    4. Test Adapter doorio v2.1.2
    • Wal
      Wal Developer @Renegade 0 last edited by Wal
      @renegade-0 ,
      hast du die Einstellungen wie im ersten Thread beschrieben für deine Soundkarte gemacht ?
      Wenn ja deine Ausgabe von "pactl list" bitte.
      • Wal
        @renegade-0 ,
        habe zufällig auch eine usb-C-Media Soundkarte hier.
        Die pulse-cookie Fehler kannst du ignorieren.
        system dot pa:
        #!/usr/bin/pulseaudio -nF
        # This file is part of PulseAudio.
        # PulseAudio is free software; you can redistribute it and/or modify it
        # under the terms of the GNU Lesser General Public License as published by
        # the Free Software Foundation; either version 2 of the License, or
        # (at your option) any later version.
        # PulseAudio is distributed in the hope that it will be useful, but
        # WITHOUT ANY WARRANTY; without even the implied warranty of
        # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
        # General Public License for more details.
        # You should have received a copy of the GNU Lesser General Public License
        # along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
        # This startup script is used only if PulseAudio is started in system
        # mode.
        ### Automatically restore the volume of streams and devices
        load-module module-device-restore
        load-module module-stream-restore
        load-module module-card-restore
        ### Automatically load driver modules depending on the hardware available
        .ifexists module-udev-detect.so
        load-module module-udev-detect
        .else
        ### Use the static hardware detection module (for systems that lack udev/hal support)
        load-module module-detect
        .endif
        ### Load several protocols
        .ifexists module-esound-protocol-unix.so
        load-module module-esound-protocol-unix
        .endif
        load-module module-native-protocol-unix auth-anonymous=1
        ### Automatically restore the default sink/source when changed by the user
        ### during runtime
        ### NOTE: This should be loaded as early as possible so that subsequent modules
        ### that look up the default sink/source get the right value
        load-module module-default-device-restore
        ### Automatically move streams to the default sink if the sink they are
        ### connected to dies, similar for sources
        load-module module-rescue-streams
        ### Make sure we always have a sink around, even if it is a null sink.
        load-module module-always-sink
        ### Automatically suspend sinks/sources that become idle for too long
        load-module module-suspend-on-idle
        ### Enable positioned event sounds
        load-module module-position-event-sounds
        load-module module-echo-cancel aec_method=webrtc format=s16le rate=16000 channels=1 source_name="noecho.mic_in" sink_name="noecho.sound_out" sink_master="alsa_output.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00.analog-stereo" source_master="alsa_input.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00.analog-mono"
        set-default-sink noecho.sound_out
        set-default-source noecho.mic_in
          Renegade 0 @Wal last edited by
          @wal
          Ich bin gerade am Versuchsaufbau dran. Beide Geräte gleich installiert.
          Ist ein Rpi 4 und ein Zero W
          Mir ist gerade aufgefallen, die Quelle und Ziel sind beim RPI4 auf BCM nicht auf meiner USC Karte. Wie stelle ich das denn um?
          • Wal
            @renegade-0 sagte in Test Adapter doorio v1.1.x:
              @wal
              Ziel #0
                      Status: IDLE
                      Beschreibung: Internes Audio Digital Stereo
                      Treiber: module-alsa-card.c
              Quelle #1
                      Status: IDLE
                      Beschreibung: Monitor of Internes Audio Analog Stereo
              Korrekt wäre ja der C-Media
              pi@DoorPi:~ $ lsusb
              Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
              Bus 001 Device 005: ID 32e4:9230
              Bus 001 Device 007: ID 0d8c:0014 C-Media Electronics, Inc. Audio Adapter (Unitek Y-247A)
              • Wal
                Dann nutzt du nicht mein Image. Bei mir ist in der config.txt das RPI-Audio ausgeschaltet. Das habe ich gefühlt schon 1000-mal geschrieben.
                # Enable audio (loads snd_bcm2835)
                dtparam=audio=off
                  Renegade 0 @Wal last edited by Renegade 0
                  @wal
                  auf einem Gerät ja und auf dem anderen, versuche ich es nachzubauen zwecks Verständnis. 🙂
                  In welcher Datei setzt du diesen flag? (/boot/config.txt?)
                  • Wal
                    @wal
                    ja
                      @wal
                      Gut jetzt sind die BCM weg.
                      Aber pulseaudio ist jetzt auf auto_null. Kann ich das nachträglich umstellen oder muss ich neu installieren?
                      • Wal
                        @renegade-0,
                        audio_player            pulse,noecho.sound_out
                        audio_source            pulse,noecho.mic_in
                        audio_alert             pulse,noecho.sound_out
                          @wal
                          in welcher Datei?
                          • Wal
                            @renegade-0 ,
                            sei mir nicht böse aber es geht hier um den DoorIO-Adapter und nicht um pulseaudio. Wenn du alles selbst installieren möchtest, nutze Google das hatte ich auch tagelang gemacht bis es funktionierte. Ich weiß selbst nicht mehr was ich alles eingestellt hatte.
                            Die Datei oben ist die Baresip-Konfig, aber wenn ich das "auto-null" öfters lese glaube ich das du was anderes meinst.
                            Mein Tipp ist es, nimm das Image. Es ist das Buster-Lite-Image incl. pulseaudio, baresip und der IN/Out MQTT-Client sonst nichts.
