    4. JavaScript
    5. Script fürTabelle der Batterie Zustände
    • hanan
      hanan @Marco Laser last edited by
      Hallo zusammen
      Ich habe mal das Skript kopiert und die entsprechenden Datenpunkte angelegt.
      Leider erhalte ich Fehlermeldungen:
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at runMicrotasks (<anonymous>)
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
      javascript.1	2021-02-14 08:21:39.079	error	(27755) at Object.createScript (vm.js:261:10)
      javascript.1	2021-02-14 08:21:39.078	error	(27755) at new Script (vm.js:88:7)
      javascript.1	2021-02-14 08:21:39.078	error	(27755) SyntaxError: Missing initializer in const declaration
      javascript.1	2021-02-14 08:21:39.078	error	(27755) ^^^^^^^^^^^^^^
      javascript.1	2021-02-14 08:21:39.078	error	(27755) const UeberSchriftHöhe="35"; //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
      javascript.1	2021-02-14 08:21:39.078	error	(27755) script.js.common.Batterien_Zustand compile failed: at script.js.common.Batterien_Zustand:80
      Hat mir bitte jemand einen Tipp was ich falsch mache.
        liv-in-sky @hanan last edited by
        @hanan hallo,
        was steht den in zeile 80 ?
        hanan 1 Reply Last reply Reply Quote 0
        • hanan
          hanan @liv-in-sky last edited by
          @liv-in-sky
          Da steht:
          Hat das vielleicht mit der Übersetzung zu tun?
            @hanan
            probier mal damit - normalerweise nutze ich keine umlaute in scripts - hab ich wohl übersehen im eifer des ....
            Batterien-script-14.2.-21.txt
            • hanan
              @liv-in-sky
              Jep, passt. Lief durch ohne Fehler und hat sieben schwache Meldungen ausgegeben.
              Ich habe bei den Zigbee einige Tadfri installiert, welche bei 60% AkkuAlarm auslösen.
              Müssten diese nicht erst unter 40% auslösen?
              var battAlarm=25;                                     //alarm batterie wert
              var battAlarmWarning=40;                                     //warnungen batterie wert
                @hanan kannst du nach belieben einstellen
                • hanan
                  hanan last edited by hanan
                  Ja, aber der Alarmwert steht ja im Skript auf 25% und das Gerät hat 60%.
                  Ich habe auch ein HMIP welches mit angezeigt wird obschon der "indicator.lowbat" auf false steht.
                  Oder verstehe ich etwas falsch?
                    liv-in-sky @hanan last edited by liv-in-sky
                    @hanan bin mir nicht sicher, ob ich folgen kann
                    wenn dort im datenpunkt 60 steht und im script als alarm 25 und warning 40 ist das gerät für das script grün !
                    zeig doch mal deine tabelle und den datenpunkt dazu
                    • hanan
                      @liv-in-sky
                      Ups, beim Zigbee stimmt es, habe mich um ein Device vertan und beim HMIP wird die Voltzahl, welche bei 2.3V steht, deklariert, daher die Meldung.
                      Alles iO und eine super Arbeit.
                      Besten Dank für die Hilfe, muss nur noch die Status-Icons einpflegen.
                        Katzenbeißer last edited by
                        Hallo Zusammen,
                        irgendwie hakt es....
                        Ich habe die Datenpunkte angelegt, Fehler werden im Script nicht angezeigt...
                        Gibt es ein Miniscript zum automatischen Anlegen der Datenpunkte?
                        Besten Dank für eure Hilfe
                          liv-in-sky @Katzenbeißer last edited by liv-in-sky
                          @katzenbeißer steht den was drin im datenpunkt ? dpVIS
                          und hast du die devices, die du haben willst, auch auf true gesetzt
                          was wird in der vis angezeigt
                            Katzenbeißer @liv-in-sky last edited by
                            @liv-in-sky "true" war das Zauberwort!!!!
                            Besten Dank
                            • SpikeNbg
                              SpikeNbg last edited by
                              Hallo @liv-in-sky ,
                              ich hätte ne Anregung für neue Devices..
                              Ich betreibe hier über den ble Adapter mehrere Sensoren für Temperatur/Luftfeuchtigkeit von Xiaomi..
                              Diese haben in einem State "battery" den Ladezustand in % angegeben.
                              Als Name taucht dort bei allen erstmal nur "MJ_HT_V1" auf, ich habe diesen dann jeweils im Objektbaum um eine Identifikation erweitert (z.B. MJ_HT_V1 Küche). Im angehängten Skript entferne ich dann einfach das "MJ_HT_V1".
