    4. Yet another HomeKit adapter
      pusemuckel last edited by
      ich wollte den Adapter heute auch mal ausprobieren.
      Die Installation hat soweit geklappt und auch das Anlegen von Geräten hat augenscheinlich geklappt. Wenn cih den Adapter aber starten will kommt im log folgende Meldung:
      yahka.0	2016-12-21 22:24:56.942	info	terminating
      yahka.0	2016-12-21 22:24:56.911	info	cleaned everything up...
      yahka.0	2016-12-21 22:24:56.908	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      yahka.0	2016-12-21 22:24:56.908	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      yahka.0	2016-12-21 22:24:56.908	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      yahka.0	2016-12-21 22:24:56.908	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      yahka.0	2016-12-21 22:24:56.908	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      yahka.0	2016-12-21 22:24:56.908	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:420:25)
      yahka.0	2016-12-21 22:24:56.908	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3093:18)
      yahka.0	2016-12-21 22:24:56.908	error	at Adapter.emit (events.js:166:7)
      yahka.0	2016-12-21 22:24:56.908	error	at emitNone (events.js:67:13)
      yahka.0	2016-12-21 22:24:56.908	error	at TIOBrokerAdapter.adapterReady (/opt/iobroker/node_modules/iobroker.yahka/yahka.ioBroker-adapter.js:31:66)
      yahka.0	2016-12-21 22:24:56.908	error	TypeError: Cannot read property 'hostname' of undefined
      yahka.0	2016-12-21 22:24:56.900	error	uncaught exception: Cannot read property 'hostname' of undefined
      yahka.0	2016-12-21 22:24:56.880	info	first time initialization
      yahka.0	2016-12-21 22:24:56.877	info	adapter ready, checking config
      yahka.0	2016-12-21 22:24:56.827	info	starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v4.7.0
      Er kann den "hostname" nicht lesen. Das System hat aber einen Hostnamem, den ich mir in der Console auch mit hostname anzeigen lassen kann…
      Hat jemand eine Idee?
      Danke und Gruß
        JW86 last edited by
        @pusemuckel:
        Hat jemand eine Idee? `
        Die im Log erwähnte Zeile lautet:
        bridgeConfig.ident = this.adapter.systemConfig.system.hostname + ':' + this.adapter.name + '.' + this.adapter.instance;
        Der Fehler bedeutet das die Eigenschaft/Variable "system" auf systemConfig wohl undefined ist. Warum das so ist ist mir aktuell nicht ganz klar.
        Hierzu kann vielleicht bluefox etwas sagen.
        Welche ioBroker Version hast du den?
        Hast du mehrere ioBroker Instanzen?
          Die Version ist eigentlich aktuell: Controller "js-controller" : 0.14.0
          • Mr. Burns
            Mr. Burns last edited by
            hab den Adapter auch ml getestet und bin echt begeistert! Tolle Arbeit.
            Beim Einbinden bin ich teilweise echt verzweifelt, weil ich die Brdge nicht einbinden konnte. Immer wenn ich den Adapter gefunden habe und den Code eingetragen habe…Keine Verbindung. Die Lösung: ALLE Felder ausfüllen. Hersteller, Typ, Seriennummer etc. Bei fehlerhafter Eingabe der Datenpunkte bricht die Kommunikation ebenfalls ab. Da hilft manchmal nur die neue Vergabe der MAC Adresse…leider muss man dann alles neu sortieren (kein Spaß).
            An die User, welche schon etwas länger Testen:
            Ich hab noch Probleme mit den Dimmern. Die sind nicht sehr stabil und sorgen immer wieder für Störungen.
            Folgende Geräte nutze ich:
            • HM-LC-Dim1PWM-CV
            • HSS-DX
            • HM-LC-Dim1T-FM
            Die Geräte gehen je nach Konfiguration (manchmal auch ohne Änderung, nur durch neuladen) in Störung.
            Außerdem kann ich die Geräte nicht einfach Ein- bzw. Ausschalten. Gehen entweder nur auf 1% oder eben nicht aus. Wenn ich es über Prozent einstelle geht es wunderbar.
