    4. ZigBee neue Version 1.4.4
      crunchip Forum Testing Most Active @Asgothian last edited by crunchip
      @asgothian
      0x00158d0002fd50
      oder muss ich das "0x"weglassen?
      Edit: ohne "0x" funktioniert es
      zigbee.0	2021-03-02 19:01:22.821	warn	(7934) ELEVATED publishToState: value generated 'true' from device 00158d0002fd50c5 for 'Time from last motion'
      zigbee.0	2021-03-02 19:01:22.821	warn	(7934) ELEVATED publishToState: value generated 'true' from device 00158d0002fd50c5 for 'Occupancy'
      zigbee.0	2021-03-02 19:01:22.820	warn	(7934) ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0002fd50c5 type 'RTCGQ11LM'
      zigbee.0	2021-03-02 19:01:22.811	warn	(7934) ELEVATED publishToState: value generated '49' from device 00158d0002fd50c5 for 'Link quality'
      zigbee.0	2021-03-02 19:01:22.811	warn	(7934) ELEVATED publishToState: message received '{"linkquality":49}' from device 00158d0002fd50c5 type 'RTCGQ11LM'
      zigbee.0	2021-03-02 19:01:22.803	warn	(7934) ELEVATED publishToState: value generated '79' from device 00158d0002fd50c5 for 'Illuminance'
      zigbee.0	2021-03-02 19:01:22.802	warn	(7934) ELEVATED publishToState: value generated 'true' from device 00158d0002fd50c5 for 'Time from last motion'
      zigbee.0	2021-03-02 19:01:22.801	warn	(7934) ELEVATED publishToState: value generated 'true' from device 00158d0002fd50c5 for 'Occupancy'
      zigbee.0	2021-03-02 19:01:22.800	warn	(7934) ELEVATED publishToState: message received '{"occupancy":true,"illuminance":79,"illuminance_lux":79}' from device 00158d0002fd50c5 type 'RTCGQ11LM'
      zigbee.0	2021-03-02 19:01:22.796	warn	(7934) ELEVATED publishToState: value generated '47' from device 00158d0002fd50c5 for 'Link quality'
      zigbee.0	2021-03-02 19:01:22.795	warn	(7934) ELEVATED publishToState: message received '{"linkquality":47}' from device 00158d0002fd50c5 type 'RTCGQ11LM'
        @asgothian sagte in ZigBee neue Version 1.4.4:
        Nachtrag: Wenn dieses Verhalten für die Rules zu einem Problem wird kann darüber nachgedacht werden eine Entstellung im Zigbee-Adapter vorzusehen, bei der States nur dann aktualisiert werden wenn die letzte Aktualisierung mehr als x ms zurück liegt oder der Wert sich geändert hat.
        Problem ist nicht speziell bei Rules, habe soeben auch mal mit nem Blockly getestet, da erfolgt ebenfalls die Ausgabe doppelt.
        letzteres "oder der Wert sich geändert hat." ist ja eher contraproduktiv
          Hatte heute einen seltsamen Effekt: Beim Betrachten der Vernetzungskarte binkte ein Synfonisk rotary encoder ständig Dauerfeuer. Wie ein bubbling idiot.
          Auch die Objekte wurden ständig aktualisiert.
          Drehen am encode hat nichts geändert.
          Nach Neustart des Adapters war Ruhe.
          Im log habe ich nichts Verdächtiges gefunden.
          • Asgothian
            Asgothian Developer @crunchip last edited by
            @crunchip sagte in ZigBee neue Version 1.4.4:
            Nein, das ist notwendig. Es gibt durchaus zigbee Geräte die auf einem State mehrere Unterschiedliche Informationen ablegen, so das wenn überhaupt nur "gleiche" Meldungen nicht wiederholt werden sollten.
            A.
            Und ja, das 0x musste weg 🙂
            A.
            • david83
              david83 last edited by
              Hallo zusammen, ich hätte da vielleicht für den einen oder anderen eine merkwürdige Anfrage, ist es möglich die Farben der offline Geräte oder der Online Geräte auf der Netzwerkkarte zu ändern?