                              Ich hab dein Skript bei mir mal erweitert, wenn du magst, kannst du es ja übernehmen:
                              var ble=true;
                              //ble
                               if (ble){
                                            tabelleMachSchoen()
                                            counter=-1
                                            for(var i=0;i<mehrfachTabelle;i++ ) {
                                              val0=""; val1=""; val2="";counter++;tabelleBind();
                                                if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">BLE DEVICES</b>";} else{val0=""; }
                                  myObjF=[];
                              $('ble.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                 if (!filterArray.includes(id)){
                                      var ida = id.split('.');
                                       // counter++;
                                         val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ; val0=val0.replace(/.battery$/,""); val0=val0.replace("MJ_HT_V1 ",""); val0=val0.replace(/_/g," ");                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                         json1=val0;
                                         json3_1=val1help=parseFloat((getState(id).val));
                                         if (val1help<=battAlarm) {val1=(" <font color=\"red\"> ")+val1help.toString()+" %";json2=val1help.toString()+" %";json5="red"} else{val1=(" <font color=\"lightgreen\"> ")+val1help.toString()+" %";json2=val1help.toString()+" %",json5="green"}
                                         if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()+" %";json2=val1help.toString()+" %";json5="yellow"}
                                         if (getState(id).val==null) {val2="never used"}; //log(id)};
                                         if (val1help<=battAlarm) {val2=symbolKO} else{val2=symbolOK}
                                         if (val1help>battAlarm && val1help<=battAlarmWarning) val2=symbolWARN;
                                         if (val1help<=battAlarm) AkkuAlarm.push(1);
                                         if (val1help<=battAlarm)  alarmMessage.push(val0);
                                         json3=val2;
                                          json6="BLE"
                                           if (braucheMaterialDesignWidget || braucheMaterialDesignWidgetTable) {
                                            json4=json4=pfadBilderMaterialWidget+"xiaomki.png"
                                            makeJsonWidget(json1,json2,json3,json4,json5,json6,json3_1);}
                                         let help=[val0,val1,val2]; myObjF.push(help);
                                   //tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                               } }); sortierMal(myObjF);
                                }  //ende ble
                              Unten ist noch ein png für die Verwendung MaterialDesignWidget angegeben. Da ich das bisher nicht verwende und nicht weiß was es da alles gibt, oder ob du die erstellst, habe ich einfach xiaomki.png angegeben. Vielleicht passt das ja direkt 😁
                              Vielen Dank dir für das Skript, ich hab bei mir mehrere Kategorien aktiviert und das ist echt ne große Hilfe! 🍻
                                liv-in-sky @SpikeNbg last edited by
                                @spikenbg
                                danke dir
                                hatte ich gestern erst drüber nachgedacht - nutze die rechteckigen 🙂
                                schau ich mir mal an
                                habe ein eigenes script dafür - aber die sollten schnell eingebunden sein - das problem ist nur, dass es keinen standard für die dp gibt - d.h. die sind immer/meist verschieden pro user
                                ich sehe geade , du nutzt den ble , da sind die dp gleich - ich nutze einen esp mit esphome als basis - da definiert man die mqtt selbst - es gib aber einen esphome adapter - dann sollen die dp auch wieder gleich sein
                                SpikeNbg K 2 Replies Last reply Reply Quote 0
                                • SpikeNbg
                                  SpikeNbg @liv-in-sky last edited by
                                  @liv-in-sky
                                  Gerne.. 🙂
                                  esphome kannte ich noch nicht.. Mit den Dingern wollte ich auch schon länger mal spielen.. 🙂 Und wieder ein Zeitvertreib für die nächsten Wochenenden 😁
                                    @spikenbg schreckte mich anfangs irgendwie ab - aber wenn man mal einen am laufen hat, ist es es super praktisch, die settings zu ändern und die möglichkeiten sind auch "grenzenlos"
                                      Kueppert @liv-in-sky last edited by
                                      @liv-in-sky puuuuh, im Büro hasts aber arsch kalt bei dir - und im Keller O.o
                                        liv-in-sky @Kueppert last edited by
                                        @kueppert das thermometer steht direkt am fenster - war offen - wäre mir auch zu kalt 🙂
                                          Als Anregung:
                                          Die Sonoff ZigBee Bridge ist eine gute Erweiterung bezüglich MQTT / Reichweite / etc.
                                          Möglicherweise ist eine Sonoff Erweiterung von Interesse... 🙂
                                            @Katzenbeißer
                                            seltsam - dachte, ich habe das schon gemacht - ist sogar vorne aufgeführt
                                            send mir mal einen export des zweigs mit der bridge
                                            https://forum.iobroker.net/post/355793
                                            javascript monitoring template
                                            67
                                            1379
                                            481141