            Eingestellt habe ich "LightBulb" und bei ON Datenpunkt ".LEVEL" und bei Brightness ebenfalls ".LEVEL"
            Mein 2. Problem ist ein Türöffner. Da ich diesen über Homeduino (NFC und Summer) mit einem Programm bzw. internen Variable steuern muss. Es geht wunderbar mit dem Lichtschalter "LightBulb" aber eben nicht mit dem Kommando "öffne die Gartentür" sondern ich muss diese einschalten lassen. Jemand schon erfahrungen diesbezüglich?
            Thomas
            P. S. Biete mich auch als tester an. Habe einiges an Homematic-Geräten und Apple Kram.
              ich komme dem Problem einfach nicht auf den Grund. Habe jetzt auch mal socket.io gelöscht, aber auch das war nicht das Problem. Hat noch jemand eine Idee wo ich suchen kann ? Danke und Gruß
              yahka.0	2016-12-23 16:13:42.328	info	terminating
              yahka.0	2016-12-23 16:13:42.294	info	cleaned everything up...
              yahka.0	2016-12-23 16:13:42.293	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
              yahka.0	2016-12-23 16:13:42.293	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              yahka.0	2016-12-23 16:13:42.293	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              yahka.0	2016-12-23 16:13:42.293	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
              yahka.0	2016-12-23 16:13:42.293	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
              yahka.0	2016-12-23 16:13:42.293	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:442:25)
              yahka.0	2016-12-23 16:13:42.293	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3235:18)
              yahka.0	2016-12-23 16:13:42.293	error	at Adapter.emit (events.js:166:7)
              yahka.0	2016-12-23 16:13:42.293	error	at emitNone (events.js:67:13)
              yahka.0	2016-12-23 16:13:42.293	error	at TIOBrokerAdapter.adapterReady (/opt/iobroker/node_modules/iobroker.yahka/yahka.ioBroker-adapter.js:31:66)
              yahka.0	2016-12-23 16:13:42.293	error	TypeError: Cannot read property 'hostname' of undefined
              yahka.0	2016-12-23 16:13:42.291	error	uncaught exception: Cannot read property 'hostname' of undefined
              yahka.0	2016-12-23 16:13:42.285	info	first time initialization
              yahka.0	2016-12-23 16:13:42.284	info	adapter ready, checking config
              yahka.0	2016-12-23 16:13:42.272	info	starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v4.7.0
              host.nuc	2016-12-23 16:13:41.231	info	instance system.adapter.yahka.0 started with pid 3344
                JW86 last edited by
                ich habe zwei Kleinigkeiten geändert:
                1. leere Felder für Hersteller, Seriennummer und Typ sollten kein Problem mehr sein
                2. der Fehler "uncaught exception: Cannot read property 'hostname' of undefined" sollte weg sein (stattdessen wird einfach "unknownHostname" angenommen).
                @pusemuckel: es wäre interessant zu sehen, was mit der neuen Version im Log erscheint (bei der Zeile " info first time initialization")
                Zum installieren, einfach das Paket neu über npm installieren lassen (vorige deinstallation ist nicht notwendig, einfach "drüber" installieren)
                • Mr. Burns
                  komische Sache:
                  Ich bin wieder mal rausgeflogen, weiß nicht warum (keine Änderungen gemacht)
                  Auf dem Telefon (6S) keine Verbindung zu den Geräten aber zur Brücke. Änderungen werden trotzdem übernommen (neue Geräte und Änderung des Names). Keine Bedienung am Telefon mehr möglich, hat ja auch keine Verbindung mehr.
                  Aber:
                  Über AppleTV geht's. Und zwar alles. Auch die neuen Geräte und die Änderungen.
                  Keine Fehlermeldungen in der LOG File (nix rotes zusehen)…werde mal die neue Version ausprobieren.
                  P.S. FROHE WEIHNACHTEN!
                  • Mr. Burns
                    neue Version Funktioniert…zumindest dass, mit den fehlenden Seriennummern.
