    4. ZigBee neue Version 1.4.4
    • Jan Fiedler
      Jan Fiedler @Asgothian last edited by
      @asgothian Hat leider nicht geholfen...
      host.raspberrypi	2021-03-04 22:54:25.246	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2021-03-04 22:54:25.246	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
      host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.raspberrypi	2021-03-04 22:54:25.245	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
      host.raspberrypi	2021-03-04 22:54:25.244	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
      host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v64-linux-arm/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.243	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/10.22.0/linux/arm/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.242	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
      host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: ^
      host.raspberrypi	2021-03-04 22:54:25.240	error	Caught by controller[0]: throw err;
      host.raspberrypi	2021-03-04 22:54:25.239	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
      host.raspberrypi	2021-03-04 22:54:23.987	info	instance system.adapter.zigbee.0 started with pid 8841
      Jan Fiedler 1 Reply Last reply Reply Quote 0
      • Jan Fiedler
        Jan Fiedler @Jan Fiedler last edited by
        @jan-fiedler Was mir noch aufgefallen ist... Das sollte so nicht sein oder?
        pi@raspberrypi:~ $ npm list serialport
        /home/pi
        └── (empty)
        Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Jan Fiedler last edited by
          @jan-fiedler Doch, das soll so sein in deinem home.
          Stell dich nach /opt/iobroker
          • Asgothian
            Asgothian Developer @Jan Fiedler last edited by
            @jan-fiedler Doch.. der Befehl muss im Verzeichnis /opt/iobroker angegeben werden
            A.
            • Jan Fiedler
              @asgothian
              pi@raspberrypi:/opt/iobroker $ npm list serialport
              iobroker.inst@2.0.3 /opt/iobroker
              ├─┬ iobroker.discovery@2.5.0
              │ └── serialport@9.0.7  deduped
                @jan-fiedler
                Schaut bei mir anders aus:
                └─┬ iobroker.zigbee@1.4.4
                  ├─┬ zigbee-herdsman@0.13.70
                  │ └── serialport@9.0.6
                  └─┬ zigbee-herdsman-converters@14.0.57
                    └─┬ zigbee-herdsman@0.13.68
                • Jan Fiedler
                  Jan Fiedler @Thomas Braun last edited by Jan Fiedler
                  @thomas-braun Ich hab jetzt nochmal ein npm rebuild in den /opt/iobroker Verzeichnis durchgeführt. Allerdings hat das nur zu einem Haufen folgender Fehler geführt. Hab ich vllt eine inkompatible node Version?
                  warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! node-aead-crypto@2.2.0 preinstall: `node lib/preinstall.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the node-aead-crypto@2.2.0 preinstall script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  2021-03-04T22_11_47_952Z-debug.log
                    @jan-fiedler Wie schaut die node-Installation denn aus?
                    • Jan Fiedler
                      @thomas-braun Wie genau meinst du das? Versionsnummern? Logs?
                      Der Adapter ist allerdings aktuell auf Grün gewechselt spannenderweise...
                        @jan-fiedler
                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        Dein System scheint aber auch steinalt zu sein.
                        sudo apt update
                        sudo apt dist-upgrade
                        sudo reboot
                        Jan Fiedler arteck 2 Replies Last reply Reply Quote 0
                        • Jan Fiedler
                          @thomas-braun sagte in ZigBee neue Version 1.4.4:
                          Das kann schon sein... macht halt nur ioBroker 😉
                          pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          /usr/bin/nodejs
                          v10.22.0
                          /usr/bin/node
                          v10.22.0
                          /usr/bin/npm
                          6.14.6
                          nodejs:
                            Installiert:           10.22.0-1nodesource1
                            Installationskandidat: 10.22.0-1nodesource1
                            Versionstabelle:
                           *** 10.22.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                  100 /var/lib/dpkg/status
                               10.21.0~dfsg-1~deb10u1+rpi1 500
                            @jan-fiedler dann mach es jetzt.
                            • Jan Fiedler
                              @thomas-braun Ziehe mir aber morgen erstmal ein Backup, nicht dass ich damit wieder alles zerschieße
                              Thomas Braun arteck 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @Jan Fiedler last edited by Thomas Braun
                                @jan-fiedler
                                Backup haben ist immer gut. Backup von einem sauberen System ist noch besser.
                                  Ob eine neueres nodejs hilft?
                                  Mein System ist älter und läuft im Prinzip
                                  Node.js v10.17.0
                                  NPM 6.11.3
                                  js-controller Installiert: 3.2.16
                                  Verbindung über COM-Port wird hergestellt. Adapter grün.
                                    arteck Developer Most Active @Thomas Braun last edited by
                                    @thomas-braun jetzt hör auf wieder irgendwelche UPDATES zu propagieren..
                                    das hat nix mit dem Fehler zu tun..
                                    VOR ALLEM NICHT IN DIESEM THREAD
                                    wie oft noch....
                                      Thomas Braun Most Active @arteck last edited by
                                      @arteck Weil's grundsätzlich eine gute Idee ist sein System auf Stand zu haben.
                                      In jedem Thread.
                                      Hier ist noch ein uralter Kernel am Start, mit uralter Firmware für den Pi.
                                      Wenn das System auf dem aktuellen Stand ist hast du die ganzen Fixes drauf und dann von der Seite her Ruhe. Warum sollte man sein System nicht updaten?
                                        arteck Developer Most Active @Jan Fiedler last edited by
                                        @jan-fiedler ist das ein Multihost??
                                        • Jan Fiedler
                                          @thomas-braun @arteck Grundsätzlich habt ihr beide Recht. Das Problem rührte von anderer Seite her, nämlich dem Serialport Treiber. Wenn man diesen richtig installiert, updated und rebuilded, scheint alles zu gehen. Auch wenn der Zigbee Adapter immer noch Cast Fehler schmeißt beim updaten. Der Hinweis auf ein Update ist gut, schließlich beschäftige ich mich damit viel zu wenig. Hätte aber auch per PM gereicht und gehört nicht in den Thread zum Zigbee Adapter 😉
                                          Danke euch für die schnelle Hilfe!
                                          • Jan Fiedler
                                            Jan Fiedler @arteck last edited by
                                            @arteck Nein.
                                            neue version zigbee zigbee neue version 1.4.0
                                            35
                                            302
                                            48345