                              @wal
                              moin,
                              ja ist mir schon klar. Ich baue ja den VErsuchsaufbau nur, um herauszufinden, wo die Probleme bei mir entstehen mit dfem doppelten Anruf bzw. dass zwar das Klingelsignal abgespielt wird, aber kein Ton beim Sprechen übertragen wird.
                              Dein Image ist schon angepasst und auf einem meiner Geräte drauf.
                              Hatte halt nur gehofft, von deinem Wissen über pulse profitieren zu können. Da ist es nicht so leicht passendes in Netz zu finden.
                              Wal 3 Replies Last reply Reply Quote 0
                              • Wal
                                @renegade-0 ,
                                das mit pulse ist schon min. 2 Jahre her und ich weiß nicht mehr was ich alles gemacht habe. Alsa muß auch gehen, es muß bei Baresip nur auf alsa eingestellt werden. Das Ganze mit dem Sound ist aber Hardwareabhängig und bei jedem anders. Ich muß mir auch alles wieder im Netz zusammen suchen damit ich dir antworten kann, deshalb suche selbst warum es nicht geht. 😉
                                • Wal
                                  @renegade-0 ,
                                  was für ein doppelten Aufruf ? In meinem Image läuft baresip als systemapp, wenn du baresip nochmal startest, läuft es na klar doppelt und es gibt Fehler.
                                  • Wal
                                    @renegade-0,
                                    Raspi-OS-Lite installieren.
                                    sudo apt install pulseaudio
                                    sudo adduser pi pulse
                                    sudo adduser pi pulse-access
                                    sudo nano /etc/systemd/system/pulseaudio.service
                                    das einfügen:
                                    [Unit]
                                    Description=PulseAudio Sound System
                                    Before=sound.target
                                    [Service]
                                    Type=forking
                                    PIDFile=/var/run/pulse/pid
                                    ExecStart=/usr/bin/pulseaudio --daemonize --system --realtime --log-target=journal --disallow-exit --disallow-module-loading
                                    ExecStop=/usr/bin/pulseaudio -k
                                    [Install]
                                    WantedBy=multi-user.target
                                    das wieder ausführen:
                                    sudo chmod +x /etc/systemd/system/pulseaudio.service
                                    sudo systemctl enable pulseaudio
                                    sudo systemctl start pulseaudio
                                    reboot
                                    danach deine Soundkarte einrichten wie auf Seite 1 beschrieben.
                                    Ich mußte das BCM-Audio nicht deaktivieren.
                                      @wal
                                      Moin,
                                      Ich hab einen total komischen fehler. Die Türe ruft den 2. Sipclient an, aber immer doppelt. also der 2. client geht dann auf anklopfen. Bei Anruf auf DECT läuft es. Jetzt baue ich halt step by step auf und schaue, ab wann dieser Fehler auftritt.
                                      Vielen lieben Dank 🙂
                                      • Wal
                                        @renegade-0 ,
                                        deshalb den DoorIO-Adapter erst weglassen bis die Telefonie richtig läuft, danach erst in ioBroker anbinden.
                                          @wal
                                          jo bin gerade an dem Weg dran.
                                          Habs jetzt mal mit und mal ohne img probiert. Das ist jetzt der Status vom img.
                                          Das Modul "module-echo-cancel" startet nicht an.
                                           pulseaudio.service - PulseAudio Sound System
                                             Loaded: loaded (/etc/systemd/system/pulseaudio.service; enabled; vendor preset: enabled)
                                             Active: active (running) since Sun 2021-03-07 11:18:38 CET; 4min 21s ago
                                            Process: 334 ExecStart=/usr/bin/pulseaudio --daemonize --system --realtime --log-target=journal (code=exited, status=0/SUCCESS)
                                           Main PID: 402 (pulseaudio)
                                              Tasks: 3 (limit: 4915)
                                             Memory: 29.4M
                                             CGroup: /system.slice/pulseaudio.service
                                                     └─402 /usr/bin/pulseaudio --daemonize --system --realtime --log-target=journal
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: Failed to load authentication key '/var/run/pulse/.config/pulse/cookie': Datei oder Verzeichnis nicht gefund
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: Failed to open cookie file '/var/run/pulse/.pulse-cookie': Datei oder Verzeichnis nicht gefunden
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: Failed to load authentication key '/var/run/pulse/.pulse-cookie': Datei oder Verzeichnis nicht gefunden
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: socket(PF_INET6): Die Adressfamilie wird von der Protokollfamilie nicht unterstützt
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: Master source not found
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: Failed to load module "module-echo-cancel" (argument: "aec_method=webrtc format=s16le rate=16000 channels=1
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: Sink noecho.sound_out does not exist.
                                          Mär 07 11:18:38 raspberrypi pulseaudio[402]: Source noecho.mic_in does not exist.
                                          Mär 07 11:18:38 raspberrypi systemd[1]: pulseaudio.service: Supervising process 402 which is not our child. We'll most likely not notice when it exits.
                                          Mär 07 11:18:38 raspberrypi systemd[1]: Started PulseAudio Sound System.
                                          • Wal
                                            @renegade-0 ,
                                            dann stimmt deine system dot pa nicht.
                                            Ohne Ausgabe von "pactl list" kann man dir nicht helfen.
                                            edit: auf dem Zero W wirst du AEC eh nicht laufen lassen können, da der zu schwach ist.
                                            79.9k
                                            door intercom doorpi türsprechstelle
                                            34
                                            583
                                            121140