                    Muss ich eine neue instanz installieren und die alte löschen? Dann würde ich ja alle bereits eingegebenen Geräte neu anlegen müssen..
                    Nachtrag:
                    Das steht im LOG beim initialisieren...bei mir:
                    yahka.1	2016-12-24 02:23:46.857	info	first time initialization, system config:{"system":{"memoryLimitMB":0},"network":{"IPv4":true,"IPv6":true,"bindAddress":null,"useSystemNpm":true},"objects":{"type":"file","typeComment":"Possible valu
                      Hallo JW86,
                      jetzt funktioniert es. Die Bridge wurde korrekt initialisiert und alle Geräte richtig übernommen.
                      Ich habe mal einen Rolladen und einen Thermostaten konfiguriert und beide lassen sich steuern!
                      Klasse arbeit!
                      Ich wünsche Euch schöne Feiertage, einen schönen Urlaub und guten Start ins neue Jahr!
                      Pusemuckel
                        PArt last edited by
                        hey, vielleicht kannst du mir auch bei der Konfiguration von nicht HomeMatic Geräten helfen?
                        Ich versuche gerade deinen Adapter für meine RWE-SmartHome anzupassen, jedoch scheitert es leider an den Einstellungen für die Heizung. Home meldet stets, das das Gerät nicht verfügbar ist. Eingerichtet habe ich dies laut Screenhots… Was mache ich falsch?
                          PArt last edited by
                          Nach ein bisschen testen habe ich ebenfalls das Problem, das die Geräte immer wieder auf "Nicht erreichbar" wechseln
                          UPDATE: Nach noch mehr testen scheint dies mit der Anzahl der Geräte zusammen zu hängen! Während eine kleine Anzahl (3-4) noch relativ zuverlässig funktioniert hat, erhalte ich bei mehreren Geräten (> 5-6) stets keine Antwort von allen Geräten
                            Möchte kurz Feedback geben.
                            Ich habe jetzt 14 Geräte aufgenommen, Rolläden und Thermostate und alles läuft recht stabil.
                            Mein Vorgehen war dabei wie folgt.
                            • In ioBroker Bride anlegen und erstes Gerät hinzugefügt
                            • In der Home App die Bridge und das Gerät hinzugefügt
                            • in ioBroker yahka weitere Geräte anlegen ohne diese zu speichern, erst nachdem alle Geräte angelegt waren gespeichert
                            • In der Home App werden die neuen Geräte aufgenommen
                            • In der Home App die Räume zugeweisen und stehen lassen, damit der sync in die icloud funktioniert
                            Nach 2 Tage ist nochalles verfügbar und lässt sich steuern
                              JW86 last edited by
                              @PArt:
                              Was mache ich falsch? `
                              Es gibt des öfteren das Problem, das die i-Geräte nicht mit der Bridge reden möchten wenn die Konfiguration ungültig ist/war.
                              Oft hilft dann nur das Ändern des "Usernames" (= die Adresse im MAC Format).
                              Des Weiteren sollte man für die "Current*" Werte die Funktion "ioBroker.State.OnlyACK" nutzen.
                              Diese Funktion gibt nur Werte weiter, welche in ioBroker das Flag "acknowledged" haben. Letztendlich bedeutet das, das nur Werte die vom Gerät kommen an diesen HomeKit Datenpunkt weitergegeben werden.
                              HomeKit unterteilt meistens nach Soll-Wert und Ist-Wert während das bei Homematic oder anderen Systemen meistens nicht der Fall ist.
                              Nimmt man für "Current*" die State-Werte direkt, werden die Soll-Werte sofort als Ist-Werte angezeigt und es gibt hässliche Effekte beim Ändern eines Sollwerts (das Hochziehen der Temperatur springt dann hässlich hin und her).
                                Michy last edited by
                                Hi, danke für deine Mühe!
                                ich bekomme bei der Installation über NPM immer folgenden Fehler:
                                $ ./iobroker url "https://github.com/ioBroker/ioBroker.yahka/tarball/master" yahka --debug
                                install https://github.com/ioBroker/ioBroker.yahka/tarball/master
                                npm install https://github.com/ioBroker/ioBroker.yahka/tarball/master --production --prefix "/root" (System call)
                                npm
                                 ERR!