              Hintergrund ist dabei das ich Farbenblind bin vor allem bei Grün und Rot. Ich sehe somit keine Unterschiede zwischen den Geräten die verfügbar und Geräte die nicht verfügbar sind.
              Mfg
              David
              • Asgothian
                Asgothian Developer @david83 last edited by
                @david83 Machst du damit bitte einen Issue auf Github auf ?
                https://github.com/ioBroker/ioBroker.zigbee/issues
                david83 1 Reply Last reply Reply Quote 0
                • nama*rian
                  nama*rian last edited by
                  Hallo!
                  ist es möglich folgenden Bewegungsmelder aufzunehmen:
                  mein Koordinator:
                  Zigbee Version: 1.4.5
                  Herstellerlink:
                  https://climax-deutschland.com/product/ir-9zbs/
                  Besten Dank im voraus.
                  • david83
                    david83 @Asgothian last edited by
                    @asgothian
                    Wird gemacht 😉
                      arteck Developer Most Active @nama*rian last edited by arteck
                      @nama-rian selektiere den bitte unter "Ausschliessen" Tab.. dann adapter neu starten
                      nama*rian 1 Reply Last reply Reply Quote 0
                      • nama*rian
                        nama*rian @arteck last edited by
                        @arteck
                        Danke für die Unterstützung!
                          klassisch Most Active @klassisch last edited by
                          @klassisch sagte in ZigBee neue Version 1.4.4:
                          Heute Nacht wieder, aber diesmal pwer History aufgezeichnet.
                          Etwa zwischen 20:00 und 04:00 freie Oszillation. Nach Adapter Restart war Ruhe. Dennoch war das Netz noch nicht in Ordnung. Der Opple Schalter neben dem rotary encoder für dieses Panel funktionierte nicht mehr.
                          Das zugehörige Panel auch nur sporadisch erreichbar.
                          Nach Neuinstallation Adapter war wieder alles in Ordnung.
                          Wollte probeweise die Version 1.3 installieren. Aber die scheint es nicht mehr zu geben?
                          Das zu diesem encoder gehörige history file hat für gestern 18 MByte
                          Hier mal ein kleiner Auszug aus dem History file:
                              "val": true,
                              "ack": 1,
                              "ts": 1614806839486,
                              "q": 0,
                              "from": "system.adapter.zigbee.0",
                              "user": "system.user.admin"
                              "val": false,
                              "ack": 1,
                              "ts": 1614806839581,
                              "q": 0,
                              "val": true,
                              "ack": 1,
                              "ts": 1614806839690,
                              "q": 0,
                              "val": false,
                              "ack": 1,
                              "ts": 1614806839795,
                              "q": 0,
                              "val": true,
                              "ack": 1,
                              "ts": 1614806839894,
                              "q": 0,
                          Oszillator mit Periode von ca. 0.2 Sekunden.
                          In diesem Zeibereich keine Warnmeldungen oder Fehlermeldungen des zigbee Adapters im log.
                          • Asgothian
                            Asgothian Developer @klassisch last edited by
                            Bitte versuch das folgende:
                            • Installiere die 1.4.5 von Github
                            • Trage die IEEE des Controllers (Ohne "0x") in den neu vorhandenen State "zigbee.0.info.debugmessages" ein
                            • lass es laufen.
                            Wenn der Controller wieder dieses Verhalten zeigt prüf das Log auf "warn" Meldungen mit dem Schlüsselwort "ELEVATED"
                            Ich gehe im Moment davon aus das
                            • der Controller eine Macke hat die das Verhalten auslöst
                            • beim Start des Adapters der Controller eine "configure" Meldung bekommt die dieses Verhalten zunächst einmal beendet.
                            A.
                              klassisch Most Active @Asgothian last edited by
                              gemacht
                              das ist die Nummer, die bei mousover über den Controller bei der Kartenansicht erscheint?
                              • lass es laufen.
                              gemacht. Ohne Adapter-Neustart?
                              VielenDank!
                              • Asgothian
                                @klassisch Ohne Neustart ist gut. Bitte bei der ieee Addresse kein 0x mit angeben.
                                A.
