_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2312555 Feb 28 14:03 2021-02-28_14-03_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318292 Feb 28 16:05 2021-02-28_16-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318408 Feb 28 18:05 2021-02-28_18-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318419 Feb 28 20:05 2021-02-28_20-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318368 Feb 28 22:05 2021-02-28_22-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400470 Feb 28 22:06 2021-02-28_22-06_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318505 Mär  1 00:05 2021-03-01_00-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400565 Mär  1 00:06 2021-03-01_00-06_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318918 Mär  1 02:05 2021-03-01_02-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400953 Mär  1 02:06 2021-03-01_02-06_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318238 Mär  1 04:05 2021-03-01_04-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  399355 Mär  1 04:07 2021-03-01_04-07_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318437 Mär  1 06:05 2021-03-01_06-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400267 Mär  1 06:07 2021-03-01_06-07_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318401 Mär  1 08:05 2021-03-01_08-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  399946 Mär  1 08:07 2021-03-01_08-07_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318364 Mär  1 10:05 2021-03-01_10-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  399653 Mär  1 10:08 2021-03-01_10-08_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318453 Mär  1 12:05 2021-03-01_12-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400137 Mär  1 12:08 2021-03-01_12-08_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318409 Mär  1 14:05 2021-03-01_14-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400420 Mär  1 14:09 2021-03-01_14-09_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318515 Mär  1 16:05 2021-03-01_16-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  401019 Mär  1 16:09 2021-03-01_16-09_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318616 Mär  1 18:05 2021-03-01_18-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400790 Mär  1 18:10 2021-03-01_18-10_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318767 Mär  1 20:05 2021-03-01_20-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  400990 Mär  1 20:10 2021-03-01_20-10_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318744 Mär  1 22:05 2021-03-01_22-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  401115 Mär  1 22:10 2021-03-01_22-10_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318801 Mär  2 00:05 2021-03-02_00-05_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  401185 Mär  2 00:11 2021-03-02_00-11_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2319118 Mär  2 02:06 2021-03-02_02-06_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  399835 Mär  2 02:11 2021-03-02_02-11_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318809 Mär  2 04:06 2021-03-02_04-06_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  398474 Mär  2 04:12 2021-03-02_04-12_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2318420 Mär  2 05:17 2021-03-02_05-17_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  391567 Mär  2 05:17 2021-03-02_05-17_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  399323 Mär  2 05:18 2021-03-02_05-18_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  391678 Mär  2 07:18 2021-03-02_07-18_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  391690 Mär  2 09:18 2021-03-02_09-18_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker    4227 Mär  2 09:35 2021-03-02_09-35_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  391630 Mär  2 09:57 2021-03-02_09-57_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker    4231 Mär  2 10:18 2021-03-02_10-18_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  389968 Mär  2 10:19 2021-03-02_10-19_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker    4228 Mär  2 10:21 2021-03-02_10-21_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  389969 Mär  2 10:21 2021-03-02_10-21_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker    4230 Mär  2 10:28 2021-03-02_10-28_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  390027 Mär  2 10:29 2021-03-02_10-29_states.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker    4229 Mär  2 11:07 2021-03-02_11-07_objects.json.gz
                        -rw-rwxr--+ 1 iobroker iobroker  389997 Mär  2 11:08 2021-03-02_11-08_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker    4220 Mär  2 11:18 2021-03-02_11-18_objects.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  389992 Mär  2 11:18 2021-03-02_11-18_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  389976 Mär  2 11:33 2021-03-02_11-33_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker    4219 Mär  2 11:43 2021-03-02_11-43_objects.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  390016 Mär  2 11:43 2021-03-02_11-43_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  390067 Mär  2 13:44 2021-03-02_13-44_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  390040 Mär  2 15:44 2021-03-02_15-44_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  390046 Mär  2 17:44 2021-03-02_17-44_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  390068 Mär  2 19:44 2021-03-02_19-44_states.json.gz
                        -rw-rw-r--+ 1 iobroker iobroker  390034 Mär  2 21:44 2021-03-02_21-44_states.json.gz
                        • wendy2702
                          @philipp-schlegel
                          Kannst versuchen iobroker zu stoppen. Das File mit Object und States aus diesem Ordner mit dem dir als zuletzt funktionierendem Zeitstempel nach hier zu entpacken:
                          dann iobroker start.
                            @wendy2702
                            Danke für Deinen Support. Leider bin ich noch nicht ganz so firm im Bugfixing: Wie kann ich eine Datei/ein Archiv dorthin entpacken?
                            • wendy2702
                              @philipp-schlegel
                              Also nur nochmal zur Sicherheit:
                              Du hast kein Full BAckup ?
                              Aktuell läuft dein System nicht?
                              Wenn du beides mit Nein beantworten kannst überprüfe ob iobroker läuft:
                              iobroker status
                              sollte es laufen beende es mit
                              iobroker stop
                              nochmal prüfen ob es wirklich nicht mehr läuft.
                              Dann
                              cd /opt/iobroker/iobroker-data/
                              mv objects.json objects.json.old
                              mv states.json states.json.old
                              cd backup-objects/
                              gunzip -c "Hier der Dateiname eines Backups der objects.json" > /opt/iobroker/iobroker-data/objects.json
                              gunzip -c "Hier der Dateiname eines Backups der states.json" > /opt/iobroker/iobroker-data/states.json
                              Dann mit
                              schauen ob im Ordner wieder zwei files mit diesen Namen liegen:
                              objects.json
                              states.json
                              zusätzlich solltest du auch zwei Files haben die genauso heißen aber am Ende ".old" stehen haben.
                              Wenn das funktioniert ein weiteres Terminalfenster aufmachen und in diesem das log beobachten:
                              tail -f /opt/iobroker/log/iobroker.current.log
                              im ersten Fenster
                              iobroker start
                              Ich hoffe das funktioniert.
                              P R. Frase 2 Replies Last reply Reply Quote 2
                                @wendy2702
                                Mega - genau das ist es. TAUSEND Dank!! Wahnsinnig gute Hilfe. Hat 1a genau so funktioniert, wie von Dir beschrieben! 🙂
                                • wendy2702
                                  @philipp-schlegel
                                  Das freut mich. Jetzt Backitup einrichten und das Thema bitte auf gelöst setzen.
                                    @wendy2702
                                    Na klar, Done. Danke! 🙂
                                    • R. Frase
                                      R. Frase @wendy2702 last edited by
                                      @wendy2702
                                      Du hast mir heute viele Stunden Arbeit erspart - vielen lieben Dank! Es funktioniert auch heute noch!!! 😀
                                        Homoran Global Moderator Administrators @R. Frase last edited by
                                        @r-frase sagte in Gelöst | IoBroker nach Stromausfall nicht mehr erreichbar:
                                        @wendy2702
                                        deswegen hat es sogar einen eigenen Thread bekommen:
                                        https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1634803511846
                                        R. Frase 1 Reply Last reply Reply Quote 1
                                        • R. Frase
                                          R. Frase @Homoran last edited by
                                          oha, danke - aber das hat Google nicht gleich gefunden 🤷‍♂️
                                          Aber ich hab mir den Link jetzt gespeichert. Sicher ist sicher...
                                          iobroker nicht erreichbar iobroker.admin stromausfall
                                          6998
