    4. Web Server Update geht nicht
      jack99n last edited by
      Kann mir jemand Helfen ich bekomme den Web Server nicht von 3.1.0 auf 3.2.3
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli   '/usr/bin/node',
      1 verbose cli   '/usr/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'iobroker.web@3.2.3',
      1 verbose cli   '--loglevel',
      1 verbose cli   'error',
      1 verbose cli   '--prefix',
      1 verbose cli   '/opt/iobroker'
      1 verbose cli ]
      2 info using npm@6.14.11
      3 info using node@v12.20.2
      4 verbose npm-session fd199d5b4a448cd9
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 warn registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EAI_AGAIN: request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
      8 warn registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
      9 http fetch GET 200 https://registry.npmjs.org/iobroker.web 138ms (from cache)
      10 silly fetchPackageMetaData error for iobroker.web@3.2.3 Unexpected end of JSON input while parsing near '...ckZbUcUg/BfCqLJSKMHNx'
      11 timing stage:rollbackFailedOptional Completed in 2ms
      12 timing stage:runTopLevelLifecycles Completed in 12135ms
      13 verbose stack SyntaxError: Unexpected end of JSON input while parsing near '...ckZbUcUg/BfCqLJSKMHNx'
      13 verbose stack     at JSON.parse (<anonymous>)
      13 verbose stack     at parseJson (/usr/lib/node_modules/npm/node_modules/json-parse-better-errors/index.js:7:17)
      13 verbose stack     at /usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/body.js:96:50
      13 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:97:5)
      14 verbose cwd /opt/iobroker
      15 verbose Linux 5.4.34-1-pve
      16 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.web@3.2.3" "--loglevel" "error" "--prefix" "/opt/iobroker"
      17 verbose node v12.20.2
      18 verbose npm  v6.14.11
      19 error Unexpected end of JSON input while parsing near '...ckZbUcUg/BfCqLJSKMHNx'
      20 verbose exit [ 1, true ]
        Thomas Braun Most Active @jack99n last edited by Thomas Braun
        @jack99n
        Wie genau gehst du vor?
        iobroker update
        iobroker upgrade
        in der Kommandozeile mal probiert?
        Zuvor
        cd /opt/iobroker
        npm cache clean --force
        kann auch helfen.
          jack99n @Thomas Braun last edited by
          @thomas-braun Danke für deine Hilfe. Leider hat das auch nichts gebracht, und vorher habe ich es immer direkt in IoBroker versucht.
          root@iobroker-lxc:/opt/iobroker# npm cache clean --force
          npm WARN using --force I sure hope you know what you are doing.
          root@iobroker-lxc:/opt/iobroker# iobroker update
          Used repository: Stable (default)
          Cannot download json from http://download.iobroker.net/sources-dist-hash.json. Error: Error: getaddrinfo EAI_AGAIN download.iobroker.net
          failed to download new sources, use cached sources
          update done
          1 verbose cli [
          1 verbose cli ]
          4 verbose npm-session 6bf6bd6c8f590318
          7 silly fetchPackageMetaData error for iobroker.web@3.2.3 request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
          8 timing stage:rollbackFailedOptional Completed in 2ms
          9 timing stage:runTopLevelLifecycles Completed in 11757ms
          10 verbose type system
          11 verbose stack FetchError: request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
          11 verbose stack     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)
          11 verbose stack     at ClientRequest.emit (events.js:314:20)
          11 verbose stack     at TLSSocket.socketErrorListener (_http_client.js:427:9)
          11 verbose stack     at TLSSocket.emit (events.js:314:20)
          11 verbose stack     at emitErrorNT (internal/streams/destroy.js:92:8)
          11 verbose stack     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
          11 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)
          12 verbose cwd /opt/iobroker
          13 verbose Linux 5.4.34-1-pve
          14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.web@3.2.3" "--loglevel" "error" "--prefix" "/opt/iobroker"
          15 verbose node v12.20.2
          16 verbose npm  v6.14.11
          17 error code EAI_AGAIN
          18 error errno EAI_AGAIN
          19 error request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
            @jack99n Dein Netzwerk ist 'kaputt', jedenfalls sind die externen Server für das Update nicht erreichbar.
              @thomas-braun Okay dann werde ich mich darum kümmern.
                A Former User last edited by
                Soll das so? Anzeigefehler?
                Aktualisieren oder lieber warten?
                  @paul-ol
                  Hat mit dem Thema hier nichts zu tun.
                  Bitte eigenes Thema eröffnen und dort auch die Versionsnummer vom js-contoller reinpacken.