                                  @asgothian Danke, 0x ist nicht davor, aber führende Nullen. Format:
                                  00124B0008c12345
                                  • Asgothian
                                    @klassisch Das ist ok
                                    Wenn du den Controller jetzt drehst sollten schon Meldungen im Log auftauchen.
                                    A.
                                      klassisch Most Active @Asgothian last edited by klassisch
                                      @asgothian Danke, stopp, gut daß wir drüber gesprochen haben. Als ich Controller las, dachte ich an den Coordinator, habe das Drehgestell aus dem Datenpunkt rausgenommen und dann diese Nummer des Coordinators reingenommen.
                                      Also ich trage jetzt die Nummer des ikea symfonisk Drehreglers rotary encoders ein. Die ist schnell gefunden und steht ja in der Objektliste.
                                      Neue Energizer Batterie hatte ich gestern schon reingemacht. 3.13V sollte noch iO sein.
                                      Und ja, beim Drehen kommen ELEVATED log-Einträge. Sieht in meinem laienhaften Auge ziemlich plausibel aus.
                                      • Jan Fiedler
                                        Jan Fiedler last edited by
                                        Moin zusammen,
                                        ich habe heute mit der beschriebenen Methode sowohl den JS-Controller als auch alle Adapter auf die aktuellste Version aktualisiert. Danach ging erstmal der Zigbee Adapter nicht mehr (v1.4.4). Mit einem Fehler bzgl Serialport. Ich habe dann Serialport mit npm aktualisiert; danach kommt jetzt folgender Fehler beim Start des Adapters - jetzt bin ich überfragt.
                                        Ein npm rebuild hat auch nichts gebracht...
                                        host.raspberrypi	2021-03-04 22:00:47.143	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.raspberrypi	2021-03-04 22:00:47.142	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
                                        host.raspberrypi	2021-03-04 22:00:47.142	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                        host.raspberrypi	2021-03-04 22:00:47.142	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                        host.raspberrypi	2021-03-04 22:00:47.142	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                        host.raspberrypi	2021-03-04 22:00:47.141	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                        host.raspberrypi	2021-03-04 22:00:47.141	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                        host.raspberrypi	2021-03-04 22:00:47.141	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                        host.raspberrypi	2021-03-04 22:00:47.140	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                        host.raspberrypi	2021-03-04 22:00:47.140	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                        host.raspberrypi	2021-03-04 22:00:47.140	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
                                        host.raspberrypi	2021-03-04 22:00:47.140	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v64-linux-arm/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.139	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.139	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.139	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.139	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/10.22.0/linux/arm/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.138	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.138	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.138	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.138	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.137	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.137	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.137	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.137	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
                                        host.raspberrypi	2021-03-04 22:00:47.136	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                        host.raspberrypi	2021-03-04 22:00:47.136	error	Caught by controller[0]: ^
                                        host.raspberrypi	2021-03-04 22:00:47.136	error	Caught by controller[0]: throw err;
                                        host.raspberrypi	2021-03-04 22:00:47.135	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
                                        • Asgothian
                                          Asgothian Developer @Jan Fiedler last edited by
                                          @jan-fiedler Bitte den Adapter noch einmal installieren, und zwar vom Admin aus, nicht aus der Konsole.
                                          A.
                                          Jan Fiedler 1 Reply Last reply Reply Quote 0
                                          • Jan Fiedler
                                            Jan Fiedler @Asgothian last edited by
                                            @asgothian Hat leider nicht geholfen...
                                            host.raspberrypi	2021-03-04 22:54:25.246	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            host.raspberrypi	2021-03-04 22:54:25.246	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
                                            host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                            host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                            host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                            host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                            host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                            host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                            host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                            host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                            host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
                                            host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v64-linux-arm/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/10.22.0/linux/arm/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
                                            host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                            host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: ^
                                            host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: throw err;
                                            host.raspberrypi	2021-03-04 22:54:25.239	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
                                            host.raspberrypi	2021-03-04 22:54:23.987	info	instance system.adapter.zigbee.0 started with pid 8841
                                            neue version zigbee zigbee neue version 1.4.0
                                            35
                                            302
                                            48317