                                 fetch failed
                                npm WARN
                                 retry
                                 will retry, error on last attempt: Error: fetch failed with status code 404
                                npm
                                ERR!
                                 fetch failed https://github.com/ioBroker/ioBroker.yahka/tarball/masternpm
                                 WARN retry will retry, error on last attempt: Error: fetch failed with status code 404
                                npm
                                 ERR!
                                npm
                                 ERR! Linux 4.4.13-v7+
                                npm ERR!
                                argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.yahka/tarball/master" "--production" "--prefix" "/root"npm ERR!
                                 node v4.5.0npm
                                 ERR! npm
                                 v4.0.5
                                npm ERR! fetch failed with status code 404npm
                                ERR! npm
                                 ERR! If you need help, you may report this error at:npm ERR!     <https: github.com/npm/issues="">
                                npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
                                ERROR: host.RIPBR Cannot install https://github.com/ioBroker/ioBroker.yahka/tarball/master: 1
                                ERROR: process exited with code 25</https:>
                                Hat das jemand schon gehabt? Habe die npm Version schon geupdatet. Oder ist es doch die falsche NodeVersion?
                                Micha
                                  JW86 last edited by
                                  Du installierst vermutlich via GIT Url statt mit dem NPM Paket
                                    @JW86:
                                    Du installierst vermutlich via GIT Url statt mit dem NPM Paket `
                                    okay das habe ich jetzt erst verstanden :lol:
                                    nun kommen aber diese Fehler:
                                    $ ./iobroker url "iobroker.yahka" --debug
                                    install iobroker.yahka
                                    npm install iobroker.yahka --production --prefix "/root" (System call)
                                    > authenticate-pam@1.0.2 install /root/node_modules/authenticate-pam
                                    > node-gyp rebuild
                                    make: Entering directory '/root/node_modules/authenticate-pam/build'
                                      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                                    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security pam_appl.h="">^
                                    compilation terminated.
                                    authenticate_pam.target.mk:94: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failed
                                    make: Leaving directory '/root/node_modules/authenticate-pam/build'make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
                                    gyp
                                     ERR! build error
                                    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                    gyp ERR! stack     at emitTwo (events.js:87:13)
                                    gyp ERR! stack     at ChildProcess.emit (events.js:172:7)
                                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
                                    gyp
                                     ERR! System Linux 4.4.13-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                    gyp ERR! cwd /root/node_modules/authenticate-pam
                                    gyp ERR! node -v v4.5.0
                                    gyp ERR! node-gyp -v v3.4.0
                                    gyp ERR! not ok</security>
                                    den Fehler konnte ich nun mit dem Befehl:
                                    npm repair –save
                                    beheben. Nun ist nach der Installation der Adapter leider nicht aufzufinden 😄
                                    gruß
                                    Micha
                                      Trident last edited by
                                      Der Adapter funktioniert bei mir auf Anhieb ohne Problem mit 12 Geräten!
                                      Vielen Dank für die tolle Arbeit!
                                        JW86 last edited by
                                        > Wichtig vor der Installation müssen einige Pakete installiert werden: sudo apt-get install libavahi-compat-libdnssd-dev
                                        Hast du das beachtet?
                                          @JW86:
                                          Hast du das beachtet? `
                                          Ja, das ist installiert.
                                          Wenn ich das ganze manuell über die Konsole mit dem Befehl
                                          npm install iobroker.yahka –production --prefix "/root"
                                          installieren möchte, kommen jetzt solche Warnungen:
                                          npm WARN enoent ENOENT: no such file or Directory, open '/opt/iobroker/package.json'
                                          npm WARN iobroker No description
                                          npm WARN iobroker No repository field.
                                          npm WARN iobroker No README data
                                          npm WARN iobroker No license field.
                                          Was ist denn da los? :lol:
                                          gruß
                                          Micha
                                            Bist du root?
                                            Ansonsten bitte sudo verwenden
                                            Rainer
                                            1761
                                            796055
